[GRASS-SVN] r61453 - grass-addons/grass7/raster3d/r3.flow
Tue Jul 29 16:39:47 PDT 2014
Author: annakrat
Date: 2014-07-29 16:39:47 -0700 (Tue, 29 Jul 2014)
New Revision: 61453
   grass-addons/grass7/raster3d/r3.flow/Makefile
   grass-addons/grass7/raster3d/r3.flow/flowline.c
   grass-addons/grass7/raster3d/r3.flow/flowline.h
   grass-addons/grass7/raster3d/r3.flow/integrate.c
   grass-addons/grass7/raster3d/r3.flow/integrate.h
   grass-addons/grass7/raster3d/r3.flow/main.c
   grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h
r3.flow: velocity and input 3d raster value added as a record in attribute table for each flowline segment (-a flag)
Modified: grass-addons/grass7/raster3d/r3.flow/Makefile
--- grass-addons/grass7/raster3d/r3.flow/Makefile	2014-07-29 21:25:32 UTC (rev 61452)
+++ grass-addons/grass7/raster3d/r3.flow/Makefile	2014-07-29 23:39:47 UTC (rev 61453)
@@ -2,8 +2,8 @@
 PGM=r3.flow
-LIBES = $(RASTER3DLIB) $(RASTERLIB) $(GISLIB) $(VECTORLIB)
-DEPENDENCIES = $(RASTER3DDEP) $(RASTERDEP) $(GISDEP) $(VECTORDEP)
+LIBES = $(RASTER3DLIB) $(RASTERLIB) $(GISLIB) $(VECTORLIB) $(DBMILIB)
+DEPENDENCIES = $(RASTER3DDEP) $(RASTERDEP) $(GISDEP) $(VECTORDEP) $(DBMIDEP)
 EXTRA_INC = $(VECT_INC)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass-addons/grass7/raster3d/r3.flow/flowline.c
--- grass-addons/grass7/raster3d/r3.flow/flowline.c	2014-07-29 21:25:32 UTC (rev 61452)
+++ grass-addons/grass7/raster3d/r3.flow/flowline.c	2014-07-29 23:39:47 UTC (rev 61453)
@@ -14,12 +14,63 @@
 #include <grass/raster3d.h>
 #include <grass/vector.h>
 #include <grass/glocale.h>
+#include <grass/dbmi.h>
 #include "r3flow_structs.h"
 #include "integrate.h"
 #include "flowline.h"
 #include "voxel_traversal.h"
+static void write_segment(struct Map_info *flowline_vec,
+			  struct line_pnts *points, struct line_cats *cats,
+			  const double *point, int *cat)
+    Vect_append_point(points, point[0], point[1], point[2]);
+    Vect_cat_set(cats, 1, *cat);
+    (*cat)++;
+    Vect_write_line(flowline_vec, GV_LINE, points, cats);
+    Vect_reset_line(points);
+    Vect_reset_cats(cats);
+static void write_segment_db(struct field_info *finfo, dbDriver * driver,
+			     dbString * sql, const double velocity,
+			     double scalar_value, int write_scalar,
+			     const int cat)
+    char buf[200];
+    if (write_scalar)
+	sprintf(buf, "insert into %s values ( %d, %e, %e )", finfo->table,
+		cat, scalar_value, velocity);
+    else
+	sprintf(buf, "insert into %s values ( %d, %e)", finfo->table, cat,
+		velocity);
+    db_set_string(sql, buf);
+    if (db_execute_immediate(driver, sql) != DB_OK) {
+	G_fatal_error(_("Unable to insert new record: '%s'"),
+		      db_get_string(sql));
+static double get_scalar_value(RASTER3D_Region * region,
+			       struct Gradient_info *gradient_info,
+			       double north, double east, double top)
+    int col, row, depth;
+    double val;
+    Rast3d_location2coord(region, north, east, top, &col, &row, &depth);
+    Rast3d_get_value(gradient_info->scalar_map, col, row, depth, &val,
+		     DCELL_TYPE);
+    return val;
    \brief Computes flowline by integrating velocity field.
@@ -30,13 +81,15 @@
    \param flowline_vec pointer to Map_info struct of flowline vector
    \param cats pointer to line_cats struct of flowline vector
    \param points pointer to line_pnts struct of flowline vector
-   \param cat category of the newly created flow line
+   \param[in,out] cat starting category of the newly created flow line
+   \param if_table TRUE if attribute table should be created and filled
 void compute_flowline(RASTER3D_Region * region, const struct Seed *seed,
 		      RASTER3D_Map * flowacc, struct Integration *integration,
 		      struct Map_info *flowline_vec, struct line_cats *cats,
-		      struct line_pnts *points, const int cat)
+		      struct line_pnts *points, int *cat, int if_table,
+		      struct field_info *finfo, dbDriver * driver)
     int i, j, count;
     double delta_t;
@@ -48,8 +101,11 @@
     int last_col, last_row, last_depth;
     int coor_diff;
     FCELL value;
+    double scalar_value;
     int *trav_coords;
     int size, trav_count;
+    dbString sql;
+    double velocity;
     point[0] = seed->x;
     point[1] = seed->y;
@@ -58,11 +114,13 @@
     last_col = last_row = last_depth = -1;
     size = 5;
+    scalar_value = 0;
     trav_coords = G_malloc(3 * size * sizeof(int));
     if (seed->flowline) {
 	/* append first point */
 	Vect_append_point(points, seed->x, seed->y, seed->z);
+	db_init_string(&sql);
     count = 1;
     while (count <= integration->limit) {
@@ -79,19 +137,30 @@
 				velocity_norm, integration->cell_size);
 	/* integrate */
-	min_step = get_time_step("cell", MIN_STEP, velocity_norm,
+	min_step = get_time_step("cell", integration->min_step, velocity_norm,
-	max_step = get_time_step("cell", MAX_STEP, velocity_norm,
+	max_step = get_time_step("cell", integration->max_step, velocity_norm,
 	delta_t *= (integration->actual_direction == FLOWDIR_UP ? 1 : -1);
 	if (rk45_integrate_next
 	    (region, gradient_info, point, new_point,
-	     &delta_t, min_step, max_step) < 0)
+	     &delta_t, &velocity, min_step, max_step,
+	     integration->max_error) < 0)
 	    break;
-	if (seed->flowline)
-	    Vect_append_point(points, new_point[0], new_point[1],
-			      new_point[2]);
+	if (seed->flowline) {
+	    if (if_table) {
+		write_segment(flowline_vec, points, cats, new_point, cat);
+		if (gradient_info->compute_gradient)
+		    scalar_value = get_scalar_value(region, gradient_info,
+						    point[1], point[0],
+						    point[2]);
+		write_segment_db(finfo, driver, &sql, velocity, scalar_value,
+				 gradient_info->compute_gradient, *cat - 1);
+	    else
 	if (seed->flowaccum) {
 	    Rast3d_location2coord(region, new_point[1], new_point[0],
 				  new_point[2], &col, &row, &depth);
@@ -132,11 +201,13 @@
 	if (points->n_points > 1) {
-	    Vect_cat_set(cats, 1, cat);
+	    (*cat)++;
 	    G_debug(1, "Flowline ended after %d steps", count - 1);
+	db_free_string(&sql);
Modified: grass-addons/grass7/raster3d/r3.flow/flowline.h
--- grass-addons/grass7/raster3d/r3.flow/flowline.h	2014-07-29 21:25:32 UTC (rev 61452)
+++ grass-addons/grass7/raster3d/r3.flow/flowline.h	2014-07-29 23:39:47 UTC (rev 61453)
@@ -13,5 +13,6 @@
-		      struct line_pnts *points, const int cat);
+		      struct field_info *finfo, dbDriver *driver);
 #endif // FLOWLINE_H
Modified: grass-addons/grass7/raster3d/r3.flow/integrate.c
--- grass-addons/grass7/raster3d/r3.flow/integrate.c	2014-07-29 21:25:32 UTC (rev 61452)
+++ grass-addons/grass7/raster3d/r3.flow/integrate.c	2014-07-29 23:39:47 UTC (rev 61453)
@@ -83,13 +83,14 @@
 static int rk45_next(RASTER3D_Region * region, struct Gradient_info *gradient_info,
 		     const double *point, double *next_point,
-		     const double delta_t, double *error)
+		     const double delta_t, double *velocity, double *error)
     double tmp1[6][3];		/* 3 is 3 dimensions, 6 is the number of k's */
     double tmp_point[3];
     double vel_x, vel_y, vel_z;
     double sum_tmp;
     int i, j, k;
+    double vel_sq;
     if (get_velocity(region, gradient_info, point[0], point[1], point[2],
 		     &vel_x, &vel_y, &vel_z) < 0)
@@ -118,6 +119,7 @@
 	tmp1[i][2] = vel_z;
+    vel_sq = 0;
     /* compute next point */
     for (j = 0; j < 3; j++) {
 	sum_tmp = 0;
@@ -125,7 +127,10 @@
 	    sum_tmp += C[i] * tmp1[i][j];
 	next_point[j] = point[j] + delta_t * sum_tmp;
+	vel_sq += sum_tmp * sum_tmp;
+    *velocity = sqrt(vel_sq);
     if (!Rast3d_is_valid_location
 	(region, next_point[1], next_point[0], next_point[2]))
 	return -1;
@@ -158,8 +163,9 @@
 int rk45_integrate_next(RASTER3D_Region * region,
 			struct Gradient_info *gradient_info, const double *point,
-			double *next_point, double *delta_t,
-			const double min_step, const double max_step)
+			double *next_point, double *delta_t, double *velocity,
+			const double min_step, const double max_step,
+			const double max_error)
     double estimated_error;
     double error_ratio;
@@ -176,16 +182,17 @@
 	*delta_t = max_step * (*delta_t > 0 ? 1 : -1);
     /* try to iteratively decrease error to less than max error */
-    while (estimated_error > MAX_ERROR) {
+    while (estimated_error > max_error) {
 	/* compute next point and get estimated error */
 	if (rk45_next
-	    (region, gradient_info, point, next_point, *delta_t, error) == 0)
+	    (region, gradient_info, point, next_point, *delta_t,
+	     velocity, error) == 0)
 	    estimated_error = norm(error[0], error[1], error[2]);
 	else
 	    return -1;
 	/* compute new step size (empirically) */
-	error_ratio = estimated_error / MAX_ERROR;
+	error_ratio = estimated_error / max_error;
 	if (error_ratio == 0.0)
 	    tmp = *delta_t > 0 ? min_step : -min_step;
 	else if (error_ratio > 1)
@@ -211,7 +218,7 @@
 	/* break when the adjustment was needed (not sure why) */
 	if (do_break) {
 	    if (rk45_next(region, gradient_info, point, next_point,
-			  *delta_t, error) < 0)
+			  *delta_t, velocity, error) < 0)
 		return -1;
 	    break;
Modified: grass-addons/grass7/raster3d/r3.flow/integrate.h
--- grass-addons/grass7/raster3d/r3.flow/integrate.h	2014-07-29 21:25:32 UTC (rev 61452)
+++ grass-addons/grass7/raster3d/r3.flow/integrate.h	2014-07-29 23:39:47 UTC (rev 61453)
@@ -5,10 +5,6 @@
-static const double MAX_ERROR = 1.0e-6;
-static const double MIN_STEP = 0.01;
-static const double MAX_STEP = 1;
 /* Cash-Karp parameters */
 static const double B[5][5] = { {1. / 5, 0, 0, 0, 0},
 {3. / 40, 9. / 40, 0, 0, 0},
@@ -33,6 +29,7 @@
-			const double min_step, const double max_step);
+			double *velocity, const double min_step,
+			const double max_step, const double max_error);
 #endif // INTEGRATE_H
Modified: grass-addons/grass7/raster3d/r3.flow/main.c
--- grass-addons/grass7/raster3d/r3.flow/main.c	2014-07-29 21:25:32 UTC (rev 61452)
+++ grass-addons/grass7/raster3d/r3.flow/main.c	2014-07-29 23:39:47 UTC (rev 61453)
@@ -19,12 +19,59 @@
 #include <grass/gis.h>
 #include <grass/raster.h>
+static void create_table(struct Map_info *flowline_vec,
+			 struct field_info **f_info, dbDriver ** driver,
+			 int write_scalar)
+    dbString sql;
+    char buf[200];
+    dbDriver *drvr;
+    struct field_info *fi;
+    fi = Vect_default_field_info(flowline_vec, 1, NULL, GV_1TABLE);
+    *f_info = fi;
+    Vect_map_add_dblink(flowline_vec, 1, NULL, fi->table, GV_KEY_COLUMN,
+			fi->database, fi->driver);
+    drvr = db_start_driver_open_database(fi->driver,
+					 Vect_subst_var(fi->database,
+							flowline_vec));
+    if (drvr == NULL) {
+	G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+		      Vect_subst_var(fi->database, flowline_vec), fi->driver);
+    *driver = drvr;
+    if (write_scalar)
+	sprintf(buf, "create table %s (cat integer, input double precision, "
+		"velocity double precision)", fi->table);
+    else
+	sprintf(buf,
+		"create table %s (cat integer, velocity double precision)",
+		fi->table);
+    db_set_string(&sql, buf);
+    db_begin_transaction(drvr);
+    /* Create table */
+    if (db_execute_immediate(drvr, &sql) != DB_OK) {
+	G_fatal_error(_("Unable to create table: %s"), db_get_string(&sql));
+    if (db_create_index2(drvr, fi->table, fi->key) != DB_OK)
+	G_warning(_("Unable to create index for table <%s>, key <%s>"),
+		  fi->table, fi->key);
+    /* Grant */
+    if (db_grant_on_table
+	(drvr, fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK) {
+	G_fatal_error(_("Unable to grant privileges on table <%s>"),
+		      fi->table);
 static void check_vector_input_maps(struct Option *vector_opt,
 				    struct Option *seed_opt)
@@ -101,7 +148,9 @@
 int main(int argc, char *argv[])
     struct Option *vector_opt, *seed_opt, *flowlines_opt, *flowacc_opt,
-	*scalar_opt, *unit_opt, *step_opt, *limit_opt, *skip_opt, *dir_opt;
+	*scalar_opt, *unit_opt, *step_opt, *limit_opt, *skip_opt, *dir_opt,
+	*error_opt;
+    struct Flag *table_fl;
     struct GModule *module;
     RASTER3D_Region region;
     RASTER3D_Map *flowacc;
@@ -114,7 +163,10 @@
     struct Map_info fl_map;
     struct line_cats *fl_cats;	/* for flowlines */
     struct line_pnts *fl_points;	/* for flowlines */
+    struct field_info *finfo;
+    dbDriver *driver;
     int cat;			/* cat of flowlines */
+    int if_table;
     int i, r, c, d;
     char *desc;
     int n_seeds, seed_count, ltype;
@@ -125,7 +177,8 @@
     G_add_keyword(_("raster3d"));
     G_add_keyword(_("voxel"));
     G_add_keyword(_("flowline"));
-    module->description = _("Computes 3D flow lines and 3D flow accumulation.");
+    module->description =
+	_("Computes 3D flow lines and 3D flow accumulation.");
     scalar_opt = G_define_standard_option(G_OPT_R3_INPUT);
@@ -197,6 +250,16 @@
     limit_opt->description = _("Maximum number of steps");
     limit_opt->guisection = _("Integration");
+    error_opt = G_define_option();
+    error_opt->key = "max_error";
+    error_opt->type = TYPE_DOUBLE;
+    error_opt->required = NO;
+    error_opt->answer = "1e-5";
+    error_opt->label = _("Maximum error of integration");
+    error_opt->description = _("Influences step, increase maximum error "
+			       "to allow bigger steps");
+    error_opt->guisection = _("Integration");
     skip_opt = G_define_option();
     skip_opt->key = "skip";
     skip_opt->type = TYPE_INTEGER;
@@ -213,16 +276,26 @@
     dir_opt->options = "up,down,both";
     dir_opt->answer = "down";
     dir_opt->description = _("Compute flowlines upstream, "
-                             "downstream or in both direction.");
+			     "downstream or in both direction.");
+    table_fl = G_define_flag();
+    table_fl->key = 'a';
+    table_fl->description = _("Create and fill attribute table");
     G_option_required(scalar_opt, vector_opt, NULL);
     G_option_exclusive(scalar_opt, vector_opt, NULL);
     G_option_required(flowlines_opt, flowacc_opt, NULL);
     G_option_requires(seed_opt, flowlines_opt, NULL);
+    G_option_requires(table_fl, flowlines_opt);
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    driver = NULL;
+    finfo = NULL;
+    if_table = table_fl->answer ? TRUE : FALSE;
     check_vector_input_maps(vector_opt, seed_opt);
     Rast3d_init_defaults();
@@ -237,13 +310,16 @@
 	integration.unit = "cell";
 	integration.step = 0.25;
+    integration.max_error = atof(error_opt->answer);
+    integration.max_step = 5 * integration.step;
+    integration.min_step = integration.step / 5;
     integration.limit = atof(limit_opt->answer);
     if (strcmp(dir_opt->answer, "up") == 0)
-        integration.direction_type = FLOWDIR_UP;
+	integration.direction_type = FLOWDIR_UP;
     else if (strcmp(dir_opt->answer, "down") == 0)
-        integration.direction_type = FLOWDIR_DOWN;
+	integration.direction_type = FLOWDIR_DOWN;
     else
-        integration.direction_type = FLOWDIR_BOTH;
+	integration.direction_type = FLOWDIR_BOTH;
     /* cell size is the diagonal */
@@ -296,6 +372,11 @@
 			  flowlines_opt->answer);
 	Vect_hist_command(&fl_map);
+	if (if_table) {
+	    create_table(&fl_map, &finfo, &driver,
+			 gradient_info.compute_gradient);
     n_seeds = 0;
@@ -321,6 +402,7 @@
     G_debug(1, "Number of seeds is %d", n_seeds);
     seed_count = 0;
+    cat = 1;
     if (seed_opt->answer) {
 	seed_points = Vect_new_line_struct();
@@ -344,18 +426,19 @@
 		seed.flowaccum = FALSE;
 	    G_percent(seed_count, n_seeds, 1);
-	    cat = seed_count + 1;
-	    if (integration.direction_type == FLOWDIR_UP ||
+	    if (integration.direction_type == FLOWDIR_UP ||
 		integration.direction_type == FLOWDIR_BOTH) {
 		integration.actual_direction = FLOWDIR_UP;
 		compute_flowline(&region, &seed, &gradient_info, flowacc,
-				 &integration, &fl_map, fl_cats, fl_points, cat);
+				 &integration, &fl_map, fl_cats, fl_points,
+				 &cat, if_table, finfo, driver);
-	    if (integration.direction_type == FLOWDIR_DOWN ||
+	    if (integration.direction_type == FLOWDIR_DOWN ||
 		integration.actual_direction = FLOWDIR_DOWN;
 	    seed_count++;
@@ -386,20 +469,22 @@
 		    if (seed.flowaccum || seed.flowline) {
-			compute_flowline(&region, &seed, &gradient_info,
-					 flowacc, &integration, &fl_map,
-					 fl_cats, fl_points, cat);
+			    compute_flowline(&region, &seed, &gradient_info,
+					     flowacc, &integration, &fl_map,
+					     fl_cats, fl_points, &cat,
+					     if_table, finfo, driver);
 			seed_count++;
@@ -407,7 +492,12 @@
+    G_percent(1, 1, 1);
     if (flowlines_opt->answer) {
+	if (if_table) {
+	    db_commit_transaction(driver);
+	    db_close_database_shutdown_driver(driver);
 	Vect_destroy_line_struct(fl_points);
 	Vect_destroy_cats_struct(fl_cats);
 	Vect_build(&fl_map);
Modified: grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h
--- grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h	2014-07-29 21:25:32 UTC (rev 61452)
+++ grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h	2014-07-29 23:39:47 UTC (rev 61453)
@@ -22,6 +22,9 @@
     double step;
     double cell_size;
     int limit;
+    double max_error;
+    double max_step;
+    double min_step;
 struct Array
