[GRASS-SVN] r60919 - in grass-addons/grass7/raster: . r.valley.bottom
Sun Jun 22 16:04:15 PDT 2014
Author: hellik
Date: 2014-06-22 16:04:15 -0700 (Sun, 22 Jun 2014)
New Revision: 60919
Added:
   grass-addons/grass7/raster/r.valley.bottom/
   grass-addons/grass7/raster/r.valley.bottom/Makefile
   grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html
   grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
r.valley.bottom: a script to calculate a Multi-resolution Valley Bottom Flatness (MrVBF) index (improvements welcome)
Added: grass-addons/grass7/raster/r.valley.bottom/Makefile
--- grass-addons/grass7/raster/r.valley.bottom/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.valley.bottom/Makefile	2014-06-22 23:04:15 UTC (rev 60919)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.valley.bottom
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html
--- grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html	2014-06-22 23:04:15 UTC (rev 60919)
@@ -0,0 +1,49 @@
+<h2>DESCRIPTION</h2>
+<p>
+<em>r.valley.bottom</em> calculates a Multi-resolution Valley Bottom
+Flatness (MrVBF) index. The user must specify the input <b>elevation
+raster</b> map.
+</p>
+<h2>EXAMPLE</h2>
+<div class="code">
+ <pre>
+  # align region to DEM and habitat vector
+  g.region -a rast=DEM align=DEM
+  # run <em>r.valley.bottom</em>
+  r.r.valley.bottom elevation=DEM
+ </pre>
+</div>
+<h2>TODO</h2>
+<p>
+Design the script independent of input elevation raster resolution. At
+the moment the input elevation raster map must have a resolution of 25m
+x 25m. Additionally the search window of the elevation percentile may be
+adapted.
+</p>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.slope.aspect.html">r.slope.aspect</a>
+</em>
+<h2>REFERENCES</h2>
+J.C. Gallant & T.I. Dowling 2003.
+A multiresolution index of valley bottom flatness for mapping depositional areas.
+Water Resources Research, Vol. 39, No. 12, 1347. doi:10.1029/2002WR001426
+<h2>AUTHOR</h2>
+Helmut Kudrnovsky
+<p>
+<i>Last changed: $Date: 2014-05-25 22:16:23 +0200 (So, 25 Mai 2014) $</i>
+</p>
\ No newline at end of file
Added: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
--- grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py	2014-06-22 23:04:15 UTC (rev 60919)
@@ -0,0 +1,574 @@
+#!/usr/bin/env python
+MODULE:    r.valley.bottom
+AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
+PURPOSE:   Calculates Multi-resolution Valley Bottom Flatness (MrVBF) index
+           Index is inspired by
+           John C. Gallant and Trevor I. Dowling 2003.
+           A multiresolution index of valley bottom flatness for mapping depositional areas.
+           WATER RESOURCES RESEARCH, VOL. 39, NO. 12, 1347, doi:10.1029/2002WR001426, 2003
+COPYRIGHT: (C) 2014 by the GRASS Development Team
+           This program is free software under the GNU General Public
+           License (>=v2). Read the file COPYING that comes with GRASS
+           for details.
+#%module
+#% description: Calculation of Multi-resolution Valley Bottom Flatness (MrVBF) index
+#% keywords: raster
+#% keywords: terrain
+#%end
+#%option G_OPT_R_ELEV
+#% key: elevation
+#% description: Name of elevation raster map
+#% required: yes
+#%end
+import sys
+import os
+import grass.script as grass
+import math
+if not os.environ.has_key("GISBASE"):
+    grass.message( "You must be in GRASS GIS to run this program." )
+    sys.exit(1)
+def main():
+    r_elevation = options['elevation'].split('@')[0] # elevation raster
+    r_slope_degree = r_elevation+'_slope_degree' # slope (percent) step 1
+	# Region settings
+    current_region = grass.region()
+    Yres_base = current_region['nsres']
+    Xres_base = current_region['ewres']
+    grass.message( "Finest scale calculations" )
+    grass.message( "Original resolution: %s x %s" % (Xres_base, Yres_base))
+    grass.run_command('g.region', flags = 'p', save = "base_region_MrVBF", overwrite = True)
+	# Region settings step 3: resolution 3 x base resolution
+    Yres_step3 = Yres_base * 3
+    Xres_step3 = Xres_base * 3
+	# Region settings step 4: resolution 4 x Xres_step3
+    Yres_step4 = Yres_step3 * 3
+    Xres_step4 = Xres_step3 * 3
+	# Step 1 (S1)
+	# Finest-Scale Step
+    # Calculation of slope step 1
+	# 100 * tan (slope in degree)
+    grass.message( "----" )
+    grass.message( "Step 1: Calculation of slope" )
+    grass.message( "..." )
+    grass.run_command('r.slope.aspect', elevation = r_elevation,
+                                     slope = r_slope_degree,
+                                     format = "degrees",
+                                     precision = "DCELL",
+                                     zfactor = 1.0,
+                                     overwrite = True)
+    grass.mapcalc("$outmap = 100 * tan($slope) ",
+                                     outmap = "r_slope_step1",
+                                     slope = r_slope_degree)
+    grass.run_command("g.remove", rast = r_slope_degree,
+                                     quiet = True)
+    grass.message( "Step 1: Calculation of slope done." )
+    # Calculation of flatness 1 (0 to 1)
+	# Flatness F1 = 1 / (1 + pow ((slope / 16), 4)
+    grass.message( "Step 1: Calculation of flatness F1" )
+    grass.mapcalc("F1 = 1.0 / (1.0 + pow( ( $slope / 16.0 ) ,4 ) )",
+                                     slope = "r_slope_step1")
+    grass.message( "Step 1: Calculation of flatness F1 done." )
+    # Calculation of elevation percentile PCTL1 step 1
+	# elevation percentile: ratio of the number of points of lower
+	# elevation to the total number of points in the surrounding region
+	# elevation of percentile step 1: radius of 3 cells
+    grass.message( "Step 1: Calculation of elevation percentile PCTL1" )
+    grass.mapcalc("elevation_step1 = $r_elevation",
+                                     r_elevation = r_elevation)
+    offsets = [d
+         for j in xrange(1,3+1)
+         for i in [j,-j]
+         for d in [(i,0),(0,i),(i,i),(i,-i)]]
+    terms = ["(elevation_step1[%d,%d] < elevation_step1)" % d
+         for d in offsets]
+    expr1 = "PCTL1 = (100.0 / 24.0) * (%s)" % " + ".join(terms)
+    grass.mapcalc( expr1 )
+    grass.message( "Step 1: Calculation of elevation percentile PCTL1 done" )
+    # Elevation percentile is transformed to a local lowness value using
+    # equation (1) with t = 0.4 and p = 3, and then combined with
+    # flatness F1 to produce the preliminary valley flatness index
+    # (PVF1) for the first step:
+    grass.message( "Step 1: Calculation of preliminary valley flatness index PVF1" )
+    grass.mapcalc("PVF1 = F1 * (1.0 / (1.0 + pow ( ( PCTL1 / 0.4 ), 3 ) ) )")
+    grass.message( "Step 1: Calculation of preliminary valley flatness index PVF1 done." )
+    # Calculation of the valley flatness step 1 VF1
+	# larger values of VF1 indicate increasing valley bottom character
+	# with values less than 0.5 considered not to be in valley bottoms
+    grass.message( "Step 1: Calculation of valley flatness VF1" )
+    grass.mapcalc("VF1 = 1 - (1.0 / (1.0 + pow ( ( PVF1 / 0.3 ), 4 ) ) )")
+    grass.message( "Step 1: Calculation of valley flatness VF1 done." )
+	# Step 2 (S2)
+	# base scale resolution
+    grass.message( "Step 2" )
+    grass.message( "base resolution: %s x %s" % (Xres_base, Yres_base))
+    # The second step commences the same way with the
+    # original DEM at its base resolution, using a slope threshold ts,2 half of ts,1:
+	# Flatness F2 = 1 / (1 + pow ((slope / 8), 4)
+    grass.message( "Step 2: Calculation of flatness F2" )
+    grass.mapcalc("F2 = 1.0 / (1.0 + pow( ( $slope / 8.0 ) ,4 ) )",
+    grass.message( "Step 2: Calculation of flatness F2 done" )
+    # Calculation of elevation percentile PCTL2 step 2
+	# elevation of percentile step 2: radius of 3 cells
+    grass.message( "Step 2: Calculation of elevation percentile PCTL2" )
+    offsets2 = [d
+         for j in xrange(1,6+1)
+         for i in [j,-j]
+    terms2 = ["(elevation_step1[%d,%d] < elevation_step1)" % d
+         for d in offsets2]
+    expr2 = "PCTL2 = (100.0 / 48.0) * (%s)" % " + ".join(terms2)
+    grass.mapcalc( expr2 )
+    grass.run_command("g.remove", rast = "elevation_step1",
+                                     quiet = True)
+    grass.message( "Step 2: Calculation of elevation percentile PCTL2 done" )
+    # PVF2 for step 2:
+    grass.message( "Step 2: Calculation of preliminary valley flatness index PVF2" )
+    grass.mapcalc("PVF2 = F2 * (1.0 / (1.0 + pow ( ( PCTL2 / 0.4 ), 3 ) ) )")
+    grass.message( "Step 2: Calculation of preliminary valley flatness index PVF2 done." )
+    # Calculation of the valley flatness step 2 VF2
+    grass.message( "Step 2: Calculation of valley flatness VF2" )
+    grass.mapcalc("VF2 = 1 - (1.0 / (1.0 + pow ( ( PVF2 / 0.3 ), 4 ) ) )")
+    grass.message( "Step 2: Calculation of valley flatness VF2 done." )
+    # Calculation of weight W2
+    grass.message( "Step 2: Calculation of weight W2" )
+    grass.mapcalc("W2 = 1 - (1.0 / (1.0 + pow ( ( VF2 / 0.4 ), 6.68 ) ) )")
+    grass.message( "Step 2: Calculation of weight W2 done." )
+    # Calculation of MRVBF2
+    grass.message( "Step 2: Calculation of MRVBF2" )
+    grass.mapcalc("MRVBF2 = (W2 * (1 + VF2)) + ((1 - W2) * VF1)")
+    grass.message( "Step 2: Calculation of MRVBF2 done." )
+    # Calculation of combined flatness index CF2
+    grass.message( "Step 2: Calculation  of combined flatness index CF2" )
+    grass.mapcalc("CF2 = F1 * F2")
+    grass.message( "Step 2: Calculation  of combined flatness index CF2 done." )
+    # step 2 finished
+    grass.message( "Step 2 calculations done." )
+    # remaining steps
+    grass.message( "two remaining steps" )
+	# Step 3
+    grass.message( "Step 3" )
+	# DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3 x 3 -> change resolution (3 x base resolution) -> calculations
+	# DEM smoothing
+    grass.message( "Step 3: DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3" )
+    grass.run_command('r.neighbors',  input = r_elevation,
+                                    output = "DEM_smoothed_step3",
+                                    size = 11,
+                                    gauss=3)
+    grass.message( "Step 3 DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3 done." )
+	# Calculate slope step 3
+    grass.message( "Step 3: Calculation of slope" )
+    grass.run_command('r.slope.aspect', elevation = "DEM_smoothed_step3",
+                                     slope = "DEM_smoothed_step3_slope_degree",
+                                     zfactor = 1.0,
+                                     overwrite = True)
+                                     outmap = "r_slope_step3",
+                                     slope = "DEM_smoothed_step3_slope_degree")
+    grass.run_command('g.remove', rast = "DEM_smoothed_step3_slope_degree",
+                                     quiet = True)
+    grass.message( "Step 3: Calculation of slope done." )
+	# change resolution
+    grass.message( "Step 3: change to resolution to 3 x base resolution" )
+    grass.run_command('g.region', res = Xres_step3,
+                                    flags = 'a')
+    current_region_step3 = grass.region()
+    Y_step3 = current_region_step3['nsres']
+    X_step3 = current_region_step3['ewres']
+    grass.message( "Resolution step 3: %s x %s" % (X_step3, Y_step3))
+	# coarsening DEM to resolution step 3 and calculate PCTL3 step 3
+    grass.message( "Step 3: Calculation of elevation percentile PCTL3" )
+    grass.mapcalc("DEM_smoothed_step3_coarsed = DEM_smoothed_step3")
+    offsets3 = [d
+         for i in [j,-j]
+    terms3 = ["(DEM_smoothed_step3_coarsed[%d,%d] < DEM_smoothed_step3_coarsed)" % d
+         for d in offsets3]
+    expr3 = "PCTL3 = (100.0 / 48.0) * (%s)" % " + ".join(terms3)
+    grass.mapcalc( expr3 )
+    grass.message( "Step 3: Calculation of elevation percentile PCTL3 done." )
+	# switch back to base resolution
+    grass.message( "Step 3: switch back to base resolution." )
+    grass.run_command('g.region', rast = r_elevation,
+                                    align = r_elevation,
+                                    flags = 'a')
+    current_region_step3_switched_back = grass.region()
+    Y_step3_switched_back = current_region_step3_switched_back['nsres']
+    X_step3_switched_back = current_region_step3_switched_back['ewres']
+    grass.message( "Resolution step 3: %s x %s" % (X_step3_switched_back, Y_step3_switched_back))
+	# resample/refine PCTL3 to base resolution
+    grass.message( "Step 3: refine PCTL3 to base resolution" )
+    grass.run_command('r.resamp.interp', input = "PCTL3",
+                                     output = "PCTL3_refined_base_resolution",
+                                     method = "bilinear")
+    grass.message( "Step 3: refine PCTL3 to base resolution done." )
+	# calculate flatness F3 at the base resolution
+    grass.message( "Step 3: calculate F3 at base resolution" )
+    grass.mapcalc("F3 = 1.0 / (1.0 + pow( ( $slope / 8.0 ) ,4 ) )",
+                                     slope = "r_slope_step3")
+    grass.message( "Step 3: calculate F3 at base resolution done." )
+	# calculate accumulated combined flatness CF3 at the base resolution
+    grass.message( "Step 3: calculate combined flatness CF3 at base resolution" )
+    grass.mapcalc("CF3 = CF2 * F3")
+    grass.message( "Step 3: calculate combined flatness CF3 at base resolution done." )
+	# calculate preliminary valley flatness index PVF3 at the base resolution
+    grass.message( "Step 3: calculate preliminary valley flatness index PVF3 at base resolution" )
+    grass.mapcalc("PVF3 = CF3 * (1.0 / (1.0 + pow ( ( PCTL3_refined_base_resolution / 0.4 ), 3 ) ) )")
+    grass.message( "Step 3: calculate preliminary valley flatness index PVF3 at base resolution done." )
+	# calculate valley flatness index VF3
+    grass.message( "Step 3: calculate valley flatness index VF3 at base resolution" )
+    grass.mapcalc("VF3 = 1 - (1.0 / (1.0 + pow ( ( PVF3 / 0.3 ), 4 ) ) )")
+    grass.message( "Step 3: calculate valley flatness index VF3 at base resolution done." )
+    # Calculation of weight W3
+    grass.message( "Step 3: Calculation of weight W3" )
+    p3 = (math.log10((3 - 0.5) / 0.1)) / math.log10(1.5)
+    grass.mapcalc("W3 = 1 - (1.0 / (1.0 + pow ( ( VF3 / 0.4 ), $p ) ) )", p = p3)
+    grass.message( "Step 3: Calculation of weight W3 done." )
+    # Calculation of MRVBF3
+    grass.message( "Step 3: Calculation of MRVBF3" )
+    grass.mapcalc("MRVBF3 = (W3 * (3 - 1 + VF3)) + ((1 - W3) * MRVBF2)")
+    grass.message( "Step 3: Calculation of MRVBF3 done." )
+	# Step 4
+    grass.message( "Step 4" )
+    grass.message( "Step 4: change to resolution of step 3" )
+                                    flags = 'a')
+    grass.message( "Resolution 1 for step 4: %s x %s" % (X_step3, Y_step3))
+	# DEM smoothing
+    grass.message( "Step 4: DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3" )
+    grass.run_command('r.neighbors',  input = "DEM_smoothed_step3_coarsed",
+                                    output = "DEM_smoothed_step4",
+                                    size = 11,
+                                    gauss=3)
+    grass.message( "Step 4 DEM smoothing 11 x 11 windows with Gaussian smoothing kernel (sigma) 3 done." )
+	# Calculate slope step 4
+    grass.message( "Step 4: Calculation of slope" )
+    grass.run_command('r.slope.aspect', elevation = "DEM_smoothed_step4",
+                                     slope = "DEM_smoothed_step4_slope_degree",
+                                     zfactor = 1.0,
+                                     overwrite = True)
+                                     outmap = "r_slope_step4",
+                                     slope = "DEM_smoothed_step4_slope_degree")
+    grass.run_command('g.remove', rast = "DEM_smoothed_step4_slope_degree",
+                                     quiet = True)
+    grass.message( "Step 4: Calculation of slope done." )
+    grass.message( "Step 4: change to resolution to 3 x 3 step 3 resolution" )
+    grass.run_command('g.region', res = Xres_step4,
+                                    flags = 'a')
+    current_region_step4 = grass.region()
+    Y_step4 = current_region_step4['nsres']
+    X_step4 = current_region_step4['ewres']
+    grass.message( "Resolution step 3: %s x %s" % (X_step4, Y_step4))
+	# coarsening DEM to resolution step 4 and calculate PCTL step 4
+    grass.message( "Step 4: Calculation of elevation percentile PCTL4" )
+    grass.mapcalc("DEM_smoothed_step4_coarsed = DEM_smoothed_step4")
+    offsets4 = [d
+         for i in [j,-j]
+    terms4 = ["(DEM_smoothed_step4_coarsed[%d,%d] < DEM_smoothed_step4_coarsed)" % d
+         for d in offsets4]
+    expr4 = "PCTL4 = (100.0 / 48.0) * (%s)" % " + ".join(terms4)
+    grass.mapcalc( expr4 )
+    grass.message( "Step 4: Calculation of elevation percentile PCTL4 done." )
+    grass.message( "Step 4: switch back to base resolution." )
+                                    flags = 'a')
+    current_region_step4_switched_back = grass.region()
+    Y_step4_switched_back = current_region_step4_switched_back['nsres']
+    X_step4_switched_back = current_region_step4_switched_back['ewres']
+    grass.message( "Resolution step 4: %s x %s" % (X_step4_switched_back, Y_step4_switched_back))
+	# resample/refine PCTL4 to base resolution
+    grass.message( "Step 4: refine PCTL4 to base resolution" )
+    grass.run_command('r.resamp.interp', input = "PCTL4",
+                                     output = "PCTL4_refined_base_resolution",
+    grass.message( "Step 4: refine PCTL4 to base resolution done." )
+	# calculate flatness F4 at the base resolution
+    grass.message( "Step 4: calculate F4 at base resolution" )
+    grass.run_command('r.resamp.interp', input = "r_slope_step4",
+                                     output = "r_slope_step4_refined_base_resolution",
+    grass.mapcalc("F4 = 1.0 / (1.0 + pow( ( $slope / 4.0 ) ,4 ) )",
+                                     slope = "r_slope_step4_refined_base_resolution")
+    grass.message( "Step 4: calculate F4 at base resolution done." )
+    grass.message( "Step 4: calculate combined flatness CF4 at base resolution" )
+    grass.mapcalc("CF4 = CF3 * F4")
+    grass.message( "Step 4: calculate combined flatness CF4 at base resolution done." )
+    grass.message( "Step 4: calculate preliminary valley flatness index PVF4 at base resolution" )
+    grass.mapcalc("PVF4 = CF4 * (1.0 / (1.0 + pow ( ( PCTL4_refined_base_resolution / 0.4 ), 3 ) ) )")
+    grass.message( "Step 4: calculate preliminary valley flatness index PVF4 at base resolution done." )
+	# calculate valley flatness index VF4
+    grass.message( "Step 4: calculate valley flatness index VF4 at base resolution" )
+    grass.mapcalc("VF4 = 1 - (1.0 / (1.0 + pow ( ( PVF4 / 0.3 ), 4 ) ) )")
+    grass.message( "Step 4: calculate valley flatness index VF4 at base resolution done." )
+    # Calculation of weight W4
+    grass.message( "Step 4: Calculation of weight W4" )
+    p4 = (math.log10((4 - 0.5) / 0.1)) / math.log10(1.5)
+    grass.mapcalc("W4 = 1 - (1.0 / (1.0 + pow ( ( VF4 / 0.4 ), $p ) ) )", p = p3)
+    grass.message( "Step 4: Calculation of weight W4 done." )
+    # Calculation of MRVBF4
+    grass.message( "Step 4: Calculation of MRVBF4" )
+    grass.mapcalc("MRVBF4 = (W4 * (3 - 1 + VF4)) + ((1 - W4) * MRVBF3)")
+    grass.message( "Step 4: Calculation of MRVBF4 done." )
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
