[GRASS-SVN] r59268 - grass/branches/develbranch_6/vector/v.buffer2
Sun Mar 16 05:40:02 PDT 2014
Author: neteler
Date: 2014-03-16 05:40:02 -0700 (Sun, 16 Mar 2014)
New Revision: 59268
Added:
   grass/branches/develbranch_6/vector/v.buffer2/v_buffer_areas.png
   grass/branches/develbranch_6/vector/v.buffer2/v_buffer_points.png
   grass/branches/develbranch_6/vector/v.buffer2/description.html
   grass/branches/develbranch_6/vector/v.buffer2/v_buffer_lines.png
v.buffer manual: more example screenshots
Modified: grass/branches/develbranch_6/vector/v.buffer2/description.html
--- grass/branches/develbranch_6/vector/v.buffer2/description.html	2014-03-16 12:37:30 UTC (rev 59267)
+++ grass/branches/develbranch_6/vector/v.buffer2/description.html	2014-03-16 12:40:02 UTC (rev 59268)
@@ -49,7 +49,24 @@
      database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf'
 </pre></div>
+<center>
+<img src="v_buffer_points.png" border="1"><br>
+Buffer of 2000m around the "hospitals" points (map subset, original points
+shown in black, new area centroids in red)
+</center>
+<h3>Buffer around input areas</h3>
+<div class="code"><pre>
+v.buffer input=lakes output=lakes_buffer type=area distance=100
+</pre></div>
+<center>
+<img src="v_buffer_areas.png" border="1"><br>
+Buffer of 100m around the "lakes" polygons (map subset, original areas
+shown in black)
+</center>
 <h2>SEE ALSO</h2>
 <em>
Added: grass/branches/develbranch_6/vector/v.buffer2/v_buffer_areas.png
(Binary files differ)
Property changes on: grass/branches/develbranch_6/vector/v.buffer2/v_buffer_areas.png
___________________________________________________________________
Added: svn:mime-type
   + image/png
Modified: grass/branches/develbranch_6/vector/v.buffer2/v_buffer_lines.png
Added: grass/branches/develbranch_6/vector/v.buffer2/v_buffer_points.png
Property changes on: grass/branches/develbranch_6/vector/v.buffer2/v_buffer_points.png
   + image/png
