[GRASS-SVN] r59333 - grass-addons/grass7/raster/r.basin
Tue Mar 25 08:30:21 PDT 2014
Author: madi
Date: 2014-03-25 08:30:21 -0700 (Tue, 25 Mar 2014)
New Revision: 59333
   grass-addons/grass7/raster/r.basin/r.basin.py
centroid-r.volume and main channel bugs fixed
Modified: grass-addons/grass7/raster/r.basin/r.basin.py
--- grass-addons/grass7/raster/r.basin/r.basin.py	2014-03-25 15:12:47 UTC (rev 59332)
+++ grass-addons/grass7/raster/r.basin/r.basin.py	2014-03-25 15:30:21 UTC (rev 59333)
@@ -110,7 +110,6 @@
     r_outlet = prefix+'_r_outlet'
     v_outlet = prefix+'_outlet'
     v_basin = prefix+'_basin'
-    v_centroid1 = prefix+'_centroid1'
     v_mainchannel = prefix+'_mainchannel'
     v_mainchannel_dim = prefix+'_mainchannel_dim'
     v_network = prefix+'_network'
@@ -377,7 +376,6 @@
         # Centroid and mean slope
         baricenter_slope_baricenter = grass.read_command("r.volume", input = r_slope,
        clump = r_basin,
-        centroids = v_centroid1,
        overwrite = True)
         grass.message("r.volume done")
@@ -446,7 +444,7 @@
         param_mainchannel = grass.read_command('v.what', map = v_mainchannel,
                                                      coordinates = '%s,%s' % (east,north),
                                                      distance = 5 )
-        tmp = param_mainchannel.split('\n')[8]
+        tmp = param_mainchannel.split('\n')[7]
         mainchannel = float(tmp.split()[1]) / 1000   # km
         # Topological Diameter
@@ -592,7 +590,6 @@
         grass.run_command('g.remove', rast = prefix+'_ord_1_thin', quiet = True)
         grass.run_command('g.remove', rast = prefix+'_stream_e_thin', quiet = True)
         grass.run_command('g.remove', vect = v_mainchannel_dim+'_point', quiet = True)
-        grass.run_command('g.remove', vect = v_centroid1, quiet = True)
         grass.run_command('g.remove', vect = v_mainchannel_dim, quiet = True)
         grass.run_command('g.remove', vect = v_ord_1, quiet = True)
