[GRASS-SVN] r59404 - grass-addons/grass7/raster/r.stream.order
Thu Mar 27 05:29:37 PDT 2014
Author: martinl
Date: 2014-03-27 05:29:36 -0700 (Thu, 27 Mar 2014)
New Revision: 59404
   grass-addons/grass7/raster/r.stream.order/Makefile
   grass-addons/grass7/raster/r.stream.order/io.c
   grass-addons/grass7/raster/r.stream.order/io.h
   grass-addons/grass7/raster/r.stream.order/local_proto.h
   grass-addons/grass7/raster/r.stream.order/local_vars.h
   grass-addons/grass7/raster/r.stream.order/main.c
   grass-addons/grass7/raster/r.stream.order/stream_init.c
   grass-addons/grass7/raster/r.stream.order/stream_order.c
   grass-addons/grass7/raster/r.stream.order/stream_raster_close.c
   grass-addons/grass7/raster/r.stream.order/stream_topology.c
   grass-addons/grass7/raster/r.stream.order/stream_vector.c
r.stream.order: more guisection, message correction
                various minor cosmetics
Modified: grass-addons/grass7/raster/r.stream.order/Makefile
--- grass-addons/grass7/raster/r.stream.order/Makefile	2014-03-27 11:57:00 UTC (rev 59403)
+++ grass-addons/grass7/raster/r.stream.order/Makefile	2014-03-27 12:29:36 UTC (rev 59404)
@@ -11,4 +11,3 @@
 include $(MODULE_TOPDIR)/include/Make/Module.make
 default: cmd
Modified: grass-addons/grass7/raster/r.stream.order/io.c
--- grass-addons/grass7/raster/r.stream.order/io.c	2014-03-27 11:57:00 UTC (rev 59403)
+++ grass-addons/grass7/raster/r.stream.order/io.c	2014-03-27 12:29:36 UTC (rev 59404)
@@ -14,7 +14,7 @@
     int r;
     if (data_type < 0 || data_type > 2)
-	G_fatal_error(_("ram_creat: Cannot create map of unrecognised type"));
+	G_fatal_error(_("Unable to create raster map of unrecognised type"));
     map->data_type = data_type;
     map->map_name = NULL;
@@ -76,10 +76,10 @@
     if (check_res)
 	if (this_window.ew_res != cellhd.ew_res ||
 	    this_window.ns_res != cellhd.ns_res)
-	    G_fatal_error(_("Region resolution and map %s resolution differs. \
-		Run g.region rast=%s to set proper region resolution"),
-			  input_map_name, input_map_name);
+          G_fatal_error(_("Region resolution and raster map <%s> resolution differs. "
+                          "Run 'g.region rast=%s' to set proper region resolution."),
+                        input_map_name, input_map_name);
     /* checking if input map is of required type */
     if (check_data_type != map->data_type)
 	G_debug(1,
@@ -87,7 +87,7 @@
     input_data_type = Rast_map_type(input_map_name, mapset);
     if (check_data_type != -1)
 	if (input_data_type != check_data_type)
-	    G_fatal_error(_("<%s> is not of type %s"),
+	    G_fatal_error(_("Raster map <%s> is not of type '%s'"),
 			  input_map_name, maptypes[check_data_type]);
     input_map_fd = Rast_open_old(input_map_name, mapset);
@@ -117,7 +117,7 @@
     input_buffer = Rast_allocate_buf(input_data_type);
     /* start reading */
-    G_message(_("Reading map <%s>"), input_map_name);
+    G_message(_("Reading raster map <%s>..."), input_map_name);
     for (r = 0; r < map->nrows; ++r) {
 	G_percent(r, map->nrows, 2);
@@ -145,7 +145,7 @@
 					 input_data_type);
 		    break;
 		default:
-		    G_fatal_error(_("ram_open:Wrong internal data type"));
+		    G_fatal_error(_("Wrong internal data type"));
 		    break;
     }				/*end for r */
@@ -192,7 +192,7 @@
 	G_debug(1,
 		"ram_write:required map type and internal map type differs: conversion forced!");
-    G_message(_("Writing map <%s>"), output_map_name);
+    G_message(_("Writing raster map <%s>..."), output_map_name);
     output_fd = Rast_open_new(output_map_name, output_data_type);
     /* writing */
@@ -218,7 +218,7 @@
 			Rast_set_d_null_value(row + c * (map->data_size), 1);
 		break;
 	    default:
-		G_debug(1, "ram_null:Cannot convert to null at: %d %d", r, c);
+		G_debug(1, "Unable to convert to NULL at: %d %d", r, c);
@@ -229,7 +229,7 @@
     Rast_short_history(output_map_name, "raster", &history);
     Rast_command_history(&history);
     Rast_write_history(output_map_name, &history);
-    G_message(_("<%s> Done"), output_map_name);
+    /* G_message(_("<%s> Done"), output_map_name); */
     return 0;
@@ -294,7 +294,7 @@
 	seg->data_size = sizeof(DCELL);
 	break;
     default:
-	G_fatal_error(_("seg_create: unrecognisabe data type"));
+	G_fatal_error(_("Uunrecognisable data type"));
     filename = G_tempfile();
@@ -305,18 +305,18 @@
 		       seg->data_size)) {
 	close(fd);
 	unlink(filename);
-	G_fatal_error(_("seg_create: cannot format segment"));
+	G_fatal_error(_("Unable to format segment"));
     close(fd);
     if (0 > (fd = open(filename, 2))) {
 	unlink(filename);
-	G_fatal_error(_("seg_create: cannot re-open file"));
+	G_fatal_error(_("Unable re-open file '%s'"), filename);
     if (0 > (fd = segment_init(&(seg->seg), fd, number_of_segs))) {
 	unlink(filename);
-	G_fatal_error(_("seg_create: cannot init segment file or out of memory"));
+	G_fatal_error(_("Unable to init segment file or out of memory"));
     seg->filename = G_store(filename);
@@ -351,7 +351,7 @@
     /* checking if map exist */
     mapset = (char *)G_find_raster2(input_map_name, "");
     if (mapset == NULL)
-	G_fatal_error(_("seg_read:Raster map <%s> not found"),
+	G_fatal_error(_("Raster map <%s> not found"),
 		      input_map_name);
     seg->mapset = mapset;
@@ -363,17 +363,17 @@
     if (check_res)
     if (check_data_type != seg->data_type)
 	G_debug(1,
 		"ram_open:required map type and internal map type differs: conversion forced!");
     input_fd = Rast_open_old(input_map_name, mapset);
@@ -401,7 +401,7 @@
     /* end opening and checking */
     target_buffer = Rast_allocate_buf(seg->data_type);
@@ -441,7 +441,7 @@
 	    G_free(input_buffer);
 	    G_free(target_buffer);
 	    Rast_close(input_fd);
-	    G_fatal_error(_("seg_read: Cannot segment put row %d for map %s"),
+	    G_fatal_error(_("Unable to segment put row %d for raster map <%s>"),
 			  r, input_map_name);
     }				/* end for row */
@@ -495,7 +495,7 @@
 	G_debug(1,
     output_buffer = Rast_allocate_buf(output_data_type);
     segment_flush(&(seg->seg));
@@ -505,7 +505,7 @@
 	G_percent(r, seg->nrows, 2);
 	if (0 > segment_get_row(&(seg->seg), output_buffer, r))
-	    G_warning(_("seg_write: Cannot segment read row %d for map %s"),
+	    G_warning(_("Unable to segment read row %d for raster map <%s>"),
 		      r, output_map_name);
 	if (convert_to_null) {
@@ -528,7 +528,7 @@
 			Rast_set_d_null_value(row + c * (seg->data_size), 1);
 		break;
 	    default:
-		G_warning(_("ram_null:Cannot convert to null at: %d %d"), r,
+		G_warning(_("Unable to convert to NULL at: %d %d"), r,
 			  c);
@@ -541,7 +541,7 @@
-    G_message(_("%s Done"), output_map_name);
+    /* G_message(_("%s Done"), output_map_name); */
     return 0;
Modified: grass-addons/grass7/raster/r.stream.order/io.h
--- grass-addons/grass7/raster/r.stream.order/io.h	2014-03-27 11:57:00 UTC (rev 59403)
+++ grass-addons/grass7/raster/r.stream.order/io.h	2014-03-27 12:29:36 UTC (rev 59404)
@@ -56,4 +56,3 @@
 int seg_reset_map (SEG *, int);
 int seg_write_map(SEG *, char *, RASTER_MAP_TYPE, int, double);
 int seg_release_map(SEG *);
Modified: grass-addons/grass7/raster/r.stream.order/local_proto.h
--- grass-addons/grass7/raster/r.stream.order/local_proto.h	2014-03-27 11:57:00 UTC (rev 59403)
+++ grass-addons/grass7/raster/r.stream.order/local_proto.h	2014-03-27 12:29:36 UTC (rev 59404)
@@ -25,5 +25,3 @@
 int ram_create_vector(CELL** streams, CELL** dirs, char* out_vector, int number_of_streams);
 int seg_create_vector(SEGMENT* streams, SEGMENT* dirs, char* out_vector, int number_of_streams);
 int stream_add_table (int number_of_streams);
Modified: grass-addons/grass7/raster/r.stream.order/local_vars.h
--- grass-addons/grass7/raster/r.stream.order/local_vars.h	2014-03-27 11:57:00 UTC (rev 59403)
+++ grass-addons/grass7/raster/r.stream.order/local_vars.h	2014-03-27 12:29:36 UTC (rev 59404)
@@ -59,8 +59,3 @@
 /* output vector */
 GLOBAL struct Map_info Out;
Modified: grass-addons/grass7/raster/r.stream.order/main.c
--- grass-addons/grass7/raster/r.stream.order/main.c	2014-03-27 11:57:00 UTC (rev 59403)
+++ grass-addons/grass7/raster/r.stream.order/main.c	2014-03-27 12:29:36 UTC (rev 59404)
@@ -1,20 +1,20 @@
- * MODULE:			r.stream.order
+ * MODULE:		r.stream.order
  * AUTHOR(S):		Jarek Jasiewicz jarekj amu.edu.pl
- * PURPOSE:			Calculate Strahler's and more streams hierarchy
- *							It use r.stream.extract or r.watershed output files:
- * 							stream, direction, accumulation and elevation.
- * 							The output are set of raster maps and vector file containing
- * 							addational stream attributes.
+ * PURPOSE:		Calculate Strahler's and more streams hierarchy
+ *			It use r.stream.extract or r.watershed output files:
+ * 			stream, direction, accumulation and elevation.
+ * 			The output are set of raster maps and vector file containing
+ * 			addational stream attributes.
- * COPYRIGHT:		(C) 2009,2010 by the GRASS Development Team
+ * COPYRIGHT:		(C) 2009-2014 by the GRASS Development Team
- *							This program is free software under the GNU General Public
- *							License (>=v2). Read the file COPYING that comes with GRASS
- *							for details.
+ *			This program is free software under the GNU General Public
+ *			License (>=v2). Read the file COPYING that comes with GRASS
+ *			for details.
 #define MAIN
@@ -29,11 +29,10 @@
     IO input[] = {
-	{"streams", YES, "output of r.stream.extract or r.watershed"},
-	{"dirs", YES, "output of r.stream.extract or r.watershed"},
-	{"elevation", NO, "any type digital elevation model"},
-	{"accum", NO,
-	 "any type acc map created by r.watershed or used in r.stream.extract"}
+        {"streams", YES, _("Name of input streams raster map")},
+	{"dirs", YES, _("Name of input direction raster map")},
+	{"elevation", NO, _("Name of input elevation raster map")},
+	{"accum", NO, _("Name of input accumulation raster map")}
     /* add new basic rdering here and in local_vars.h declaration
@@ -43,11 +42,11 @@
      * derivative orders (like Scheideggers/Shreve) shall be added only
      * to table definition as a formula and to description file. */
     IO output[] = {
-	{"strahler", NO, "Strahler's stream order"},
-	{"horton", NO, "Original Hortons's stream order"},
-	{"shreve", NO, "Shereve's stream magnitude"},
-	{"hack", NO, "Hack's streams or Gravelius stream hierarchy"},
-	{"topo", NO, "Topological dimension of streams"}
+	{"strahler", NO, _("Name for output Strahler's stream order raster map")},
+	{"horton", NO, _("Name for output original Hortons's stream order raster map")},
+	{"shreve", NO, _("Name for output Shereve's stream magnitude raster map")},
+	{"hack", NO, _("Name for outut Hack's streams or Gravelius stream hierarchy raster map")},
+	{"topo", NO, _("Name for output topological dimension of streams raster map")}
     struct GModule *module;	/* GRASS module for parsing arguments */
@@ -58,7 +57,7 @@
     struct Flag *flag_zerofill, *flag_accum, *flag_segmentation;
     int output_num = 0;
-    int num_seg;		/* number of segments */
+    /* int num_seg; */		/* number of segments */
     int segmentation, zerofill;
     int i;			/* iteration vars */
     int number_of_segs;
@@ -70,28 +69,27 @@
     G_gisinit(argv[0]);
     module = G_define_module();
+    module->label = _("Calculates Strahler's and more streams hierarchy.");
     module->description =
-	_("Calculate Strahler's and more streams hierarchy. Basic module for topological analysis of drainage network");
+	_("Basic module for topological analysis of drainage network.");
     G_add_keyword(_("raster"));
     G_add_keyword(_("hydrology"));
-    G_add_keyword("Strahler stream order");
-    G_add_keyword("Hack streams");
-    G_add_keyword("Stream network topology");
-    G_add_keyword("Stream network geometry");
-    G_add_keyword("Network vectorisation");
+    G_add_keyword(_("stream network"));
+    G_add_keyword(_("stream order"));
     for (i = 0; i < input_size; ++i) {
 	opt_input[i] = G_define_standard_option(G_OPT_R_INPUT);
 	opt_input[i]->key = input[i].name;
 	opt_input[i]->required = input[i].required;
 	opt_input[i]->description = _(input[i].description);
+        opt_input[i]->guisection = _("Input");
     opt_vector = G_define_standard_option(G_OPT_V_OUTPUT);
     opt_vector->key = "vector";
     opt_vector->required = NO;
     opt_vector->description =
-	_("OUTPUT vector file to write stream atributes");
+	_("Name for output vector map to write stream atributes");
     opt_vector->guisection = _("Output");
     for (i = 0; i < orders_size; ++i) {
@@ -107,7 +105,7 @@
     opt_swapsize->type = TYPE_INTEGER;
     opt_swapsize->answer = "300";
     opt_swapsize->description = _("Max memory used in memory swap mode (MB)");
-    opt_swapsize->guisection = _("Optional");
+    opt_swapsize->guisection = _("Memory settings");
     flag_zerofill = G_define_flag();
     flag_zerofill->key = 'z';
@@ -117,6 +115,7 @@
     flag_segmentation = G_define_flag();
     flag_segmentation->key = 'm';
     flag_segmentation->description = _("Use memory swap (operation is slow)");
+    flag_segmentation->guisection = _("Memory settings");
     flag_accum = G_define_flag();
     flag_accum->key = 'a';
@@ -138,21 +137,19 @@
     if (use_vector)
 	if (!opt_input[o_elev]->answer || !opt_input[o_accum]->answer)
-	    G_fatal_error(_("To calculate vector file both accum and elev are required"));
+	    G_fatal_error(_("To calculate vector map both accumulation and elevation raster maps are required"));
     if (use_accum)
 	if (!opt_input[o_accum]->answer)
-	    G_fatal_error(_("with -a (use accumulation) accum map is required"));
+	    G_fatal_error(_("Flag -a (use accumulation) accumulation raster map is required"));
 	if (!opt_output[i]->answer)
 	    continue;
-	if (G_legal_filename(opt_output[i]->answer) < 0)
-	    G_fatal_error(_("<%s> is an illegal file name"),
-			  opt_output[i]->answer);
 	output_num++;
     }				/* end for */
     if (!output_num && !opt_vector->answer)
-	G_fatal_error(_("You must select one or more output orders maps or insert the table name"));
+	G_fatal_error(_("You must select one or more output orders raster maps or insert the table name"));
     /* start */
     in_streams = opt_input[o_streams]->answer;
@@ -170,7 +167,7 @@
     /* ALL IN RAM VERSION */
     if (!segmentation) {
-	G_message("ALL IN RAM CALCULATION");
+        G_message(_("All in RAM calculation..."));
 	MAP map_streams, map_dirs;
 	CELL **streams, **dirs;
@@ -224,7 +221,7 @@
     /* SEGMENTATION VERSION */
     if (segmentation) {
-	G_message("MEMORY SWAP CALCULATION: MAY TAKE SOME TIME!");
+        G_message(_("Memory swap calculation (may take some time)..."));
 	SEG map_streams, map_dirs;
 	SEGMENT *streams, *dirs;
Modified: grass-addons/grass7/raster/r.stream.order/stream_init.c
--- grass-addons/grass7/raster/r.stream.order/stream_init.c	2014-03-27 11:57:00 UTC (rev 59403)
+++ grass-addons/grass7/raster/r.stream.order/stream_init.c	2014-03-27 12:29:36 UTC (rev 59404)
@@ -5,9 +5,9 @@
     int number_of_streams = max_index_of_stream;
     if (max_index_of_stream == 0)
-	G_fatal_error(_("Empty stream input map: check if a stream map"));
+        G_fatal_error(_("Empty stream input raster map"));
     if (min_index_of_stream < 0)
-	G_fatal_error(_("Stream map has negative values: check if a stream map"));
+	G_fatal_error(_("Stream map has negative values"));
     stream_attributes =
 	(STREAM *) G_malloc((number_of_streams + 1) * sizeof(STREAM));
Modified: grass-addons/grass7/raster/r.stream.order/stream_order.c
--- grass-addons/grass7/raster/r.stream.order/stream_order.c	2014-03-27 11:57:00 UTC (rev 59403)
+++ grass-addons/grass7/raster/r.stream.order/stream_order.c	2014-03-27 12:29:36 UTC (rev 59404)
@@ -13,7 +13,7 @@
     int max_strahler = 0, max_strahler_num;
     STREAM *SA = stream_attributes;	/* for better code readability */
-    G_message(_("Calculating Strahler's stream order ..."));
+    G_message(_("Calculating Strahler's stream order..."));
     for (j = 0; j < init_num; ++j) {	/* main loop on inits */
@@ -65,7 +65,8 @@
     int max_shreve = 0;
-    G_message(_("Calculating Shreve's stream magnitude, Scheidegger's consistent integer and Drwal's streams hierarchy (old style) ..."));
+    G_message(_("Calculating Shreve's stream magnitude, "
+                "Scheidegger's consistent integer and Drwal's streams hierarchy (old style)..."));
@@ -118,7 +119,7 @@
     int up_stream = 0;
-    G_message(_("Calculating Hortons's stream order ..."));
+    G_message(_("Calculating Hortons's stream order..."));
     stack = (int *)G_malloc(stack_max * sizeof(int));
     for (j = 0; j < outlet_num; ++j) {
Modified: grass-addons/grass7/raster/r.stream.order/stream_raster_close.c
--- grass-addons/grass7/raster/r.stream.order/stream_raster_close.c	2014-03-27 11:57:00 UTC (rev 59403)
+++ grass-addons/grass7/raster/r.stream.order/stream_raster_close.c	2014-03-27 12:29:36 UTC (rev 59404)
@@ -3,7 +3,9 @@
 			   int zerofill)
-    G_message("Closing maps...");
+    G_debug(3, "ram_close_raster_order(): number_of_streams=%d", number_of_streams);
+    G_message("Writing outpout raster maps...");
     int *output_fd;
     int r, c, i;
     CELL *output_buffer, *streams_buffer;
@@ -56,7 +58,7 @@
 	Rast_short_history(output_map_names[i], "raster", &history);
 	Rast_write_history(output_map_names[i], &history);
-	G_message(_("%s Done"), output_map_names[i]);
+	/* G_message(_("%s Done"), output_map_names[i]); */
     G_free(output_fd);
@@ -74,6 +76,8 @@
     struct History history;
     size_t data_size;
+    G_debug(3, "seg_close_raster_order(): number_of_streams=%d", number_of_streams);
     output_fd = (int *)G_malloc(orders_size * sizeof(int));
 	if (output_map_names[i] == NULL)
@@ -88,7 +92,7 @@
     for (r = 0; r < nrows; ++r) {
 	if (0 > segment_get_row(streams, streams_buffer, r))
 		      r, output_map_names[i]);
@@ -122,7 +126,7 @@
+	/* G_message(_("%s Done"), output_map_names[i]);*/
     G_free(output_fd);
Modified: grass-addons/grass7/raster/r.stream.order/stream_topology.c
--- grass-addons/grass7/raster/r.stream.order/stream_topology.c	2014-03-27 11:57:00 UTC (rev 59403)
+++ grass-addons/grass7/raster/r.stream.order/stream_topology.c	2014-03-27 12:29:36 UTC (rev 59404)
@@ -15,10 +15,10 @@
     if (trib > 5)
-	G_fatal_error(_("Error finding nodes. \
-		Stream and direction maps probably do not match..."));
+	G_fatal_error(_("Error finding nodes. "
+                        "Stream and direction maps probably do not match."));
     if (trib > 3)
-	G_warning(_("Stream network may be too dense..."));
+	G_warning(_("Stream network may be too dense"));
     return trib;
@@ -62,8 +62,8 @@
 		if (cur_stream != next_stream) {	/* junction: building topology */
 		    if (outlet_num > (number_of_streams - 1))
 		    SA[cur_stream].stream = cur_stream;
 		    SA[cur_stream].next_stream = next_stream;
@@ -74,8 +74,8 @@
 		if (trib_num == 0) {	/* is init */
 		    if (init_num > (number_of_streams - 1))
 		    SA[cur_stream].trib_num = 0;
 		    init_cells[init_num] = r * ncols + c;
@@ -87,8 +87,8 @@
 		    for (i = 1; i < 9; ++i) {
 			if (trib > 4)
 			if (NOT_IN_REGION(i))
 			    continue;
 			j = DIAG(i);
@@ -222,10 +222,10 @@
     if (trib > 5)
     if (trib > 3)
     return trib;
@@ -280,8 +280,8 @@
@@ -292,8 +292,8 @@
@@ -306,8 +306,8 @@
 			if (trib > 4)
 			    continue;
 			j = DIAG(i);
@@ -426,6 +426,6 @@
 	    }			/* end if */
 	}			/* end while */
     }				/* end for s */
-    G_percent(s, init_num, 2);
+    G_percent(1, 1, 1);
     return 0;
Modified: grass-addons/grass7/raster/r.stream.order/stream_vector.c
--- grass-addons/grass7/raster/r.stream.order/stream_vector.c	2014-03-27 11:57:00 UTC (rev 59403)
+++ grass-addons/grass7/raster/r.stream.order/stream_vector.c	2014-03-27 12:29:36 UTC (rev 59404)
@@ -75,7 +75,7 @@
     /* build vector after adding table */
     if (0 < stream_add_table(number_of_streams))
-	G_warning(_("Cannot add table to vector %s"), out_vector);
+	G_warning(_("Unable to add attribute table to vector map <%s>"), out_vector);
     Vect_hist_command(&Out);
     Vect_build(&Out);
     Vect_close(&Out);
@@ -167,7 +167,7 @@
     Vect_build(&Out);
     Vect_close(&Out);
@@ -246,14 +246,14 @@
 	    "prev_str01 integer, prev_str02 integer, prev_str03 integer, prev_str04 integer, prev_str05 integer";
 	break;
     default:
-	G_fatal_error("Error with number of tributuaries");
+	G_fatal_error(_("Error with number of tributuaries"));
 	break;
-    sprintf(buf, "create table %s (%s, %s, %s, %s, %s, \
-																%s, %s, %s, %s, %s, \
-																%s,	%s,	%s)", Fi->table, tab_cat_col_name,	/* 1 */
+    sprintf(buf, "create table %s (%s, %s, %s, %s, %s,"
+            "%s, %s, %s, %s, %s,"
+            "%s, %s, %s)", Fi->table, tab_cat_col_name,	/* 1 */
 	    tab_stream, tab_next_stream, tab_prev_streams, tab_orders,	/* 5 */
 	    tab_scheidegger, tab_drwal_old, tab_length, tab_stright, tab_sinusoid,	/* 10 */
 	    tab_cumlength, tab_accum, tab_distance, tab_elev_init, tab_elev_outlet,	/* 15 */
@@ -265,16 +265,16 @@
     if (db_execute_immediate(driver, &db_sql) != DB_OK) {
 	db_close_database(driver);
 	db_shutdown_driver(driver);
-	G_warning("Cannot create table %s", db_get_string(&db_sql));
+	G_warning("Unable to create table <%s>", db_get_string(&db_sql));
 	return -1;
     if (db_create_index2(driver, Fi->table, cat_col_name) != DB_OK)
-	G_warning(_("cannot create index on table %s"), Fi->table);
+	G_warning(_("Unable to create index on table <%s>"), Fi->table);
     if (db_grant_on_table(driver, Fi->table,
 			  DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK) {
-	G_warning(_("cannot grant privileges on table %s"), Fi->table);
+	G_warning(_("Unable to grant privileges on table <%s>"), Fi->table);
 	return -1;
     db_begin_transaction(driver);
@@ -325,7 +325,7 @@
 		    SA[i].trib[4]);
 	    break;
 	default:
 	    break;
@@ -333,10 +333,10 @@
 		all_orders[0][i], all_orders[1][i],
 		all_orders[2][i], all_orders[3][i], all_orders[4][i]);
-	sprintf(buf, "insert into %s values(	%d, %d, %d, %s, %s, \
-																				%d, %d, %f, %f, %f, \
-																				%f, %f, %f, %f, %f, \
-																				%f,	%f, %f)", Fi->table, i,	/* 1 */
+	sprintf(buf, "insert into %s values( %d, %d, %d, %s, %s, "
+                "%d, %d, %f, %f, %f, "
+                "%f, %f, %f, %f, %f, "
+                "%f, %f, %f)", Fi->table, i,	/* 1 */
 		SA[i].stream, SA[i].next_stream, ins_prev_streams,	/* buffer created before */
 		insert_orders,	/* 5 *//* buffer created before */
 		scheidegger, drwal_old, SA[i].length, SA[i].stright, sinusoid,	/* 10 */
@@ -349,7 +349,7 @@
-	    G_warning(_("Cannot inset new row: %s"), db_get_string(&db_sql));
+	    G_warning(_("Unable to inset new row: '%s'"), db_get_string(&db_sql));
 	    return -1;
     }				/* end for */
