[GRASS-SVN] r59437 - grass/trunk/gui/wxpython/rlisetup
Thu Mar 27 08:48:56 PDT 2014
Author: lucadelu
Date: 2014-03-27 08:48:56 -0700 (Thu, 27 Mar 2014)
New Revision: 59437
   grass/trunk/gui/wxpython/rlisetup/functions.py
   grass/trunk/gui/wxpython/rlisetup/sampling_frame.py
g.gui.rlisetup: check if masked area raster already exist
Modified: grass/trunk/gui/wxpython/rlisetup/functions.py
--- grass/trunk/gui/wxpython/rlisetup/functions.py	2014-03-27 15:48:44 UTC (rev 59436)
+++ grass/trunk/gui/wxpython/rlisetup/functions.py	2014-03-27 15:48:56 UTC (rev 59437)
@@ -66,6 +66,17 @@
         return rlipath
+def checkMapExists(name, typ='rast'):
+    """!Check if a map already exist in the working mapset"""
+    env = grass.gisenv()
+    mapset = env['MAPSET']
+    mapp = grass.find_file(name, typ, mapset)
+    if mapp.name != '':
+        return True
+    else:
+        return False
 def convertFeature(vect, outrast, cat, origrast):
     """Convert a single feature to a raster"""
     tmp_vect = "tmp_{rast}".format(rast=outrast)
Modified: grass/trunk/gui/wxpython/rlisetup/sampling_frame.py
--- grass/trunk/gui/wxpython/rlisetup/sampling_frame.py	2014-03-27 15:48:44 UTC (rev 59436)
+++ grass/trunk/gui/wxpython/rlisetup/sampling_frame.py	2014-03-27 15:48:56 UTC (rev 59437)
@@ -51,11 +51,11 @@
 from core.render import Map
 from gui_core.toolbars import BaseToolbar, BaseIcons, ToolSwitcher
 from icons.icon import MetaIcon
+from core.gcmd import GMessage
 from grass.pydispatch.signal import Signal
 from grass.pydispatch.errors import DispatcherKeyError
-from functions import SamplingType
+from functions import SamplingType, checkMapExists
 class Circle:
@@ -206,13 +206,21 @@
         dlg = wx.TextEntryDialog(None, 'Name of sample region',
                                  'Create region', 'region' + str(self.catId))
         ret = dlg.ShowModal()
-        if ret == wx.ID_OK:
-            raster = dlg.GetValue()
-            marea = self.writeArea(self._registeredGraphics.GetItem(0).GetCoords(), raster)
-            self.nextRegion(next=True, area=marea)
-        else:
-            self.nextRegion(next=False)
-        dlg.Destroy()
+        while True:
+            if ret == wx.ID_OK:
+                raster = dlg.GetValue()
+                if checkMapExists(raster):
+                    GMessage(parent=self, message=_("The raster file %s already"
+                             " exists, please change name") % raster)
+                    ret = dlg.ShowModal()
+                else:
+                    dlg.Destroy()
+                    marea = self.writeArea(self._registeredGraphics.GetItem(0).GetCoords(), raster)
+                    self.nextRegion(next=True, area=marea)
+                    break
+            else:
+                self.nextRegion(next=False)
+                break
     def nextRegion(self, next=True, area=None):
         self.mapWindow.ClearLines()
@@ -255,7 +263,7 @@
                    type='area', overwrite=True)
         RunCommand('v.to.rast', input=tmpvector, output=rasterName,
-                   value=1, use='val', overwrite=True)
+                   value=1, use='val')
         wx.EndBusyCursor()
         grass.use_temp_region()
         grass.run_command('g.region', vect=tmpvector)
@@ -301,13 +309,21 @@
         dlg = wx.TextEntryDialog(None, 'Name of sample circle region',
                                  'Create circle region', 'circle' + str(self.catId))
-            circle = self.writeCircle(c, raster)
-            self.nextCircle(next=True, circle=circle)
-        else:
-            self.nextCircle(next=False)
-        dlg.Destroy()
+        while True:
+                else:
+                    dlg.Destroy()
+                    circle = self.writeCircle(c, raster)
+                    self.nextCircle(next=True, circle=circle)
+                    break
+            else:
+                self.nextCircle(next=False)
+                break
     def nextCircle(self, next=True, circle=None):
