[GRASS-SVN] r59447 - grass-addons/grass7/raster/r.stream.distance
Thu Mar 27 10:16:46 PDT 2014
Author: hellik
Date: 2014-03-27 10:16:46 -0700 (Thu, 27 Mar 2014)
New Revision: 59447
   grass-addons/grass7/raster/r.stream.distance/r.stream.distance.html
r.stream.distance: manual reorder and formatting
Modified: grass-addons/grass7/raster/r.stream.distance/r.stream.distance.html
--- grass-addons/grass7/raster/r.stream.distance/r.stream.distance.html	2014-03-27 16:56:42 UTC (rev 59446)
+++ grass-addons/grass7/raster/r.stream.distance/r.stream.distance.html	2014-03-27 17:16:46 UTC (rev 59447)
@@ -1,3 +1,31 @@
+<h2>DESCRIPTION</h2>
+<p>
+Module <em>r.stream.distance</em> may calculate distance using two methods: downstream
+and upstream.
+<p>
+The default is downstream method when it calculates distance to streams and
+outlets and relative elevation to streams and outlets. The distance and
+elevation is calculated along watercourses. In outlets mode it can also
+calculate parameters for subbasins.
+<p>
+In streams mode (default) it calculates that parameters downstream to streams
+which are added as stream mask. In outlets mode there are some additional
+possibilities. If subbasin is off it calculate parameters only for last point of
+last (downstream) CELL. In subbasin mode it calculates parameters for every
+subbasin separately. Subbasin mode acts similar to subbasin mask. Streams file
+prepared to create basins and subbasins with <em>r.stream.basins</em> can be used to
+calculate distance and elevation parameters.
+<p>
+With upstream method it calculates distance to the local maximum or divide.
+Opposite to downstream method, where every cell has one and only one downstream
+cell in upstream method every cell has usually more than one upstream cell. So
+it is impossible to determine interchangeable path from any cell. The upstream
+method offers two alternative modes switched with -n flag: nearest local
+maximum/divide:  means the shortest path to local maximum and default option
+farthest maximum/divide means the longest path. In hydrological sense, nearest
+mode means the shortest path which a particle of water must run from divide to
+reach particular cell, while farthest mode means the possible longest path.
 <h2>OPTIONS</h2>
 <dl>
@@ -16,19 +44,18 @@
 nearest local maximum/divide. With the default option distance/elevation is
 calculated to the farthest possible maximum/divide.</dd>
 <dt><b>stream_rast</b></dt>
 <dd>Stream network: name of input stream map on which ordering will be performed,
-produced by r.watershed or r.stream.extract. Because streams network produced by
-r.watershed and r.stream.extract may slighty differ in detail it is required to
+produced by <em>r.watershed</em> or <em>r.stream.extract</em>. Because streams network produced by
+<em>r.watershed</em> and <em>r.stream.extract</em> may slightly differ in detail it is required to
 use both stream and direction map produced by the same module. Stream background
 shall have NULL value or zero value. Background values of NULL are by default
-produced by r.watershed and r.stream.extract. If not 0 or NULL use <a
-href="r.mapcalc.html">r.mapcalc</a> to set background values to NULL.</dd>
+produced by <em>r.watershed</em> and <em>r.stream.extract</em>. If not 0 or NULL use <em><a
+href="r.mapcalc.html">r.mapcalc</a></em> to set background values to NULL.</dd>
 <dt><b>direction</b></dt>
-<dd>Flow direction: name of input direction map produced by r.watershed or
-r.stream.extract. If r.stream.extract output map is used, it only has non-NULL
+<dd>Flow direction: name of input direction map produced by <em>r.watershed</em> or
+<em>r.stream.extract</em>. If r.stream.extract output map is used, it only has non-NULL
 values in places where streams occur. NULL (nodata) cells are ignored, zero and
 negative values are valid direction data if they vary from -8 to 8 (CCW from
 East in steps of 45 degrees). Direction map shall be of type CELL values. Region
@@ -58,57 +85,29 @@
 watercoures. The map is of FCELL type.</dd>
 </dl>
-<h2>DESCRIPTION</h2>
-<p>
-Module r.stream.distance may calculate distance using two methods: downstream
-and upstream.
-<p>
-The default is downstream method when it calculates distance to streams and
-outlets and relative elevation to streams and outlets. The distance and
-elevation is calculated along watercourses. In outlets mode it can also
-calculate parameters for subbasins.
-<p>
-In streams mode (default) it calculates that parameters downstream to streams
-which are added as stream mask. In outlets mode there are some additional
-possibilities. If subbasin is off it calculate parameters only for last point of
-last (downstream) CELL. In subbasin mode it calculates parameters for every
-subbasin separately. Subbasin mode acts similar to subbasin mask. Streams file
-prepared to create basins and subbasins with r.stream.basins can be used to
-calculate distance and elevation parameters.
-<p>
-With upstream method it calculates distance to the local maximum or divide.
-Opposite to downstream method, where every cell has one and only one downstream
-cell in upstream method every cell has usually more than one upstream cell. So
-it is impossible to determine interchangeable path from any cell. The upstream
-method offers two alternative modes switched with -n flag: nearest local
-maximum/divide:  means the shortest path to local maximum and default option
-farthest maximum/divide means the longest path. In hydrological sense, nearest
-mode means the shortest path which a particle of water must run from divide to
-reach particular cell, while farthest mode means the possible longest path.
 <h2>NOTES</h2>
 <p>
 If there are more than one point or one stream network and some separate points
 or separate streams networks are in catchment area defined by others it will
-results as in subbasin mode. In stream mode subbasin options is ommited. Input
-maps must be in CELL format (default output of r.watershed, r.stream.order and
-r.stream.extract).
+results as in subbasin mode. In stream mode subbasin options is omited. Input
+maps must be in CELL format (default output of <em>r.watershed</em>, <em>r.stream.order</em> and
+<em>r.stream.extract</em>).
 The distance are calculated in meters both for planimeters and
 Latitude-Longitude projections. The distance is calculated for flat areas not
 corrected by topography. Distance correction by topography may be done with
-following r.mapcalc formula:
+following <em>r.mapcalc</em> formula:
 <p>
 <code>echo 'dist_corrected = sqrt(distance^2 + elevation^2)' | r.mapcalc</code>
 <p>
 The module can work only if direction map, streams map and region have the same settings.
 It is also required that streams map and direction map come from the same source.
 For lots of reason this limitation probably cannot be omitted. This means that if
-stream_rast map comes from r.stream.extract also direction map from r.stream.extract
+stream_rast map comes from r.stream.extract also direction map from <em>r.stream.extract</em>
 must be used. If stream network was generated with MFD method also MFD direction
 map must be used.
 <p>
-Probably one of the most imortant features of r.stream.distance is the ability to
-calculate distance not only for streams generated with r.stream.extract, but also
+Probably one of the most important features of <em>r.stream.distance</em> is the ability to
+calculate distance not only for streams generated with <em>r.stream.extract</em>, but also
 to any CELL map with resolution corresponding to direction map. It can be a lake,
 swamp, depression and lake boundaries even divided into smaller fragments each
 with its own category.
@@ -131,7 +130,7 @@
 <a href="r.stream.order.html">r.stream.order</a>,
 <a href="r.stream.basins.html">r.stream.basins</a>,
 <a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r.reclass.html">r.reclass</a>,
+<a href="r.reclass.html">r.reclass</a>
 </em>
 <h2>AUTHOR</h2>
