[GRASS-SVN] r59450 - grass-addons/grass7/raster/r.stream.slope
Thu Mar 27 10:44:16 PDT 2014
Author: wenzeslaus
Date: 2014-03-27 10:44:15 -0700 (Thu, 27 Mar 2014)
New Revision: 59450
   grass-addons/grass7/raster/r.stream.slope/r.stream.slope.html
r.stream.slope: html cleanup (fix typo in r59446)
Modified: grass-addons/grass7/raster/r.stream.slope/r.stream.slope.html
--- grass-addons/grass7/raster/r.stream.slope/r.stream.slope.html	2014-03-27 17:34:17 UTC (rev 59449)
+++ grass-addons/grass7/raster/r.stream.slope/r.stream.slope.html	2014-03-27 17:44:15 UTC (rev 59450)
@@ -6,7 +6,7 @@
 <h2>OPTIONS</h2>
 <dl>
-<dt><em>direction</b></em>
+<dt><em>direction</em></dt>
 <dd>Flow direction: name of input direction map produced by r.watershed or
 r.stream.extract. If r.stream.extract output map is used, it only has non-NULL
 values in places where streams occur. NULL (nodata) cells are ignored, zero and
@@ -51,7 +51,7 @@
 g.region -p -a rast=elevation align=elevation
 r.watershed elevation=elevation threshold=10000 drainage=dirs stream=streams
 r.stream.slope dir=dirs elevation=elevation difference=downstream_elev_difference \
-gradient=downstream_gradient maxcurv=downstream_maxcurv mincurv=downstream_mincurv
+  gradient=downstream_gradient maxcurv=downstream_maxcurv mincurv=downstream_mincurv
 </pre></div>
 <h2>SEE ALSO</h2>
