[GRASS-SVN] r60038 - grass/branches/releasebranch_6_4/raster/r.covar
Fri May 2 06:50:51 PDT 2014
Author: neteler
Date: 2014-05-02 06:50:51 -0700 (Fri, 02 May 2014)
New Revision: 60038
   grass/branches/releasebranch_6_4/raster/r.covar/description.html
r.covar manual: fix m.eigensystem reference
Modified: grass/branches/releasebranch_6_4/raster/r.covar/description.html
--- grass/branches/releasebranch_6_4/raster/r.covar/description.html	2014-05-02 12:47:32 UTC (rev 60037)
+++ grass/branches/releasebranch_6_4/raster/r.covar/description.html	2014-05-02 13:50:51 UTC (rev 60038)
@@ -1,16 +1,13 @@
 <h2>DESCRIPTION</h2>
 <em>r.covar</em> outputs a covariance/correlation matrix for user-specified
 raster map layer(s).  The output can be printed, or saved by redirecting
 output into a file.
 <p>
 The output is an N x N symmetric covariance (correlation) matrix,
 where N is the number of raster map layers specified on the command line.
 <h2>NOTES</h2>
 This module can be used as the first step of a principle components
@@ -20,11 +17,10 @@
 N real eigen values and N eigen vectors (each composed of N real numbers).
 <p>
+The module <em><a href="http://grasswiki.osgeo.org/wiki/AddOns/GRASS_6#m.eigensystem">m.eigensystem</a></em>
+in <a href="http://grass.osgeo.org/download/addons/">GRASS GIS Addons</a>
+can be compiled and used to generate the eigen values and vectors.
-The module <em><a href="m.eigensystem.html">m.eigensystem</a></em> in
-src.contrib can be compiled and used to generate the eigen values and
-vectors.
 <h2>EXAMPLE</h2>
 For example,
