[GRASS-SVN] r60100 - grass/trunk/raster3d/r3.stats
Mon May 5 01:50:41 PDT 2014
Author: hamish
Date: 2014-05-05 01:50:41 -0700 (Mon, 05 May 2014)
New Revision: 60100
Added:
   grass/trunk/raster3d/r3.stats/local_proto.h
   grass/trunk/raster3d/r3.stats/support.c
   grass/trunk/raster3d/r3.stats/main.c
split up into bite sized chunks
Property changes on: grass/trunk/raster3d/r3.stats
___________________________________________________________________
Modified: svn:ignore
   - OBJ.*
   + OBJ.*
*.tmp.html
Added: grass/trunk/raster3d/r3.stats/local_proto.h
--- grass/trunk/raster3d/r3.stats/local_proto.h	                        (rev 0)
+++ grass/trunk/raster3d/r3.stats/local_proto.h	2014-05-05 08:50:41 UTC (rev 60100)
@@ -0,0 +1,49 @@
+#include <grass/raster3d.h>
+#define COMPARE_PRECISION 0.000000001
+/* statistic table row struct */
+typedef struct
+    double min, max, vol, perc;
+    int num, count;
+} stat_row;
+/* the statistic table struct */
+typedef struct
+    stat_row **table;
+    stat_row *null;
+    int sum_count, nsteps, equal;
+    double sum_vol, sum_perc;
+} stat_table;
+/* the equal value struct */
+typedef struct
+    double val;			/* the equal value */
+    int count;			/* the appearance count */
+} equal_val;
+/* an array of groups with equal values */
+typedef struct
+    equal_val **values;
+    int count;
+} equal_val_array;
+/* prototypes */
+equal_val_array *alloc_equal_val_array(int count);
+void free_equal_val_array(equal_val_array *vals);
+equal_val_array *add_equal_val_to_array(equal_val_array *array, double val);
+int check_equal_value(equal_val_array * array, double val);
+stat_table *create_stat_table(int nsteps, equal_val_array *values,
+ 			      double min, double max);
+void free_stat_table(stat_table *stats);
+void print_stat_table(stat_table *stats);
+void update_stat_table(stat_table *stats, RASTER3D_Region *region);
+void heapsort_eqvals(equal_val_array *data, int n);
+void downheap_eqvals(equal_val_array *data, int n, int k);
+void check_range_value(stat_table *stats, double value);
+void tree_search_range(stat_table *stats, int left, int right,
+		       double value);
Property changes on: grass/trunk/raster3d/r3.stats/local_proto.h
Added: svn:mime-type
   + text/x-chdr
Added: svn:eol-style
   + native
Modified: grass/trunk/raster3d/r3.stats/main.c
--- grass/trunk/raster3d/r3.stats/main.c	2014-05-05 08:36:44 UTC (rev 60099)
+++ grass/trunk/raster3d/r3.stats/main.c	2014-05-05 08:50:41 UTC (rev 60100)
@@ -18,529 +18,9 @@
 #include <grass/gis.h>
 #include <grass/glocale.h>
+#include "local_proto.h"
-#define COMPARE_PRECISION 0.000000001
-/*statistic table row struct */
-typedef struct
-    double min, max, vol, perc;
-    int num, count;
-} stat_row;
-/*the statistic table struct */
-typedef struct
-    stat_row **table;
-    stat_row *null;
-    int sum_count, nsteps, equal;
-    double sum_vol, sum_perc;
-} stat_table;
-/*the equal value struct */
-typedef struct
-    double val;			/* the equal value */
-    int count;			/* the appearance count */
-} equal_val;
-/*an array of groups with equal values */
-typedef struct
-    equal_val **values;
-    int count;
-} equal_val_array;
-/*prototypes */
-static equal_val_array *alloc_equal_val_array(int count);
-static void free_equal_val_array(equal_val_array * vals);
-static equal_val_array *add_equal_val_to_array(equal_val_array * array, double val);
-static int check_equal_value(equal_val_array * array, double val);
-static stat_table *create_stat_table(int nsteps, equal_val_array * values,
-			      double min, double max);
-static void free_stat_table(stat_table * stats);
-static void print_stat_table(stat_table * stats);
-static void update_stat_table(stat_table * stats, RASTER3D_Region * region);
-static void heapsort_eqvals(equal_val_array * data, int n);
-static void downheap_eqvals(equal_val_array * data, int n, int k);
-static void check_range_value(stat_table * stats, double value);
-static void tree_search_range(stat_table * stats, int left, int right,
-			      double value);
-/* ***** allocate equal_val_array structure ********************* */
-equal_val_array *alloc_equal_val_array(int count)
-    equal_val_array *p;
-    int i;
-    p = (equal_val_array *) G_calloc(1, sizeof(equal_val_array));
-    p->count = count;
-    p->values = (equal_val **) G_calloc(p->count, sizeof(equal_val *));
-    for (i = 0; i < p->count; i++)
-	p->values[i] = (equal_val *) G_calloc(1, sizeof(equal_val));
-    return p;
-/* ***** add an equal_val to the equal_val_array structure ******* */
-equal_val_array *add_equal_val_to_array(equal_val_array * array, double val)
-    equal_val_array *p = array;
-    int count;
-    if (p == NULL) {
-	p = alloc_equal_val_array(1);
-	p->values[0]->val = val;
-	p->values[0]->count = 1;
-	G_debug(5, "Create new equal_array with value %g\n", val);
-    else {
-	/*increase the count */
-	count = array->count;
-	count++;
-	/*new memory */
-	p->values =
-	    (equal_val **) G_realloc(p->values, count * sizeof(equal_val *));
-	p->values[count - 1] = (equal_val *) G_calloc(1, sizeof(equal_val));
-	/*set the new value */
-	p->values[count - 1]->val = val;
-	p->values[count - 1]->count = 1;
-	/*set the new counter */
-	p->count = count;
-	G_debug(5, "Add new value %g at position %i\n", val, p->count);
-    return p;
-/* ***** check if a value exists in the equal_val_array ********* */
-int check_equal_value(equal_val_array * array, double val)
-    int i;
-    /*search if the new value exists and increase the counter */
-    if (array != NULL)
-	for (i = 0; i < array->count; i++) {
-	    if (array->values[i]->val == val) {
-		array->values[i]->count++;
-		G_debug(5, "found value %g with count %i at pos %i\n", val,
-			array->values[i]->count, i);
-		return 1;
-    /*if it does not exists, add it to the array */
-    add_equal_val_to_array(array, val);
-    /*return 1 if found, 0 otherwise */
-    return 0;
-/* ***** Release the memory of a equal_val_array structure ****** */
-void free_equal_val_array(equal_val_array * uvals)
-    int i;
-    for (i = 0; i < uvals->count; i++) {
-	G_free(uvals->values[i]);
-    G_free(uvals->values);
-    G_free(uvals);
-    uvals = NULL;
-    return;
-/* **** Create the structure which manages the statistical ******* */
-/* **** values for a value range or equal values **************** */
-stat_table *create_stat_table(int nsteps, equal_val_array * eqvals,
-    stat_table *p;
-    int i;
-    double step;
-    /* Memory */
-    p = (stat_table *) G_calloc(1, sizeof(stat_table));
-    p->null = (stat_row *) G_calloc(nsteps, sizeof(stat_row));
-    p->table = (stat_row **) G_calloc(nsteps, sizeof(stat_row *));
-    for (i = 0; i < nsteps; i++)
-	p->table[i] = (stat_row *) G_calloc(1, sizeof(stat_row));
-    /* Some value initializing */
-    p->null->min = 0;
-    p->null->max = 0;
-    p->null->vol = 0;
-    p->null->perc = 0;
-    p->null->count = 0;
-    p->null->num = nsteps + 1;
-    p->nsteps = nsteps;
-    p->sum_count = 0;
-    p->sum_vol = 0;
-    p->sum_perc = 0;
-    p->equal = 0;
-    /*if no equal values are provided, calculate the range and the length of each step */
-    if (!eqvals) {
-	/*calculate the steplength */
-	step = (max - min) / (nsteps);
-	p->equal = 0;
-	p->table[0]->min = min;
-	p->table[0]->max = min + step;
-	p->table[0]->num = 1;
-	p->table[0]->count = 0;
-	p->table[0]->vol = 0;
-	p->table[0]->perc = 0;
-	G_debug(3, "Step %i range min %.11lf max %.11lf\n", p->table[0]->num,
-		p->table[0]->min, p->table[0]->max);
-	for (i = 1; i < nsteps; i++) {
-	    p->table[i]->min = p->table[i - 1]->max;
-	    p->table[i]->max = p->table[i - 1]->max + step;
-	    p->table[i]->num = i + 1;
-	    p->table[i]->count = 0;
-	    p->table[i]->vol = 0;
-	    p->table[i]->perc = 0;
-	    G_debug(5, "Step %i range min %.11lf max %.11lf\n",
-		    p->table[i]->num, p->table[i]->min, p->table[i]->max);
-	/* the last value must be a bit larger */
-	p->table[nsteps - 1]->max += COMPARE_PRECISION;
-    else {			/* Create equal value statistic */
-	p->equal = 1;
-	for (i = 0; i < eqvals->count; i++) {
-	    p->table[i]->min = eqvals->values[i]->val;	/* equal values have no range, set min and max to the same value */
-	    p->table[i]->max = eqvals->values[i]->val;
-	    p->table[i]->count = eqvals->values[i]->count;	/* the appearance count for each equal value */
-	    G_debug(5, "Unique value %i = %g count %i\n", p->table[i]->num,
-		    p->table[i]->min, p->table[i]->count);
-    return p;
-/* ***** Release the memory of a stat_table structure ************ */
-void free_stat_table(stat_table * stats)
-    int i;
-    for (i = 0; i < stats->nsteps; i++) {
-	G_free(stats->table[i]);
-    G_free(stats->table);
-    G_free(stats->null);
-    G_free(stats);
-    stats = NULL;
-    return;
-/* **** Compute the volume, percentage and sums ****************** */
-void update_stat_table(stat_table * stats, RASTER3D_Region * region)
-    int i;
-    double vol = region->ns_res * region->ew_res * region->tb_res;
-    int cellnum = region->rows * region->cols * region->depths;
-    /*Calculate volume and percentage for each range or equal value and the sum stats */
-	stats->table[i]->vol = stats->table[i]->count * vol;
-	stats->table[i]->perc =
-	    (double)(100.0 * (double)stats->table[i]->count /
-		     (double)cellnum);
-	stats->sum_count += stats->table[i]->count;
-	stats->sum_vol += stats->table[i]->vol;
-	stats->sum_perc += stats->table[i]->perc;
-    /*calculate the null value stats */
-    stats->null->vol = stats->null->count * vol;
-    stats->null->perc =
-	(double)(100.0 * (double)stats->null->count / (double)cellnum);
-    return;
-void print_stat_table(stat_table * stats)
-    int i;
-    if (stats->equal) {
-	/*       1234567   012345678901234567   0123456789012   0123456   0123456789 */
-	fprintf(stdout,
-		"  num   |        value       |     volume    |   perc  | cell count\n");
-	    fprintf(stdout, "%7i   %18.6lf   %13.3lf   %7.5lf   %10i\n",
-		    stats->table[i]->num, stats->table[i]->min,
-		    stats->table[i]->vol, stats->table[i]->perc,
-		    stats->table[i]->count);
-	fprintf(stdout,
-		"%7i                    *   %13.3lf   %7.5lf   %10i\n",
-		stats->null->num, stats->null->vol, stats->null->perc,
-		stats->null->count);
-	fprintf(stdout, "\nNumber of groups with equal values: %i",
-		stats->nsteps);
-    else {
-	/*       1234567   012345678901234567   012345678901234567   0123456789012   0123456   0123456789 */
-	fprintf(stdout,
-		"  num   | minimum <= value   | value < maximum    |     volume    |   perc  | cell count\n");
-	    fprintf(stdout,
-		    "%7i   %18.9lf   %18.9lf   %13.3lf   %7.5lf   %10i\n",
-		    stats->table[i]->max, stats->table[i]->vol,
-		    stats->table[i]->perc, stats->table[i]->count);
-	fprintf(stdout,
-		"%7i                    *                    *   %13.3lf   %7.5lf   %10i\n",
-    fprintf(stdout,
-	    "\nSum of non Null cells: \n\tVolume = %13.3lf \n\tPercentage = %7.3lf  \n\tCell count = %i\n",
-	    stats->sum_vol, stats->sum_perc, stats->sum_count);
-    fprintf(stdout,
-	    "\nSum of all cells: \n\tVolume = %13.3lf \n\tPercentage = %7.3lf  \n\tCell count = %i\n",
-	    stats->sum_vol + stats->null->vol,
-	    stats->sum_perc + stats->null->perc,
-	    stats->sum_count + stats->null->count);
-    return;
-/*  Make an entry in the statistic table based on range value check */
-void check_range_value(stat_table * stats, double value)
-    /* this is very expensive for large range arrays! */
-     * int i;
-     * for (i = 0; i < stats->nsteps; i++) {
-     * if (value >= stats->table[i]->min && value < stats->table[i]->max) {
-     * stats->table[i]->count++;
-    /* the much faster tree search is used */
-    tree_search_range(stats, 0, stats->nsteps - 1, value);
-    return;
-/*  tree search method developed by Soeren Gebbert *************** */
- * This is a divide and conquer tree search algorithm
- * The algorithm counts how many values are located in each range.
- * It divides therefor the range array in smaller pices.
- * e.g:
- *    0     1     2     3     4     5     6     7     8
- * [[0,1],[1,2],[2,3],[3,4],[4,5],[5,6],[6,7],[7,8],[8,9]]
- * [[0,1],[1,2],[2,3],[3,4]]   [[4,5],[5,6],[6,7],[7,8],[8,9]]
- * [[0,1],[1,2]]   [[2,3],[3,4]]   [[4,5],[5,6]]   [[6,7],[7,8],[8,9]]
- * [[0,1]]  [[1,2]]  [[2,3]]  [[3,4]]  [[4,5]]  [[5,6]]  [[6,7]]  [[7,8],[8,9]]
- *                                                               [[7,8]]  [[8,9]]
- * Searching the value 5.5 will result in the follwoing steps:
- * value 5.5 in range of
- * 1.) left array index = 0 - right array index = 8 -> range [0 - 9]
- * 2.) left array index = 4 - right array index = 8 -> range [4 - 9]
- * 3.) left array index = 4 - right array index = 5 -> range [4 - 6]
- * 4.) the value is located in range array 5 with a range of [5 - 6]
- * 5.) now increase the value range counter of range array with index 5
-void tree_search_range(stat_table * stats, int left, int right, double value)
-    int size = right - left;
-    G_debug(5,
-	    "Search value %g in array size %i left border index %i right border index %i\n",
-	    value, size, left, right);
-    /*if left and right are equal */
-    if (size == 0) {
-	stats->table[left]->count++;
-	return;
-    else if (size == 1) {	/* if the size is one, check directly */
-	if (value >= stats->table[left]->min &&
-	    value < stats->table[left]->max) {
-	else if (value >= stats->table[right]->min &&
-		 value < stats->table[right]->max) {
-	    stats->table[right]->count++;
-	return;
-    else {
-	if ((size % 2 == 0)) {	/*even */
-	    /*left side */
-	    right = left + (size) / 2;
-		tree_search_range(stats, left, right, value);
-		return;
-	    /*right side */
-	    left += (size) / 2;
-		return;
-	else {			/*odd */
-	    /*left side */
-	    right = left + (size - 1) / 2;
-		return;
-	    /*right side */
-	    left += (size - 1) / 2;
-	    right = left + (size - 1) / 2 + 1;	/*the right array is one col larger */
-		return;
-    return;
-/* ****** heapsort for equal value arrays of size n ************** */
-/* ** Code based on heapsort from Sebastian Cyris **************** */
-void heapsort_eqvals(equal_val_array * e, int n)
-    int k;
-    double t;
-    int count = 0;
-    --n;
-    for (k = n / 2; k >= 0; k--)
-	downheap_eqvals(e, n, k);
-    while (n > 0) {
-	t = e->values[0]->val;
-	count = e->values[0]->count;
-	e->values[0]->val = e->values[n]->val;
-	e->values[0]->count = e->values[n]->count;
-	e->values[n]->val = t;
-	e->values[n]->count = count;
-	downheap_eqvals(e, --n, 0);
-    return;
-void downheap_eqvals(equal_val_array * e, int n, int k)
-    int j;
-    double v;
-    int count;
-    v = e->values[k]->val;
-    count = e->values[k]->count;
-    while (k <= n / 2) {
-	j = k + k;
-	if (j < n && e->values[j]->val < e->values[j + 1]->val)
-	    j++;
-	if (v >= e->values[j]->val)
-	    break;
-	e->values[k]->val = e->values[j]->val;
-	e->values[k]->count = e->values[j]->count;
-	k = j;
-    e->values[k]->val = v;
-    e->values[k]->count = count;
-    return;
-/* ** Main function ********************************************** */
 int main(int argc, char *argv[])
Added: grass/trunk/raster3d/r3.stats/support.c
--- grass/trunk/raster3d/r3.stats/support.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.stats/support.c	2014-05-05 08:50:41 UTC (rev 60100)
@@ -0,0 +1,485 @@
+ *   r3.stats support functions
+ *   Copyright (C) 2004-2014 by the GRASS Development Team
+ *   Author(s): Soeren Gebbert
+ *      This program is free software under the GNU General Public
+ *      License (>=v2). Read the file COPYING that comes with GRASS
+ *      for details.
+#include <grass/gis.h>
+/* ***** allocate equal_val_array structure ********************* */
+    equal_val_array *p;
+    int i;
+    p = (equal_val_array *) G_calloc(1, sizeof(equal_val_array));
+    p->count = count;
+    p->values = (equal_val **) G_calloc(p->count, sizeof(equal_val *));
+    for (i = 0; i < p->count; i++)
+	p->values[i] = (equal_val *) G_calloc(1, sizeof(equal_val));
+    return p;
+/* ***** add an equal_val to the equal_val_array structure ******* */
+    equal_val_array *p = array;
+    int count;
+    if (p == NULL) {
+	p = alloc_equal_val_array(1);
+	p->values[0]->val = val;
+	p->values[0]->count = 1;
+	G_debug(5, "Create new equal_array with value %g\n", val);
+    else {
+	/*increase the count */
+	count = array->count;
+	count++;
+	/*new memory */
+	p->values =
+	    (equal_val **) G_realloc(p->values, count * sizeof(equal_val *));
+	p->values[count - 1] = (equal_val *) G_calloc(1, sizeof(equal_val));
+	/*set the new value */
+	p->values[count - 1]->val = val;
+	p->values[count - 1]->count = 1;
+	/*set the new counter */
+	p->count = count;
+	G_debug(5, "Add new value %g at position %i\n", val, p->count);
+    return p;
+/* ***** check if a value exists in the equal_val_array ********* */
+int check_equal_value(equal_val_array *array, double val)
+    int i;
+    /*search if the new value exists and increase the counter */
+    if (array != NULL)
+	for (i = 0; i < array->count; i++) {
+	    if (array->values[i]->val == val) {
+		array->values[i]->count++;
+		G_debug(5, "found value %g with count %i at pos %i\n", val,
+			array->values[i]->count, i);
+		return 1;
+    /*if it does not exists, add it to the array */
+    add_equal_val_to_array(array, val);
+    /*return 1 if found, 0 otherwise */
+    return 0;
+/* ***** Release the memory of a equal_val_array structure ****** */
+void free_equal_val_array(equal_val_array *uvals)
+    int i;
+    for (i = 0; i < uvals->count; i++) {
+	G_free(uvals->values[i]);
+    G_free(uvals->values);
+    G_free(uvals);
+    uvals = NULL;
+    return;
+/* **** Create the structure which manages the statistical ******* */
+/* **** values for a value range or equal values **************** */
+stat_table *create_stat_table(int nsteps, equal_val_array *eqvals,
+    stat_table *p;
+    int i;
+    double step;
+    /* Memory */
+    p = (stat_table *) G_calloc(1, sizeof(stat_table));
+    p->null = (stat_row *) G_calloc(nsteps, sizeof(stat_row));
+    p->table = (stat_row **) G_calloc(nsteps, sizeof(stat_row *));
+    for (i = 0; i < nsteps; i++)
+	p->table[i] = (stat_row *) G_calloc(1, sizeof(stat_row));
+    /* Some value initializing */
+    p->null->min = 0;
+    p->null->max = 0;
+    p->null->vol = 0;
+    p->null->perc = 0;
+    p->null->count = 0;
+    p->null->num = nsteps + 1;
+    p->nsteps = nsteps;
+    p->sum_count = 0;
+    p->sum_vol = 0;
+    p->sum_perc = 0;
+    p->equal = 0;
+    /*if no equal values are provided, calculate the range and the length of each step */
+    if (!eqvals) {
+	/*calculate the steplength */
+	step = (max - min) / (nsteps);
+	p->equal = 0;
+	p->table[0]->min = min;
+	p->table[0]->max = min + step;
+	p->table[0]->num = 1;
+	p->table[0]->count = 0;
+	p->table[0]->vol = 0;
+	p->table[0]->perc = 0;
+	G_debug(3, "Step %i range min %.11lf max %.11lf\n", p->table[0]->num,
+		p->table[0]->min, p->table[0]->max);
+	for (i = 1; i < nsteps; i++) {
+	    p->table[i]->min = p->table[i - 1]->max;
+	    p->table[i]->max = p->table[i - 1]->max + step;
+	    p->table[i]->num = i + 1;
+	    p->table[i]->count = 0;
+	    p->table[i]->vol = 0;
+	    p->table[i]->perc = 0;
+	    G_debug(5, "Step %i range min %.11lf max %.11lf\n",
+		    p->table[i]->num, p->table[i]->min, p->table[i]->max);
+	/* the last value must be a bit larger */
+	p->table[nsteps - 1]->max += COMPARE_PRECISION;
+    else {			/* Create equal value statistic */
+	p->equal = 1;
+	for (i = 0; i < eqvals->count; i++) {
+	    p->table[i]->min = eqvals->values[i]->val;	/* equal values have no range, set min and max to the same value */
+	    p->table[i]->max = eqvals->values[i]->val;
+	    p->table[i]->count = eqvals->values[i]->count;	/* the appearance count for each equal value */
+	    G_debug(5, "Unique value %i = %g count %i\n", p->table[i]->num,
+		    p->table[i]->min, p->table[i]->count);
+    return p;
+/* ***** Release the memory of a stat_table structure ************ */
+    int i;
+    for (i = 0; i < stats->nsteps; i++) {
+	G_free(stats->table[i]);
+    G_free(stats->table);
+    G_free(stats->null);
+    G_free(stats);
+    stats = NULL;
+    return;
+/* **** Compute the volume, percentage and sums ****************** */
+    int i;
+    double vol = region->ns_res * region->ew_res * region->tb_res;
+    int cellnum = region->rows * region->cols * region->depths;
+    /*Calculate volume and percentage for each range or equal value and the sum stats */
+	stats->table[i]->vol = stats->table[i]->count * vol;
+	stats->table[i]->perc =
+	    (double)(100.0 * (double)stats->table[i]->count /
+		     (double)cellnum);
+	stats->sum_count += stats->table[i]->count;
+	stats->sum_vol += stats->table[i]->vol;
+	stats->sum_perc += stats->table[i]->perc;
+    /*calculate the null value stats */
+    stats->null->vol = stats->null->count * vol;
+    stats->null->perc =
+	(double)(100.0 * (double)stats->null->count / (double)cellnum);
+    return;
+    int i;
+    if (stats->equal) {
+	/*       1234567   012345678901234567   0123456789012   0123456   0123456789 */
+	fprintf(stdout,
+		"  num   |        value       |     volume    |   perc  | cell count\n");
+	    fprintf(stdout, "%7i   %18.6lf   %13.3lf   %7.5lf   %10i\n",
+		    stats->table[i]->num, stats->table[i]->min,
+		    stats->table[i]->vol, stats->table[i]->perc,
+		    stats->table[i]->count);
+	fprintf(stdout,
+		"%7i                    *   %13.3lf   %7.5lf   %10i\n",
+		stats->null->num, stats->null->vol, stats->null->perc,
+	fprintf(stdout, "\nNumber of groups with equal values: %i",
+		stats->nsteps);
+    else {
+	/*       1234567   012345678901234567   012345678901234567   0123456789012   0123456   0123456789 */
+	fprintf(stdout,
+		"  num   | minimum <= value   | value < maximum    |     volume    |   perc  | cell count\n");
+	    fprintf(stdout,
+		    "%7i   %18.9lf   %18.9lf   %13.3lf   %7.5lf   %10i\n",
+		    stats->table[i]->max, stats->table[i]->vol,
+		    stats->table[i]->perc, stats->table[i]->count);
+	fprintf(stdout,
+		"%7i                    *                    *   %13.3lf   %7.5lf   %10i\n",
+    fprintf(stdout,
+	    "\nSum of non Null cells: \n\tVolume = %13.3lf \n\tPercentage = %7.3lf  \n\tCell count = %i\n",
+	    stats->sum_vol, stats->sum_perc, stats->sum_count);
+    fprintf(stdout,
+	    "\nSum of all cells: \n\tVolume = %13.3lf \n\tPercentage = %7.3lf  \n\tCell count = %i\n",
+	    stats->sum_vol + stats->null->vol,
+	    stats->sum_perc + stats->null->perc,
+	    stats->sum_count + stats->null->count);
+    return;
+/*  Make an entry in the statistic table based on range value check */
+    /* this is very expensive for large range arrays! */
+     * int i;
+     * for (i = 0; i < stats->nsteps; i++) {
+     * if (value >= stats->table[i]->min && value < stats->table[i]->max) {
+     * stats->table[i]->count++;
+    /* the much faster tree search is used */
+    tree_search_range(stats, 0, stats->nsteps - 1, value);
+    return;
+/*  tree search method developed by Soeren Gebbert *************** */
+ * This is a divide and conquer tree search algorithm
+ * The algorithm counts how many values are located in each range.
+ * It divides therefor the range array in smaller pices.
+ * e.g:
+ *    0     1     2     3     4     5     6     7     8
+ * [[0,1],[1,2],[2,3],[3,4],[4,5],[5,6],[6,7],[7,8],[8,9]]
+ * [[0,1],[1,2],[2,3],[3,4]]   [[4,5],[5,6],[6,7],[7,8],[8,9]]
+ * [[0,1],[1,2]]   [[2,3],[3,4]]   [[4,5],[5,6]]   [[6,7],[7,8],[8,9]]
+ * [[0,1]]  [[1,2]]  [[2,3]]  [[3,4]]  [[4,5]]  [[5,6]]  [[6,7]]  [[7,8],[8,9]]
+ *                                                               [[7,8]]  [[8,9]]
+ * Searching the value 5.5 will result in the follwoing steps:
+ * value 5.5 in range of
+ * 1.) left array index = 0 - right array index = 8 -> range [0 - 9]
+ * 2.) left array index = 4 - right array index = 8 -> range [4 - 9]
+ * 3.) left array index = 4 - right array index = 5 -> range [4 - 6]
+ * 4.) the value is located in range array 5 with a range of [5 - 6]
+ * 5.) now increase the value range counter of range array with index 5
+void tree_search_range(stat_table *stats, int left, int right, double value)
+    int size = right - left;
+    G_debug(5,
+	    "Search value %g in array size %i left border index %i right border index %i\n",
+	    value, size, left, right);
+    /*if left and right are equal */
+    if (size == 0) {
+	stats->table[left]->count++;
+	return;
+    else if (size == 1) {	/* if the size is one, check directly */
+	if (value >= stats->table[left]->min &&
+	    value < stats->table[left]->max) {
+	else if (value >= stats->table[right]->min &&
+		 value < stats->table[right]->max) {
+	    stats->table[right]->count++;
+	return;
+    else {
+	if ((size % 2 == 0)) {	/*even */
+	    /*left side */
+	    right = left + (size) / 2;
+		tree_search_range(stats, left, right, value);
+		return;
+	    /*right side */
+	    left += (size) / 2;
+		return;
+	else {			/*odd */
+	    /*left side */
+	    right = left + (size - 1) / 2;
+		return;
+	    /*right side */
+	    left += (size - 1) / 2;
+	    right = left + (size - 1) / 2 + 1;	/*the right array is one col larger */
+		return;
+    return;
+/* ****** heapsort for equal value arrays of size n ************** */
+/* ** Code based on heapsort from Sebastian Cyris **************** */
+void heapsort_eqvals(equal_val_array *e, int n)
+    int k;
+    double t;
+    int count = 0;
+    --n;
+    for (k = n / 2; k >= 0; k--)
+	downheap_eqvals(e, n, k);
+    while (n > 0) {
+	t = e->values[0]->val;
+	count = e->values[0]->count;
+	e->values[0]->val = e->values[n]->val;
+	e->values[0]->count = e->values[n]->count;
+	e->values[n]->val = t;
+	e->values[n]->count = count;
+	downheap_eqvals(e, --n, 0);
+    return;
+void downheap_eqvals(equal_val_array *e, int n, int k)
+    int j;
+    double v;
+    int count;
+    v = e->values[k]->val;
+    count = e->values[k]->count;
+    while (k <= n / 2) {
+	j = k + k;
+	if (j < n && e->values[j]->val < e->values[j + 1]->val)
+	    j++;
+	if (v >= e->values[j]->val)
+	    break;
+	e->values[k]->val = e->values[j]->val;
+	e->values[k]->count = e->values[j]->count;
+	k = j;
+    e->values[k]->val = v;
+    e->values[k]->count = count;
+    return;
Property changes on: grass/trunk/raster3d/r3.stats/support.c
   + text/x-csrc
   + native
