[GRASS-SVN] r60102 - grass/trunk/display/d.legend
Mon May 5 02:43:33 PDT 2014
Author: hamish
Date: 2014-05-05 02:43:33 -0700 (Mon, 05 May 2014)
New Revision: 60102
   grass/trunk/display/d.legend/Makefile
   grass/trunk/display/d.legend/d.legend.html
   grass/trunk/display/d.legend/get_stats.c
   grass/trunk/display/d.legend/histogram.c
   grass/trunk/display/d.legend/local_proto.h
   grass/trunk/display/d.legend/main.c
add support for 3D raster map legends (#2083, thanks Vaclav)
Modified: grass/trunk/display/d.legend/Makefile
--- grass/trunk/display/d.legend/Makefile	2014-05-05 09:06:44 UTC (rev 60101)
+++ grass/trunk/display/d.legend/Makefile	2014-05-05 09:43:33 UTC (rev 60102)
@@ -2,8 +2,8 @@
 PGM = d.legend
-LIBES = $(DISPLAYLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
-DEPENDENCIES = $(DISPLAYDEP) $(RASTERDEP) $(GISDEP)
+LIBES = $(DISPLAYLIB) $(RASTERLIB) $(RASTER3DLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(DISPLAYDEP) $(RASTERDEP) $(RASTER3DDEP) $(GISDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/display/d.legend/d.legend.html
--- grass/trunk/display/d.legend/d.legend.html	2014-05-05 09:06:44 UTC (rev 60101)
+++ grass/trunk/display/d.legend/d.legend.html	2014-05-05 09:43:33 UTC (rev 60102)
@@ -1,7 +1,7 @@
 <h2>DESCRIPTION</h2>
-<em>d.legend</em> displays a legend for a user-specified
-raster map layer in the active frame on the graphics monitor.
+<em>d.legend</em> displays a legend for a user-specified raster map or
+3D raster map layer in the active frame on the graphics monitor.
 <p>
 The legend's default size is based on the dimensions of the
 active frame, specifically its height.  <em>d.legend</em> will only
@@ -65,10 +65,11 @@
 output with a meaningful number of significant digits. For very small values,
 numbers will be expressed in scientific notation, e.g. "1.7e-9".
 <p>
-Note that old scripts which relied on setting <b>lines</b> greater than the
-number of categories to scale the legend may no longer produce the desired
-output, although the auto-scaling should still produce something that looks
-good in this case.
+When the <b>-d</b> flag is used to display a histogram distribution along
+side the smoothed gradient legend, note that the statistics are calculated
+on the <i>current computational region</i> settings set by <em>g.region</em>.
+The default <b>range</b> however covers the entire natural bounds of the input map.
+If the histogram appears empty, check your region settings.
 <h2>SEE ALSO</h2>
@@ -76,14 +77,15 @@
 <em>
 <a href="d.barscale.html">d.barscale</a>,
 <a href="d.colortable.html">d.colortable</a>,
-<a href="d.erase.html">d.erase</a>,
 <a href="d.font.html">d.font</a>,
 <a href="d.grid.html">d.grid</a>,
 <a href="d.rast.html">d.rast</a>,
 <a href="d.rast.leg.html">d.rast.leg</a>,
 <a href="d.text.html">d.text</a>,
 <a href="d.vect.thematic.html">d.vect.thematic</a>,
-<a href="r.reclass.html">r.reclass</a>
+<a href="r.reclass.html">r.reclass</a>,
+<a href="r.stats.html">r.stats</a>,
+<a href="r3.stats.html">r3.stats</a>
 </em>
Modified: grass/trunk/display/d.legend/get_stats.c
--- grass/trunk/display/d.legend/get_stats.c	2014-05-05 09:06:44 UTC (rev 60101)
+++ grass/trunk/display/d.legend/get_stats.c	2014-05-05 09:43:33 UTC (rev 60102)
@@ -1,6 +1,4 @@
 #include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
 #include <unistd.h>
 #include <grass/gis.h>
 #include <grass/raster.h>
@@ -8,15 +6,20 @@
 #include "local_proto.h"
-void run_stats(const char *mapname, int nsteps, const char *tempfile)
+void run_stats(const char *mapname, int nsteps, const char *tempfile,
+	       int map_type)
     char buf[32];
     const char *argv[12];
     int argc = 0;
-    argv[argc++] = "r.stats";
+    if (map_type == MAP_TYPE_RASTER2D) {
+	argv[argc++] = "r.stats";
+	argv[argc++] = "-r";
+    else
+	argv[argc++] = "r3.stats";
-    argv[argc++] = "-r";
     argv[argc++] = "-c";
     argv[argc++] = mapname;
@@ -35,7 +38,8 @@
 /* linked list of stats */
-void get_stats(const char *mapname, struct stat_list *dist_stats, int nsteps)
+void get_stats(const char *mapname, struct stat_list *dist_stats, int nsteps,
+	       int map_type)
     char buf[1024];		/* input buffer for reading stats */
     int done = FALSE;
@@ -59,7 +63,7 @@
 	    G_fatal_error("Can't read frange file");
-    run_stats(mapname, nsteps, tempfile);
+    run_stats(mapname, nsteps, tempfile, map_type);
     /* open temp file and read the stats into a linked list */
     fd = fopen(tempfile, "r");
Modified: grass/trunk/display/d.legend/histogram.c
--- grass/trunk/display/d.legend/histogram.c	2014-05-05 09:06:44 UTC (rev 60101)
+++ grass/trunk/display/d.legend/histogram.c	2014-05-05 09:43:33 UTC (rev 60102)
@@ -12,7 +12,8 @@
 void draw_histogram(const char *map_name, int x0, int y0, int width,
-		    int height, int color, int flip, int horiz)
+		    int height, int color, int flip, int horiz,
+		    int map_type)
     int i, nsteps;
     long cell_count;
@@ -30,7 +31,7 @@
     /* get the distribution statistics */
-    get_stats(map_name, &dist_stats, nsteps);
+    get_stats(map_name, &dist_stats, nsteps, map_type);
     width_mult = max_width / dist_stats.maxstat;
@@ -38,6 +39,7 @@
     D_begin();
     ptr = dist_stats.ptr;
     for (i = dist_stats.mincat; i <= dist_stats.maxcat; i++) {
 	if (!ptr)
 	    break;
@@ -84,7 +86,6 @@
 	    D_cont_rel(-dx, 0);
     D_close();
Modified: grass/trunk/display/d.legend/local_proto.h
--- grass/trunk/display/d.legend/local_proto.h	2014-05-05 09:06:44 UTC (rev 60101)
+++ grass/trunk/display/d.legend/local_proto.h	2014-05-05 09:43:33 UTC (rev 60102)
@@ -1,3 +1,10 @@
+#define MAP_TYPE_RASTER2D 1
+#define MAP_TYPE_RASTER3D 2
+/* possibles for the future:
+#define MAP_TYPE_VECTOR 3
+#define MAP_TYPE_RULES 4
 struct stat_node
     long int cat;               /* cell-file category value */
@@ -20,8 +27,8 @@
 /* histogram.c */
-void draw_histogram(const char *, int, int, int, int, int, int, int);
+void draw_histogram(const char *, int, int, int, int, int, int, int, int);
 /* get_stats.c */
-void get_stats(const char *, struct stat_list *, int);
-void run_stats(const char *, int, const char *);
+void get_stats(const char *, struct stat_list *, int, int);
+void run_stats(const char *, int, const char *, int);
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c	2014-05-05 09:06:44 UTC (rev 60101)
+++ grass/trunk/display/d.legend/main.c	2014-05-05 09:43:33 UTC (rev 60102)
@@ -29,6 +29,7 @@
 #include <math.h>
+#include <grass/raster3d.h>
 #include <grass/display.h>
 #include <grass/glocale.h>
@@ -38,6 +39,7 @@
     char buff[512];
     char *map_name;
+    int maptype;
     int black;
     int cats_num;
     int color;
@@ -57,13 +59,13 @@
     struct Categories cats;
     struct Colors colors;
     struct GModule *module;
-    struct Option *opt_input, *opt_color, *opt_lines, *opt_thin,
-		  *opt_labelnum, *opt_at, *opt_use, *opt_range,
+    struct Option *opt_rast2d, *opt_rast3d, *opt_color, *opt_lines,
+		  *opt_thin, *opt_labelnum, *opt_at, *opt_use, *opt_range,
 		  *opt_font, *opt_path, *opt_charset, *opt_fontsize;
     struct Flag *hidestr, *hidenum, *hidenodata, *smooth, *flipit, *histo;
     struct Range range;
     struct FPRange fprange;
-    CELL min_ind, max_ind, null_cell;
+    CELL min_ind, max_ind;
     DCELL dmin, dmax, val;
     CELL min_colr, max_colr;
     DCELL min_dcolr, max_dcolr;
@@ -89,12 +91,15 @@
 	_("Displays a legend for a raster map in the active frame "
 	  "of the graphics monitor.");
-    opt_input = G_define_standard_option(G_OPT_R_MAP);
-    opt_input->description = _("Name of raster map");
+    opt_rast2d = G_define_standard_option(G_OPT_R_MAP);
+    opt_rast2d->key = "rast";
+    opt_rast2d->required = NO;
+    opt_rast2d->guisection = _("Input");
-    opt_color = G_define_standard_option(G_OPT_C_FG);
-    opt_color->label = _("Text color");
-    opt_color->guisection = _("Font settings");
+    opt_rast3d = G_define_standard_option(G_OPT_R3_MAP);
+    opt_rast3d->key = "rast3d";
+    opt_rast3d->required = NO;
+    opt_rast3d->guisection = _("Input");
     opt_lines = G_define_option();
     opt_lines->key = "lines";
@@ -154,6 +159,10 @@
 	_("Use a subset of the map range for the legend (min,max)");
     opt_range->guisection = _("Subset");
+    opt_color = G_define_standard_option(G_OPT_C_FG);
+    opt_color->label = _("Text color");
+    opt_color->guisection = _("Font settings");
     opt_font = G_define_option();
     opt_font->key = "font";
     opt_font->type = TYPE_STRING;
@@ -213,15 +222,26 @@
     histo = G_define_flag();
     histo->key = 'd';
     histo->description = _("Add histogram to smoothed legend");
-    histo->guisection = _("Advanced");
+    histo->guisection = _("Gradient");
     /* Check command line */
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    /* FIXME: add GUI launching logic to G_parser() call */
+    if ((opt_rast2d->answer && opt_rast3d->answer) ||
+        !(opt_rast2d->answer || opt_rast3d->answer))
+	G_fatal_error(_("Please specify a single map name. To launch GUI use d.legend --ui."));
-    map_name = opt_input->answer;
+    if (opt_rast2d->answer) {
+	map_name = opt_rast2d->answer;
+	maptype = MAP_TYPE_RASTER2D;
+    else {
+	map_name = opt_rast3d->answer;
+	maptype = MAP_TYPE_RASTER3D;
     hide_catstr = hidestr->answer;	/* note hide_catstr gets changed and re-read below */
     hide_catnum = hidenum->answer;
@@ -274,22 +294,29 @@
+    if (maptype == MAP_TYPE_RASTER2D) {
+	if (Rast_read_colors(map_name, "", &colors) == -1)
+	    G_fatal_error(_("Color file for <%s> not available"), map_name);
-    if (Rast_read_colors(map_name, "", &colors) == -1)
-	G_fatal_error(_("Color file for <%s> not available"), map_name);
+	fp = Rast_map_is_fp(map_name, "");
+	Rast_read_cats(map_name, "", &cats);
+    else {
+	if (Rast3d_read_colors(map_name, "", &colors) == -1)
-    fp = Rast_map_is_fp(map_name, "");
+	fp = TRUE;  /* currently raster 3D is always floating point */
+	Rast3d_read_cats(map_name, "", &cats);
     if (fp && !use_catlist) {
 	do_smooth = TRUE;
 	/* fprintf(stderr, "FP map found - switching gradient legend on\n"); */
 	flip = !flip;
-    if (Rast_read_cats(map_name, "", &cats) == -1)
-	G_warning(_("Category file for <%s> not available"), map_name);
-    Rast_set_c_null_value(&null_cell, 1);
     if (D_open_driver() != 0)
 	G_fatal_error(_("No graphics device selected. "
 			"Use d.mon to select graphics device."));
@@ -334,7 +361,7 @@
     x0 = l + (int)((r - l) * X0 / 100.);
     x1 = l + (int)((r - l) * X1 / 100.);
-    y0 = t + (int)((b - t) * (100. - Y0) / 100.);	/* make lower left the origin */
+    y0 = t + (int)((b - t) * (100. - Y0) / 100.);  /* make lower left the origin */
     y1 = t + (int)((b - t) * (100. - Y1) / 100.);
     if (y0 > y1) {		/* allow for variety in order of corner */
@@ -532,13 +559,19 @@
 		sprintf(DispFormat, "%%2d");
-    else {			/* is fp */
-	if (Rast_read_fp_range(map_name, "", &fprange) == -1)
-	    G_fatal_error(_("Range information for <%s> not available"),
-			  map_name);
+    else {	/* is fp */
+	    if (Rast_read_fp_range(map_name, "", &fprange) == -1)
+		G_fatal_error(_("Range information for <%s> not available"),
+				map_name);
+	else {
+	    if (Rast3d_read_range(map_name, "", &fprange) == -1)
+				map_name);
 	Rast_get_fp_range_min_max(&fprange, &dmin, &dmax);
 	Rast_get_d_color_range(&min_dcolr, &max_dcolr, &colors);
 	if (UserRange) {
@@ -776,7 +809,7 @@
 		G_warning(_("Histogram constrained by range not yet implemented"));
 	    else
 		draw_histogram(map_name, x0, y0, wleg, lleg, color, flip,
-			       horiz);
+			       horiz, maptype);
