[GRASS-SVN] r60104 - in grass/trunk/gui/wxpython: core mapdisp	mapwin
    svn_grass at osgeo.org
    Mon May  5 02:52:45 PDT 2014
Author: hamish
Date: 2014-05-05 02:52:45 -0700 (Mon, 05 May 2014)
New Revision: 60104
   grass/trunk/gui/wxpython/core/render.py
   grass/trunk/gui/wxpython/mapdisp/frame.py
   grass/trunk/gui/wxpython/mapwin/decorations.py
Vaclav: add support for 3D raster legends (#2083)
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py	2014-05-05 09:45:45 UTC (rev 60103)
+++ grass/trunk/gui/wxpython/core/render.py	2014-05-05 09:52:45 UTC (rev 60104)
@@ -358,7 +358,7 @@
         @param id overlay id (for PseudoDC)
         @param type overlay type ('barscale', 'legend', etc.)
         @param cmd GRASS command to render overlay,
-        given as list, e.g. ['d.legend', 'map=elevation at PERMANENT']
+        given as list, e.g. ['d.legend', 'rast=elevation at PERMANENT']
         @param Map render.Map instance
         @param active layer is active, will be rendered only if True
         @param hidden layer is hidden, won't be listed in Layer Manager if True
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py	2014-05-05 09:45:45 UTC (rev 60103)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py	2014-05-05 09:52:45 UTC (rev 60104)
@@ -1072,15 +1072,15 @@
                     for i, legendParam in enumerate(self.legend.cmd[1:]):
                         idx = i + 1
                         param, val = legendParam.split('=')
-                        if param == 'map':
-                            self.legend.cmd[idx] = 'map={rast}'.format(rast=layer.maplayer.name)
+                        if param == 'rast':
+                            self.legend.cmd[idx] = 'rast={rast}'.format(rast=layer.maplayer.name)
                             isMap = True
                         elif param in ('use', 'range'):
                             # clear range or use to avoid problems
                             del self.legend.cmd[idx]
                     if not isMap:  # for the first time
-                        self.legend.cmd.append('map=%s' % layer.maplayer.name)
+                        self.legend.cmd.append('rast=%s' % layer.maplayer.name)
                     break
         if not showDialog and self.legend.CmdIsValid():
Modified: grass/trunk/gui/wxpython/mapwin/decorations.py
--- grass/trunk/gui/wxpython/mapwin/decorations.py	2014-05-05 09:45:45 UTC (rev 60103)
+++ grass/trunk/gui/wxpython/mapwin/decorations.py	2014-05-05 09:52:45 UTC (rev 60104)
@@ -229,9 +229,14 @@
             return x, y
     def CmdIsValid(self):
+        inputs = 0
         for param in self._cmd:
             param = param.split('=')
-            if param[0] == 'map' and len(param) == 2:
+            if param[0] == 'rast' and len(param) == 2:
+                inputs += 1
+            elif param[0] == 'rast3d' and len(param) == 2:
+                inputs += 1
+            if inputs == 1:
                 return True
         return False
