[GRASS-SVN] r60128 - grass/trunk/locale/po
Tue May 6 05:14:40 PDT 2014
Author: hcho
Date: 2014-05-06 05:14:39 -0700 (Tue, 06 May 2014)
New Revision: 60128
   grass/trunk/locale/po/grasslibs_ko.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grasswxpy_ko.po
Korean translation
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po	2014-05-05 21:48:22 UTC (rev 60127)
+++ grass/trunk/locale/po/grasslibs_ko.po	2014-05-06 12:14:39 UTC (rev 60128)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ko\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2014-05-03 16:44-0400\n"
+"POT-Creation-Date: 2014-05-06 07:42-0400\n"
 "PO-Revision-Date: 2013-10-30 22:07-0500\n"
 "Last-Translator: Huidae Cho <grass4u at gmail.com>\n"
 "Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -1733,7 +1733,7 @@
 #: ../lib/ogsf/GS2.c:1854
 msgid "Error finding range"
-msgstr "범위를 찾지 못했습니다."
+msgstr "범위를 찾지 못 했습니다."
 #: ../lib/ogsf/gs_bm.c:124
 msgid "Bitmap mismatch"
@@ -1956,8 +1956,8 @@
 "%d points without category. Unable to determine color rules for features "
 "without category."
 msgstr ""
-"%d 점들이 카테고리를 가지고 있지 않습니다. 카테고리 없는 점은 색상규칙을 "
-"정할 수 없습니다."
+"%d 점들이 카테고리를 가지고 있지 않습니다. 카테고리 없는 점은 색상규칙을 정"
+"할 수 없습니다."
 #: ../lib/ogsf/Gs3.c:132 ../lib/ogsf/Gs3.c:196 ../lib/ogsf/Gs3.c:348
 #: ../lib/ogsf/Gs3.c:454 ../lib/ogsf/Gs3.c:540
@@ -2883,34 +2883,33 @@
 #: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
 #, c-format
 msgid "G_spawn: unable to duplicate descriptor %d to %d"
-msgstr ""
+msgstr "G_spwan: 디스크립터 %d를 %d로 복재하지 못 했습니다"
 #: ../lib/gis/spawn.c:666
 msgid "Unable to create a new process"
-msgstr ""
+msgstr "새 프로세스를 생성하지 못 했습니다"
 #: ../lib/gis/spawn.c:681
 #, c-format
 msgid "Unable to change directory to %s"
-msgstr ""
+msgstr "%s로 디렉토리를 변경하지 못 했습니다"
 #: ../lib/gis/error.c:344
 msgid "WARNING: "
-msgstr ""
+msgstr "경고: "
 #: ../lib/gis/error.c:345
 msgid "ERROR: "
-msgstr ""
+msgstr "오류: "
 #: ../lib/gis/home.c:37
-#, fuzzy
 msgid "Unable to determine user's home directory"
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
+msgstr "사용자의 홈디렉토리를 결정할 수 없습니다"
 #: ../lib/gis/home.c:118
-#, fuzzy, c-format
+#, c-format
 msgid "Failed to create directory [%s]"
+msgstr "[%s] 디렉토리를 생성하지 못 했습니다"
 #: ../lib/gis/adj_cellhd.c:42 ../lib/gis/adj_cellhd.c:191
 msgid "Illegal n-s resolution value"
@@ -3033,7 +3032,7 @@
 #: ../lib/gis/parser.c:569 ../lib/init/grass.py:129
 msgid "ERROR"
-msgstr ""
+msgstr "오류"
 #: ../lib/gis/parser.c:806
 msgid "Unable to determine program name"
@@ -3102,7 +3101,7 @@
 #: ../lib/gis/parser.c:1365
 #, c-format
 msgid "ERROR: option <%s>: <%s> exists.\n"
-msgstr ""
+msgstr "오류: 옵션 <%s>: <%s>이 존재합니다.\n"
 #: ../lib/gis/parser.c:1449
 msgid "No separator given"
@@ -3147,7 +3146,7 @@
 #: ../lib/gis/parser_help.c:127
 msgid "ERROR: Option key not defined"
-msgstr ""
+msgstr "오류: 옵션키가 정의되지 않았습니다"
 #: ../lib/gis/parser_help.c:174
 msgid "Flags:"
@@ -4244,7 +4243,7 @@
 #: ../lib/init/grass.py:612
 #, python-format
 msgid "ERROR: <%s> is not a valid GRASS location"
-msgstr ""
+msgstr "오류: <%s>은 유효한 GRASS 로케이션이 아닙니다"
 #: ../lib/init/grass.py:615
 #, python-format
@@ -4969,74 +4968,74 @@
 msgid "Unable to locate symbol <%s>"
-#: ../lib/raster/gdal.c:140
+#: ../lib/raster/gdal.c:141
 #, fuzzy
 msgid "Unable to load GDAL library"
 msgstr "임시파일을 열 수 없습니다"
-#: ../lib/raster/gdal.c:370
+#: ../lib/raster/gdal.c:371
 #, fuzzy
 msgid "Unable to open GDAL file"
-#: ../lib/raster/gdal.c:474 ../lib/raster/open.c:569
+#: ../lib/raster/gdal.c:475 ../lib/raster/open.c:569
 #, fuzzy, c-format
 msgid "Invalid map type <%d>"
-#: ../lib/raster/gdal.c:480
+#: ../lib/raster/gdal.c:481
 #, fuzzy, c-format
 msgid "Unable to get <%s> driver"
-#: ../lib/raster/gdal.c:489
+#: ../lib/raster/gdal.c:490
 #, fuzzy, c-format
 msgid "Unable to create <%s> dataset using <%s> driver"
-#: ../lib/raster/gdal.c:497
+#: ../lib/raster/gdal.c:498
 #, c-format
 msgid ""
 "Driver <%s> does not support direct writing. Using MEM driver for "
 "intermediate dataset."
 msgstr ""
-#: ../lib/raster/gdal.c:503
+#: ../lib/raster/gdal.c:504
 #, fuzzy
 msgid "Unable to get in-memory raster driver"
 msgstr "자동 MASK파일을 열 수 없습니다"
-#: ../lib/raster/gdal.c:510
+#: ../lib/raster/gdal.c:511
 #, fuzzy, c-format
 msgid "Unable to create <%s> dataset using memory driver"
 msgstr "'%s' 디버그파일을 열 수 없습니다"
-#: ../lib/raster/gdal.c:514
+#: ../lib/raster/gdal.c:515
 #, c-format
 msgid "Driver <%s> does not support creating rasters"
 msgstr ""
-#: ../lib/raster/gdal.c:530
+#: ../lib/raster/gdal.c:531
 #, fuzzy
 msgid "Unable to set geo transform"
-#: ../lib/raster/gdal.c:534
+#: ../lib/raster/gdal.c:535
 #, fuzzy
 msgid "Unable to set projection"
-#: ../lib/raster/gdal.c:538
+#: ../lib/raster/gdal.c:539
 #, fuzzy, c-format
 msgid "Unable to create cell_misc/%s/gdal file"
-#: ../lib/raster/gdal.c:554
+#: ../lib/raster/gdal.c:555
 #, fuzzy, c-format
 msgid "Error writing cell_misc/%s/gdal file"
-#: ../lib/raster/gdal.c:602
+#: ../lib/raster/gdal.c:603
 #, fuzzy, c-format
 msgid "Unable to create output file <%s> using driver <%s>"
@@ -6862,7 +6861,9 @@
 msgid ""
 "Unable to build spatial index from topology, vector map is not opened at "
 "topology level 2"
-msgstr "벡터맵이 위상레벨 2에서 열리지 않았기 때문에 위상정보로부터 공간색인을 만들지 못 했습니다."
+msgstr ""
+"벡터맵이 위상레벨 2에서 열리지 않았기 때문에 위상정보로부터 공간색인을 만들"
+"지 못 했습니다."
 #: ../lib/vector/Vlib/build.c:1212
 #, c-format
@@ -6879,73 +6880,72 @@
 msgstr "벡터맵 <%s>를 위한 공간색인파일을 생성할 수 없습니다"
 #: ../lib/vector/Vlib/build.c:1257
-#, fuzzy
 msgid "Error writing out spatial index file"
-msgstr "임시파일을 열 수 없습니다"
+msgstr "공간색인파일을 쓰는데 오류가 발생했습니다"
 #: ../lib/vector/Vlib/read_sfa.c:90
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to construct centroid for area %d. Skipped."
+msgstr "면 %d를 위한 중심점을 생성하지 못 해서 넘어갑니다."
 #: ../lib/vector/Vlib/read_sfa.c:95
 #, c-format
 msgid "Centroid %d: invalid area %d"
-msgstr ""
+msgstr "중심점 %d: 잘못된 면 %d"
 #: ../lib/vector/Vlib/read_sfa.c:117 ../lib/vector/Vlib/read_pg.c:192
-#, fuzzy, c-format
+#, c-format
 msgid "Unexpected feature type (%d) - should be (%d)"
-msgstr "알려지지 않은 벡터타입입니다"
+msgstr "기대하지 않았던 피쳐타입 (%d) - (%d)라야 합니다"
 #: ../lib/vector/Vlib/read_sfa.c:124 ../lib/vector/Vlib/write_sfa.c:127
 #: ../lib/vector/Vlib/write_sfa.c:170 ../lib/vector/Vlib/write_sfa.c:266
 msgid "GRASS is not compiled with OGR/PostgreSQL support"
-msgstr ""
+msgstr "GRASS가 OGR/PostgreSQL의 지원없이 컴파일되었습니다"
 #: ../lib/vector/Vlib/dangles.c:148
 msgid "Changed"
-msgstr ""
+msgstr "바뀌었습니다"
 #: ../lib/vector/Vlib/dangles.c:151
 msgid "Removed"
-msgstr ""
+msgstr "지워졌습니다"
 #: ../lib/vector/Vlib/dangles.c:154
 msgid "Selected"
-msgstr ""
+msgstr "선택했습니다"
 #: ../lib/vector/Vlib/dangles.c:262
-#, fuzzy, c-format
+#, c-format
 msgid "%s lines: %d"
+msgstr "%s 선: %d"
 #: ../lib/vector/Vlib/dangles.c:263
 #, c-format
 msgid "%s dangles: %d"
-msgstr ""
+msgstr "%s 댕글: %d"
 #: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to calculate centroid for area %d"
+msgstr "면 %d를 위한 중심점을 계산할 수 없습니다"
 #: ../lib/vector/Vlib/build_sfa.c:305
 #, c-format
 msgid "Feature type %d not supported"
-msgstr ""
+msgstr "피쳐타입 %d를 지원하지 않습니다"
 #: ../lib/vector/Vlib/build_sfa.c:354 ../lib/vector/Vlib/build_sfa.c:364
 #: ../lib/vector/Vlib/read_pg.c:378
-#, fuzzy, c-format
+#, c-format
 msgid "Feature %d without geometry skipped"
+msgstr "지오메트리가 없는 피쳐 %d를 넘어갑니다"
 #: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
 #: ../lib/vector/Vlib/read_ogr.c:578
 #, c-format
 msgid "OGR feature type %d not supported"
-msgstr ""
+msgstr "OGR 피쳐타입 %d를 지원하지 않습니다"
 #: ../lib/vector/Vlib/build_sfa.c:665
 #, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2014-05-05 21:48:22 UTC (rev 60127)
+++ grass/trunk/locale/po/grassmods_ko.po	2014-05-06 12:14:39 UTC (rev 60128)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ko\n"
 "PO-Revision-Date: 2005-08-09 22:53-0500\n"
@@ -726,7 +726,7 @@
 #: ../general/g.proj/main.c:68
 msgid ""
-"Prints and manipulates GRASS projection information files (in various co-"
+"Prints or modifies GRASS projection information files (in various co-"
 "ordinate system descriptions)."
 msgstr ""
@@ -832,39 +832,38 @@
 msgstr ""
 #: ../general/g.proj/main.c:193
-#, fuzzy
-msgid "Create new projection files (modifies current location)"
-msgstr "출력할 래스터맵"
+msgid "Modify current location projection files"
+msgstr ""
-#: ../general/g.proj/main.c:201 ../general/g.mapset/main.c:83
+#: ../general/g.proj/main.c:200 ../general/g.mapset/main.c:83
 #: ../locale/scriptstrings/r.mask_to_translate.c:18
 msgid "Create"
 msgstr ""
-#: ../general/g.proj/main.c:202
+#: ../general/g.proj/main.c:201
 msgid "Name of new location to create"
 msgstr ""
-#: ../general/g.proj/main.c:218
+#: ../general/g.proj/main.c:217
 #, c-format
 msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
 msgstr ""
-#: ../general/g.proj/main.c:261
+#: ../general/g.proj/main.c:260
 msgid "Projection files missing"
 msgstr ""
-#: ../general/g.proj/main.c:281
+#: ../general/g.proj/main.c:280
 #, c-format
 msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
 msgstr ""
-#: ../general/g.proj/main.c:308
+#: ../general/g.proj/main.c:307
 #, c-format
 msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
 msgstr ""
-#: ../general/g.proj/main.c:312
+#: ../general/g.proj/main.c:311
 #, c-format
 msgid "No output format specified, define one of flags -%c, -%c, or -%c"
 msgstr ""
@@ -902,7 +901,7 @@
 #, c-format
 msgid ""
 "You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)."
+"projection (current mapset is <%s>)"
 msgstr ""
 #: ../general/g.proj/create.c:62
@@ -1212,7 +1211,7 @@
 msgstr ""
 #: ../general/g.region/main.c:485 ../raster3d/r3.mask/main.c:57
-#: ../raster3d/r3.stats/main.c:612 ../raster3d/r3.null/main.c:102
+#: ../raster3d/r3.stats/main.c:95 ../raster3d/r3.null/main.c:102
 #: ../raster3d/r3.neighbors/main.c:225 ../raster3d/r3.retile/main.c:113
 #: ../raster3d/r3.out.v5d/main.c:306 ../raster3d/r3.out.vtk/main.c:142
 #: ../raster3d/r3.support/main.c:134 ../raster3d/r3.out.netcdf/main.c:599
@@ -1581,7 +1580,7 @@
 #: ../display/d.colortable/main.c:60 ../display/d.mon/main.c:38
 #: ../display/d.rgb/main.c:53 ../display/d.linegraph/main.c:119
 #: ../display/d.what.rast/main.c:49 ../display/d.text/main.c:138
-#: ../display/d.histogram/main.c:84 ../display/d.title/main.c:49
+#: ../display/d.histogram/main.c:83 ../display/d.title/main.c:49
 #: ../display/d.vect/main.c:70 ../display/d.barscale/main.c:54
 #: ../display/d.rast.num/main.c:76 ../display/d.profile/main.c:191
 #: ../display/d.where/main.c:43 ../display/d.rast/main.c:53
@@ -3707,8 +3706,7 @@
 msgstr "출력할 래스터맵"
 #: ../imagery/i.landsat.toar/main.c:532 ../raster/r.flow/main.c:316
-#: ../raster/r.topidx/new/topidx.c:41 ../raster/r.topidx/topidx.c:41
-#: ../raster/r.topidx/old/topidx.c:41
+#: ../raster/r.topidx/topidx.c:41
 #, fuzzy
 msgid "Calculating..."
 msgstr "출력할 래스터맵"
@@ -6187,14 +6185,14 @@
 msgid "Transform completed.\n"
 msgstr ""
-#: ../imagery/i.cca/main.c:85 ../raster3d/r3.stats/main.c:569
+#: ../imagery/i.cca/main.c:85 ../raster3d/r3.stats/main.c:49
 #: ../raster3d/r3.neighbors/main.c:211 ../raster/r.statistics/main.c:56
 #: ../raster/r.surf.area/main.c:78 ../raster/r.neighbors/main.c:142
 #: ../raster/r.cross/main.c:70 ../raster/r.quantile/main.c:257
 #: ../raster/r.univar/r.univar_main.c:101
 #: ../raster/r.univar/r3.univar_main.c:99 ../raster/r.kappa/main.c:69
 #: ../raster/r.clump/main.c:50 ../raster/r.coin/main.c:67
-#: ../raster/r.stats/main.c:106 ../raster/r.quant/main.c:49
+#: ../raster/r.stats/main.c:105 ../raster/r.quant/main.c:49
 #: ../raster/r.regression.multi/main.c:129
 #: ../raster/r.regression.line/main.c:47 ../raster/r.mode/main.c:56
 #: ../raster/r.stats.zonal/main.c:102 ../raster/r.support.stats/main.c:39
@@ -6205,7 +6203,7 @@
 #: ../vector/v.random/main.c:114 ../vector/v.normal/main.c:75
 #: ../vector/v.outlier/main.c:70 ../vector/v.perturb/main.c:63
 #: ../vector/v.kcv/main.c:63 ../vector/v.qcount/main.c:61
-#: ../display/d.histogram/main.c:86
+#: ../display/d.histogram/main.c:85
 #: ../locale/scriptstrings/t.vect.univar_to_translate.c:3
 #: ../locale/scriptstrings/v.report_to_translate.c:4
 #: ../locale/scriptstrings/i.oif_to_translate.c:4
@@ -6924,7 +6922,7 @@
 msgstr ""
 #: ../raster3d/r3.info/r3.info.main.c:75 ../raster3d/r3.mask/main.c:132
-#: ../raster3d/r3.stats/main.c:568 ../raster3d/r3.null/main.c:185
+#: ../raster3d/r3.stats/main.c:48 ../raster3d/r3.null/main.c:185
 #: ../raster3d/r3.neighbors/main.c:208 ../raster3d/r3.in.ascii/main.c:316
 #: ../raster3d/r3.retile/main.c:96 ../raster3d/r3.out.v5d/main.c:283
 #: ../raster3d/r3.gwflow/main.c:159 ../raster3d/r3.out.vtk/main.c:376
@@ -7001,7 +6999,7 @@
 msgstr "출력할 래스터맵"
 #: ../raster3d/r3.info/r3.info.main.c:110 ../raster3d/r3.mask/main.c:63
-#: ../raster3d/r3.stats/main.c:619 ../raster3d/r3.null/main.c:109
+#: ../raster3d/r3.stats/main.c:102 ../raster3d/r3.null/main.c:109
 #: ../raster3d/r3.neighbors/main.c:262 ../raster3d/r3.neighbors/main.c:271
 #: ../raster3d/r3.retile/main.c:127 ../raster3d/r3.out.v5d/main.c:311
 #: ../raster3d/r3.out.vtk/main.c:207 ../raster3d/r3.out.vtk/main.c:292
@@ -7111,25 +7109,30 @@
 msgid "Cannot create mask file: RASTER3D_MASK already exists"
 msgstr ""
-#: ../raster3d/r3.stats/main.c:570
+#: ../raster3d/r3.stats/main.c:50
 #, fuzzy
 msgid "Generates volume statistics for 3D raster maps."
 msgstr "출력할 래스터맵"
-#: ../raster3d/r3.stats/main.c:581
+#: ../raster3d/r3.stats/main.c:61
 #, fuzzy
 msgid "Number of subranges to collect stats from"
 msgstr "출력할 래스터맵"
-#: ../raster3d/r3.stats/main.c:587
+#: ../raster3d/r3.stats/main.c:66
 msgid "Calculate statistics based on equal value groups"
 msgstr ""
-#: ../raster3d/r3.stats/main.c:607
+#: ../raster3d/r3.stats/main.c:70
+#, fuzzy
+msgid "Only print cell counts"
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.stats/main.c:90
 msgid "The number of subranges has to be equal or greater than 1"
 msgstr ""
-#: ../raster3d/r3.stats/main.c:666
+#: ../raster3d/r3.stats/main.c:149
 msgid "Sort non-null values"
 msgstr ""
@@ -7525,8 +7528,7 @@
 #: ../raster/simwe/r.sim.sediment/main.c:112
 #: ../raster/r.watershed/front/main.c:73 ../raster/r.basins.fill/main.c:55
 #: ../raster/r.stream.channel/main.c:57 ../raster/r.gwflow/main.c:210
-#: ../raster/r.uslek/main.c:54 ../raster/r.topidx/new/main.c:40
-#: ../raster/r.topidx/main.c:40 ../raster/r.topidx/old/main.c:40
+#: ../raster/r.uslek/main.c:54 ../raster/r.topidx/main.c:40
 #: ../raster/r.stream.segment/main.c:58 ../raster/r.stream.order/main.c:76
 #: ../raster/r.water.outlet/main.c:68 ../raster/r.stream.stats/main.c:54
 msgid "hydrology"
@@ -8168,7 +8170,7 @@
 #: ../raster/r.out.mat/main.c:62 ../raster/r.coin/main.c:66
 #: ../raster/r.resamp.bspline/main.c:80 ../raster/simwe/r.sim.water/main.c:110
 #: ../raster/simwe/r.sim.sediment/main.c:111 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.ascii/main.c:59 ../raster/r.stats/main.c:105
+#: ../raster/r.out.ascii/main.c:59 ../raster/r.stats/main.c:104
 #: ../raster/r.surf.fractal/main.c:38 ../raster/r.proj/main.c:144
 #: ../raster/r.quant/main.c:47 ../raster/r.in.gdal/main.c:81
 #: ../raster/r.null/main.c:59 ../raster/r.out.ppm3/main.c:57
@@ -8206,8 +8208,7 @@
 #: ../raster/r.surf.random/main.c:36 ../raster/r.category/main.c:52
 #: ../raster/r.uslek/main.c:53 ../raster/r.describe/main.c:54
 #: ../raster/r.what/main.c:98 ../raster/r.composite/main.c:72
-#: ../raster/r.topidx/new/main.c:39 ../raster/r.topidx/main.c:39
-#: ../raster/r.topidx/old/main.c:39 ../raster/r.out.vtk/main.c:59
+#: ../raster/r.topidx/main.c:39 ../raster/r.out.vtk/main.c:59
 #: ../raster/r.texture/main.c:101 ../raster/r.random.surface/main.c:57
 #: ../raster/r.out.gridatb/main.c:67 ../raster/r.le/r.le.trace/main.c:55
 #: ../raster/r.le/r.le.patch/main.c:48 ../raster/r.le/r.le.setup/main.c:57
@@ -9468,11 +9469,11 @@
 #: ../raster/r.his/main.c:140 ../raster/r.his/main.c:156
 #: ../raster/r.his/main.c:174 ../raster/r.out.ppm3/main.c:115
-#: ../display/d.legend/main.c:279 ../display/d.his/main.c:141
-#: ../display/d.his/main.c:158 ../display/d.his/main.c:176
-#: ../display/d.colortable/main.c:137 ../display/d.rgb/main.c:101
-#: ../display/d.histogram/main.c:174 ../display/d.rast.num/main.c:224
-#: ../display/d.rast/display.c:23
+#: ../display/d.legend/main.c:296 ../display/d.legend/main.c:304
+#: ../display/d.his/main.c:141 ../display/d.his/main.c:158
+#: ../display/d.his/main.c:176 ../display/d.colortable/main.c:137
+#: ../display/d.rgb/main.c:101 ../display/d.histogram/main.c:168
+#: ../display/d.rast.num/main.c:224 ../display/d.rast/display.c:23
 #, c-format
 msgid "Color file for <%s> not available"
 msgstr ""
@@ -11011,7 +11012,7 @@
 msgstr "출력할 래스터맵"
 #: ../raster/r.series/main.c:268 ../raster/r.series.accumulate/main.c:267
-#: ../raster/r.stats/main.c:289
+#: ../raster/r.stats/main.c:288
 #, fuzzy
 msgid "Raster map not found"
 msgstr "출력할 래스터맵"
@@ -12417,6 +12418,7 @@
 #: ../raster/simwe/r.sim.sediment/main.c:161 ../raster/r.external/main.c:64
 #: ../raster/r.external/main.c:72 ../raster/r.external/main.c:81
 #: ../vector/v.edit/args.c:90 ../vector/v.edit/args.c:209
+#: ../display/d.legend/main.c:94 ../display/d.legend/main.c:99
 #: ../locale/scriptstrings/t.remove_to_translate.c:5
 #: ../locale/scriptstrings/t.remove_to_translate.c:8
 #: ../locale/scriptstrings/t.remove_to_translate.c:10
@@ -12803,7 +12805,7 @@
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:41
-#: ../raster/r.univar/r3.univar_main.c:42 ../raster/r.stats/main.c:118
+#: ../raster/r.univar/r3.univar_main.c:42 ../raster/r.stats/main.c:117
 #: ../raster/r.what/main.c:129 ../vector/v.db.select/main.c:88
 #: ../locale/scriptstrings/i.oif_to_translate.c:5
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
@@ -12834,8 +12836,8 @@
 #: ../raster/r.univar/r.univar_main.c:56 ../raster/r.univar/r.univar_main.c:62
 #: ../raster/r.univar/r.univar_main.c:72 ../raster/r.kappa/main.c:104
-#: ../raster/r.kappa/main.c:109 ../raster/r.stats/main.c:122
-#: ../raster/r.stats/main.c:131 ../raster/r.stats/main.c:155
+#: ../raster/r.kappa/main.c:109 ../raster/r.stats/main.c:121
+#: ../raster/r.stats/main.c:130 ../raster/r.stats/main.c:154
 #: ../raster/r.report/parse.c:76 ../raster/r.report/parse.c:85
 #: ../raster/r.report/parse.c:94 ../raster/r.report/parse.c:118
 #: ../raster/r.report/parse.c:123 ../raster/r.report/parse.c:128
@@ -12884,7 +12886,7 @@
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:116
-#: ../raster/r.univar/r3.univar_main.c:124 ../raster/r.stats/main.c:231
+#: ../raster/r.univar/r3.univar_main.c:124 ../raster/r.stats/main.c:230
 #: ../raster/r.regression.multi/main.c:168
 #: ../raster/r.regression.line/main.c:76 ../raster/r.what/main.c:174
 #: ../vector/v.db.select/main.c:114 ../db/db.select/main.c:141
@@ -13516,8 +13518,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:244 ../raster/r.gwflow/main.c:222
-#: ../raster/r.topidx/new/main.c:55 ../raster/r.topidx/main.c:55
-#: ../raster/r.topidx/old/main.c:55
+#: ../raster/r.topidx/main.c:55
 #, c-format
 msgid "Lat/Long location is not supported by %s. Please reproject map first."
 msgstr ""
@@ -14902,153 +14903,153 @@
 msgid "Read failed at row %d"
 msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:108
+#: ../raster/r.stats/main.c:107
 #, fuzzy
 msgid "Generates area statistics for raster map."
 msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:113 ../raster/r.report/parse.c:40
+#: ../raster/r.stats/main.c:112 ../raster/r.report/parse.c:40
 #, fuzzy
 msgid "Name of raster map(s) to report on"
 msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:130 ../raster/r.describe/main.c:68
+#: ../raster/r.stats/main.c:129 ../raster/r.describe/main.c:68
 #: ../raster/r.report/parse.c:75
 msgid "String representing no data cell value"
 msgstr ""
-#: ../raster/r.stats/main.c:140 ../raster/r.report/parse.c:103
+#: ../raster/r.stats/main.c:139 ../raster/r.report/parse.c:103
 #, fuzzy
 msgid "Number of floating-point subranges to collect stats from"
 msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:141 ../raster/r.stats/main.c:196
-#: ../raster/r.stats/main.c:201 ../raster/r.stats/main.c:216
-#: ../raster/r.stats/main.c:221 ../raster/r.report/parse.c:104
+#: ../raster/r.stats/main.c:140 ../raster/r.stats/main.c:195
+#: ../raster/r.stats/main.c:200 ../raster/r.stats/main.c:215
+#: ../raster/r.stats/main.c:220 ../raster/r.report/parse.c:104
 #: ../raster/r.report/parse.c:148 ../raster/r.report/parse.c:154
 #, fuzzy
 msgid "Floating point"
 msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:148 ../raster/r.report/parse.c:111
+#: ../raster/r.stats/main.c:147 ../raster/r.report/parse.c:111
 msgid "Sort output statistics by cell counts"
 msgstr ""
-#: ../raster/r.stats/main.c:149 ../raster/r.report/parse.c:112
+#: ../raster/r.stats/main.c:148 ../raster/r.report/parse.c:112
 #, fuzzy
 msgid "Default: sorted by categories or intervals"
 msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:153 ../raster/r.report/parse.c:116
+#: ../raster/r.stats/main.c:152 ../raster/r.report/parse.c:116
 msgid "Sort by cell counts in ascending order"
 msgstr ""
-#: ../raster/r.stats/main.c:154 ../raster/r.report/parse.c:117
+#: ../raster/r.stats/main.c:153 ../raster/r.report/parse.c:117
 msgid "Sort by cell counts in descending order"
 msgstr ""
-#: ../raster/r.stats/main.c:161
+#: ../raster/r.stats/main.c:160
 msgid "Print area totals in square meters"
 msgstr ""
-#: ../raster/r.stats/main.c:162 ../raster/r.stats/main.c:167
-#: ../raster/r.stats/main.c:173 ../raster/r.report/parse.c:60
+#: ../raster/r.stats/main.c:161 ../raster/r.stats/main.c:166
+#: ../raster/r.stats/main.c:172 ../raster/r.report/parse.c:60
 #, fuzzy
 msgid "Statistics"
 msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:166
+#: ../raster/r.stats/main.c:165
 msgid "Print cell counts (sortable)"
 msgstr ""
-#: ../raster/r.stats/main.c:172
+#: ../raster/r.stats/main.c:171
 msgid "Print approximate (total percent may not be 100%) percents"
 msgstr ""
-#: ../raster/r.stats/main.c:177
+#: ../raster/r.stats/main.c:176
 msgid "Print category labels"
 msgstr ""
-#: ../raster/r.stats/main.c:181
+#: ../raster/r.stats/main.c:180
 msgid "One cell (range) per line"
 msgstr ""
-#: ../raster/r.stats/main.c:185
+#: ../raster/r.stats/main.c:184
 msgid "Print grid coordinates (east and north)"
 msgstr ""
-#: ../raster/r.stats/main.c:186 ../raster/r.stats/main.c:191
+#: ../raster/r.stats/main.c:185 ../raster/r.stats/main.c:190
 #, fuzzy
 msgid "Coordinates"
 msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:190
+#: ../raster/r.stats/main.c:189
 msgid "Print x and y (column and row)"
 msgstr ""
-#: ../raster/r.stats/main.c:195
+#: ../raster/r.stats/main.c:194
 msgid "Print averaged values instead of intervals (floating-point maps only)"
 msgstr ""
-#: ../raster/r.stats/main.c:200
+#: ../raster/r.stats/main.c:199
 msgid "Print raw indexes of floating-point ranges (floating-point maps only)"
 msgstr ""
-#: ../raster/r.stats/main.c:205 ../raster/r.report/parse.c:137
+#: ../raster/r.stats/main.c:204 ../raster/r.report/parse.c:137
 #, fuzzy
 msgid "Do not report no data value"
 msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:206 ../raster/r.stats/main.c:211
+#: ../raster/r.stats/main.c:205 ../raster/r.stats/main.c:210
 #: ../raster/r.report/parse.c:138 ../raster/r.report/parse.c:143
 #, fuzzy
 msgid "No data"
 msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:210 ../raster/r.report/parse.c:142
+#: ../raster/r.stats/main.c:209 ../raster/r.report/parse.c:142
 msgid "Do not report cells where all maps have no data"
 msgstr ""
-#: ../raster/r.stats/main.c:215 ../raster/r.report/parse.c:147
+#: ../raster/r.stats/main.c:214 ../raster/r.report/parse.c:147
 msgid "Report for cats floating-point ranges (floating-point maps only)"
 msgstr ""
-#: ../raster/r.stats/main.c:220 ../raster/r.report/parse.c:153
+#: ../raster/r.stats/main.c:219 ../raster/r.report/parse.c:153
 msgid "Read floating-point map as integer (use map's quant rules)"
 msgstr ""
-#: ../raster/r.stats/main.c:237
+#: ../raster/r.stats/main.c:236
 #, c-format
 msgid "'%s' must be greater than zero; using %s=255"
 msgstr ""
-#: ../raster/r.stats/main.c:307
+#: ../raster/r.stats/main.c:306
 #, c-format
 msgid ""
 "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
 "will be ignored."
 msgstr ""
-#: ../raster/r.stats/main.c:323
+#: ../raster/r.stats/main.c:322
 #, c-format
 msgid ""
 "Cats for raster map <%s> are either missing or have no explicit labels. "
 "Using %s=%d."
 msgstr ""
-#: ../raster/r.stats/main.c:329
+#: ../raster/r.stats/main.c:328
 #, c-format
 msgid ""
 "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
 "option"
 msgstr ""
-#: ../raster/r.stats/main.c:335 ../raster/r.contour/main.c:146
+#: ../raster/r.stats/main.c:334 ../raster/r.contour/main.c:146
 #, fuzzy, c-format
 msgid "Unable to read fp range of raster map <%s>"
 msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:362 ../raster/r.recode/read_rules.c:35
+#: ../raster/r.stats/main.c:361 ../raster/r.recode/read_rules.c:35
 #, fuzzy, c-format
 msgid "Unable to read range for map <%s>"
 msgstr "출력할 래스터맵"
@@ -19976,9 +19977,9 @@
 msgstr ""
 #: ../raster/r.what/main.c:141 ../raster/r.what/main.c:166
-#: ../display/d.legend/main.c:105 ../display/d.legend/main.c:114
-#: ../display/d.legend/main.c:188 ../display/d.legend/main.c:193
-#: ../display/d.legend/main.c:198 ../display/d.legend/main.c:208
+#: ../display/d.legend/main.c:108 ../display/d.legend/main.c:118
+#: ../display/d.legend/main.c:197 ../display/d.legend/main.c:202
+#: ../display/d.legend/main.c:207 ../display/d.legend/main.c:217
 msgid "Advanced"
 msgstr ""
@@ -20070,25 +20071,21 @@
 msgid "Creating color table for output raster map..."
 msgstr "출력할 래스터맵"
-#: ../raster/r.topidx/new/topidx.c:277 ../raster/r.topidx/topidx.c:277
-#: ../raster/r.topidx/old/topidx.c:277
+#: ../raster/r.topidx/topidx.c:277
 #, fuzzy, c-format
 msgid "Number of sinks or boundaries: %d"
 msgstr "출력할 래스터맵"
-#: ../raster/r.topidx/new/main.c:42 ../raster/r.topidx/main.c:42
-#: ../raster/r.topidx/old/main.c:42
+#: ../raster/r.topidx/main.c:42
 #, fuzzy
 msgid "Creates topographic index map from elevation raster map."
 msgstr "출력할 래스터맵"
-#: ../raster/r.topidx/new/main.c:48 ../raster/r.topidx/main.c:48
-#: ../raster/r.topidx/old/main.c:48
+#: ../raster/r.topidx/main.c:48
 #, fuzzy
 msgid "Name for output topographic index map"
 msgstr "출력할 래스터맵"
-#: ../raster/r.topidx/new/file_io.c:35 ../raster/r.topidx/old/file_io.c:35
 #: ../raster/r.topidx/file_io.c:35
 #, c-format
 msgid ""
@@ -20097,13 +20094,11 @@
 "coarser than, the input map's resolution."
 msgstr ""
-#: ../raster/r.topidx/new/file_io.c:42 ../raster/r.topidx/old/file_io.c:42
 #: ../raster/r.topidx/file_io.c:42
 #, fuzzy
 msgid "Reading elevation map..."
 msgstr "출력할 래스터맵"
-#: ../raster/r.topidx/new/file_io.c:87 ../raster/r.topidx/old/file_io.c:87
 #: ../raster/r.topidx/file_io.c:87
 #, fuzzy
 msgid "Writing topographic index map..."
@@ -23932,7 +23927,7 @@
 msgid ""
 "Vector map <%s> cannot be overwritten because input table <%s> is linked to "
 "this map."
-msgstr ""
+msgstr "입력테이블 <%2$s>이 벡터맵 <%1$s>와 연결되어 있어서 벡터맵을 덮어 쓸 수 없습니다."
 #: ../vector/v.in.db/main.c:177
 #, c-format
@@ -28254,7 +28249,7 @@
 msgid "Reference position"
 msgstr ""
-#: ../vector/v.label/main.c:122 ../display/d.legend/main.c:157
+#: ../vector/v.label/main.c:122 ../display/d.legend/main.c:167
 #: ../display/d.text/main.c:218 ../display/d.vect/main.c:256
 msgid "Font name"
 msgstr ""
@@ -28280,7 +28275,7 @@
 msgstr ""
 #: ../vector/v.label/main.c:151 ../vector/v.lrs/v.lrs.label/main.c:194
-#: ../vector/v.label.sa/main.c:98 ../display/d.legend/main.c:95
+#: ../vector/v.label.sa/main.c:98 ../display/d.legend/main.c:160
 #: ../display/d.grid/main.c:102 ../display/d.rhumbline/main.c:68
 msgid "Text color"
 msgstr ""
@@ -34181,14 +34176,14 @@
 #: ../display/d.labels/main.c:117 ../display/d.vect.chart/main.c:254
 #: ../display/d.font/main.c:85 ../display/d.thematic.area/main.c:371
-#: ../display/d.fontlist/main.c:54 ../display/d.legend/main.c:294
+#: ../display/d.fontlist/main.c:54 ../display/d.legend/main.c:318
 #: ../display/d.northarrow/main.c:130 ../display/d.erase/main.c:45
 #: ../display/d.info/main.c:70 ../display/d.rast.arrow/main.c:224
 #: ../display/d.his/main.c:119 ../display/d.grid/main.c:253
 #: ../display/d.rhumbline/main.c:96 ../display/d.colortable/main.c:141
 #: ../display/d.mon/main.c:200 ../display/d.rgb/main.c:82
 #: ../display/d.linegraph/main.c:268 ../display/d.text/main.c:286
-#: ../display/d.histogram/main.c:190 ../display/d.vect/main.c:323
+#: ../display/d.histogram/main.c:184 ../display/d.vect/main.c:323
 #: ../display/d.barscale/main.c:221 ../display/d.rast.num/main.c:195
 #: ../display/d.profile/main.c:263 ../display/d.where/main.c:170
 #: ../display/d.rast/main.c:97 ../display/d.graph/main.c:98
@@ -34626,160 +34621,166 @@
 msgstr ""
 #: ../display/d.legend/main.c:88
+#, fuzzy
 msgid ""
-"Displays a legend for a raster map in the active frame of the graphics "
-"monitor."
-msgstr ""
-#: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:76
-msgid "Name of raster map"
-msgstr ""
-#: ../display/d.legend/main.c:96 ../display/d.legend/main.c:158
-#: ../display/d.legend/main.c:168 ../display/d.legend/main.c:175
-#: ../display/d.legend/main.c:183 ../display/d.legend/main.c:213
-#, fuzzy
-msgid "Font settings"
+"Displays a legend for a raster map (2 or 3D) in the active frame of the "
+"graphics monitor."
 msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:104
+#: ../display/d.legend/main.c:107
 msgid "Number of text lines (useful for truncating long legends)"
 msgstr ""
-#: ../display/d.legend/main.c:113
+#: ../display/d.legend/main.c:117
 msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
 msgstr ""
-#: ../display/d.legend/main.c:121
+#: ../display/d.legend/main.c:126
 msgid "Number of text labels for smooth gradient legend"
 msgstr ""
-#: ../display/d.legend/main.c:122 ../display/d.legend/main.c:203
+#: ../display/d.legend/main.c:127 ../display/d.legend/main.c:212
+#: ../display/d.legend/main.c:222
 #, fuzzy
 msgid "Gradient"
 msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:131
+#: ../display/d.legend/main.c:136
 msgid ""
 "Size and placement as percentage of screen coordinates (0,0 is lower left)"
 msgstr ""
-#: ../display/d.legend/main.c:140
+#: ../display/d.legend/main.c:146
 msgid "List of discrete category numbers/values for legend"
 msgstr ""
-#: ../display/d.legend/main.c:142 ../display/d.legend/main.c:151
+#: ../display/d.legend/main.c:148 ../display/d.legend/main.c:157
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:10
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:11
 msgid "Subset"
 msgstr ""
-#: ../display/d.legend/main.c:150
+#: ../display/d.legend/main.c:156
 msgid "Use a subset of the map range for the legend (min,max)"
 msgstr ""
-#: ../display/d.legend/main.c:167
-msgid "Font scaling factor for floating point legends"
+#: ../display/d.legend/main.c:161 ../display/d.legend/main.c:168
+#: ../display/d.legend/main.c:177 ../display/d.legend/main.c:184
+#: ../display/d.legend/main.c:192
+#, fuzzy
+msgid "Font settings"
+msgstr "출력할 래스터맵"
+#: ../display/d.legend/main.c:175 ../display/d.northarrow/main.c:86
+#: ../display/d.barscale/main.c:132
+msgid "Font size"
 msgstr ""
-#: ../display/d.legend/main.c:173 ../display/d.text/main.c:223
+#: ../display/d.legend/main.c:176
+msgid "Default: Auto-scaled"
+msgstr ""
+#: ../display/d.legend/main.c:182 ../display/d.text/main.c:223
 msgid "Path to font file"
 msgstr ""
-#: ../display/d.legend/main.c:182 ../display/d.text/main.c:231
+#: ../display/d.legend/main.c:191 ../display/d.text/main.c:231
 msgid "Text encoding (only applicable to TrueType fonts)"
 msgstr ""
-#: ../display/d.legend/main.c:187
+#: ../display/d.legend/main.c:196
 msgid "Do not show category labels"
 msgstr ""
-#: ../display/d.legend/main.c:192
+#: ../display/d.legend/main.c:201
 msgid "Do not show category numbers"
 msgstr ""
-#: ../display/d.legend/main.c:197
+#: ../display/d.legend/main.c:206
 msgid "Skip categories with no label"
 msgstr ""
-#: ../display/d.legend/main.c:202
+#: ../display/d.legend/main.c:211
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
 msgid "Draw smooth gradient"
 msgstr ""
-#: ../display/d.legend/main.c:207
+#: ../display/d.legend/main.c:216
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
 msgid "Flip legend"
 msgstr ""
-#: ../display/d.legend/main.c:212 ../display/d.text/main.c:255
-msgid "Font size is height in pixels"
+#: ../display/d.legend/main.c:221
+msgid "Add histogram to smoothed legend"
 msgstr ""
-#: ../display/d.legend/main.c:289 ../display/d.histogram/main.c:177
-#: ../ps/ps.map/ps_clrtbl.c:39
-#, c-format
-msgid "Category file for <%s> not available"
+#: ../display/d.legend/main.c:232
+msgid "Please specify a single map name. To launch GUI use d.legend --ui."
 msgstr ""
-#: ../display/d.legend/main.c:348
+#: ../display/d.legend/main.c:382
 msgid "Legend box lies outside of frame. Text may not display properly."
 msgstr ""
-#: ../display/d.legend/main.c:352
+#: ../display/d.legend/main.c:386
 msgid "Drawing horizontal legend as box width exceeds height"
 msgstr ""
-#: ../display/d.legend/main.c:363
+#: ../display/d.legend/main.c:397
 #, c-format
 msgid "Range information for <%s> not available (run r.support)"
 msgstr ""
-#: ../display/d.legend/main.c:368
+#: ../display/d.legend/main.c:402
 #, fuzzy
 msgid "Input map contains no data"
 msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:381
+#: ../display/d.legend/main.c:415
 msgid "Requested range exceeds lower limit of actual data"
 msgstr ""
-#: ../display/d.legend/main.c:387
+#: ../display/d.legend/main.c:421
 msgid "Requested range exceeds upper limit of actual data"
 msgstr ""
-#: ../display/d.legend/main.c:446
+#: ../display/d.legend/main.c:480
 #, c-format
 msgid "use=%s out of range [%d,%d] (extend with range= ?)"
 msgstr ""
-#: ../display/d.legend/main.c:487
+#: ../display/d.legend/main.c:521
 msgid "Nothing to draw! (no categories with labels? out of range?)"
 msgstr ""
-#: ../display/d.legend/main.c:497
+#: ../display/d.legend/main.c:531
 msgid "Forcing a smooth legend: too many categories for current window height"
 msgstr ""
-#: ../display/d.legend/main.c:527 ../display/d.histogram/main.c:180
+#: ../display/d.legend/main.c:562 ../display/d.legend/main.c:567
+#: ../display/d.histogram/main.c:174
 #, c-format
 msgid "Range information for <%s> not available"
 msgstr ""
-#: ../display/d.legend/main.c:541
+#: ../display/d.legend/main.c:581
 msgid "Color range exceeds lower limit of actual data"
 msgstr ""
-#: ../display/d.legend/main.c:545
+#: ../display/d.legend/main.c:585
 msgid "Color range exceeds upper limit of actual data"
 msgstr ""
-#: ../display/d.legend/main.c:552
+#: ../display/d.legend/main.c:592
 #, c-format
 msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
 msgstr ""
-#: ../display/d.legend/main.c:926
+#: ../display/d.legend/main.c:831
+msgid "Histogram constrained by range not yet implemented"
+msgstr ""
+#: ../display/d.legend/main.c:1008
 msgid "Nothing to draw! (no categories with labels?)"
 msgstr ""
@@ -34889,10 +34890,6 @@
 msgid "Line width"
 msgstr ""
-#: ../display/d.northarrow/main.c:86 ../display/d.barscale/main.c:132
-msgid "Font size"
-msgstr ""
 #: ../display/d.northarrow/main.c:87 ../display/d.northarrow/main.c:92
 #: ../display/d.barscale/main.c:65 ../display/d.barscale/main.c:124
 #: ../display/d.barscale/main.c:133
@@ -35610,6 +35607,10 @@
 msgid "Use radians instead of degrees for rotation"
 msgstr ""
+#: ../display/d.text/main.c:255
+msgid "Font size is height in pixels"
+msgstr ""
 #: ../display/d.text/main.c:266
 msgid "Please choose only one placement method"
 msgstr ""
@@ -35630,59 +35631,60 @@
 msgid "[%s]: No such color. Use '%s'"
 msgstr ""
-#: ../display/d.histogram/main.c:85
+#: ../display/d.histogram/main.c:84
 #, fuzzy
 msgid "histogram"
 msgstr "출력할 래스터맵"
-#: ../display/d.histogram/main.c:88
+#: ../display/d.histogram/main.c:87
 msgid ""
 "Displays a histogram in the form of a pie or bar chart for a user-specified "
 "raster map."
 msgstr ""
-#: ../display/d.histogram/main.c:92
+#: ../display/d.histogram/main.c:91
 #, fuzzy
 msgid "Raster map for which histogram will be displayed"
 msgstr "출력할 래스터맵"
-#: ../display/d.histogram/main.c:96
+#: ../display/d.histogram/main.c:95
 msgid "Indicate if a pie or bar chart is desired"
 msgstr ""
-#: ../display/d.histogram/main.c:105
+#: ../display/d.histogram/main.c:104
 msgid "Color for text and axes"
 msgstr ""
-#: ../display/d.histogram/main.c:113
+#: ../display/d.histogram/main.c:112
 msgid "Indicate if cell counts or map areas should be displayed"
 msgstr ""
-#: ../display/d.histogram/main.c:123
+#: ../display/d.histogram/main.c:122
 msgid "Number of steps to divide the data range into (fp maps only)"
 msgstr ""
-#: ../display/d.histogram/main.c:130
+#: ../display/d.histogram/main.c:129
 msgid "Display information for null cells"
 msgstr ""
 #: ../display/d.histogram/main.c:134
-msgid "Gather the histogram quietly"
-msgstr ""
-#: ../display/d.histogram/main.c:139
 msgid "Report for ranges defined in cats file (fp maps only)"
 msgstr ""
-#: ../display/d.histogram/main.c:163
+#: ../display/d.histogram/main.c:158
 #, c-format
 msgid "Invalid number of steps: %s"
 msgstr ""
-#: ../display/d.histogram/main.c:168
+#: ../display/d.histogram/main.c:163
 msgid "When -C flag is set, the nsteps argument is ignored"
 msgstr ""
+#: ../display/d.histogram/main.c:171 ../ps/ps.map/ps_clrtbl.c:39
+#, c-format
+msgid "Category file for <%s> not available"
+msgstr ""
 #: ../display/d.title/main.c:52
 msgid ""
 "Create a TITLE for a raster map in a form suitable for display with d.text."
@@ -36366,6 +36368,10 @@
 "interactively, with a mouse."
 msgstr ""
+#: ../display/d.zoom/main.c:76
+msgid "Name of raster map"
+msgstr ""
 #: ../display/d.zoom/main.c:92
 msgid "Magnification: >1.0 zooms in, <1.0 zooms out"
 msgstr ""
@@ -41164,6 +41170,10 @@
 msgstr ""
 #, fuzzy
+#~ msgid "Create new projection files (modifies current location)"
+#~ msgstr "출력할 래스터맵"
+#, fuzzy
 #~ msgid "Name for output distance/accumulation raster map"
Modified: grass/trunk/locale/po/grasswxpy_ko.po
--- grass/trunk/locale/po/grasswxpy_ko.po	2014-05-05 21:48:22 UTC (rev 60127)
+++ grass/trunk/locale/po/grasswxpy_ko.po	2014-05-06 12:14:39 UTC (rev 60128)
@@ -3,11 +3,12 @@
 # Copyright (C) 2005, 2014 GRASS Development Team
 # Huidae Cho <grass4u at gmail.com>, 2005, 2014.
+#: ../gui/wxpython/gis_set.py:122
 msgid ""
 msgstr ""
 "Project-Id-Version: grasswxpy_ko\n"
 "PO-Revision-Date: 2014-05-03 16:44-0400\n"
@@ -69,46 +70,46 @@
 msgid "Add space-time dataset or series of map layers for animation"
 msgstr ""
-#: ../gui/wxpython/animation/utils.py:69 ../gui/wxpython/animation/utils.py:75
+#: ../gui/wxpython/animation/utils.py:69 ../gui/wxpython/animation/utils.py:77
 #: ../gui/wxpython/animation/temporal_manager.py:225
-#: ../gui/wxpython/timeline/frame.py:399
+#: ../gui/wxpython/timeline/frame.py:404
 #, python-format
 msgid "Space time dataset <%s> not found."
 msgstr ""
-#: ../gui/wxpython/animation/utils.py:93
-#: ../gui/wxpython/animation/utils.py:101
+#: ../gui/wxpython/animation/utils.py:95
+#: ../gui/wxpython/animation/utils.py:103
 #: ../gui/wxpython/mapswipe/frame.py:392
 #: ../gui/wxpython/lmgr/layertree.py:1612 ../gui/wxpython/gis_set.py:539
 #, python-format
 msgid "Map <%s> not found."
 msgstr ""
-#: ../gui/wxpython/animation/utils.py:156
+#: ../gui/wxpython/animation/utils.py:158
 msgid "The number of maps in space-time datasets has to be the same."
 msgstr ""
-#: ../gui/wxpython/animation/utils.py:160
+#: ../gui/wxpython/animation/utils.py:162
 msgid ""
 "The temporal type (absolute/relative) of space-time datasets has to be the "
 "same."
 msgstr ""
-#: ../gui/wxpython/animation/utils.py:164
+#: ../gui/wxpython/animation/utils.py:166
 msgid ""
 "The map type (point/interval) of space-time datasets has to be the same."
 msgstr ""
-#: ../gui/wxpython/animation/utils.py:168
+#: ../gui/wxpython/animation/utils.py:170
 msgid ""
 "The temporal extents of maps in space-time datasets have to be the same."
 msgstr ""
-#: ../gui/wxpython/animation/utils.py:176
+#: ../gui/wxpython/animation/utils.py:178
 msgid "The number of maps to animate has to be the same for each map series."
 msgstr ""
-#: ../gui/wxpython/animation/utils.py:180
+#: ../gui/wxpython/animation/utils.py:182
 msgid ""
 "The number of maps to animate has to be the same as the number of maps in "
 "temporal dataset."
@@ -535,7 +536,7 @@
 msgstr ""
 #: ../gui/wxpython/animation/dialogs.py:845
-#: ../gui/wxpython/mapwin/decorations.py:361
+#: ../gui/wxpython/mapwin/decorations.py:366
 #: ../gui/wxpython/gui_core/preferences.py:394
 #: ../gui/wxpython/gui_core/preferences.py:589
 msgid "Set font"
@@ -1917,7 +1918,7 @@
 #: ../gui/wxpython/core/workspace.py:1329 ../gui/wxpython/core/gcmd.py:140
 #: ../gui/wxpython/wxplot/dialogs.py:802
-#: ../gui/wxpython/mapwin/buffered.py:1888
+#: ../gui/wxpython/mapwin/buffered.py:1913
 msgid "Warning"
 msgstr ""
@@ -3425,18 +3426,16 @@
 msgid "Select output vector map:"
 msgstr ""
-#: ../gui/wxpython/modules/vclean.py:137
+#: ../gui/wxpython/modules/vclean.py:137 ../gui/wxpython/modules/vkrige.py:137
 #: ../gui/wxpython/modules/mcalc_builder.py:231
-#: ../gui/wxpython/scripts/vkrige.py:137
 #: ../gui/wxpython/gmodeler/preferences.py:529
 #: ../gui/wxpython/gui_core/dialogs.py:1652
 #: ../gui/wxpython/gui_core/preferences.py:816
 msgid "Allow output files to overwrite existing files"
 msgstr ""
-#: ../gui/wxpython/modules/vclean.py:158
+#: ../gui/wxpython/modules/vclean.py:158 ../gui/wxpython/modules/vkrige.py:151
 #: ../gui/wxpython/modules/mcalc_builder.py:135
-#: ../gui/wxpython/scripts/vkrige.py:151
 #: ../gui/wxpython/gmodeler/frame.py:1665
 #: ../gui/wxpython/gmodeler/model.py:2535 ../gui/wxpython/gui_core/menu.py:156
 #: ../gui/wxpython/gui_core/forms.py:502
@@ -3550,6 +3549,85 @@
 msgid "Vector cleaning command copied to clipboard"
 msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:32
+msgid "No GRASS-python library found."
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:62
+msgid "Input Data"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:68
+msgid "Point dataset:"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:80
+msgid "Numeric column:"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:91
+msgid "Kriging"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:102 ../gui/wxpython/gmodeler/frame.py:129
+#: ../gui/wxpython/gui_core/forms.py:1777
+msgid "Command output"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:113
+#: ../gui/wxpython/modules/mcalc_builder.py:124
+#: ../gui/wxpython/vnet/dialogs.py:302
+msgid "Output"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:116
+msgid "Name for the output raster map:"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:124
+msgid "Export variance map as well: "
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:276
+msgid "Kriging Module"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:280
+msgid "Ready."
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:304
+msgid "Variogram fitting"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:314
+msgid "Plot/refresh variogram"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:325
+msgid ":"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:350
+msgid "Kriging techniques"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:364
+msgid "Block size:"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:397
+msgid "Auto-fit variogram"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:421
+msgid "Model: "
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:510
+msgid "Work in progress! No functionality provided."
+msgstr ""
 #: ../gui/wxpython/modules/mcalc_builder.py:52
 msgid "GRASS GIS Raster Map Calculator"
 msgstr ""
@@ -3566,11 +3644,6 @@
 msgid "Operators"
 msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:124
-#: ../gui/wxpython/scripts/vkrige.py:113 ../gui/wxpython/vnet/dialogs.py:302
-msgid "Output"
-msgstr ""
 #: ../gui/wxpython/modules/mcalc_builder.py:126
 msgid "Operands"
 msgstr ""
@@ -4183,27 +4256,31 @@
 msgid "No raster or vector map layer selected for querying."
 msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1249 ../gui/wxpython/gcp/mapdisplay.py:463
+#: ../gui/wxpython/mapdisp/frame.py:1253 ../gui/wxpython/gcp/mapdisplay.py:463
 msgid "Zoom to default region"
 msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1250 ../gui/wxpython/gcp/mapdisplay.py:467
+#: ../gui/wxpython/mapdisp/frame.py:1254 ../gui/wxpython/gcp/mapdisplay.py:467
 msgid "Zoom to saved region"
 msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1252
-msgid "Set computational region from display extent"
+#: ../gui/wxpython/mapdisp/frame.py:1256
+msgid "Set computational region extent from display"
 msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1253
+#: ../gui/wxpython/mapdisp/frame.py:1257
+msgid "Set computational region extent interactively"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1258
 msgid "Set computational region from named region"
 msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1255 ../gui/wxpython/gcp/mapdisplay.py:475
+#: ../gui/wxpython/mapdisp/frame.py:1260 ../gui/wxpython/gcp/mapdisplay.py:475
 msgid "Save display geometry to named region"
 msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1256
+#: ../gui/wxpython/mapdisp/frame.py:1261
 msgid "Save computational region to named region"
 msgstr ""
@@ -4871,21 +4948,21 @@
 "for better control of legend and other decorations."
 msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:321
+#: ../gui/wxpython/mapwin/decorations.py:326
 msgid "Show text object"
 msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:331
+#: ../gui/wxpython/mapwin/decorations.py:336
 #: ../gui/wxpython/psmap/dialogs.py:3713
 msgid "Enter text:"
 msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:348
+#: ../gui/wxpython/mapwin/decorations.py:353
 #: ../gui/wxpython/nviz/tools.py:1008
 msgid "Rotation:"
 msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:372
+#: ../gui/wxpython/mapwin/decorations.py:377
 msgid ""
 "Drag text with mouse in pointer mode to position.\n"
 "Double-click to change options"
@@ -4984,28 +5061,28 @@
 msgid "Unable to draw registered graphics. The graphics was unregistered."
 msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1831
+#: ../gui/wxpython/mapwin/buffered.py:1856
 msgid "Zoom to saved region extents"
 msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1833
+#: ../gui/wxpython/mapwin/buffered.py:1858
 msgid "Set compulational region from named region"
 msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1845
+#: ../gui/wxpython/mapwin/buffered.py:1870
 #, python-format
 msgid "Region <%s> not found. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1874
+#: ../gui/wxpython/mapwin/buffered.py:1899
 msgid "Save display extents to region file"
 msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1876
+#: ../gui/wxpython/mapwin/buffered.py:1901
 msgid "Save computational region to region file"
 msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:1886
+#: ../gui/wxpython/mapwin/buffered.py:1911
 #, python-format
 msgid "Region file <%s> already exists. Do you want to overwrite it?"
 msgstr ""
@@ -5453,79 +5530,6 @@
 msgid "Forward: %(forw)s, Backward: %(back)s"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:32
-msgid "No GRASS-python library found."
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:62
-msgid "Input Data"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:68
-msgid "Point dataset:"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:80
-msgid "Numeric column:"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:91
-msgid "Kriging"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:102 ../gui/wxpython/gmodeler/frame.py:129
-#: ../gui/wxpython/gui_core/forms.py:1777
-msgid "Command output"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:116
-msgid "Name for the output raster map:"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:124
-msgid "Export variance map as well: "
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:276
-msgid "Kriging Module"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:280
-msgid "Ready."
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:304
-msgid "Variogram fitting"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:314
-msgid "Plot/refresh variogram"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:325
-msgid ":"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:350
-msgid "Kriging techniques"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:364
-msgid "Block size:"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:397
-msgid "Auto-fit variogram"
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:421
-msgid "Model: "
-msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:510
-msgid "Work in progress! No functionality provided."
-msgstr ""
 #: ../gui/wxpython/gmodeler/frame.py:62
 msgid "GRASS GIS Graphical Modeler"
 msgstr ""
@@ -6250,59 +6254,59 @@
 msgid "Time [%s]"
 msgstr ""
-#: ../gui/wxpython/timeline/frame.py:348 ../gui/wxpython/timeline/frame.py:439
+#: ../gui/wxpython/timeline/frame.py:350 ../gui/wxpython/timeline/frame.py:448
 msgid "Invalid input data"
 msgstr ""
-#: ../gui/wxpython/timeline/frame.py:412
+#: ../gui/wxpython/timeline/frame.py:417
 #, python-format
 msgid "Please specify the space time dataset <%s>."
 msgstr ""
-#: ../gui/wxpython/timeline/frame.py:413
+#: ../gui/wxpython/timeline/frame.py:418
 msgid "Ambiguous dataset name"
 msgstr ""
-#: ../gui/wxpython/timeline/frame.py:491
+#: ../gui/wxpython/timeline/frame.py:500
 #, python-format
 msgid "Space time raster dataset: %s"
 msgstr ""
-#: ../gui/wxpython/timeline/frame.py:493
+#: ../gui/wxpython/timeline/frame.py:502
 #, python-format
 msgid "Space time vector dataset: %s"
 msgstr ""
-#: ../gui/wxpython/timeline/frame.py:495
+#: ../gui/wxpython/timeline/frame.py:504
 #, python-format
 msgid "Space time 3D raster dataset: %s"
 msgstr ""
-#: ../gui/wxpython/timeline/frame.py:497
+#: ../gui/wxpython/timeline/frame.py:506
 #, python-format
 msgid "Mapset: %s"
 msgstr ""
-#: ../gui/wxpython/timeline/frame.py:498
+#: ../gui/wxpython/timeline/frame.py:507
 #, python-format
 msgid "Map name: %s"
 msgstr ""
-#: ../gui/wxpython/timeline/frame.py:499
+#: ../gui/wxpython/timeline/frame.py:508
 #, python-format
 msgid "Start time: %s"
 msgstr ""
-#: ../gui/wxpython/timeline/frame.py:500
+#: ../gui/wxpython/timeline/frame.py:509
 #, python-format
 msgid "End time: %s"
 msgstr ""
-#: ../gui/wxpython/timeline/frame.py:503
+#: ../gui/wxpython/timeline/frame.py:512
 msgid "WARNING: invalid topology"
 msgstr ""
-#: ../gui/wxpython/timeline/frame.py:505
+#: ../gui/wxpython/timeline/frame.py:514
 msgid ""
 "\n"
 "Press Del to dismiss."
