[GRASS-SVN] r60193 - grass/branches/releasebranch_7_0/lib/gis
Sun May 11 13:45:14 PDT 2014
Author: neteler
Date: 2014-05-11 13:45:14 -0700 (Sun, 11 May 2014)
New Revision: 60193
   grass/branches/releasebranch_7_0/lib/gis/gisinit.c
libgis: improve version mismatch compilation warning (modified patch from trac #1467)
Modified: grass/branches/releasebranch_7_0/lib/gis/gisinit.c
--- grass/branches/releasebranch_7_0/lib/gis/gisinit.c	2014-05-11 20:42:41 UTC (rev 60192)
+++ grass/branches/releasebranch_7_0/lib/gis/gisinit.c	2014-05-11 20:45:14 UTC (rev 60193)
@@ -48,8 +48,10 @@
     G_set_program_name(pgm);
     if (strcmp(version, GIS_H_VERSION) != 0)
-	G_fatal_error(_("Incompatible library version for module. "
-			"You need to rebuild GRASS or untangle multiple installations."));
+	G_fatal_error(_("Module built against version %s but "
+			"trying to use version %s."
+			"You need to rebuild GRASS GIS or untangle multiple installations."),
+                        version, GIS_H_VERSION);
     /* Make sure location and mapset are set */
     G_location_path();
@@ -80,9 +82,10 @@
 	return;
     gisinit();
