[GRASS-SVN] r60213 - in grass/trunk: lib/python/temporal temporal/t.support temporal/t.unregister
Mon May 12 16:07:03 PDT 2014
Author: huhabla
Date: 2014-05-12 16:07:02 -0700 (Mon, 12 May 2014)
New Revision: 60213
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
   grass/trunk/lib/python/temporal/register.py
   grass/trunk/lib/python/temporal/space_time_datasets.py
   grass/trunk/lib/python/temporal/temporal_extent.py
   grass/trunk/temporal/t.support/t.support.py
   grass/trunk/temporal/t.unregister/t.unregister.py
API fixes for consistent method naming
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2014-05-12 15:16:51 UTC (rev 60212)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2014-05-12 23:07:02 UTC (rev 60213)
@@ -214,7 +214,7 @@
             self.print_topology_info()
         self.spatial_extent.print_info()
         self.metadata.print_info()
-        datasets = self.get_registered_datasets()
+        datasets = self.get_registered_stds()
         count = 0
         string = ""
         if datasets is not None:
@@ -236,7 +236,7 @@
         self.temporal_extent.print_shell_info()
         self.spatial_extent.print_shell_info()
         self.metadata.print_shell_info()
         count = 0
         string = ""
@@ -875,7 +875,7 @@
         dbif, connected = init_dbif(dbif)
         # Get all datasets in which this map is registered
-        datasets = self.get_registered_datasets(dbif)
+        datasets = self.get_registered_stds(dbif)
         # For each stds in which the map is registered
@@ -899,7 +899,7 @@
         return statement
-    def get_registered_datasets(self, dbif=None):
+    def get_registered_stds(self, dbif=None):
         """!Return all space time dataset ids in which this map is registered
            as as a list of strings, or None if this map is not
            registered in any space time dataset.
@@ -923,7 +923,7 @@
         return datasets
-    def add_dataset_to_register(self, stds_id, dbif=None, execute=True):
+    def add_stds_to_register(self, stds_id, dbif=None, execute=True):
         """!Add a new space time dataset to the register
            @param stds_id The id of the space time dataset to be registered
@@ -937,7 +937,7 @@
         dbif, connected = init_dbif(dbif=dbif)
-        datasets = self.get_registered_datasets(dbif=dbif)
+        datasets = self.get_registered_stds(dbif=dbif)
         if stds_id is None or stds_id == "":
             return ""
@@ -969,7 +969,7 @@
         return statement
-    def remove_dataset_from_register(self, stds_id, dbif=None, execute=True):
+    def remove_stds_from_register(self, stds_id, dbif=None, execute=True):
         """!Remove a space time dataset from the register
            @param stds_id The id of the space time dataset to removed from the registered
@@ -983,7 +983,7 @@
         # Check if no datasets are present
         if datasets is None:
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2014-05-12 15:16:51 UTC (rev 60212)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2014-05-12 23:07:02 UTC (rev 60213)
@@ -1810,7 +1810,7 @@
                                          dbif=dbif)
             # Save the datasets that must be updated
-            datasets = map.get_registered_datasets(dbif)
+            datasets = map.get_registered_stds(dbif)
             if datasets:
                 for dataset in datasets:
                     datatsets_to_modify[dataset] = dataset
@@ -1882,8 +1882,8 @@
         # We need to rename the space time dataset in the maps register table
         if maps:
             for map in maps:
-                map.remove_dataset_from_register(stds_id=old_ident, dbif=dbif)
-                map.add_dataset_to_register(stds_id=ident, dbif=dbif)
+                map.remove_stds_from_register(stds_id=old_ident, dbif=dbif)
+                map.add_stds_to_register(stds_id=ident, dbif=dbif)
         # Execute the accumulated statements
         dbif.execute_transaction(statement)
@@ -2111,7 +2111,7 @@
             return False
         # Register the stds in the map stds register table column
-        statement += map.add_dataset_to_register(stds_id=self.base.get_id(),
+        statement += map.add_stds_to_register(stds_id=self.base.get_id(),
                                                  dbif=dbif, execute=False)
         # Now put the raster name in the stds map register table
@@ -2179,7 +2179,7 @@
         # Remove the space time dataset from the dataset register
         # We need to execute the statement here, otherwise the space time dataset will not be
         # removed correctly
-        map.remove_dataset_from_register(self.base.get_id(),
+        map.remove_stds_from_register(self.base.get_id(),
                                                       dbif=dbif, execute=True)
         # Remove the map from the space time dataset register
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py	2014-05-12 15:16:51 UTC (rev 60212)
+++ grass/trunk/lib/python/temporal/register.py	2014-05-12 23:07:02 UTC (rev 60213)
@@ -243,7 +243,7 @@
             map.select(dbif)
                     if dataset != "":
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py	2014-05-12 15:16:51 UTC (rev 60212)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py	2014-05-12 23:07:02 UTC (rev 60213)
@@ -51,6 +51,7 @@
         >>> rmap.get_temporal_extent_as_tuple()
         (datetime.datetime(1999, 1, 15, 0, 0), None)
         >>> rmap.load()
+        True
         >>> rmap.spatial_extent.print_info()
          +-------------------- Spatial extent ----------------------------------------+
          | North:...................... 80.0
@@ -366,6 +367,7 @@
         >>> r3map.get_temporal_extent_as_tuple()
         >>> r3map.load()
+        True
         >>> r3map.spatial_extent.print_info()
@@ -694,6 +696,7 @@
         >>> vmap.get_temporal_extent_as_tuple()
         >>> vmap.load()
+        True
         >>> vmap.absolute_time.print_info()
          +-------------------- Absolute time -----------------------------------------+
          | Start time:................. 1999-01-15 00:00:00
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py	2014-05-12 15:16:51 UTC (rev 60212)
+++ grass/trunk/lib/python/temporal/temporal_extent.py	2014-05-12 23:07:02 UTC (rev 60213)
@@ -27,7 +27,7 @@
-class AbstractTemporalExtent(SQLDatabaseInterface):
+class TemporalExtent(SQLDatabaseInterface):
     """!This is the abstract time base class for relative and absolute time objects
         It abstract class implements the interface to absolute and relative time.
@@ -42,7 +42,7 @@
         @code
         >>> init()
-        >>> A = AbstractTemporalExtent(table="raster_absolute_time",
+        >>> A = TemporalExtent(table="raster_absolute_time",
         ... ident="soil at PERMANENT", start_time=datetime(2001, 01, 01),
         ... end_time=datetime(2005,01,01) )
         >>> A.id
@@ -58,7 +58,7 @@
         start_time=2001-01-01 00:00:00
         end_time=2005-01-01 00:00:00
         >>> # relative time
         ... ident="soil at PERMANENT", start_time=0, end_time=1 )
         >>> A.id
         'soil at PERMANENT'
@@ -95,14 +95,14 @@
            @code
-           >>> A = AbstractTemporalExtent(start_time=5, end_time=6 )
+           >>> A = TemporalExtent(start_time=5, end_time=6 )
            >>> inter = A.intersect(A)
            >>> inter.print_info()
             | Start time:................. 5
             | End time:................... 6
-           >>> B = AbstractTemporalExtent(start_time=5, end_time=7 )
+           >>> B = TemporalExtent(start_time=5, end_time=7 )
            >>> inter = A.intersect(B)
            >>> inter.print_info()
@@ -112,8 +112,8 @@
-           >>> A = AbstractTemporalExtent(start_time=3, end_time=6 )
+           >>> A = TemporalExtent(start_time=3, end_time=6 )
            >>> inter.print_info()
@@ -123,8 +123,8 @@
-           >>> A = AbstractTemporalExtent(start_time=3, end_time=8 )
-           >>> B = AbstractTemporalExtent(start_time=5, end_time=6 )
+           >>> A = TemporalExtent(start_time=3, end_time=8 )
+           >>> B = TemporalExtent(start_time=5, end_time=6 )
            >>> inter.print_info()
@@ -134,8 +134,8 @@
-           >>> A = AbstractTemporalExtent(start_time=5, end_time=8 )
-           >>> B = AbstractTemporalExtent(start_time=3, end_time=6 )
+           >>> A = TemporalExtent(start_time=5, end_time=8 )
+           >>> B = TemporalExtent(start_time=3, end_time=6 )
            >>> inter.print_info()
@@ -145,8 +145,8 @@
-           >>> A = AbstractTemporalExtent(start_time=5, end_time=None )
+           >>> A = TemporalExtent(start_time=5, end_time=None )
            >>> inter.print_info()
@@ -156,14 +156,14 @@
             | End time:................... None
-           >>> B = AbstractTemporalExtent(start_time=3, end_time=4 )
+           >>> B = TemporalExtent(start_time=3, end_time=4 )
            >>> print inter
            None
-           >>> B = AbstractTemporalExtent(start_time=3, end_time=None )
+           >>> B = TemporalExtent(start_time=3, end_time=None )
            >>> print inter
            None
@@ -176,10 +176,10 @@
             return None
         if self.D["end_time"] is None:
-            return AbstractTemporalExtent(start_time=self.D["start_time"])
+            return TemporalExtent(start_time=self.D["start_time"])
         if extent.D["end_time"] is None:
-            return AbstractTemporalExtent(start_time=extent.D["start_time"])
+            return TemporalExtent(start_time=extent.D["start_time"])
         start = None
         end = None
@@ -199,8 +199,8 @@
                                           unit=self.get_unit())
         elif issubclass(type(self), AbsoluteTemporalExtent):
             return AbsoluteTemporalExtent(start_time=start, end_time=end)
-        elif issubclass(type(self), AbstractTemporalExtent):
-            return AbstractTemporalExtent(start_time=start, end_time=end)
+        elif issubclass(type(self), TemporalExtent):
+            return TemporalExtent(start_time=start, end_time=end)
     def disjoint_union(self, extent):
         """!Creates a disjoint union with this temporal extent and the provided one.
@@ -213,14 +213,14 @@
            @code
            >>> inter.print_info()
            >>> inter = A.disjoint_union(B)
            >>> inter.print_info()
@@ -230,8 +230,8 @@
             | End time:................... 7
            >>> inter.print_info()
             | Start time:................. 3
@@ -241,8 +241,8 @@
            >>> inter.print_info()
@@ -252,8 +252,8 @@
             | End time:................... 8
            >>> inter.print_info()
@@ -263,8 +263,8 @@
            >>> inter.print_info()
@@ -274,8 +274,8 @@
            >>> inter.print_info()
@@ -284,8 +284,8 @@
            >>> inter.print_info()
            >>> inter.print_info()
@@ -294,8 +294,8 @@
            >>> inter.print_info()
-           >>> B = AbstractTemporalExtent(start_time=3, end_time=8 )
+           >>> B = TemporalExtent(start_time=3, end_time=8 )
            >>> inter.print_info()
@@ -304,8 +304,8 @@
            >>> inter.print_info()
            >>> inter.print_info()
@@ -384,8 +384,8 @@
     def union(self, extent):
         """!Creates a union with this temporal extent and the provided one.
@@ -397,14 +397,14 @@
            @code
            >>> print inter
            None
            >>> print inter
            None
@@ -433,8 +433,8 @@
            @code
            >>> A.starts(B)
            True
            >>> B.starts(A)
@@ -465,8 +465,8 @@
            @code
-           >>> A = AbstractTemporalExtent(start_time=5, end_time=7 )
+           >>> A = TemporalExtent(start_time=5, end_time=7 )
            >>> A.started(B)
            True
            >>> B.started(A)
@@ -497,8 +497,8 @@
            @code
-           >>> A = AbstractTemporalExtent(start_time=6, end_time=7 )
+           >>> A = TemporalExtent(start_time=6, end_time=7 )
            >>> A.finishes(B)
            True
            >>> B.finishes(A)
@@ -529,8 +529,8 @@
            @code
-           >>> B = AbstractTemporalExtent(start_time=6, end_time=7 )
+           >>> B = TemporalExtent(start_time=6, end_time=7 )
            >>> A.finished(B)
            True
            >>> B.finished(A)
@@ -561,8 +561,8 @@
            @code
-           >>> A = AbstractTemporalExtent(start_time=8, end_time=9 )
+           >>> A = TemporalExtent(start_time=8, end_time=9 )
            >>> A.after(B)
            True
            >>> B.after(A)
@@ -595,8 +595,8 @@
            @code
-           >>> B = AbstractTemporalExtent(start_time=8, end_time=9 )
+           >>> B = TemporalExtent(start_time=8, end_time=9 )
            >>> A.before(B)
            True
            >>> B.before(A)
@@ -632,14 +632,14 @@
            @code
-           >>> B = AbstractTemporalExtent(start_time=7, end_time=9 )
+           >>> B = TemporalExtent(start_time=7, end_time=9 )
            >>> A.adjacent(B)
            True
            >>> B.adjacent(A)
            True
-           >>> B = AbstractTemporalExtent(start_time=3, end_time=5 )
+           >>> B = TemporalExtent(start_time=3, end_time=5 )
            >>> A.adjacent(B)
            True
            >>> B.adjacent(A)
@@ -671,8 +671,8 @@
            @code
            >>> A.follows(B)
            True
            >>> B.follows(A)
@@ -703,8 +703,8 @@
            @code
            >>> A.precedes(B)
            True
            >>> B.precedes(A)
@@ -734,8 +734,8 @@
            @code
-           >>> B = AbstractTemporalExtent(start_time=4, end_time=9 )
+           >>> B = TemporalExtent(start_time=4, end_time=9 )
            >>> A.during(B)
            True
            >>> B.during(A)
@@ -776,8 +776,8 @@
            @code
-           >>> A = AbstractTemporalExtent(start_time=4, end_time=9 )
-           >>> B = AbstractTemporalExtent(start_time=5, end_time=8 )
+           >>> A = TemporalExtent(start_time=4, end_time=9 )
+           >>> B = TemporalExtent(start_time=5, end_time=8 )
            >>> A.contains(B)
            True
            >>> B.contains(A)
@@ -818,8 +818,8 @@
            @code
            >>> A.equal(B)
            True
            >>> B.equal(A)
@@ -856,15 +856,15 @@
            @code
-           >>> B = AbstractTemporalExtent(start_time=6, end_time=8 )
+           >>> B = TemporalExtent(start_time=6, end_time=8 )
            >>> A.overlaps(B)
            True
            >>> B.overlaps(A)
            False
            >>> A.overlaps(B)
            False
            >>> B.overlaps(A)
@@ -897,15 +897,15 @@
            @code
-           >>> A = AbstractTemporalExtent(start_time=6, end_time=8 )
+           >>> A = TemporalExtent(start_time=6, end_time=8 )
            >>> A.overlapped(B)
            True
            >>> B.overlapped(A)
            False
            >>> A.overlapped(B)
            False
            >>> B.overlapped(A)
@@ -1046,25 +1046,25 @@
-class AbsoluteTemporalExtent(AbstractTemporalExtent):
+class AbsoluteTemporalExtent(TemporalExtent):
     """!This is the absolute time class for all maps and spacetime datasets
         start_time and end_time must be of type datetime
     def __init__(self, table=None, ident=None, start_time=None, end_time=None):
-        AbstractTemporalExtent.__init__(
+        TemporalExtent.__init__(
             self, table, ident, start_time, end_time)
     def print_info(self):
         """!Print information about this class in human readable style"""
         #      0123456789012345678901234567890
         print " +-------------------- Absolute time -----------------------------------------+"
-        AbstractTemporalExtent.print_info(self)
+        TemporalExtent.print_info(self)
     def print_shell_info(self):
         """!Print information about this class in shell style"""
-        AbstractTemporalExtent.print_shell_info(self)
+        TemporalExtent.print_shell_info(self)
@@ -1212,7 +1212,7 @@
-class RelativeTemporalExtent(AbstractTemporalExtent):
+class RelativeTemporalExtent(TemporalExtent):
     """!This is the relative time class for all maps and space time datasets
         start_time and end_time must be of type integer
@@ -1247,7 +1247,7 @@
     def __init__(self, table=None, ident=None, start_time=None, end_time=None,
                  unit=None):
         self.set_unit(unit)
@@ -1287,7 +1287,7 @@
         if self.D["unit"] != map.D["unit"]:
             return None
-        return AbstractTemporalExtent.temporal_relation(self, map)
+        return TemporalExtent.temporal_relation(self, map)
     # Properties
     unit = property(fget=get_unit, fset=set_unit)
@@ -1296,12 +1296,12 @@
         print " +-------------------- Relative time -----------------------------------------+"
         print " | Relative time unit:......... " + str(self.get_unit())
         print "unit=" + str(self.get_unit())
Modified: grass/trunk/temporal/t.support/t.support.py
--- grass/trunk/temporal/t.support/t.support.py	2014-05-12 15:16:51 UTC (rev 60212)
+++ grass/trunk/temporal/t.support/t.support.py	2014-05-12 23:07:02 UTC (rev 60213)
@@ -130,7 +130,7 @@
             else:
                 # Delete the map from the temporal database
                 # We need to update all effected space time datasets
                 if datasets:
                         dataset_dict[dataset] = dataset
Modified: grass/trunk/temporal/t.unregister/t.unregister.py
--- grass/trunk/temporal/t.unregister/t.unregister.py	2014-05-12 15:16:51 UTC (rev 60212)
+++ grass/trunk/temporal/t.unregister/t.unregister.py	2014-05-12 23:07:02 UTC (rev 60213)
@@ -131,7 +131,7 @@
             else:
                 # We need to update all datasets after the removement of maps
                 map.metadata.select(dbif)
                 # Store all unique dataset ids in a dictionary
                 if datasets:
