[GRASS-SVN] r60216 - grass/trunk/lib/init
    svn_grass at osgeo.org
    Mon May 12 21:15:54 PDT 2014
Author: hcho
Date: 2014-05-12 21:15:54 -0700 (Mon, 12 May 2014)
New Revision: 60216
Removed:
   grass/trunk/lib/init/prompt.py
   grass/trunk/lib/init/grass.py
Replaced prompt.py with a bash function for bash startup.
Fixed ticket #2284.
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py	2014-05-13 03:28:43 UTC (rev 60215)
+++ grass/trunk/lib/init/grass.py	2014-05-13 04:15:54 UTC (rev 60216)
@@ -1113,8 +1113,17 @@
     else:
         f.write("PS1='GRASS %s (%s):\w > '\n" % (grass_version, location_name))
-    f.write("PROMPT_COMMAND=\"'%s'\"\n" % os.path.join(gisbase, 'etc',
-                                                       'prompt.py'))
+    f.write("""grass_prompt() {
+	LOCATION="`g.gisenv GISDBASE`/`g.gisenv LOCATION_NAME`/`g.gisenv MAPSET`"
+	if test -d "$LOCATION/grid3/G3D_MASK" && test -f "$LOCATION/cell/MASK" ; then
+		echo [Raster and Volume MASKs present]
+	elif test -f "$LOCATION/cell/MASK" ; then
+		echo [Raster MASK present]
+	elif test -d "$LOCATION/grid3/G3D_MASK" ; then
+		echo [Volume MASK present]
+	fi
+PROMPT_COMMAND=grass_prompt\n""")
     # read environmental variables
     path = os.path.join(userhome, ".grass.bashrc") # left for backward compatibility
Deleted: grass/trunk/lib/init/prompt.py
--- grass/trunk/lib/init/prompt.py	2014-05-13 03:28:43 UTC (rev 60215)
+++ grass/trunk/lib/init/prompt.py	2014-05-13 04:15:54 UTC (rev 60216)
@@ -1,29 +0,0 @@
-#!/usr/bin/env python
-import os
-import sys
-from grass.script import core as grass
-gisenv = grass.gisenv()
-import gettext
-gettext.install('grasslibs', os.path.join(gisenv['GISDBASE'], 'locale'), unicode = True)
-location = os.path.join(gisenv['GISDBASE'], gisenv['LOCATION_NAME'], gisenv['MAPSET'])
-has_mask   = os.path.isfile(os.path.join(location, 'cell', 'MASK'))
-has_mask3d = os.path.isdir(os.path.join(location, 'grid3', 'G3D_MASK'))
-def main():
-    if has_mask and has_mask3d:
-        grass.info(_("[Raster and Volume MASKs present]"))
-    elif has_mask:
-        grass.info(_("[Raster MASK present]"))
-    elif has_mask3d:
-        grass.info(_("[Volume MASK present]"))
-    return 0
-if __name__ == "__main__":
-    sys.exit(main())
