[GRASS-SVN] r60258 - in grass/branches/releasebranch_7_0/raster: r.li/r.li.daemon r.surf.random
Fri May 16 00:30:52 PDT 2014
Author: neteler
Date: 2014-05-16 00:30:52 -0700 (Fri, 16 May 2014)
New Revision: 60258
   grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c
   grass/branches/releasebranch_7_0/raster/r.surf.random/main.c
i18n: minor message standardization
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c	2014-05-16 07:08:48 UTC (rev 60257)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c	2014-05-16 07:30:52 UTC (rev 60258)
@@ -174,10 +174,10 @@
 	Rast_short_history(output, "raster", &history);
 	Rast_command_history(&history);
 	Rast_write_history(output, &history);
-	G_message(_("Raster map <%s> created."), output);
+	G_done_msg(_("Raster map <%s> created."), output);
     } else {
 	/* text file output */
-	G_message("Result written to ASCII file <%s>", out);
+	G_done_msg("Result written to text file <%s>", out);
     return 1;
Modified: grass/branches/releasebranch_7_0/raster/r.surf.random/main.c
--- grass/branches/releasebranch_7_0/raster/r.surf.random/main.c	2014-05-16 07:08:48 UTC (rev 60257)
+++ grass/branches/releasebranch_7_0/raster/r.surf.random/main.c	2014-05-16 07:30:52 UTC (rev 60258)
@@ -63,7 +63,7 @@
     randsurf(out->answer, atoi(min->answer), atoi(max->answer),
 	     i_flag->answer);
-    G_done_msg(_("Raster map <%s> generated."), out->answer);
+    G_done_msg(_("Raster map <%s> created."), out->answer);
     exit(EXIT_SUCCESS);
