[GRASS-SVN] r60293 - grass-addons/grass7/raster/r.stream.basins
Sat May 17 13:57:41 PDT 2014
Author: hellik
Date: 2014-05-17 13:57:41 -0700 (Sat, 17 May 2014)
New Revision: 60293
   grass-addons/grass7/raster/r.stream.basins/main.c
   grass-addons/grass7/raster/r.stream.basins/r.stream.basins.html
r.stream.basins: clean up/cosmetics
Modified: grass-addons/grass7/raster/r.stream.basins/main.c
--- grass-addons/grass7/raster/r.stream.basins/main.c	2014-05-17 19:49:47 UTC (rev 60292)
+++ grass-addons/grass7/raster/r.stream.basins/main.c	2014-05-17 20:57:41 UTC (rev 60293)
@@ -6,7 +6,7 @@
  * PURPOSE:      Calculate basins according user' input data.
  *               It uses multiple type of inputs:
  * 		 r.stream.order, r.stream.extract or r.watershed stream  map
- *               list of categoires to create basins (require stream map);
+ *               list of categories to create basins (require stream map);
  *               vector file containing outputs;
  *               list of coordinates;
  *               with analogous  direction map;
@@ -36,7 +36,7 @@
     struct Flag *flag_zerofill, *flag_cats, *flag_lasts, *flag_segmentation;
-    int b_test = 0;		/* test which option has been choosed: like chmod */
+    int b_test = 0;		/* test which option has been chosen: like chmod */
     int segmentation, zerofill, lasts, cats;
     int i, outlets_num = 0;
     int max_number_of_streams;
@@ -81,7 +81,7 @@
     opt_swapsize->key = "memory";
     opt_swapsize->type = TYPE_INTEGER;
     opt_swapsize->answer = "300";
-    opt_swapsize->description = _("Max memory used in memory swap mode (MB)");
+    opt_swapsize->description = _("Maximum memory used in memory swap mode (MB)");
     opt_swapsize->guisection = _("Memory settings");
     opt_basins = G_define_standard_option(G_OPT_R_OUTPUT);
Modified: grass-addons/grass7/raster/r.stream.basins/r.stream.basins.html
--- grass-addons/grass7/raster/r.stream.basins/r.stream.basins.html	2014-05-17 19:49:47 UTC (rev 60292)
+++ grass-addons/grass7/raster/r.stream.basins/r.stream.basins.html	2014-05-17 20:57:41 UTC (rev 60293)
@@ -6,8 +6,7 @@
 with three methods:
 <ul>
-<li>Using coordinates: this option simply copies functionality of
-    <a href="r.water.outlet.html">r.water.outlet</a>.
+<li>Using coordinates: this option simply copies functionality of <em>r.water.outlet</em>.
 <li>Using vector points: it allow to manually point outlets with any method
 <li>Using streams (most advanced) it allow on lots of modifications. See
 examples for more details.
@@ -21,7 +20,7 @@
 which basins are to be created (cats option). Module is prepared to
 work with output data of <em>r.watershed</em>, <em>r.stream.extract</em>,
 <em>r.stream.order</em> also with modification done by
-<em>r.reclass</em> and <em>r.mapcalc</em>. r.stream.basin can delineate
+<em>r.reclass</em> and <em>r.mapcalc</em>. <em>r.stream.basin</em> can delineate
 basins according outlets marked by raster streams, and polygons,
 vector points and numerical coordinates. If outlets are marked by
 points or coordinates it delineates basins which cells contribute to
@@ -45,8 +44,8 @@
 each basin (do not work in vector point mode).
 </dd>
 <dt><b>-l</b></dt>
-<dd>By default r.stream.basins create basins for all unique streams. This option
-delineate basins only for last streams ignoring upstreams (do not work in vector
+<dd>By default <em>r.stream.basins</em> create basins for all unique streams. This option
+delineate basins only for last streams ignoring upstream (do not work in vector
 point mode).
 </dd>
@@ -68,7 +67,7 @@
 <dt><b>coors</b></dt>
 <dd>East and north coordinates for basin outlet. It can delineate only
 one basin using that option. This option simply copies functionality of
-<a href="r.water.outlet.html">r.water.outlet</a>.
+<em>r.water.outlet</em>.
 </dd>
 <dt><b>stream_rast</b></dt>
 <dd>Stream network: name of input stream map on which ordering will
@@ -79,7 +78,7 @@
 module. Stream background shall have NULL value or zero value.
 Background values of NULL are by default produced by <em>r.watershed</em>
 and <em>r.stream.extract</em>. If not 0 or NULL use
-<a href="r.mapcalc.html">r.mapcalc</a> to set background values to null. </dd>
+<em>>r.mapcalc</em> to set background values to null. </dd>
 <dt><b>cats</b></dt>
 <dd>Stream categories to delineate basins for: All categories which are not in
@@ -111,11 +110,11 @@
 Module can work only if direction map, stream map and region map has same
 settings. It is also required that stream map and direction map come from the
 same source. For lots of reason this limitation probably cannot be omitted.
-This means, if stream map comes from r.stream.extract, also direction map from
+This means, if stream map comes from <em>r.stream.extract</em>, also direction map from
 <em>r.stream.extract</em> must be used. If stream network was generated
 with MFD method, also MFD direction map must be used. Nowadays, if direction
 map comes from <em>r.stream.extract</em>, it must be patched by direction
-map from <em>r.watershed</em>. (with <em>r.patch</em>).
+map from <em>r.watershed</em> (with <em>r.patch</em>).
 <h2>EXAMPLES</h2>
 <p>
@@ -188,6 +187,7 @@
 <a href="r.mapcalc.html">r.mapcalc</a>,
 <a href="r.reclass.html">r.reclass</a>,
 <a href="r.patch.html">r.patch</a>
+<a href="r.water.outlet.html">r.water.outlet</a>
 </em>
 <h2>AUTHOR</h2>
