[GRASS-SVN] r60308 - in grass/trunk/raster: r.stream.channel r.stream.distance r.stream.order r.stream.segment r.stream.slope r.stream.snap r.stream.stats
Sun May 18 01:44:24 PDT 2014
Author: hcho
Date: 2014-05-18 01:44:24 -0700 (Sun, 18 May 2014)
New Revision: 60308
   grass/trunk/raster/r.stream.channel/main.c
   grass/trunk/raster/r.stream.distance/main.c
   grass/trunk/raster/r.stream.order/main.c
   grass/trunk/raster/r.stream.segment/main.c
   grass/trunk/raster/r.stream.slope/main.c
   grass/trunk/raster/r.stream.snap/main.c
   grass/trunk/raster/r.stream.stats/main.c
r.stream.*: Name of input/Name for output
Modified: grass/trunk/raster/r.stream.channel/main.c
--- grass/trunk/raster/r.stream.channel/main.c	2014-05-18 08:05:51 UTC (rev 60307)
+++ grass/trunk/raster/r.stream.channel/main.c	2014-05-18 08:44:24 UTC (rev 60308)
@@ -61,11 +61,11 @@
     in_stm_opt = G_define_standard_option(G_OPT_R_INPUT);
     in_stm_opt->key = "stream_rast";
-    in_stm_opt->description = _("Name for input raster map with stream network");
+    in_stm_opt->description = _("Name of input raster map with stream network");
     in_dir_opt = G_define_standard_option(G_OPT_R_INPUT);
     in_dir_opt->key = "direction";
-    in_dir_opt->description = _("Name for input raster map with flow direction");
+    in_dir_opt->description = _("Name of input raster map with flow direction");
     in_elev_opt = G_define_standard_option(G_OPT_R_ELEV);
Modified: grass/trunk/raster/r.stream.distance/main.c
--- grass/trunk/raster/r.stream.distance/main.c	2014-05-18 08:05:51 UTC (rev 60307)
+++ grass/trunk/raster/r.stream.distance/main.c	2014-05-18 08:44:24 UTC (rev 60308)
@@ -57,12 +57,12 @@
-    in_stm_opt->description = _("Name for input raster map with stream network "
+    in_stm_opt->description = _("Name of input raster map with stream network "
                                 "(in outlet mode is the name for outlet raster map)");
     in_elev_opt->required = NO;
Modified: grass/trunk/raster/r.stream.order/main.c
--- grass/trunk/raster/r.stream.order/main.c	2014-05-18 08:05:51 UTC (rev 60307)
+++ grass/trunk/raster/r.stream.order/main.c	2014-05-18 08:44:24 UTC (rev 60308)
@@ -29,7 +29,7 @@
     IO input[] = {
-        {"stream_rast", YES, _("Name for input raster map with stream network")},
+        {"stream_rast", YES, _("Name of input raster map with stream network")},
 	{"direction", YES, _("Name of input flow direction raster map")},
 	{"elevation", NO, _("Name of input elevation raster map")},
 	{"accumulation", NO, _("Name of input accumulation raster map")}
Modified: grass/trunk/raster/r.stream.segment/main.c
--- grass/trunk/raster/r.stream.segment/main.c	2014-05-18 08:05:51 UTC (rev 60307)
+++ grass/trunk/raster/r.stream.segment/main.c	2014-05-18 08:44:24 UTC (rev 60308)
@@ -61,11 +61,11 @@
Modified: grass/trunk/raster/r.stream.slope/main.c
--- grass/trunk/raster/r.stream.slope/main.c	2014-05-18 08:05:51 UTC (rev 60307)
+++ grass/trunk/raster/r.stream.slope/main.c	2014-05-18 08:44:24 UTC (rev 60308)
@@ -77,7 +77,7 @@
     in_elev_opt = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/raster/r.stream.snap/main.c
--- grass/trunk/raster/r.stream.snap/main.c	2014-05-18 08:05:51 UTC (rev 60307)
+++ grass/trunk/raster/r.stream.snap/main.c	2014-05-18 08:44:24 UTC (rev 60308)
@@ -55,12 +55,12 @@
     in_points_opt->description = _("Name of input vector points map");
     out_points_opt = G_define_standard_option(G_OPT_V_OUTPUT);
-    out_points_opt->description = _("Name of output vector points map");
+    out_points_opt->description = _("Name for output vector points map");
     in_stream_opt = G_define_standard_option(G_OPT_R_INPUT);
     in_stream_opt->key = "stream_rast";
     in_stream_opt->required = NO;
-    in_stream_opt->description = _("Name for input raster map with stream network");
+    in_stream_opt->description = _("Name of input raster map with stream network");
     in_stream_opt->guisection = _("Input maps");
     in_accum_opt = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/raster/r.stream.stats/main.c
--- grass/trunk/raster/r.stream.stats/main.c	2014-05-18 08:05:51 UTC (rev 60307)
+++ grass/trunk/raster/r.stream.stats/main.c	2014-05-18 08:44:24 UTC (rev 60308)
@@ -57,7 +57,7 @@
