[GRASS-SVN] r60319 - in grass/trunk: locale/po vector/v.edit vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.where vector/v.net vector/v.support
Sun May 18 09:12:33 PDT 2014
Author: hcho
Date: 2014-05-18 09:12:33 -0700 (Sun, 18 May 2014)
New Revision: 60319
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grasswxpy_ko.po
   grass/trunk/vector/v.edit/args.c
   grass/trunk/vector/v.lrs/v.lrs.create/main.c
   grass/trunk/vector/v.lrs/v.lrs.where/main.c
   grass/trunk/vector/v.net/args.c
   grass/trunk/vector/v.support/main.c
Reverted 60318 because of mixed commits
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2014-05-18 16:06:18 UTC (rev 60318)
+++ grass/trunk/locale/po/grassmods_ko.po	2014-05-18 16:12:33 UTC (rev 60319)
@@ -18311,9 +18311,9 @@
 msgstr "출력할 격자지도"
 #: ../raster/r.colors/edit_colors.c:466
-#, c-format
+#, fuzzy, c-format
 msgid "Color table for %s map <%s> set to '%s'"
-msgstr "%s지도 <%s>를 위한 색상표가 '%s'로 설정되었습니다"
+msgstr "출력할 격자지도"
 #: ../raster/r.colors/rules.c:40
 #, c-format
@@ -29538,8 +29538,8 @@
 #, c-format
 msgid "%d lost"
 msgid_plural "%d lost"
-msgstr[0] "%d개를 잃어 버렸습니다"
-msgstr[1] "%d개를 잃어 버렸습니다"
+msgstr[0] ""
+msgstr[1] ""
 #. GTC %s will be replaced with a message about lost points.
 #: ../vector/v.lrs/v.lrs.segment/main.c:362
@@ -32250,34 +32250,34 @@
 msgstr ""
 #: ../vector/v.segment/main.c:257
-#, c-format
+#, fuzzy, c-format
 msgid "%d point read from input"
 msgid_plural "%d points read from input"
-msgstr[0] "입력으로부터 %d개의 점을 읽었습니다"
-msgstr[1] "입력으로부터 %d개의 점을 읽었습니다"
+msgstr[0] "출력할 격자지도"
+msgstr[1] "출력할 격자지도"
 #. GTC %s is replaced with message indicating number of lost points.
 #: ../vector/v.segment/main.c:263
-#, c-format
+#, fuzzy, c-format
 msgid "%d point written to output map (%s)"
 msgid_plural "%d points written to output map (%s)"
-msgstr[0] "%d개의 점을 출력지도로 썼습니다 (%s)"
-msgstr[1] "%d개의 점을 출력지도로 썼습니다 (%s)"
 #: ../vector/v.segment/main.c:268
-#, c-format
+#, fuzzy, c-format
 msgid "%d line read from input"
 msgid_plural "%d lines read from input"
-msgstr[0] "입력으로부터 %d개의 선을 읽었습니다"
-msgstr[1] "입력으로부터 %d개의 선을 읽었습니다"
 #. GTC %s is replaced with message indicating number of lost lines.
 #: ../vector/v.segment/main.c:274
-#, c-format
+#, fuzzy, c-format
 msgid "%d line written to output map (%s)"
 msgid_plural "%d lines written to output map (%s)"
-msgstr[0] "%d개의 선을 출력지도로 썼습니다 (%s)"
-msgstr[1] "%d개의 선을 출력지도로 썼습니다 (%s)"
 #: ../vector/v.to.3d/trans3.c:45 ../vector/v.to.3d/trans2.c:43
 #, c-format
Modified: grass/trunk/locale/po/grasswxpy_ko.po
--- grass/trunk/locale/po/grasswxpy_ko.po	2014-05-18 16:06:18 UTC (rev 60318)
+++ grass/trunk/locale/po/grasswxpy_ko.po	2014-05-18 16:12:33 UTC (rev 60319)
@@ -13462,11 +13462,11 @@
 #: ../gui/wxpython/gui_core/query.py:60
 msgid "Copy all to clipboard"
-msgstr "모두 클립보드로 복사"
+msgstr ""
 #: ../gui/wxpython/gui_core/query.py:63
 msgid "Redirect to console"
-msgstr "콘솔로 보내기"
+msgstr ""
 #: ../gui/wxpython/gui_core/query.py:111 ../gui/wxpython/gui_core/query.py:112
 #, python-format
@@ -13496,7 +13496,7 @@
 #: ../gui/wxpython/gui_core/query.py:222
 msgid "east, north"
-msgstr "동, 북"
+msgstr ""
 #: ../gui/wxpython/gui_core/query.py:233
 msgid "Nothing found"
Modified: grass/trunk/vector/v.edit/args.c
--- grass/trunk/vector/v.edit/args.c	2014-05-18 16:06:18 UTC (rev 60318)
+++ grass/trunk/vector/v.edit/args.c	2014-05-18 16:12:33 UTC (rev 60319)
@@ -99,7 +99,7 @@
 	_("Difference in x,y,z direction for moving feature or vertex");
     params->maxdist = G_define_option();
-    params->maxdist->key = "threshold";
+    params->maxdist->key = "thresh";
     params->maxdist->type = TYPE_DOUBLE;
     params->maxdist->required = NO;
     params->maxdist->multiple = YES;
Modified: grass/trunk/vector/v.lrs/v.lrs.create/main.c
--- grass/trunk/vector/v.lrs/v.lrs.create/main.c	2014-05-18 16:06:18 UTC (rev 60318)
+++ grass/trunk/vector/v.lrs/v.lrs.create/main.c	2014-05-18 16:12:33 UTC (rev 60319)
@@ -224,7 +224,7 @@
     table_opt->description = _("New table is created by this module");
     thresh_opt = G_define_option();
-    thresh_opt->key = "threshold";
+    thresh_opt->key = "thresh";
     thresh_opt->type = TYPE_DOUBLE;
     thresh_opt->required = NO;
     thresh_opt->answer = "1";
Modified: grass/trunk/vector/v.lrs/v.lrs.where/main.c
--- grass/trunk/vector/v.lrs/v.lrs.where/main.c	2014-05-18 16:06:18 UTC (rev 60318)
+++ grass/trunk/vector/v.lrs/v.lrs.where/main.c	2014-05-18 16:12:33 UTC (rev 60319)
@@ -101,7 +101,7 @@
     table_opt->description = _("Name of the reference system table");
     thresh_opt->answer = "1000";
Modified: grass/trunk/vector/v.net/args.c
--- grass/trunk/vector/v.net/args.c	2014-05-18 16:06:18 UTC (rev 60318)
+++ grass/trunk/vector/v.net/args.c	2014-05-18 16:12:33 UTC (rev 60319)
@@ -63,7 +63,7 @@
     opt->nfield_opt->guisection = _("Nodes");
     opt->thresh_opt = G_define_option();
-    opt->thresh_opt->key = "threshold";
+    opt->thresh_opt->key = "thresh";
     opt->thresh_opt->type = TYPE_DOUBLE;
     opt->thresh_opt->required = NO;
     opt->thresh_opt->multiple = NO;
Modified: grass/trunk/vector/v.support/main.c
--- grass/trunk/vector/v.support/main.c	2014-05-18 16:06:18 UTC (rev 60318)
+++ grass/trunk/vector/v.support/main.c	2014-05-18 16:12:33 UTC (rev 60319)
@@ -95,7 +95,7 @@
     zone->description = _("Vector map projection zone");
     thresh = G_define_option();
-    thresh->key = "threshold";
+    thresh->key = "thresh";
     thresh->type = TYPE_DOUBLE;
     thresh->required = NO;
     thresh->description =
