[GRASS-SVN] r60326 - in grass/branches/releasebranch_7_0/gui/wxpython: gui_core mapswipe mapwin
Sun May 18 11:30:16 PDT 2014
Author: annakrat
Date: 2014-05-18 11:30:16 -0700 (Sun, 18 May 2014)
New Revision: 60326
   grass/branches/releasebranch_7_0/gui/wxpython/gui_core/mapdisp.py
   grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/frame.py
   grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/toolbars.py
   grass/branches/releasebranch_7_0/gui/wxpython/mapwin/base.py
wxGUI/mapswipe: add query tool (merge from trunk r60290)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/mapdisp.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/mapdisp.py	2014-05-18 18:20:34 UTC (rev 60325)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/mapdisp.py	2014-05-18 18:30:16 UTC (rev 60326)
@@ -587,6 +587,11 @@
         self.GetFirstWindow().SetModePointer()
         self.GetSecondWindow().SetModePointer()
+    def OnQuery(self, event):
+        """!Set query mode"""
+        self.GetFirstWindow().SetModeQuery()
+        self.GetSecondWindow().SetModeQuery()
     def OnRender(self, event):
         """!Re-render map composition (each map layer)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/frame.py	2014-05-18 18:20:34 UTC (rev 60325)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/frame.py	2014-05-18 18:30:16 UTC (rev 60326)
@@ -30,6 +30,7 @@
 from core.gcmd          import GError, GMessage
 from core.utils import _
 from core.layerlist import LayerListToRendererConverter
+from gui_core.query import QueryDialog, PrepareQueryResults
 from mapswipe.toolbars  import SwipeMapToolbar, SwipeMainToolbar, SwipeMiscToolbar
 from mapswipe.mapwindow import SwipeBufferedWindow
@@ -71,6 +72,10 @@
         self.secondMapWindow = SwipeBufferedWindow(parent = self.splitter, giface = self._giface,
                                                    properties=self.mapWindowProperties,
                                                    Map = self.secondMap)
+        # bind query signal
+        self.firstMapWindow.mapQueried.connect(self.Query)
+        self.secondMapWindow.mapQueried.connect(self.Query)
         self.MapWindow = self.firstMapWindow # current by default
         self.firstMapWindow.zoomhistory = self.secondMapWindow.zoomhistory
         self.SetBindRegions(True)
@@ -100,6 +105,7 @@
         self._inputDialog = None
         self._preferencesDialog = None
+        self._queryDialog = None
         # default action in map toolbar
         self.GetMapToolbar().SelectDefault()
@@ -602,6 +608,75 @@
             self.GetFirstWindow().SetRasterNameText('', 101)
             self.GetSecondWindow().SetRasterNameText('', 102)
+    def Query(self, x, y):
+        """!Query active layers from both mapwindows.
+        @param x,y coordinates
+        rasters = ([layer.GetName() for layer in
+                    self.GetFirstMap().GetListOfLayers(ltype='raster', active=True)],
+                   [layer.GetName() for layer in
+                    self.GetSecondMap().GetListOfLayers(ltype='raster', active=True)])
+        vectors = ([layer.GetName() for layer in
+                    self.GetFirstMap().GetListOfLayers(ltype='vector', active=True)],
+                    self.GetSecondMap().GetListOfLayers(ltype='vector', active=True)])
+        if not (rasters[0] + rasters[1] + vectors[0] + vectors[1]):
+            GMessage(parent=self,
+                     message=_('No raster or vector map layer selected for querying.'))
+            return
+        # set query snap distance for v.what at map unit equivalent of 10 pixels
+        qdist = 10.0 * ((self.GetFirstMap().region['e'] -
+                         self.GetFirstMap().region['w']) / self.GetFirstMap().width)
+        east, north = self.GetFirstWindow().Pixel2Cell((x, y))
+        # use display region settings instead of computation region settings
+        self.tmpreg = os.getenv("GRASS_REGION")
+        os.environ["GRASS_REGION"] = self.GetFirstMap().SetRegion(windres=False)
+        result = []
+        if rasters[0]:
+            result.extend(grass.raster_what(map=rasters[0], coord=(east, north)))
+        if vectors[0]:
+            result.extend(grass.vector_what(map=vectors[0], coord=(east, north), distance=qdist))
+        if rasters[1]:
+            result.extend(grass.raster_what(map=rasters[1], coord=(east, north)))
+        if vectors[1]:
+            result.extend(grass.vector_what(map=vectors[1], coord=(east, north), distance=qdist))
+        self._QueryMapDone()
+        result = PrepareQueryResults(coordinates=(east, north), result=result)
+        if self._queryDialog:
+            self._queryDialog.Raise()
+            self._queryDialog.SetData(result)
+        else:
+            self._queryDialog = QueryDialog(parent=self, data=result)
+            self._queryDialog.Bind(wx.EVT_CLOSE, self._oncloseQueryDialog)
+            self._queryDialog.redirectOutput.connect(lambda output: self._giface.WriteLog(output))
+            self._queryDialog.Show()
+    def _oncloseQueryDialog(self, event):
+        event.Skip()
+    def _QueryMapDone(self):
+        """!Restore settings after querying (restore GRASS_REGION)
+        if hasattr(self, "tmpreg"):
+            if self.tmpreg:
+                os.environ["GRASS_REGION"] = self.tmpreg
+            elif 'GRASS_REGION' in os.environ:
+                del os.environ["GRASS_REGION"]
+            del self.tmpreg
     def GetMapToolbar(self):
         """!Returns toolbar with zooming tools"""
         return self.toolbars['swipeMap']
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/toolbars.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/toolbars.py	2014-05-18 18:20:34 UTC (rev 60325)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapswipe/toolbars.py	2014-05-18 18:30:16 UTC (rev 60326)
@@ -23,12 +23,15 @@
-swipeIcons = {
-        'tools': MetaIcon(img = 'tools', label = _("Tools")),
-        'quit' : BaseIcons['quit'].SetLabel(_("Quit Map Swipe")),
-        'addRast' : BaseIcons['addRast'].SetLabel(_("Select raster maps")),
+swipeIcons = {'tools': MetaIcon(img='tools', label=_("Tools")),
+              'quit': BaseIcons['quit'].SetLabel(_("Quit Map Swipe")),
+              'addRast': BaseIcons['addRast'].SetLabel(_("Select raster maps")),
+              'query': MetaIcon(img='info',
+                                label=_('Query raster/vector map(s)'),
+                                desc=_('Query selected raster/vector map(s)')),
 class SwipeMapToolbar(BaseToolbar):
     """!Map toolbar (to control map zoom and rendering)
@@ -36,18 +39,18 @@
         """!Map toolbar constructor
         BaseToolbar.__init__(self, parent, toolSwitcher)
         self.InitToolbar(self._toolbarData())
         self._default = self.pan
         # realize the toolbar
         self.Realize()
-        for tool in (self.pointer, self.pan, self.zoomIn, self.zoomOut):
+        for tool in (self.pointer, self.query, self.pan, self.zoomIn, self.zoomOut):
             self.toolSwitcher.AddToolToGroup(group='mouseUse', toolbar=self, tool=tool)
         self.EnableTool(self.zoomBack, False)
     def _toolbarData(self):
         """!Returns toolbar data (name, icon, handler)"""
         # BaseIcons are a set of often used icons. It is possible
@@ -59,13 +62,16 @@
                                       self.parent.OnRender),
                                      ("erase", icons["erase"],
                                       self.parent.OnErase),
-                                     (None, ), # creates separator
+                                     (None, ),  # creates separator
                                      ("pointer", icons["pointer"],
                                       self.parent.OnPointer,
                                       wx.ITEM_CHECK),
+                                     ("query", swipeIcons["query"],
+                                      self.parent.OnQuery,
+                                      wx.ITEM_CHECK),
                                      ("pan", icons["pan"],
                                       self.parent.OnPan,
-                                      wx.ITEM_CHECK), # toggle tool
+                                      wx.ITEM_CHECK),  # toggle tool
                                      ("zoomIn", icons["zoomIn"],
                                       self.parent.OnZoomIn,
                                       wx.ITEM_CHECK),
@@ -80,14 +86,15 @@
                                      (None, ),
                                      ('saveFile', icons['saveFile'],
                                       self.parent.SaveToFile),
     def SetActiveMap(self, index):
         """!Set currently selected map.
         Unused, needed because of DoubleMapFrame API.
         pass
 class SwipeMainToolbar(BaseToolbar):
     """!Toolbar with tools related to application functionality
@@ -95,18 +102,18 @@
         """!Toolbar constructor
         BaseToolbar.__init__(self, parent)
         # add tool to toggle active map window
         self.toggleModeId = wx.NewId()
-        self.toggleMode = wx.Choice(parent = self, id = self.toggleModeId)
+        self.toggleMode = wx.Choice(parent=self, id=self.toggleModeId)
         for label, cdata in zip([_('Swipe mode'), _('Mirror mode')], ['swipe', 'mirror']):
             self.toggleMode.Append(label, cdata)
         self.toggleMode.SetSelection(0)
         self.toggleMode.SetSize(self.toggleMode.GetBestSize())
         self.toggleMode.Bind(wx.EVT_CHOICE,
-                             lambda event:
+                             lambda event:
                              self.parent.SetViewMode(self.toggleMode.GetClientData(event.GetSelection())))
         self.InsertControl(3, self.toggleMode)
@@ -114,7 +121,7 @@
         self.SetToolShortHelp(self.toggleModeId, help)
         self.Realize()
         """!Toolbar data"""
         return self._getToolbarData((("addRaster", swipeIcons['addRast'],
@@ -122,7 +129,7 @@
                                      (None, ),
                                      ("tools", swipeIcons['tools'],
                                       self.OnToolMenu)
     def SetMode(self, mode):
         for i in range(self.toggleMode.GetCount()):
@@ -132,19 +139,19 @@
     def OnToolMenu(self, event):
         """!Menu for additional tools"""
         toolMenu = wx.Menu()
         for label, itype, handler, desc in (
             (_("Switch orientation"),
              wx.ITEM_NORMAL, self.parent.OnSwitchOrientation, "switchOrientation"),
             (_("Switch maps"),
              wx.ITEM_NORMAL, self.parent.OnSwitchWindows, "switchMaps")):
             # Add items to the menu
-            item = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
-                               text = label,
-                               kind = itype)
+            item = wx.MenuItem(parentMenu=toolMenu, id=wx.ID_ANY,
+                               text=label,
+                               kind=itype)
             toolMenu.AppendItem(item)
             self.parent.GetWindow().Bind(wx.EVT_MENU, handler, item)
         # Popup the menu.  If an item is selected then its handler
         # will be called before PopupMenu returns.
         self.parent.GetWindow().PopupMenu(toolMenu)
@@ -158,11 +165,11 @@
         self.Realize()
         """!Toolbar data"""
         return self._getToolbarData((("settings", BaseIcons['settings'],
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapwin/base.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapwin/base.py	2014-05-18 18:20:34 UTC (rev 60325)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapwin/base.py	2014-05-18 18:30:16 UTC (rev 60326)
@@ -390,6 +390,13 @@
         self.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
         self.SetNamedCursor('cross')
+    def SetModeQuery(self):
+        """!Query mode on"""
+        self.mouse['use'] = "query"
+        self.mouse['box'] = "point"
+        self.zoomtype = 0
+        self.SetNamedCursor('cross')
     def DisactivateWin(self):
         """!Use when the class instance is hidden in MapFrame."""
         raise NotImplementedError()
