[GRASS-SVN] r60363 - in grass-addons/grass6/raster: . r.out.mbtiles r.out.mbtiles_prep
Mon May 19 22:04:11 PDT 2014
Author: hamish
Date: 2014-05-19 22:04:11 -0700 (Mon, 19 May 2014)
New Revision: 60363
Added:
   grass-addons/grass6/raster/r.out.mbtiles/
   grass-addons/grass6/raster/r.out.mbtiles/description.html
   grass-addons/grass6/raster/r.out.mbtiles/r.out.mbtiles_prep
Removed:
   grass-addons/grass6/raster/r.out.mbtiles_prep/Makefile
   grass-addons/grass6/raster/r.out.mbtiles_prep/description.html
   grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
   grass-addons/grass6/raster/Makefile
   grass-addons/grass6/raster/r.out.mbtiles/Makefile
rename module, part 1
Modified: grass-addons/grass6/raster/Makefile
--- grass-addons/grass6/raster/Makefile	2014-05-20 04:59:03 UTC (rev 60362)
+++ grass-addons/grass6/raster/Makefile	2014-05-20 05:04:11 UTC (rev 60363)
@@ -44,7 +44,7 @@
 	r.out.kap_template \
 	r.out.kml \
 	r.out.maxent_swd \
-	r.out.mbtiles_prep \
+	r.out.mbtiles \
 	r.out.netcdf \
 	r.pi \
 	r.prominence \
Modified: grass-addons/grass6/raster/r.out.mbtiles/Makefile
--- grass-addons/grass6/raster/r.out.mbtiles_prep/Makefile	2014-05-18 20:31:22 UTC (rev 60329)
+++ grass-addons/grass6/raster/r.out.mbtiles/Makefile	2014-05-20 05:04:11 UTC (rev 60363)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = r.out.mbtiles_prep
+PGM = r.out.mbtiles
 include $(MODULE_TOPDIR)/include/Make/Script.make
Deleted: grass-addons/grass6/raster/r.out.mbtiles/description.html
--- grass-addons/grass6/raster/r.out.mbtiles_prep/description.html	2014-05-18 20:31:22 UTC (rev 60329)
+++ grass-addons/grass6/raster/r.out.mbtiles/description.html	2014-05-20 05:04:11 UTC (rev 60363)
@@ -1,112 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.out.mbtiles_prep</em> creates a TMS tileset and support files ready to
-load into software like Geopaparazzi which will make the final conversion to
-a MBTiles SQLite database file.
-<h2>NOTES</h2>
-Either an individual raster map or a raster map imagery group may be given as input.
-<p>
-If not specified the zoom level will be automatically chosen.
-<p>
-When finished, copy the <b>output</b> directory and mapurl file to
-<tt>/sdcard/maps/</tt> on your Android device and select the mapurl file
-as the tile source in <em>Geopaparazzi</em>. The MBTiles SQLite
-database will then be populated in the background.
-<p>
-Too many tiles? Use the <b>zoom</b> parameter to limit the current
-operation to a single zoom level, then crop the region with
-<em>g.region</em> to where you need detailed coverage and re-run
-the tile creation with a higher <b>zoom</b> level. Afterwards you
-can combine the directories into a single tree and adjust the
-maxzoom and minzoom values in the mapurl file as needed.
-<h2>EXAMPLE</h2>
-Example 1:
-Creates a tileset for the North Carolina sample dataset's <tt>soilsID</tt> raster
-map at automatically chosen zoom levels 11-14.
-<div class="code"><pre>
-g.region rast=soilsID
-r.out.mbtiles_prep in=soilsID out=soil_tiles format=jpeg
-</pre></div>
-<p>
-Example 2:
-Drape the soils map over a shaded relief of the elevation map, and bundle
-it up into a tarball for easier copying.
-d.mon x0
-d.resize w=750 h=675
-r.colors -e elevation_shade color=sepia
-d.shadedmap relief=elevation_shade drape=soilsID output=shaded_soilsID
-r.out.mbtiles_prep -t in=shaded_soilsID out=shaded_soil_tiles format=jpeg
-</pre></div>
-<p>
-Example 3:
-Take a series of georegistered JPEG images (with .jgw world files),
-combine them into a virtual raster map with GDAL's <tt>gdalbuildvrt</tt>,
-import into a virtual GRASS raster map with <em>r.external</em>,
-and export as a TMS tileset ready for conversion into MBTiles. This
-is somewhat more computationally expensive but much easier on the
-disk space since the intermediate files are relatively tiny.
-r.external in=ortho_images.vrt out=ortho.mosaic \
-   title="Rural Aerial Photos (2009-2011)"
-g.region rast=ortho.mosaic.1
-r.out.mbtiles_prep -t in=ortho.mosaic out=ortho_mosaic format=jpeg
-</pre></div>
-<!-- prep companion data for North Carolina
-# in lat/lon location
-v.proj in=usgsgages map=PERMANENT loc=nc_spm_08
-v.proj in=geodetic_swwake_pts map=PERMANENT loc=nc_spm_08
-v.proj in=roadsmajor map=PERMANENT loc=nc_spm_08
-v.out.ogr in=usgsgages dsn=usgsgages.gpx \
-   format=GPX type=point dsco='GPX_USE_EXTENSIONS=YES'
-v.out.ogr in=geodetic_swwake_pts dsn=geodetic_swwake_pts.gpx \
-v.out.ogr in=roadsmajor dsn=roadsmajor.gpx \
-   format=GPX type=line dsco='GPX_USE_EXTENSIONS=YES'
-<h2>TODO</h2>
-Ability to create the MBTiles SQLite database directly.
-<p>
-On MS Windows <tt>gdal2tiles.py</tt> is called <tt>gdal2tiles.bat</tt>.
-Some minor adjust is needed in the script to select the correct name.
-<h2>SEE ALSO</h2>
-<em><a href="i.group.html">i.group</a></em>
-<br><br>
-<a href="http://www.gdal.org/gdal2tiles.html">gdal2tiles</a><br>
-<a href="https://github.com/geopaparazzi/geopaparazzi/wiki/.mapurl-parameters">mapurl specification</a><br>
-<h2>AUTHOR</h2>
-Hamish Bowman<br>
-<i>Department of Geology<br>
-University of Otago<br>
-Dunedin, New Zealand</i>
-<p>
-<i>Last changed: $Date$</i>
Copied: grass-addons/grass6/raster/r.out.mbtiles/description.html (from rev 60358, grass-addons/grass6/raster/r.out.mbtiles_prep/description.html)
--- grass-addons/grass6/raster/r.out.mbtiles/description.html	                        (rev 0)
@@ -0,0 +1,117 @@
+<h2>DESCRIPTION</h2>
+<em>r.out.mbtiles</em> creates a TMS tileset and support files ready to
+load into software like Geopaparazzi which will make the final conversion to
+a MBTiles SQLite database file.
+<h2>NOTES</h2>
+Either an individual raster map or a raster map imagery group may be given as input.
+<p>
+If not specified the zoom level will be automatically chosen.
+<p>
+The MBTiles output file has not been deduplicated to only store unique
+images in the database. Currently this can be accomplished by copying
+the tile tree onto an Android device and letting <em>Geopaparazzi</em>
+create the .mbtiles file.
+To do this, copy the <b>output</b> directory and mapurl file to
+<tt>/sdcard/maps/</tt> on your Android device and select the mapurl file
+as the tile source in <em>Geopaparazzi</em>. The MBTiles SQLite
+database will then be populated in the background.
+<p>
+Too many tiles? Use the <b>zoom</b> parameter to limit the current
+operation to a single zoom level, then crop the region with
+<em>g.region</em> to where you need detailed coverage and re-run
+the tile creation with a higher <b>zoom</b> level. Afterwards you
+can combine the directories into a single tree and adjust the
+maxzoom and minzoom values in the mapurl file as needed.
+<h2>EXAMPLE</h2>
+Example 1:
+Creates a tileset for the North Carolina sample dataset's <tt>soilsID</tt> raster
+map at automatically chosen zoom levels 11-14.
+<div class="code"><pre>
+g.region rast=soilsID
+r.out.mbtiles in=soilsID out=soil_tiles format=jpeg
+</pre></div>
+<p>
+Example 2:
+Drape the soils map over a shaded relief of the elevation map, and bundle
+it up into a tarball for easier copying.
+d.mon x0
+d.resize w=750 h=675
+r.colors -e elevation_shade color=sepia
+d.shadedmap relief=elevation_shade drape=soilsID output=shaded_soilsID
+r.out.mbtiles -t in=shaded_soilsID out=shaded_soil_tiles format=jpeg
+</pre></div>
+<p>
+Example 3:
+Take a series of georegistered JPEG images (with .jgw world files),
+combine them into a virtual raster map with GDAL's <tt>gdalbuildvrt</tt>,
+import into a virtual GRASS raster map with <em>r.external</em>,
+and export as a TMS tileset ready for conversion into MBTiles. This
+is somewhat more computationally expensive but much easier on the
+disk space since the intermediate files are relatively tiny.
+r.external in=ortho_images.vrt out=ortho.mosaic \
+   title="Rural Aerial Photos (2009-2011)"
+g.region rast=ortho.mosaic.1
+r.out.mbtiles -m in=ortho.mosaic out=ortho_mosaic format=jpeg
+</pre></div>
+<!-- prep companion data for North Carolina
+# in lat/lon location
+v.proj in=usgsgages map=PERMANENT loc=nc_spm_08
+v.proj in=geodetic_swwake_pts map=PERMANENT loc=nc_spm_08
+v.proj in=roadsmajor map=PERMANENT loc=nc_spm_08
+v.out.ogr in=usgsgages dsn=usgsgages.gpx \
+   format=GPX type=point dsco='GPX_USE_EXTENSIONS=YES'
+v.out.ogr in=geodetic_swwake_pts dsn=geodetic_swwake_pts.gpx \
+v.out.ogr in=roadsmajor dsn=roadsmajor.gpx \
+   format=GPX type=line dsco='GPX_USE_EXTENSIONS=YES'
+<h2>TODO</h2>
+Ability to create the MBTiles SQLite database with a deduplication
+process to store only unique tile images.
+<p>
+On MS Windows <tt>gdal2tiles.py</tt> is called <tt>gdal2tiles.bat</tt>.
+Some minor adjust is needed in the script to select the correct name.
+<h2>SEE ALSO</h2>
+<em><a href="i.group.html">i.group</a></em>
+<br><br>
+<a href="http://www.gdal.org/gdal2tiles.html">gdal2tiles</a><br>
+<a href="https://github.com/geopaparazzi/geopaparazzi/wiki/.mapurl-parameters">mapurl specification</a><br>
+<h2>AUTHOR</h2>
+Hamish Bowman<br>
+<i>Department of Geology<br>
+University of Otago<br>
+Dunedin, New Zealand</i>
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass-addons/grass6/raster/r.out.mbtiles/r.out.mbtiles_prep
--- grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep	2014-05-18 20:31:22 UTC (rev 60329)
+++ grass-addons/grass6/raster/r.out.mbtiles/r.out.mbtiles_prep	2014-05-20 05:04:11 UTC (rev 60363)
@@ -1,478 +0,0 @@
-#!/bin/sh
-# MODULE:       r.out.mbtiles_prep
-# AUTHOR(S):    M. Hamish Bowman, Dunedin, New Zealand
-# PURPOSE:      Export a raster map into a TMS bundle ready for conversion
-#		 to MBTiles SQLite format
-# COPYRIGHT:    (C) 2014 Hamish Bowman, and the GRASS Development Team
-#     This program is free software; you can redistribute it and/or modify
-#     it under the terms of the GNU General Public License as published by
-#     the Free Software Foundation; either version 2 of the License, or
-#     (at your option) any later version.
-#     This program is distributed in the hope that it will be useful,
-#     but WITHOUT ANY WARRANTY; without even the implied warranty of
-#     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-#     GNU General Public License for more details.
-#    *** NOT FOR NAVIGATIONAL USE - USE AT YOUR OWN RISK ***
-# https://github.com/geopaparazzi/geopaparazzi/wiki/.mapurl-Converting-Tile-Set-to-.mbtiles
-# https://github.com/geopaparazzi/geopaparazzi/wiki/.mapurl-parameters
-#%Module
-#% description: Export GRASS raster as a TMS tree ready for converting to mbtiles format.
-#% keywords: raster, export, tms, mbtiles
-#%End
-#%Option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name of input raster map
-#% gisprompt: old,cell,raster
-#%End
-#%Option
-#% key: output
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: name
-#% label: Name for output project directory
-#% description: default: input map name
-#% gisprompt: new_file,file,output
-#%End
-#%Option
-#% key: format
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: string
-#% description: Image format to store the tiles
-#% options: png,jpeg
-#% answer: png
-#%End
-#%Option
-#% key: zoom
-#% type: string
-#% required: no
-#% multiple: no
-#% label: TMS zoom levels to create
-#% description: Format: '0-19', or '10' (default: automatic)
-#%End
-#%Option
-#% key: dpi
-#% type: integer
-#% label: DPI of the target display
-#% description: Value for a smartphone might be 225, a desktop perhaps 96.
-#% answer: 225
-#%End
-#%Flag
-#% key: t
-#% description: Create a tarball
-#%End
-if  [ -z "$GISBASE" ] ; then
-   echo "You must be in GRASS GIS to run this program." >&2
-   exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
-   exec g.parser "$0" "$@"
-fi
-#### check if we have awk, gdalwarp, gdal2tiles, seq
-pgms="awk seq gdalwarp gdalinfo gdal2tiles.py"
-for pgm in $pgms ; do
-   if [ ! -x "`which $pgm`" ] ; then
-       g.message -e "$pgm is required, please install it first."
-       exit 1
-   fi
-done
-MAP_NAME="$GIS_OPT_INPUT"
-if [ -n "$GIS_OPT_OUTPUT" ] ; then
-   OUTFILE="$GIS_OPT_OUTPUT"
-else
-   OUTFILE=`echo "$MAP_NAME" | cut -f1 -d'@'`
-fi
-g.findfile element=cell file="$MAP_NAME" > /dev/null
-if [ $? -eq 0 ] ; then
-   MAP_TYPE=raster
-else
-  g.findfile element=group file="$MAP_NAME" > /dev/null
-   if [ $? -eq 0 ] ; then
-      MAP_TYPE=group
-   else
-      g.message -e "Could not find <$MAP_NAME>"
-      exit 1
-   fi
-fi
-cleanup()
-   #remove temporary files
-   if [ -e "$TMPFILE" ] ; then
-      rm -rf "$TMPFILE"*
-   fi
-# what to do in case of user break:
-exitprocedure()
-   g.message -e message='User break!'
-   cleanup
-   exit 1
-# shell check for user break (signal list: trap -l)
-trap "exitprocedure" 2 3 15
-#### setup temporary file
-TMPFILE="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMPFILE" ] ; then
-    g.message -e "Unable to create temporary file"
-    exit 1
-fi
-TMP_GTIFF="${TMPFILE}_export.tif"
-TMP_DIR=`dirname "$TMP_GTIFF"`
-TMP_GMERC="$TMP_DIR"/`basename "$TMP_GTIFF" .tif`_gmerc.tif
-if [ -n "$GRASS_VERBOSE" ] && [ "$GRASS_VERBOSE" -eq 0 ] ; then
-   QUIET="-q"
-else
-   QUIET=""
-fi
-# ?? do the source of TMS tiles sometimes need to be reprojected into the
-#    funny google merc projection first?
-if [ "$MAP_TYPE" = "raster" ] ; then
-   r.out.tiff -t input="$MAP_NAME" output="$TMP_GTIFF"
-   #gdalwarp -s_srs "`g.proj -jf`" -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
-   gdal_translate $QUIET -a_srs "`g.proj -jf`" "$TMP_GTIFF" "$TMP_GMERC"
-else
-   if [ `echo "$MAP_NAME" | grep -c '@'` -gt 0 ] ; then
-      g.message -e "Imagery groups must exist in the current mapset, sorry."
-      cleanup
-      exit 1
-   fi
-   r.out.gdal input="$MAP_NAME" output="$TMP_GTIFF" format=GTiff
-   #gdalwarp -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
-   mv "$TMP_GTIFF" "$TMP_GMERC"
-fi
-## gdalwarp -srcnodata -dstnodata -dstalpha ?
-if [ $? -ne 0 ] ; then
-   g.message -e "Problem exporting image"
-   cleanup
-   exit 1
-fi
-# free the disk space ASAP
-rm -f "$TMP_GTIFF"
-if [ 0 -eq 1 ] ; then
-## I don't think we need to do the gdalwarp, but it's worth keeping this
-## next bit of code for parsing the lat/lon bbox out of gdalinfo for a
-## rainy day.
-#### we need to find the bounding box in lat/lon of the post-warped geotiff
-# -- parse gdalinfo --
-gdalinfo -noct -nomd "$TMP_GMERC" > "$TMPFILE.warpinfo"
-IN_PROJ="+proj=longlat +datum=WGS84"
-OUT_PROJ="+proj=longlat +datum=WGS84"
-#?OUT_PROJ="+proj=longlat +ellps=sphere +a=6378137 +b=6378137 +nadgrids=@null"
-UL_DMS=`grep '^Upper Left ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
-             sed -e 's/^ //' -e 's/, / /' -e 's/)$//'`
-LL_DMS=`grep '^Lower Left ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
-UR_DMS=`grep '^Upper Right ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
-LR_DMS=`grep '^Lower Right ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
-# FIXME: will this work for geographic coords?
-CENTER_DMS=`grep '^Center ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
-N1=`echo "$UL_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f2 -d'|'`
-N2=`echo "$UR_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f2 -d'|'`
-S1=`echo "$LL_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f2 -d'|'`
-S2=`echo "$LR_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f2 -d'|'`
-E1=`echo "$UR_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f1 -d'|'`
-E2=`echo "$LR_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f1 -d'|'`
-W1=`echo "$UL_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f1 -d'|'`
-W2=`echo "$LL_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f1 -d'|'`
-CENTER_DDD=`echo "$CENTER_DMS" | \
-   m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" fs=' ' --quiet | \
-   cut -f1,2 -d ' '`
-WARP_N=`echo "$N1 $N2" | awk '{ if ($1 > $2) {print $1} else {print $2} }'`
-WARP_S=`echo "$S1 $S2" | awk '{ if ($1 < $2) {print $1} else {print $2} }'`
-WARP_E=`echo "$E1 $E2" | awk '{ if ($1 > $2) {print $1} else {print $2} }'`
-WARP_W=`echo "$W1 $W2" | awk '{ if ($1 < $2) {print $1} else {print $2} }'`
-# then this would go in the mapurl file:
-#center=$CENTER_DDD
-#bounds=$WARP_W $WARP_S $WARP_E $WARP_N
-fi
-# Screen DPI is monitor/device dependent, and therefore a crude one
-#   size fits none.
-# a: major radius of Earth (WGS84)
-# pixel factor: meters/pixel for a 256 pixel wide tile
-# zoom_level, map_scale results at 96 dpi, 45deg:
-# [0   1 : 418365887]
-# [1   1 : 209182943]
-# [2   1 : 104591472]
-# [3   1 : 52295736]
-# [4   1 : 26147868]
-# [5   1 : 13073934]
-# [6   1 : 6536967]
-# [7   1 : 3268483]
-# [8   1 : 1634242]
-# [9   1 : 817121]
-# [10  1 : 408560]
-# [11  1 : 204280]
-# [12  1 : 102140]
-# [13  1 : 51070]
-# [14  1 : 25535]
-# [15  1 : 12768]
-# [16  1 : 6384]
-# [17  1 : 3192]
-# [18  1 : 1596]
-# [19  1 : 798]
-# [20  1 : 399]
-calc_webtile_scale()
-    lat=$1
-    scale=$2
-    dpi=$3
-    echo "$lat $scale $dpi" | awk \
-       a = 6378137.0;
-       PI = 3.14159265358979323846;
-       pixelfact = a * 2*PI / 256;
-       resolution = pixelfact * cos($1 * PI/180) / 2^$2;
-       printf("%.0f\n", $3 * resolution / 0.0254)
-if [ -n "$GIS_OPT_ZOOM" ] ; then
-   ZOOM="$GIS_OPT_ZOOM"
-   if [ `echo "$ZOOM" | grep -c '\-'` -gt 0 ] ; then
-      # pick a mid-level zoom for the mapurl file
-      default_zoom=`echo "$ZOOM" | awk -F '-' '{print $1 + int(($2 - $1) / 2)}'`
-      maxzoom=`echo "$ZOOM" | cut -f2 -d'-'`
-      minzoom=`echo "$ZOOM" | cut -f1 -d'-'`
-   else
-      default_zoom="$ZOOM"
-      maxzoom="$ZOOM"
-      minzoom="$ZOOM"
-   fi
-else
-   # auto-calc map scale from map extent and dpi
-   eval `g.region -gu`
-   eval `g.region -legu`
-   # adjust as needed depending if you are working on a desktop monitor or mobile device:
-   #  a value of 96 might be appropriate for desktop, 225 for tablet or smartphone. YMMV.
-   SCREEN_DPI="$GIS_OPT_DPI"
-   #SCALE_NS=$ns_extent/(($rows/$DPI)*$INCH2METER)
-   #SCALE_EW=$ew_extent/(($cols/$DPI)*$INCH2METER)
-   SCALE_NS=`echo "$ns_extent $rows $SCREEN_DPI" | awk '{print $1/(($2/$3)*0.0254)}'`
-   SCALE_EW=`echo "$ew_extent $cols $SCREEN_DPI" | awk '{print $1/(($2/$3)*0.0254)}'`
-   # for use with TMS the two above should be the same.
-   MAP_SCALE=`echo "$SCALE_NS $SCALE_EW" | awk '{print int(0.5 + ($1 + $2) / 2)}'`
-   # beware zoom levels lower than 9 (~1:500k) badly distort the Mercator
-   minzoom=0
-   maxzoom=3
-   for zoom in `seq 0 20` ; do
-      zoomscale=`calc_webtile_scale $center_lat $zoom $SCREEN_DPI`
-      #echo "[$zoom   1 : $zoomscale]"  #  @ ${SCREEN_DPI}dpi]"
-      if [ "$zoomscale" -gt "$MAP_SCALE" ] ; then
-	 maxzoom=`expr "$zoom" + 2`
-	 minzoom=`expr "$zoom" - 2`
-      fi
-   done
-   if [ "$maxzoom" -gt 20 ] ; then
-      maxzoom=20
-   fi
-   if [ "$minzoom" -lt 0 ] ; then
-      minzoom=0
-   fi
-   ZOOM="$minzoom-$maxzoom"
-   default_zoom=`expr $maxzoom - 2`
-fi
-   TITLE=`r.info -m "$MAP_NAME" | cut -f2- -d=`
-else
-   TITLE=`r.info -m $(i.group -g $MAP_NAME  | head -n 1) | cut -f2- -d=`
-fi
-if [ -z "$TITLE" ] ; then
-   TITLE="$MAP_NAME"
-fi
-if [ -n "$GRASS_VERBOSE" ] && [ "$GRASS_VERBOSE" -gt 1 ] ; then
-   VERBOSE="-v"
-else
-   VERBOSE=""
-fi
-OUT_DIR="$TMP_DIR"/`basename "$TMP_GMERC" .tif`
-g.message "Generating tiles for zoom level(s) $ZOOM"
-gdal2tiles.py $VERBOSE -r bilinear -z "$ZOOM" -w none -t "$TITLE" \
-  "$TMP_GMERC" "$OUT_DIR"
-   g.message -e "gdal2tiles failed."
-   cleanup
-   exit 1
-fi
-rm -f "$TMP_GMERC"
-g.message "Dropping unneeded auxiliary metadata files ..."
-for file in `find $(dirname "$OUT_DIR") | grep .aux.xml` ; do
-   rm -f "$file"
-done
-#### write out .mapurl file
-# get max extent bbox in lat/lon
-eval `g.region -bgu`
-URLFILE="$OUT_DIR"/`basename "$OUTFILE"`.mapurl
-if [ "$GIS_OPT_FORMAT" = "jpeg" ] ; then
-   ext=jpg
-else
-   ext=png
-fi
-cat << EOF > "$URLFILE"
-url=$OUTFILE/ZZZ/XXX/YYY.$ext
-minzoom=$minzoom
-maxzoom=$maxzoom
-center=$ll_clon $ll_clat
-bounds=$ll_w $ll_s $ll_e $ll_n
-type=tms
-mbtiles=$OUTFILE/$OUTFILE.mbtiles
-name=$TITLE
-description=Exported zoom level(s) $ZOOM from GRASS GIS r.out.mbtiles_prep
-defaultzoom=$default_zoom
-format=$ext
-request_type=run,fill,load,reset_metadata
-EOF
-cd "$OUT_DIR"
-g.message "Scanning for blank tiles ..."
-# warping can leave a lot of left over border around the edges due to skew
-# MBTiles links these all to a single tile, but they're unsightly.
-# This takes a while so consider running in parallel, but it is probably
-# near-saturation already due to the large number of tiny processes creaded
-# and destroyed.
-i=0
-for file in `find . | grep '.png$'` ; do
-     # check if image is empty
-    COUNT=`gdalinfo -mm -noct -nomd "$file" | grep 'Min/Max' | \
-       cut -f2 -d= | tr ',' '\n' | uniq | wc -l`
-    if [ "$COUNT" -eq 1 ] ; then
-       rm -f "$file"
-       i=`expr $i + 1`
-    fi
-done
-if [ "$i" -gt 0 ] ; then
-   g.message "Removed $i blank tiles."
-fi
-   g.message "Converting to JPEG ..."
-   pgms="pngtopnm pnmtojpeg"
-   for pgm in $pgms ; do
-          g.message -e "$pgm is required, please install the NetPBM tools."
-          cleanup
-	  exit 1
-      fi
-   done
-   for file in `find . | grep '.png$'` ; do
-      outfile=`echo "$file" | sed -e 's/\.png$/.jpg/'`
-      pngtopnm -mix -background '#FFFFFF' "$file" | pnmtojpeg > "$outfile"
-        rm "$file"
-      fi
-   done
-   # sed -i is not portable to BSD/Mac
-   mv tilemapresource.xml tilemapresource.xml.tmp
-   sed -e 's+mime-type="image/png"+mime-type="image/jpeg"+' \
-       -e 's+extension="png"+extension="jpg"+' \
-	   tilemapresource.xml.tmp > tilemapresource.xml
-   rm tilemapresource.xml.tmp
-fi
-cd - > /dev/null
-mv "$OUT_DIR" "$OUTFILE"
-mv "$OUTFILE"/*.mapurl "$OUTFILE"/..
-cleanup
-if [ "$GIS_FLAG_T" -eq 1 ] ; then
-   cd `dirname "$OUTFILE"`
-   tar cf `basename "$OUTFILE"`.tar `basename "$OUTFILE"` `basename "$OUTFILE"`.mapurl
-fi
-g.message message=""
-g.message "Done."
-g.message "Next copy the '$OUTFILE' directory and mapurl file to \
-/sdcard/maps/ on your Android device and select the mapurl file as the \
-tile source in Geopaparazzi. The MBTiles SQLite database will then \
-be populated in the background."
Copied: grass-addons/grass6/raster/r.out.mbtiles/r.out.mbtiles_prep (from rev 60362, grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep)
--- grass-addons/grass6/raster/r.out.mbtiles/r.out.mbtiles_prep	                        (rev 0)
@@ -0,0 +1,550 @@
+#!/bin/sh
+# MODULE:       r.out.mbtiles
+# AUTHOR(S):    M. Hamish Bowman, Dunedin, New Zealand
+# PURPOSE:      Export a raster map into a TMS bundle ready for conversion
+#		 to MBTiles SQLite format
+# COPYRIGHT:    (C) 2014 Hamish Bowman, and the GRASS Development Team
+#     This program is free software; you can redistribute it and/or modify
+#     it under the terms of the GNU General Public License as published by
+#     the Free Software Foundation; either version 2 of the License, or
+#     (at your option) any later version.
+#     This program is distributed in the hope that it will be useful,
+#     but WITHOUT ANY WARRANTY; without even the implied warranty of
+#     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#     GNU General Public License for more details.
+#    *** NOT FOR NAVIGATIONAL USE - USE AT YOUR OWN RISK ***
+# https://github.com/geopaparazzi/geopaparazzi/wiki/.mapurl-Converting-Tile-Set-to-.mbtiles
+# https://github.com/geopaparazzi/geopaparazzi/wiki/.mapurl-parameters
+# https://github.com/mapbox/mbtiles-spec/blob/master/1.1/spec.md
+# https://github.com/geopaparazzi/geopaparazzi/wiki/mbtiles-Implementation
+#%Module
+#% description: Export GRASS raster as a TMS tree ready for converting to mbtiles format.
+#% keywords: raster, export, tms, mbtiles
+#%End
+#%Option
+#% key: input
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input raster map
+#% gisprompt: old,cell,raster
+#%End
+#%Option
+#% key: output
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% label: Name for output project directory
+#% description: default: input map name
+#% gisprompt: new_file,file,output
+#%End
+#%Option
+#% key: format
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: string
+#% description: Image format to store the tiles
+#% options: png,jpeg
+#% answer: png
+#%End
+#%Option
+#% key: zoom
+#% type: string
+#% required: no
+#% multiple: no
+#% label: TMS zoom levels to create
+#% description: Format: '0-19', or '10' (default: automatic)
+#%End
+#%Option
+#% key: dpi
+#% type: integer
+#% label: DPI of the target display
+#% description: Value for a smartphone might be 225, a desktop perhaps 96.
+#% answer: 225
+#%End
+#%Flag
+#% key: m
+#% description: Create a MBTiles database (requires SQLite3)
+#%End
+#%Flag
+#% key: t
+#% description: Create a tarball of the tile tree
+#%End
+if  [ -z "$GISBASE" ] ; then
+   echo "You must be in GRASS GIS to run this program." >&2
+   exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+   exec g.parser "$0" "$@"
+fi
+#### check if we have awk, gdalwarp, gdal2tiles, seq
+pgms="awk seq gdalwarp gdalinfo gdal2tiles.py"
+for pgm in $pgms ; do
+   if [ ! -x "`which $pgm`" ] ; then
+       g.message -e "$pgm is required, please install it first."
+       exit 1
+   fi
+done
+MAP_NAME="$GIS_OPT_INPUT"
+if [ -n "$GIS_OPT_OUTPUT" ] ; then
+   OUTFILE="$GIS_OPT_OUTPUT"
+else
+   OUTFILE=`echo "$MAP_NAME" | cut -f1 -d'@'`
+fi
+g.findfile element=cell file="$MAP_NAME" > /dev/null
+if [ $? -eq 0 ] ; then
+   MAP_TYPE=raster
+else
+  g.findfile element=group file="$MAP_NAME" > /dev/null
+   if [ $? -eq 0 ] ; then
+      MAP_TYPE=group
+   else
+      g.message -e "Could not find <$MAP_NAME>"
+      exit 1
+   fi
+fi
+cleanup()
+   #remove temporary files
+   if [ -e "$TMPFILE" ] ; then
+      rm -rf "$TMPFILE"*
+   fi
+# what to do in case of user break:
+exitprocedure()
+   g.message -e message='User break!'
+   cleanup
+   exit 1
+# shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
+#### setup temporary file
+TMPFILE="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMPFILE" ] ; then
+    g.message -e "Unable to create temporary file"
+    exit 1
+fi
+TMP_GTIFF="${TMPFILE}_export.tif"
+TMP_DIR=`dirname "$TMP_GTIFF"`
+TMP_GMERC="$TMP_DIR"/`basename "$TMP_GTIFF" .tif`_gmerc.tif
+if [ -n "$GRASS_VERBOSE" ] && [ "$GRASS_VERBOSE" -eq 0 ] ; then
+   QUIET="-q"
+else
+   QUIET=""
+fi
+# ?? do the source of TMS tiles sometimes need to be reprojected into the
+#    funny google merc projection first?
+if [ "$MAP_TYPE" = "raster" ] ; then
+   r.out.tiff -t input="$MAP_NAME" output="$TMP_GTIFF"
+   #gdalwarp -s_srs "`g.proj -jf`" -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
+   gdal_translate $QUIET -a_srs "`g.proj -jf`" "$TMP_GTIFF" "$TMP_GMERC"
+else
+   if [ `echo "$MAP_NAME" | grep -c '@'` -gt 0 ] ; then
+      g.message -e "Imagery groups must exist in the current mapset, sorry."
+      cleanup
+      exit 1
+   fi
+   r.out.gdal input="$MAP_NAME" output="$TMP_GTIFF" format=GTiff
+   #gdalwarp -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
+   mv "$TMP_GTIFF" "$TMP_GMERC"
+fi
+## gdalwarp -srcnodata -dstnodata -dstalpha ?
+if [ $? -ne 0 ] ; then
+   g.message -e "Problem exporting image"
+   cleanup
+   exit 1
+fi
+# free the disk space ASAP
+rm -f "$TMP_GTIFF"
+if [ 0 -eq 1 ] ; then
+## I don't think we need to do the gdalwarp, but it's worth keeping this
+## next bit of code for parsing the lat/lon bbox out of gdalinfo for a
+## rainy day.
+#### we need to find the bounding box in lat/lon of the post-warped geotiff
+# -- parse gdalinfo --
+gdalinfo -noct -nomd "$TMP_GMERC" > "$TMPFILE.warpinfo"
+IN_PROJ="+proj=longlat +datum=WGS84"
+OUT_PROJ="+proj=longlat +datum=WGS84"
+#?OUT_PROJ="+proj=longlat +ellps=sphere +a=6378137 +b=6378137 +nadgrids=@null"
+UL_DMS=`grep '^Upper Left ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
+             sed -e 's/^ //' -e 's/, / /' -e 's/)$//'`
+LL_DMS=`grep '^Lower Left ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
+UR_DMS=`grep '^Upper Right ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
+LR_DMS=`grep '^Lower Right ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
+# FIXME: will this work for geographic coords?
+CENTER_DMS=`grep '^Center ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
+N1=`echo "$UL_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f2 -d'|'`
+N2=`echo "$UR_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f2 -d'|'`
+S1=`echo "$LL_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f2 -d'|'`
+S2=`echo "$LR_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f2 -d'|'`
+E1=`echo "$UR_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f1 -d'|'`
+E2=`echo "$LR_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f1 -d'|'`
+W1=`echo "$UL_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f1 -d'|'`
+W2=`echo "$LL_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f1 -d'|'`
+CENTER_DDD=`echo "$CENTER_DMS" | \
+   m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" fs=' ' --quiet | \
+   cut -f1,2 -d ' '`
+WARP_N=`echo "$N1 $N2" | awk '{ if ($1 > $2) {print $1} else {print $2} }'`
+WARP_S=`echo "$S1 $S2" | awk '{ if ($1 < $2) {print $1} else {print $2} }'`
+WARP_E=`echo "$E1 $E2" | awk '{ if ($1 > $2) {print $1} else {print $2} }'`
+WARP_W=`echo "$W1 $W2" | awk '{ if ($1 < $2) {print $1} else {print $2} }'`
+# then this would go in the mapurl file:
+#center=$CENTER_DDD
+#bounds=$WARP_W $WARP_S $WARP_E $WARP_N
+fi
+# Screen DPI is monitor/device dependent, and therefore a crude one
+#   size fits none.
+# a: major radius of Earth (WGS84)
+# pixel factor: meters/pixel for a 256 pixel wide tile
+# zoom_level, map_scale results at 96 dpi, 45deg:
+# [0   1 : 418365887]
+# [1   1 : 209182943]
+# [2   1 : 104591472]
+# [3   1 : 52295736]
+# [4   1 : 26147868]
+# [5   1 : 13073934]
+# [6   1 : 6536967]
+# [7   1 : 3268483]
+# [8   1 : 1634242]
+# [9   1 : 817121]
+# [10  1 : 408560]
+# [11  1 : 204280]
+# [12  1 : 102140]
+# [13  1 : 51070]
+# [14  1 : 25535]
+# [15  1 : 12768]
+# [16  1 : 6384]
+# [17  1 : 3192]
+# [18  1 : 1596]
+# [19  1 : 798]
+# [20  1 : 399]
+calc_webtile_scale()
+    lat=$1
+    scale=$2
+    dpi=$3
+    echo "$lat $scale $dpi" | awk \
+       a = 6378137.0;
+       PI = 3.14159265358979323846;
+       pixelfact = a * 2*PI / 256;
+       resolution = pixelfact * cos($1 * PI/180) / 2^$2;
+       printf("%.0f\n", $3 * resolution / 0.0254)
+if [ -n "$GIS_OPT_ZOOM" ] ; then
+   ZOOM="$GIS_OPT_ZOOM"
+   if [ `echo "$ZOOM" | grep -c '\-'` -gt 0 ] ; then
+      # pick a mid-level zoom for the mapurl file
+      default_zoom=`echo "$ZOOM" | awk -F '-' '{print $1 + int(($2 - $1) / 2)}'`
+      maxzoom=`echo "$ZOOM" | cut -f2 -d'-'`
+      minzoom=`echo "$ZOOM" | cut -f1 -d'-'`
+   else
+      default_zoom="$ZOOM"
+      maxzoom="$ZOOM"
+      minzoom="$ZOOM"
+   fi
+else
+   # auto-calc map scale from map extent and dpi
+   eval `g.region -gu`
+   eval `g.region -legu`
+   # adjust as needed depending if you are working on a desktop monitor or mobile device:
+   #  a value of 96 might be appropriate for desktop, 225 for tablet or smartphone. YMMV.
+   SCREEN_DPI="$GIS_OPT_DPI"
+   #SCALE_NS=$ns_extent/(($rows/$DPI)*$INCH2METER)
+   #SCALE_EW=$ew_extent/(($cols/$DPI)*$INCH2METER)
+   SCALE_NS=`echo "$ns_extent $rows $SCREEN_DPI" | awk '{print $1/(($2/$3)*0.0254)}'`
+   SCALE_EW=`echo "$ew_extent $cols $SCREEN_DPI" | awk '{print $1/(($2/$3)*0.0254)}'`
+   # for use with TMS the two above should be the same.
+   MAP_SCALE=`echo "$SCALE_NS $SCALE_EW" | awk '{print int(0.5 + ($1 + $2) / 2)}'`
+   # beware zoom levels lower than 9 (~1:500k) badly distort the Mercator
+   minzoom=0
+   maxzoom=3
+   for zoom in `seq 0 20` ; do
+      zoomscale=`calc_webtile_scale $center_lat $zoom $SCREEN_DPI`
+      #echo "[$zoom   1 : $zoomscale]"  #  @ ${SCREEN_DPI}dpi]"
+      if [ "$zoomscale" -gt "$MAP_SCALE" ] ; then
+	 maxzoom=`expr "$zoom" + 2`
+	 minzoom=`expr "$zoom" - 2`
+      fi
+   done
+   if [ "$maxzoom" -gt 20 ] ; then
+      maxzoom=20
+   fi
+   if [ "$minzoom" -lt 0 ] ; then
+      minzoom=0
+   fi
+   ZOOM="$minzoom-$maxzoom"
+   default_zoom=`expr $maxzoom - 2`
+fi
+   TITLE=`r.info -m "$MAP_NAME" | cut -f2- -d=`
+else
+   TITLE=`r.info -m $(i.group -g $MAP_NAME  | head -n 1) | cut -f2- -d=`
+fi
+if [ -z "$TITLE" ] ; then
+   TITLE="$MAP_NAME"
+fi
+if [ -n "$GRASS_VERBOSE" ] && [ "$GRASS_VERBOSE" -gt 1 ] ; then
+   VERBOSE="-v"
+else
+   VERBOSE=""
+fi
+OUT_DIR="$TMP_DIR"/`basename "$TMP_GMERC" .tif`
+g.message "Generating tiles for zoom level(s) $ZOOM"
+gdal2tiles.py $VERBOSE -r bilinear -z "$ZOOM" -w none -t "$TITLE" \
+  "$TMP_GMERC" "$OUT_DIR"
+   g.message -e "gdal2tiles failed."
+   cleanup
+   exit 1
+fi
+rm -f "$TMP_GMERC"
+g.message "Dropping unneeded auxiliary metadata files ..."
+for file in `find $(dirname "$OUT_DIR") | grep .aux.xml` ; do
+   rm -f "$file"
+done
+#### write out .mapurl file
+# get max extent bbox in lat/lon
+eval `g.region -bgu`
+URLFILE="$OUT_DIR"/`basename "$OUTFILE"`.mapurl
+if [ "$GIS_OPT_FORMAT" = "jpeg" ] ; then
+   ext=jpg
+else
+   ext=png
+fi
+cat << EOF > "$URLFILE"
+url=$OUTFILE/ZZZ/XXX/YYY.$ext
+minzoom=$minzoom
+maxzoom=$maxzoom
+center=$ll_clon $ll_clat
+bounds=$ll_w $ll_s $ll_e $ll_n
+type=tms
+mbtiles=$OUTFILE/$OUTFILE.mbtiles
+name=$TITLE
+description=Exported zoom level(s) $ZOOM from GRASS GIS r.out.mbtiles
+defaultzoom=$default_zoom
+format=$ext
+request_type=run,fill,load
+EOF
+cd "$OUT_DIR"
+g.message "Scanning for blank tiles ..."
+# warping can leave a lot of left over border around the edges due to skew
+# MBTiles links these all to a single tile, but they're unsightly.
+# This takes a while so consider running in parallel, but it is probably
+# near-saturation already due to the large number of tiny processes creaded
+# and destroyed.
+i=0
+for file in `find . | grep '.png$'` ; do
+     # check if image is empty
+    COUNT=`gdalinfo -mm -noct -nomd "$file" | grep 'Min/Max' | \
+       cut -f2 -d= | tr ',' '\n' | uniq | wc -l`
+    if [ "$COUNT" -eq 1 ] ; then
+       rm -f "$file"
+       i=`expr $i + 1`
+    fi
+done
+if [ "$i" -gt 0 ] ; then
+   g.message "Removed $i blank tiles."
+fi
+   g.message "Converting to JPEG ..."
+   pgms="pngtopnm pnmtojpeg"
+   for pgm in $pgms ; do
+          g.message -e "$pgm is required, please install the NetPBM tools."
+          cleanup
+	  exit 1
+      fi
+   done
+   for file in `find . | grep '.png$'` ; do
+      outfile=`echo "$file" | sed -e 's/\.png$/.jpg/'`
+      pngtopnm -mix -background '#FFFFFF' "$file" | pnmtojpeg > "$outfile"
+        rm "$file"
+      fi
+   done
+   # sed -i is not portable to BSD/Mac
+   mv tilemapresource.xml tilemapresource.xml.tmp
+   sed -e 's+mime-type="image/png"+mime-type="image/jpeg"+' \
+       -e 's+extension="png"+extension="jpg"+' \
+	   tilemapresource.xml.tmp > tilemapresource.xml
+   rm tilemapresource.xml.tmp
+fi
+cd - > /dev/null
+mv "$OUT_DIR" "$OUTFILE"
+mv "$OUTFILE"/*.mapurl "$OUTFILE"/..
+#### Set up SQLite commands to build MBTiles database
+# must use sqlite3+
+if [ "$GIS_FLAG_M" -eq 1 ] ; then
+   g.message "Creating SQLite instructions ..."
+   if [ ! -x "`which sqlite3`" ] ; then
+      g.message -e "sqlite3 is required for creating the MBTiles database, please install it first."
+      cleanup
+      exit 1
+   fi
+   TITLE_CLEAN=`echo "$TITLE" | sed -e "s|'|''|g"`
+   cat << EOF > "$TMPFILE.sql"
+CREATE TABLE metadata (name text, value text);
+INSERT INTO metadata VALUES ('name', '`basename "$OUTFILE"`');
+INSERT INTO metadata VALUES ('type', 'baselayer');
+INSERT INTO metadata VALUES ('version', '1.1');
+INSERT INTO metadata VALUES ('description', '$TITLE_CLEAN');
+INSERT INTO metadata VALUES ('format', '$ext');
+INSERT INTO metadata VALUES ('bounds', '$ll_w,$ll_s,$ll_e,$ll_n');
+INSERT INTO metadata VALUES ('center', '$ll_clon,$ll_clat');
+INSERT INTO metadata VALUES ('minzoom', '$minzoom');
+INSERT INTO metadata VALUES ('maxzoom', '$maxzoom');
+INSERT INTO metadata VALUES ('tile_row_type', 'tms');
+CREATE TABLE tiles (zoom_level integer, tile_column integer, tile_row integer, tile_data blob);
+BEGIN TRANSACTION;
+EOF
+   # FIXME: keep DB small by checking for duplicate tile images (ocean, wasteland)
+   #  Make the 'tiles' table a view, then replace 'blob' with (tile_id text),
+   #  and in the 'images' table keep unique tiles in (tile_data blob, tile_id text).
+   # perhaps try 'md5sum | sort | uniq -d' to weed out duplicates?
+   # see https://github.com/geopaparazzi/geopaparazzi/wiki/mbtiles-Implementation
+   for file in `find "$OUTFILE" -name "*.$ext" | sort -n -t / -k 2` ; do
+      zoomcolrow=`echo "$file" | sed -e "s|.*$OUTFILE/||" -e "s|\.$ext||" -e 's|/|, |g'`
+      echo "INSERT INTO tiles VALUES ($zoomcolrow, X'`hexdump -v -e '1/1 "%.2x"' $file`');"
+   done
+   ) >> "$TMPFILE.sql"
+   echo "COMMIT TRANSACTION;" >> "$TMPFILE.sql"
+   if [ `wc -l < "${TMPFILE}_tiles.sql"` -gt 65535 ] ; then
+      echo "FIXME: insert some 'COMMIT TRANSACTION; BEGIN TRANSACTION;' inline the sql every 65535 inserts or so"
+   fi
+   g.message "Populating SQLite database ..."
+   cat "$TMPFILE.sql" | sqlite3 "$OUTFILE.mbtiles"
+fi
+cleanup
+if [ "$GIS_FLAG_T" -eq 1 ] ; then
+   if [ ! -x "`which tar`" ] ; then
+      g.message -e "tar is required, please install it first."
+      exit 1
+   fi
+   cd `dirname "$OUTFILE"`
+   tar cf `basename "$OUTFILE"`.tar `basename "$OUTFILE"` `basename "$OUTFILE"`.mapurl
+fi
+g.message message=""
+g.message "Done."
+#g.message "Next copy the '$OUTFILE' directory and mapurl file to \
+# /sdcard/maps/ on your Android device and select the mapurl file as the \
+# tile source in Geopaparazzi. The MBTiles SQLite database will then \
+# be populated in the background."
Deleted: grass-addons/grass6/raster/r.out.mbtiles_prep/Makefile
--- grass-addons/grass6/raster/r.out.mbtiles_prep/Makefile	2014-05-20 04:59:03 UTC (rev 60362)
+++ grass-addons/grass6/raster/r.out.mbtiles_prep/Makefile	2014-05-20 05:04:11 UTC (rev 60363)
@@ -1,7 +0,0 @@
-MODULE_TOPDIR = ../..
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
Deleted: grass-addons/grass6/raster/r.out.mbtiles_prep/description.html
--- grass-addons/grass6/raster/r.out.mbtiles_prep/description.html	2014-05-20 04:59:03 UTC (rev 60362)
+++ grass-addons/grass6/raster/r.out.mbtiles_prep/description.html	2014-05-20 05:04:11 UTC (rev 60363)
@@ -1,117 +0,0 @@
-<h2>NOTES</h2>
-<p>
-<p>
-The MBTiles output file has not been deduplicated to only store unique
-images in the database. Currently this can be accomplished by copying
-the tile tree onto an Android device and letting <em>Geopaparazzi</em>
-create the .mbtiles file.
-To do this, copy the <b>output</b> directory and mapurl file to
-<p>
-<h2>EXAMPLE</h2>
-Example 1:
-</pre></div>
-<p>
-Example 2:
-d.mon x0
-</pre></div>
-<p>
-Example 3:
-</pre></div>
-<h2>TODO</h2>
-Ability to create the MBTiles SQLite database with a deduplication
-process to store only unique tile images.
-<p>
-<h2>SEE ALSO</h2>
-<br><br>
-<h2>AUTHOR</h2>
-Hamish Bowman<br>
-<p>
Deleted: grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
--- grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep	2014-05-20 04:59:03 UTC (rev 60362)
+++ grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep	2014-05-20 05:04:11 UTC (rev 60363)
@@ -1,550 +0,0 @@
-#!/bin/sh
-# https://github.com/mapbox/mbtiles-spec/blob/master/1.1/spec.md
-# https://github.com/geopaparazzi/geopaparazzi/wiki/mbtiles-Implementation
-#%Module
-#%End
-#%Option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#%End
-#%Option
-#% key: output
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: name
-#%End
-#%Option
-#% key: format
-#% type: string
-#% required: no
-#% multiple: no
-#% answer: png
-#%End
-#%Option
-#% key: zoom
-#% type: string
-#% required: no
-#% multiple: no
-#%End
-#%Option
-#% key: dpi
-#% type: integer
-#% answer: 225
-#%End
-#%Flag
-#% key: m
-#% description: Create a MBTiles database (requires SQLite3)
-#%End
-#%Flag
-#% key: t
-#% description: Create a tarball of the tile tree
-#%End
-   exit 1
-fi
-fi
-       exit 1
-   fi
-done
-else
-fi
-   MAP_TYPE=raster
-else
-      MAP_TYPE=group
-   else
-      exit 1
-   fi
-fi
-cleanup()
-   fi
-exitprocedure()
-   cleanup
-   exit 1
-    exit 1
-fi
-   QUIET="-q"
-else
-   QUIET=""
-fi
-else
-      cleanup
-      exit 1
-   fi
-fi
-   cleanup
-   exit 1
-fi
-rm -f "$TMP_GTIFF"
-## rainy day.
-   cut -f1,2 -d ' '`
-fi
-#   size fits none.
-# [3   1 : 52295736]
-# [4   1 : 26147868]
-# [5   1 : 13073934]
-# [6   1 : 6536967]
-# [7   1 : 3268483]
-# [8   1 : 1634242]
-# [9   1 : 817121]
-# [10  1 : 408560]
-# [11  1 : 204280]
-# [12  1 : 102140]
-# [13  1 : 51070]
-# [14  1 : 25535]
-# [15  1 : 12768]
-# [16  1 : 6384]
-# [17  1 : 3192]
-# [18  1 : 1596]
-# [19  1 : 798]
-# [20  1 : 399]
-    lat=$1
-    scale=$2
-    dpi=$3
-       a = 6378137.0;
-   else
-      maxzoom="$ZOOM"
-      minzoom="$ZOOM"
-   fi
-else
-   minzoom=0
-   maxzoom=3
-      fi
-   done
-      maxzoom=20
-   fi
-      minzoom=0
-   fi
-fi
-else
-fi
-   TITLE="$MAP_NAME"
-fi
-   VERBOSE="-v"
-else
-   VERBOSE=""
-fi
-   cleanup
-   exit 1
-fi
-rm -f "$TMP_GMERC"
-   rm -f "$file"
-done
-   ext=jpg
-else
-   ext=png
-fi
-minzoom=$minzoom
-maxzoom=$maxzoom
-type=tms
-name=$TITLE
-format=$ext
-EOF
-cd "$OUT_DIR"
-# and destroyed.
-i=0
-       rm -f "$file"
-       i=`expr $i + 1`
-    fi
-done
-fi
-          cleanup
-	  exit 1
-      fi
-   done
-        rm "$file"
-      fi
-   done
-fi
-cd - > /dev/null
-#### Set up SQLite commands to build MBTiles database
-# must use sqlite3+
-if [ "$GIS_FLAG_M" -eq 1 ] ; then
-   g.message "Creating SQLite instructions ..."
-   if [ ! -x "`which sqlite3`" ] ; then
-      g.message -e "sqlite3 is required for creating the MBTiles database, please install it first."
-      cleanup
-      exit 1
-   fi
-   TITLE_CLEAN=`echo "$TITLE" | sed -e "s|'|''|g"`
-   cat << EOF > "$TMPFILE.sql"
-CREATE TABLE metadata (name text, value text);
-INSERT INTO metadata VALUES ('name', '`basename "$OUTFILE"`');
-INSERT INTO metadata VALUES ('type', 'baselayer');
-INSERT INTO metadata VALUES ('version', '1.1');
-INSERT INTO metadata VALUES ('description', '$TITLE_CLEAN');
-INSERT INTO metadata VALUES ('format', '$ext');
-INSERT INTO metadata VALUES ('bounds', '$ll_w,$ll_s,$ll_e,$ll_n');
-INSERT INTO metadata VALUES ('center', '$ll_clon,$ll_clat');
-INSERT INTO metadata VALUES ('minzoom', '$minzoom');
-INSERT INTO metadata VALUES ('maxzoom', '$maxzoom');
-INSERT INTO metadata VALUES ('tile_row_type', 'tms');
-CREATE TABLE tiles (zoom_level integer, tile_column integer, tile_row integer, tile_data blob);
-BEGIN TRANSACTION;
-EOF
-   # FIXME: keep DB small by checking for duplicate tile images (ocean, wasteland)
-   #  Make the 'tiles' table a view, then replace 'blob' with (tile_id text),
-   #  and in the 'images' table keep unique tiles in (tile_data blob, tile_id text).
-   # perhaps try 'md5sum | sort | uniq -d' to weed out duplicates?
-   # see https://github.com/geopaparazzi/geopaparazzi/wiki/mbtiles-Implementation
-   for file in `find "$OUTFILE" -name "*.$ext" | sort -n -t / -k 2` ; do
-      zoomcolrow=`echo "$file" | sed -e "s|.*$OUTFILE/||" -e "s|\.$ext||" -e 's|/|, |g'`
-      echo "INSERT INTO tiles VALUES ($zoomcolrow, X'`hexdump -v -e '1/1 "%.2x"' $file`');"
-   done
-   ) >> "$TMPFILE.sql"
-   echo "COMMIT TRANSACTION;" >> "$TMPFILE.sql"
-   if [ `wc -l < "${TMPFILE}_tiles.sql"` -gt 65535 ] ; then
-      echo "FIXME: insert some 'COMMIT TRANSACTION; BEGIN TRANSACTION;' inline the sql every 65535 inserts or so"
-   fi
-   g.message "Populating SQLite database ..."
-   cat "$TMPFILE.sql" | sqlite3 "$OUTFILE.mbtiles"
-fi
-cleanup
-   if [ ! -x "`which tar`" ] ; then
-      g.message -e "tar is required, please install it first."
-      exit 1
-   fi
-fi
-g.message "Done."
-#g.message "Next copy the '$OUTFILE' directory and mapurl file to \
-# /sdcard/maps/ on your Android device and select the mapurl file as the \
-# tile source in Geopaparazzi. The MBTiles SQLite database will then \
-# be populated in the background."
