[GRASS-SVN] r60389 - grass-addons/grass7/raster/r.area
Wed May 21 05:21:06 PDT 2014
Author: zarch
Date: 2014-05-21 05:21:06 -0700 (Wed, 21 May 2014)
New Revision: 60389
   grass-addons/grass7/raster/r.area/main.c
Add lesser and greater options
Modified: grass-addons/grass7/raster/r.area/main.c
--- grass-addons/grass7/raster/r.area/main.c	2014-05-21 09:51:19 UTC (rev 60388)
+++ grass-addons/grass7/raster/r.area/main.c	2014-05-21 12:21:06 UTC (rev 60389)
@@ -25,7 +25,7 @@
     struct GModule *module;
-    struct Option *input, *output, *par_threshold;
+    struct Option *input, *output, *lesser, *greater;
     struct Flag *flag_binary;
     struct Cell_head cellhd;
@@ -34,7 +34,7 @@
     char *mapset;
     int nrows, ncols;
-    int binary, threshold;
+    int binary, les, grt, gt;
     int row, col;
     int infd, outfd;
     CELL *in_buf;
@@ -50,7 +50,7 @@
     G_add_keyword(_("statistics"));
     G_add_keyword(_("area"));
     module->description =
-        _("Calculates area of clumped areas and remove areas smaller than given threshold.");
+        _("Cacullates area of clumped areas and remove areas smaller than given threshold.");
     input = G_define_standard_option(G_OPT_R_INPUT);
     input->description = _("Map created with r.clump");
@@ -58,35 +58,42 @@
     output = G_define_standard_option(G_OPT_R_OUTPUT);
     output->description = _("Map with area size (in cells)");
-    par_threshold = G_define_option();	/* input stream mask file - optional */
-    par_threshold->key = "threshold";
-    par_threshold->type = TYPE_INTEGER;
-    par_threshold->answer = "0";
-    par_threshold->description = _("Remove areas lower than (0 for none):");
+    lesser = G_define_option();        /* input stream mask file - optional */
+    lesser->key = "lesser";
+    lesser->type = TYPE_INTEGER;
+    lesser->answer = "0";
+    lesser->description = _("Remove areas lower than (0 for none):");
+    greater = G_define_option();        /* input stream mask file - optional */
+    greater->key = "greater";
+    greater->type = TYPE_INTEGER;
+    greater->answer = "-1";
+    greater->description = _("Remove areas greater than (-1 for none):");
     flag_binary = G_define_flag();
     flag_binary->key = 'b';
     flag_binary->description = _("Binary output");
     if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
+        exit(EXIT_FAILURE);
-    threshold = atof(par_threshold->answer);
     binary = (flag_binary->answer != 0);
     mapset = (char *)G_find_raster2(input->answer, "");
     if (mapset == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), input->answer);
+        G_fatal_error(_("Raster map <%s> not found"), input->answer);
     infd = Rast_open_old(input->answer, mapset);
     Rast_get_cellhd(input->answer, mapset, &cellhd);
+    les = atof(lesser->answer);
+    grt = atof(greater->answer);
+    gt = grt > 0 ? grt : cellhd.rows * cellhd.cols;
     if (Rast_map_type(input->answer, mapset) != CELL_TYPE)
-	G_fatal_error(_("<%s> is not of type CELL, probably not crated with r.clump"),
-		      input->answer);
+        G_fatal_error(_("<%s> is not of type CELL, probably not crated with r.clump"),
+                      input->answer);
     Rast_init_range(&range);
     Rast_read_range(input->answer, mapset, &range);
@@ -101,28 +108,28 @@
     G_message(_("Reading..."));
     for (row = 0; row < nrows; row++) {
-	G_percent(row, nrows, 2);
-	Rast_get_row(infd, in_buf, row, CELL_TYPE);
+        G_percent(row, nrows, 2);
+        Rast_get_row(infd, in_buf, row, CELL_TYPE);
-	for (col = 0; col < ncols; col++) {
-	    if (!Rast_is_c_null_value(&in_buf[col])) {
-		if (in_buf[col] < c_min || in_buf[col] > c_max)
-		    G_fatal_error(_("Value at row %d, col %d out of range: %d"),
-				  row, col, in_buf[col]);
-		ncells[in_buf[col]]++;
-    }				/* end for row */
+        for (col = 0; col < ncols; col++) {
+            if (!Rast_is_c_null_value(&in_buf[col])) {
+                if (in_buf[col] < c_min || in_buf[col] > c_max)
+                    G_fatal_error(_("Value at row %d, col %d out of range: %d"),
+                                  row, col, in_buf[col]);
+                ncells[in_buf[col]]++;
+    }                                /* end for row */
-    if (threshold) {
-	for (i = 1; i < c_max; ++i)
-	    if (ncells[i] < threshold)
-		ncells[i] = -1;
+    if (les) {
+        for (i = 1; i < c_max; ++i)
+            if (ncells[i] < les || ncells[i] > gt)
+                ncells[i] = -1;
     if (binary) {
-	    ncells[i] = ncells[i] < threshold ? -1 : 1;
+            ncells[i] = ncells[i] < les ? -1 : 1;
     outfd = Rast_open_new(output->answer, CELL_TYPE);
@@ -130,22 +137,21 @@
     G_message(_("Writing..."));
-	    if (Rast_is_c_null_value(&in_buf[col]) ||
-		ncells[in_buf[col]] == -1)
-		if (binary)
-		    out_buf[col] = 0;
-		else
-		    Rast_set_c_null_value(&out_buf[col], 1);
-	    else
-		out_buf[col] = ncells[in_buf[col]];
-	Rast_put_row(outfd, out_buf, CELL_TYPE);
+            if (Rast_is_c_null_value(&in_buf[col]) || ncells[in_buf[col]] == -1)
+                if (binary)
+                    out_buf[col] = 0;
+                else
+                    Rast_set_c_null_value(&out_buf[col], 1);
+            else
+                out_buf[col] = ncells[in_buf[col]];
+        Rast_put_row(outfd, out_buf, CELL_TYPE);
     G_free(ncells);
     G_free(in_buf);
