[GRASS-SVN] r60409 - grass/trunk/lib/gis
Thu May 22 06:42:25 PDT 2014
Author: hcho
Date: 2014-05-22 06:42:25 -0700 (Thu, 22 May 2014)
New Revision: 60409
   grass/trunk/lib/gis/area.c
libgis: Fixed the description for G_area_of_polygon
Modified: grass/trunk/lib/gis/area.c
--- grass/trunk/lib/gis/area.c	2014-05-22 09:30:25 UTC (rev 60408)
+++ grass/trunk/lib/gis/area.c	2014-05-22 13:42:25 UTC (rev 60409)
@@ -143,12 +143,6 @@
  * <i>n</i> pairs of <i>x,y</i> coordinate vertices. It is used both for
  * planimetric and latitude-longitude projections.
- * Returns the area in coordinate units of the polygon described by
- * the <i>n</i> pairs of <i>x,y</i> coordinate vertices for
- * planimetric grids.  If the units for <i>x,y</i> are meters, then
- * the area is in square meters.  If the units are feet, then the area
- * is in square feet, and so on.
  * You should call G_begin_polygon_area_calculations() function before
  * calling this function.
@@ -160,7 +154,7 @@
  * \param y array of y coordinates
  * \param n number of x,y coordinate pairs
- * \return area in coordinate units of the polygon
+ * \return area in square meters of the polygon
 double G_area_of_polygon(const double *x, const double *y, int n)
