[GRASS-SVN] r60415 - in grass/branches/releasebranch_7_0: include/defs lib/gis misc/m.measure raster/r.surf.area vector/v.to.db
Thu May 22 08:08:04 PDT 2014
Author: hcho
Date: 2014-05-22 08:08:04 -0700 (Thu, 22 May 2014)
New Revision: 60415
   grass/branches/releasebranch_7_0/include/defs/gis.h
   grass/branches/releasebranch_7_0/lib/gis/units.c
   grass/branches/releasebranch_7_0/misc/m.measure/main.c
   grass/branches/releasebranch_7_0/raster/r.surf.area/area.c
   grass/branches/releasebranch_7_0/vector/v.to.db/units.c
libgis, r.surf.area, v.to.db, m.measure: Renamed G_units_to_meters_factor* to G_meters_to_units_factor* (merge from r60414)
Modified: grass/branches/releasebranch_7_0/include/defs/gis.h
--- grass/branches/releasebranch_7_0/include/defs/gis.h	2014-05-22 15:00:16 UTC (rev 60414)
+++ grass/branches/releasebranch_7_0/include/defs/gis.h	2014-05-22 15:08:04 UTC (rev 60415)
@@ -662,8 +662,8 @@
 void G_trim_decimal(char *);
 /* units.c */
-double G_units_to_meters_factor(int);
-double G_units_to_meters_factor_sq(int);
+double G_meters_to_units_factor(int);
+double G_meters_to_units_factor_sq(int);
 const char *G_get_units_name(int, int, int);
 int G_units(const char *);
 int G_is_units_type_spatial(int);
Modified: grass/branches/releasebranch_7_0/lib/gis/units.c
--- grass/branches/releasebranch_7_0/lib/gis/units.c	2014-05-22 15:00:16 UTC (rev 60414)
+++ grass/branches/releasebranch_7_0/lib/gis/units.c	2014-05-22 15:08:04 UTC (rev 60415)
@@ -19,7 +19,7 @@
 #include <grass/glocale.h>
-  \brief Units conversion to meters
+  \brief Units conversion from meters to units
   Units codes (gis.h):
    - U_METERS
@@ -27,14 +27,13 @@
    - U_MILES
    - U_FEET
-  Returns a factor which converts the grid unit to meters (by
-  multiplication).
+  Returns a factor which converts meters to units (by multiplication).
   \param units units code
   \return factor
-double G_units_to_meters_factor(int units)
+double G_meters_to_units_factor(int units)
     switch (units) {
     case U_METERS:
@@ -62,7 +61,7 @@
-  \brief Units conversion to square meters
+  \brief Units conversion from square meters to square units
    - U_METERS
@@ -72,14 +71,14 @@
    - U_MILES
    - U_FEET
-  Returns a factor which converts the grid unit to square meters (by
+  Returns a factor which converts square meters to square units (by
   multiplication).
   \return factor
-double G_units_to_meters_factor_sq(int units)
+double G_meters_to_units_factor_sq(int units)
     switch (units) {
     case U_METERS:
Modified: grass/branches/releasebranch_7_0/misc/m.measure/main.c
--- grass/branches/releasebranch_7_0/misc/m.measure/main.c	2014-05-22 15:00:16 UTC (rev 60414)
+++ grass/branches/releasebranch_7_0/misc/m.measure/main.c	2014-05-22 15:08:04 UTC (rev 60415)
@@ -82,8 +82,8 @@
 	units_name    = G_get_units_name(G_units(units->answer), 1, 0);
 	sq_units_name = G_get_units_name(G_units(units->answer), 1, 1);
-    f    = G_units_to_meters_factor(G_units(units->answer));
-    sq_f = G_units_to_meters_factor_sq(G_units(units->answer));
+    f    = G_meters_to_units_factor(G_units(units->answer));
+    sq_f = G_meters_to_units_factor_sq(G_units(units->answer));
     G_debug(1, "using '%s (%f) %s (%f)'",
 	    units_name, f, sq_units_name, sq_f);
Modified: grass/branches/releasebranch_7_0/raster/r.surf.area/area.c
--- grass/branches/releasebranch_7_0/raster/r.surf.area/area.c	2014-05-22 15:00:16 UTC (rev 60414)
+++ grass/branches/releasebranch_7_0/raster/r.surf.area/area.c	2014-05-22 15:08:04 UTC (rev 60415)
@@ -120,5 +120,5 @@
     if (units == U_UNDEFINED)
 	return value;
-    return value * G_units_to_meters_factor_sq(units);
+    return value * G_meters_to_units_factor_sq(units);
Modified: grass/branches/releasebranch_7_0/vector/v.to.db/units.c
--- grass/branches/releasebranch_7_0/vector/v.to.db/units.c	2014-05-22 15:00:16 UTC (rev 60414)
+++ grass/branches/releasebranch_7_0/vector/v.to.db/units.c	2014-05-22 15:08:04 UTC (rev 60415)
@@ -7,8 +7,8 @@
     double f, sq_f;
     rad  = 0;
-    f    = G_units_to_meters_factor(options.units);
-    sq_f = G_units_to_meters_factor_sq(options.units);
+    f    = G_meters_to_units_factor(options.units);
+    sq_f = G_meters_to_units_factor_sq(options.units);
     if (options.units == U_RADIANS)
 	rad = 1;
