[GRASS-SVN] r60449 - grass/branches/releasebranch_7_0/general/g.mremove
Fri May 23 05:18:17 PDT 2014
Author: hcho
Date: 2014-05-23 05:18:17 -0700 (Fri, 23 May 2014)
New Revision: 60449
   grass/branches/releasebranch_7_0/general/g.mremove/main.c
g.mremove: description refined. regular expression => search pattern (merge from r60447)
Modified: grass/branches/releasebranch_7_0/general/g.mremove/main.c
--- grass/branches/releasebranch_7_0/general/g.mremove/main.c	2014-05-23 12:17:14 UTC (rev 60448)
+++ grass/branches/releasebranch_7_0/general/g.mremove/main.c	2014-05-23 12:18:17 UTC (rev 60449)
@@ -63,7 +63,7 @@
     G_add_keyword(_("remove"));
     module->description =
 	_("Removes data base element files from "
-	  "the user's current mapset using regular expressions.");
+	  "the user's current mapset using the search pattern.");
     flag.regex = G_define_flag();
     flag.regex->key = 'r';
     flag.regex->description =
