[GRASS-SVN] r60567 - grass/trunk/lib/python/pygrass/modules/interface
Wed May 28 14:51:40 PDT 2014
Author: neteler
Date: 2014-05-28 14:51:40 -0700 (Wed, 28 May 2014)
New Revision: 60567
   grass/trunk/lib/python/pygrass/modules/interface/module.py
pygrass: fix error message
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py	2014-05-28 21:43:24 UTC (rev 60566)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py	2014-05-28 21:51:40 UTC (rev 60567)
@@ -373,7 +373,7 @@
                 if ((k in self.inputs and self.inputs[k].value is None) or
                         (k in self.outputs and self.outputs[k].value is None)):
                     msg = "Required parameter <%s> not set."
-                    raise ParameterError(msg % key)
+                    raise ParameterError(msg % k)
             return self.run()
