[GRASS-SVN] r62560 - in grass/trunk: gui/wxpython/xml raster raster/r.stream.extract
Sun Nov 2 14:25:13 PST 2014
Author: neteler
Date: 2014-11-02 14:25:13 -0800 (Sun, 02 Nov 2014)
New Revision: 62560
Removed:
   grass/trunk/raster/r.stream.channel/
   grass/trunk/raster/r.stream.distance/
   grass/trunk/raster/r.stream.order/
   grass/trunk/raster/r.stream.segment/
   grass/trunk/raster/r.stream.slope/
   grass/trunk/raster/r.stream.snap/
   grass/trunk/raster/r.stream.stats/
   grass/trunk/gui/wxpython/xml/toolboxes.xml
   grass/trunk/raster/Makefile
   grass/trunk/raster/r.stream.extract/r.stream.extract.html
selected r.stream modules: removed r.stream.channel, r.stream.distance, r.stream.order, r.stream.segment, r.stream.slope, r.stream.snap, r.stream.stats as moved back to Addons (r62511 and r62512)
Modified: grass/trunk/gui/wxpython/xml/toolboxes.xml
--- grass/trunk/gui/wxpython/xml/toolboxes.xml	2014-11-02 22:16:25 UTC (rev 62559)
+++ grass/trunk/gui/wxpython/xml/toolboxes.xml	2014-11-02 22:25:13 UTC (rev 62560)
@@ -857,30 +857,9 @@
         <label>Watershed basin creation</label>
       </module-item>
       <separator/>
-      <module-item name="r.stream.channel">
-        <label>Stream channel characteristics</label>
-      </module-item>
-      <module-item name="r.stream.distance">
-        <label>Stream distance and elevation characteristics</label>
-      </module-item>
       <module-item name="r.stream.extract">
         <label>Extraction of stream networks</label>
       </module-item>
-      <module-item name="r.stream.order">
-        <label>Stream ordering and hierarchy</label>
-      </module-item>
-      <module-item name="r.stream.segment">
-        <label>Stream segment characteristics</label>
-      </module-item>
-      <module-item name="r.stream.slope">
-        <label>Stream elevation change</label>
-      </module-item>
-      <module-item name="r.stream.snap">
-        <label>Position correction of water outlet point</label>
-      </module-item>
-      <module-item name="r.stream.stats">
-        <label>Horton's statistics</label>
-      </module-item>
       <separator/>
       <module-item name="r.sim.water">
         <label>SIMWE Overland flow modeling</label>
Modified: grass/trunk/raster/Makefile
--- grass/trunk/raster/Makefile	2014-11-02 22:16:25 UTC (rev 62559)
+++ grass/trunk/raster/Makefile	2014-11-02 22:25:13 UTC (rev 62560)
@@ -95,14 +95,7 @@
 	r.stats.zonal \
 	r.stats.quantile \
 	r.stats \
-	r.stream.channel \
-	r.stream.distance \
 	r.stream.extract \
-	r.stream.order \
-	r.stream.segment \
-	r.stream.slope \
-	r.stream.snap \
-	r.stream.stats \
 	r.sun \
 	r.sunhours \
 	r.sunmask \
Modified: grass/trunk/raster/r.stream.extract/r.stream.extract.html
--- grass/trunk/raster/r.stream.extract/r.stream.extract.html	2014-11-02 22:16:25 UTC (rev 62559)
+++ grass/trunk/raster/r.stream.extract/r.stream.extract.html	2014-11-02 22:25:13 UTC (rev 62560)
@@ -229,13 +229,13 @@
 <em>
 <a href="r.mapcalc.html">r.mapcalc</a>,
 <a href="r.param.scale.html">r.param.scale</a>,
-<a href="r.stream.channel.html">r.stream.channel</a>,
-<a href="r.stream.distance.html">r.stream.distance</a>,
-<a href="r.stream.order.html">r.stream.order</a>,
-<a href="r.stream.segment.html">r.stream.segment</a>,
-<a href="r.stream.slope.html">r.stream.slope</a>,
-<a href="r.stream.snap.html">r.stream.snap</a>,
-<a href="r.stream.stats.html">r.stream.stats</a>,
+<a href="http://grass.osgeo.org/grass70/manuals/addons/r.stream.channel.html">r.stream.channel</a> (Addon),
+<a href="http://grass.osgeo.org/grass70/manuals/addons/r.stream.distance.html">r.stream.distance</a> (Addon),
+<a href="http://grass.osgeo.org/grass70/manuals/addons/r.stream.order.html">r.stream.order</a> (Addon),
+<a href="http://grass.osgeo.org/grass70/manuals/addons/r.stream.segment.html">r.stream.segment</a> (Addon),
+<a href="http://grass.osgeo.org/grass70/manuals/addons/r.stream.slope.html">r.stream.slope</a> (Addon),
+<a href="http://grass.osgeo.org/grass70/manuals/addons/r.stream.snap.html">r.stream.snap</a> (Addon),
+<a href="http://grass.osgeo.org/grass70/manuals/addons/r.stream.stats.html">r.stream.stats</a> (Addon),
 <a href="r.terraflow.html">r.terraflow</a>,
 <a href="r.thin.html">r.thin</a>,
 <a href="r.to.vect.html">r.to.vect</a>,
