[GRASS-SVN] r62565 - grass/trunk/temporal/t.vect.what.strds
Sun Nov 2 15:42:46 PST 2014
Author: annakrat
Date: 2014-11-02 15:42:46 -0800 (Sun, 02 Nov 2014)
New Revision: 62565
   grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
temporal: fix g.remove call
Modified: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
--- grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py	2014-11-02 23:13:51 UTC (rev 62564)
+++ grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py	2014-11-02 23:42:46 UTC (rev 62565)
@@ -184,7 +184,7 @@
        rastermap))
                 if aggreagated_map_name:
-                    ret = grass.run_command("g.remove", flags='f', type=rast,
+                    ret = grass.run_command("g.remove", flags='f', type='rast',
                                             name=aggreagated_map_name)
                     if ret != 0:
                         dbif.close()
