[GRASS-SVN] r62573 - grass/trunk/gui/wxpython/docs
Mon Nov 3 07:27:44 PST 2014
Author: annakrat
Date: 2014-11-03 07:27:44 -0800 (Mon, 03 Nov 2014)
New Revision: 62573
   grass/trunk/gui/wxpython/docs/wxGUI.html
wxGUI/docs: clarify misleading text about removing/renaming layers
Modified: grass/trunk/gui/wxpython/docs/wxGUI.html
--- grass/trunk/gui/wxpython/docs/wxGUI.html	2014-11-03 15:16:30 UTC (rev 62572)
+++ grass/trunk/gui/wxpython/docs/wxGUI.html	2014-11-03 15:27:44 UTC (rev 62573)
@@ -104,7 +104,7 @@
 <p>
 A right mouse click on a layer or left clicking the button to the right of
 the layer opens a dropdown menu with options to remove or rename the layer
-(g.remove, g.rename), change its display properties (d.rast and d.vect
+(not the actual map), change its display properties (d.rast and d.vect
 options such as color, symbol, etc.), show its metadata (r.info, v.info) or
 attributes, if applicable.
 <p>
