[GRASS-SVN] r62581 - in grass-addons/grass7: display/d.mon2 gui/wxpython/newgui vector/v.out.png
Mon Nov 3 10:43:48 PST 2014
Author: martinl
Date: 2014-11-03 10:43:48 -0800 (Mon, 03 Nov 2014)
New Revision: 62581
   grass-addons/grass7/display/d.mon2/d.mon2.py
   grass-addons/grass7/gui/wxpython/newgui/render2.py
   grass-addons/grass7/vector/v.out.png/v.out.png.py
update grass7 addons: r62577
Modified: grass-addons/grass7/display/d.mon2/d.mon2.py
--- grass-addons/grass7/display/d.mon2/d.mon2.py	2014-11-03 18:41:40 UTC (rev 62580)
+++ grass-addons/grass7/display/d.mon2/d.mon2.py	2014-11-03 18:43:48 UTC (rev 62581)
@@ -19,13 +19,13 @@
 #%Option
 #% key: width
 #% type: integer
-#% description: Width for display monitor if not set by GRASS_WIDTH
+#% description: Width for display monitor if not set by GRASS_RENDER_WIDTH
 #% answer: 800
 #%End
 #%Option
 #% key: height
 #% type: integer
-#% description: Height for display monitor if not set by GRASS_HEIGHT
+#% description: Height for display monitor if not set by GRASS_RENDER_HEIGHT
 #% answer: 600
 #%End
 #%Option
@@ -77,7 +77,7 @@
     if options['tempfile']:
         img_tmp = options['tempfile']
-        #TODO: add option for GRASS_PNG_COMPRESSION=0,1-9
+        #TODO: add option for GRASS_RENDER_FILE_COMPRESSION=0,1-9
     else:
         img_tmp = grass.tempfile()
         os.remove(img_tmp)
@@ -85,18 +85,18 @@
     if flags['b']:
-        print('GRASS_PNGFILE="%s"' % img_tmp)
-        if not os.environ.has_key("GRASS_WIDTH"):
-            print('GRASS_WIDTH=%s' % options['width'])
-        if not os.environ.has_key("GRASS_HEIGHT"):
-           print('GRASS_HEIGHT=%s' % options['height'])
+        print('GRASS_RENDER_FILE="%s"' % img_tmp)
+        if not os.environ.has_key("GRASS_RENDER_WIDTH"):
+            print('GRASS_RENDER_WIDTH=%s' % options['width'])
+        if not os.environ.has_key("GRASS_RENDER_HEIGHT"):
+           print('GRASS_RENDER_HEIGHT=%s' % options['height'])
         if flags['c']:
             print('GRASS_RENDER_IMMEDIATE=cairo')
         else:
             print('GRASS_RENDER_IMMEDIATE=PNG')
-        print('GRASS_PNG_MAPPED=TRUE')
-        print('GRASS_PNG_READ=TRUE')
-        print('export GRASS_PNGFILE GRASS_WIDTH GRASS_HEIGHT GRASS_RENDER_IMMEDIATE GRASS_PNG_MAPPED GRASS_PNG_READ;')
+        print('GRASS_RENDER_FILE_MAPPED=TRUE')
+        print('GRASS_RENDER_FILE_READ=TRUE')
+        print('export GRASS_RENDER_FILE GRASS_RENDER_WIDTH GRASS_RENDER_HEIGHT GRASS_RENDER_IMMEDIATE GRASS_RENDER_FILE_MAPPED GRASS_RENDER_FILE_READ;')
         print('d.erase bgcolor=%s;' % options['color'])
         if handler == "none":
@@ -119,15 +119,15 @@
     if not grass.find_program(handler, '--help'):
         grass.fatal(_("'%s' not found.") % handler)
-    os.environ['GRASS_PNGFILE'] = img_tmp
-        os.environ['GRASS_WIDTH'] = options['width']
-        os.environ['GRASS_HEIGHT'] = options['height']
+    os.environ['GRASS_RENDER_FILE'] = img_tmp
+        os.environ['GRASS_RENDER_WIDTH'] = options['width']
+        os.environ['GRASS_RENDER_HEIGHT'] = options['height']
     if flags['c']:
         os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
-    os.environ['GRASS_PNG_MAPPED'] = 'TRUE'
-    os.environ['GRASS_PNG_READ'] = 'TRUE'
+    os.environ['GRASS_RENDER_FILE_MAPPED'] = 'TRUE'
+    os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
     #? os.environ['GRASS_PNG_AUTO_WRITE'] = 'FALSE'
     grass.run_command('d.erase', bgcolor = options['color'])
Modified: grass-addons/grass7/gui/wxpython/newgui/render2.py
--- grass-addons/grass7/gui/wxpython/newgui/render2.py	2014-11-03 18:41:40 UTC (rev 62580)
+++ grass-addons/grass7/gui/wxpython/newgui/render2.py	2014-11-03 18:43:48 UTC (rev 62581)
@@ -135,7 +135,7 @@
                                  {'type' : self.type, 'name' : self.name})
         if self.mapfile:
-            os.environ["GRASS_PNGFILE"] = self.mapfile
+            os.environ["GRASS_RENDER_FILE"] = self.mapfile
         # execute command
         try:
@@ -146,9 +146,9 @@
                     if ret != 0:
                         break
                     if not read:
-                        os.environ["GRASS_PNG_READ"] = "TRUE"
+                        os.environ["GRASS_RENDER_FILE_READ"] = "TRUE"
-                os.environ["GRASS_PNG_READ"] = "FALSE"
+                os.environ["GRASS_RENDER_FILE_READ"] = "FALSE"
             else:
                 ret, msg = self._runCommand(self.cmd)
             if ret != 0:
@@ -166,8 +166,8 @@
                 f = None
         # stop monitor
-        if self.mapfile and "GRASS_PNGFILE" in os.environ:
-            del os.environ["GRASS_PNGFILE"]
+        if self.mapfile and "GRASS_RENDER_FILE" in os.environ:
+            del os.environ["GRASS_RENDER_FILE"]
         self.forceRender = False
@@ -405,11 +405,11 @@
         self.receiver = None
         # GRASS environment variable (for rendering)
-        self.env = {"GRASS_BACKGROUNDCOLOR" : "FFFFFF",
+        self.env = {"GRASS_RENDER_BACKGROUNDCOLOR" : "FFFFFF",
                "GRASS_COMPRESSION"     : "0",
-               "GRASS_TRUECOLOR"       : "TRUE",
+               "GRASS_RENDER_TRUECOLOR"       : "TRUE",
                "GRASS_TRANSPARENT"     : "TRUE",
-               "GRASS_PNG_READ"        : "FALSE",
+               "GRASS_RENDER_FILE_READ"        : "FALSE",
         for k, v in self.env.iteritems():
@@ -947,8 +947,8 @@
         tmp_region = os.getenv("GRASS_REGION")
         os.environ["GRASS_REGION"] = self.SetRegion(windres)
-        os.environ["GRASS_WIDTH"]  = str(self.width)
-        os.environ["GRASS_HEIGHT"] = str(self.height)
+        os.environ["GRASS_RENDER_WIDTH"]  = str(self.width)
+        os.environ["GRASS_RENDER_HEIGHT"] = str(self.height)
         driver = UserSettings.Get(group = 'display', key = 'driver', subkey = 'type')
         if driver == 'png':
             os.environ["GRASS_RENDER_IMMEDIATE"] = "png"
Modified: grass-addons/grass7/vector/v.out.png/v.out.png.py
--- grass-addons/grass7/vector/v.out.png/v.out.png.py	2014-11-03 18:41:40 UTC (rev 62580)
+++ grass-addons/grass7/vector/v.out.png/v.out.png.py	2014-11-03 18:43:48 UTC (rev 62581)
@@ -59,10 +59,10 @@
 def main():
     os.environ['GRASS_RENDER_IMMEDIATE'] = 'png'
-    os.environ['GRASS_PNGFILE'] = options['output']
-    os.environ['GRASS_PNG_COMPRESSION'] = options['compression']
+    os.environ['GRASS_RENDER_FILE'] = options['output']
+    os.environ['GRASS_RENDER_FILE_COMPRESSION'] = options['compression']
     monitor_old = None
     genv = gisenv()
