[GRASS-SVN] r62626 - in grass/trunk/temporal/t.rast.aggregate: . testsuite
Wed Nov 5 12:30:53 PST 2014
Author: huhabla
Date: 2014-11-05 12:30:53 -0800 (Wed, 05 Nov 2014)
New Revision: 62626
Added:
   grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
   grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py
Removed:
   grass/trunk/temporal/t.rast.aggregate/testsuite/test.t.rast.aggregate.relative_time.sh
   grass/trunk/temporal/t.rast.aggregate/testsuite/test.t.rast.aggregate.sh
   grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
temporal modules: fixed aggregation computation, converted bash tests into python tests
Modified: grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
--- grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py	2014-11-05 20:29:17 UTC (rev 62625)
+++ grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py	2014-11-05 20:30:53 UTC (rev 62626)
@@ -176,7 +176,12 @@
         output_strds = tgis.open_new_stds(output, "strds", temporal_type,
        title, description, semantic_type,
        dbif, gcore.overwrite())
-        tgis.register_map_object_list("rast", output_list,  output_strds,  register_null,
+        if register_null:
+            register_null=False
+        else:
+            register_null=True
+        tgis.register_map_object_list("rast", output_list,  output_strds, register_null,
                                                        sp.get_relative_time_unit(),  dbif)
         # Update the raster metadata table entries with aggregation type
Deleted: grass/trunk/temporal/t.rast.aggregate/testsuite/test.t.rast.aggregate.relative_time.sh
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test.t.rast.aggregate.relative_time.sh	2014-11-05 20:29:17 UTC (rev 62625)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test.t.rast.aggregate.relative_time.sh	2014-11-05 20:30:53 UTC (rev 62626)
@@ -1,42 +0,0 @@
-#!/bin/sh
-# Space time raster dataset aggregation
-# We need to set a specific region in the
-# @preprocess step of this test.
-# The region setting should work for UTM and LL test locations
-g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-# Data generation
-r.mapcalc --o expr="prec_1 = rand(0, 550)" -s
-r.mapcalc --o expr="prec_2 = rand(0, 450)" -s
-r.mapcalc --o expr="prec_3 = rand(0, 320)" -s
-r.mapcalc --o expr="prec_4 = null()"
-r.mapcalc --o expr="prec_5 = rand(0, 300)" -s
-r.mapcalc --o expr="prec_6 = rand(0, 650)" -s
-t.create --o type=strds temporaltype=relative output=precip_abs1 title="A test" descr="A test"
-t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start=0 unit=days increment=3
-# The first @test
-t.rast.aggregate --o --v input=precip_abs1 output=precip_abs2 base=prec_sum \
-    granularity=6 method=average sampling=overlaps,overlapped,contains -ns nprocs=2
-t.info type=strds input=precip_abs2
-t.rast.list input=precip_abs2
-    granularity=9 method=maximum sampling=contains offset=130 nprocs=3
-    granularity=4 method=minimum sampling=contains -s
-    granularity=5 method=sum sampling=overlaps,overlapped,contains -n
-t.remove -rf type=strds input=precip_abs1,precip_abs2
Deleted: grass/trunk/temporal/t.rast.aggregate/testsuite/test.t.rast.aggregate.sh
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test.t.rast.aggregate.sh	2014-11-05 20:29:17 UTC (rev 62625)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test.t.rast.aggregate.sh	2014-11-05 20:30:53 UTC (rev 62626)
@@ -1,51 +0,0 @@
-#!/bin/sh
-export GRASS_OVERWRITE=1
-# Generate data
-r.mapcalc expr="prec_1 = rand(0, 550)" -s
-r.mapcalc expr="prec_2 = rand(0, 450)" -s
-r.mapcalc expr="prec_3 = rand(0, 320)" -s
-r.mapcalc expr="prec_4 = rand(0, 510)" -s
-r.mapcalc expr="prec_5 = rand(0, 300)" -s
-r.mapcalc expr="prec_6 = rand(0, 650)" -s
-r.mapcalc expr="prec_7 = null()"
-t.create type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6,prec_7 \
-    start="2001-01-15 12:05:45" increment="14 days"
-# The first @test
-t.rast.aggregate --v input=precip_abs1 output=precip_abs2 \
-    base=prec_sum granularity="2 days" method=average \
-    sampling=overlaps,overlapped,during nprocs=5 -sn
-t.rast.list input=precip_abs1
-    base=prec_sum granularity="1 months" method=maximum \
-    sampling=contains nprocs=5 -n
-t.rast.aggregate --v input=precip_abs1 output=precip_abs3 offset=10 \
-    base=prec_sum granularity="2 months" method=minimum \
-    sampling=contains
-t.info type=strds input=precip_abs3
-t.rast.list input=precip_abs3
-t.rast.aggregate --v input=precip_abs1 output=precip_abs4 offset=100 \
-    base=prec_sum granularity="3 months" method=sum \
-    sampling=contains
-t.info type=strds input=precip_abs4
-t.rast.list input=precip_abs4
-t.remove -rf type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4
Added: grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py	2014-11-05 20:30:53 UTC (rev 62626)
@@ -0,0 +1,178 @@
+"""Test t.rast.aggregation
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert
+import os
+import grass.pygrass.modules as pymod
+import grass.temporal as tgis
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestUnregister(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """Initiate the temporal GIS and set the region
+        tgis.init()
+        cls.use_temp_region()
+        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,
+                      t=50,  res=10,  res3=10)
+        cls.runModule("r.mapcalc", expression="a1 = 100",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a2 = 200",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a3 = 300",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a4 = 400",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a5 = 500",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a6 = 600",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a7 = null()",  overwrite=True)
+        cls.runModule("t.create",  type="strds",  temporaltype="absolute",
+                                    output="A",  title="A test",
+                                    description="A test",  overwrite=True)
+        cls.runModule("t.register", flags="i",  type="rast",  input="A",
+                                     maps="a1,a2,a3,a4,a5,a6,a7",
+                                     start="2001-01-15 12:05:45",
+                                     increment="14 days",
+                                     overwrite=True)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the temporary region
+        cls.del_temp_region()
+        cls.runModule("t.remove", flags="rf", type="strds", inputs="A")
+    def tearDown(self):
+        """Remove generated data"""
+        self.runModule("t.remove", flags="rf", type="strds", inputs="B")
+    def test_disaggregation(self):
+        """Disaggregation with empty maps"""
+        self.assertModule("t.rast.aggregate", input="A", output="B",
+                          basename="b", granularity="2 days",
+                          method="average",
+                          sampling=["overlaps","overlapped","during"],
+                          nprocs=2, flags="n")
+        tinfo_string="""start_time=2001-01-15 00:00:00
+                        end_time=2001-04-25 00:00:00
+                        granularity=2 days
+                        aggregation_type=average
+                        number_of_maps=50
+                        map_time=interval
+                        min_min=100.0
+                        min_max=600.0
+                        max_min=100.0
+                        max_max=600.0"""
+        info = SimpleModule("t.info", flags="g", input="B")
+        #info.run()
+        #print info.outputs.stdout
+        self.assertModuleKeyValue(module=info, reference=tinfo_string,
+                                  precision=2, sep="=")
+    def test_aggregation_1month(self):
+        """Aggregation one month"""
+                          basename="b", granularity="1 months",
+                          method="maximum", sampling=["contains"],
+                          nprocs=3, flags="s")
+        tinfo_string="""start_time=2001-01-01 00:00:00
+                        end_time=2001-04-01 00:00:00
+                        granularity=1 month
+                        map_time=interval
+                        aggregation_type=maximum
+                        number_of_maps=3
+                        min_min=100.0
+                        min_max=500.0
+                        max_min=100.0
+                        max_max=500.0"""
+        #info.run()
+        # Check the map names are correct
+        lister = SimpleModule("t.rast.list", input="B", columns="name",
+                              flags="s")
+        self.runModule(lister)
+        #print lister.outputs.stdout
+        maps="b_2001_01" + os.linesep + "b_2001_02" + os.linesep + \
+             "b_2001_03" + os.linesep
+        self.assertEqual(maps, lister.outputs.stdout)
+    def test_aggregation_2months(self):
+        """Aggregation two month"""
+                          basename="b", granularity="2 months",
+                          method="minimum", sampling=["contains"],
+                          nprocs=4, offset=10)
+                        end_time=2001-05-01 00:00:00
+                        granularity=2 months
+                        map_time=interval
+                        aggregation_type=minimum
+                        number_of_maps=2
+                        min_min=100.0
+                        min_max=500.0
+                        max_min=100.0
+                        max_max=500.0"""
+        #info.run()
+                              flags="s")
+        maps="b_11" + os.linesep + "b_12" + os.linesep
+    def test_aggregation_3months(self):
+        """Aggregation three month"""
+                          basename="b", granularity="3 months",
+                          method="sum", sampling=["contains"],
+                          nprocs=9, offset=100)
+                        granularity=3 months
+                        map_time=interval
+                        aggregation_type=sum
+                        number_of_maps=1
+                        min_min=1500.0
+                        min_max=1500.0
+                        max_min=1500.0
+                        max_max=1500.0"""
+        #info.run()
+                              flags="s")
+        maps="b_101" + os.linesep
+if __name__ == '__main__':
+    from grass.gunittest.main import test
+    test()
Added: grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py	2014-11-05 20:30:53 UTC (rev 62626)
@@ -0,0 +1,162 @@
+for details.
+import os
+    @classmethod
+        tgis.init()
+        cls.runModule("t.create",  type="strds",  temporaltype="relative",
+                                     start=0, unit="days", increment=3,
+                                     overwrite=True)
+    @classmethod
+    def test_1(self):
+        """Simple test"""
+                          basename="b", granularity=6,
+                          method="average",
+                          sampling=["overlaps","overlapped","contains"],
+                          nprocs=2)
+        tinfo_string="""start_time=0
+                        end_time=18
+                        unit=days
+                        granularity=6
+                        map_time=interval
+                        number_of_maps=3
+                        min_min=150.0
+                        min_max=550.0
+                        max_min=150.0
+                        max_max=550.0"""
+        #info.run()
+    def test_2(self):
+        """Simple test register null maps"""
+                          basename="b", granularity=9,
+                          method="maximum",
+                          sampling=["contains"],
+                          nprocs=4, flags="n")
+        tinfo_string="""semantic_type=mean
+                        start_time=0
+                        end_time=27
+                        unit=days
+                        granularity=9
+                        map_time=interval
+                        number_of_maps=3
+                        min_min=300.0
+                        min_max=600.0
+                        max_min=300.0
+                        max_max=600.0"""
+        #info.run()
+    def test_3(self):
+        """Simple test"""
+                          method="maximum",
+                          nprocs=4)
+                        start_time=0
+                        end_time=18
+                        unit=days
+                        granularity=9
+                        map_time=interval
+                        number_of_maps=2
+                        min_min=300.0
+                        min_max=600.0
+                        max_min=300.0
+                        max_max=600.0"""
+        #info.run()
+    def test_4(self):
+        """Simple test"""
+                          basename="b", granularity=21,
+                          method="average",
+                          nprocs=4)
+                        start_time=0
+                        end_time=21
+                        unit=days
+                        granularity=21
+                        map_time=interval
+                        number_of_maps=2
+                        min_min=350.0
+                        min_max=350.0
+                        max_min=350.0
+                        max_max=350.0"""
+        #info.run()
+    test()
