[GRASS-SVN] r62669 - grass-addons/grass7/vector/v.fixed.segmentpoints
Sat Nov 8 08:23:59 PST 2014
Author: hellik
Date: 2014-11-08 08:23:59 -0800 (Sat, 08 Nov 2014)
New Revision: 62669
Added:
   grass-addons/grass7/vector/v.fixed.segmentpoints/Makefile
   grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html
   grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py
v.fixed.segmentpoints addon - step 2
Added: grass-addons/grass7/vector/v.fixed.segmentpoints/Makefile
--- grass-addons/grass7/vector/v.fixed.segmentpoints/Makefile	                        (rev 0)
+++ grass-addons/grass7/vector/v.fixed.segmentpoints/Makefile	2014-11-08 16:23:59 UTC (rev 62669)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.fixed.segmentpoints
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html
--- grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html	2014-11-08 16:23:59 UTC (rev 62669)
@@ -0,0 +1,39 @@
+<h2>DESCRIPTION</h2>
+<em>v.fixed.segmenpoints</em> creates segment points along a vector line
+with fixed distances by using the <em>v.segment</em> module. A category
+of 1 line has to be given. Start and end point of the line will be
+considered.
+<h2>EXAMPLE</h2>
+<div class="code">
+ <pre>
+  # nc sampe data set
+  v.fixed.segmentpoints vector=streams at PERMANENT cat=40102 dir=C:\tmp distance=25
+ </pre>
+</div>
+<h2>DEPENDENCIES</h2>
+<ul>
+<li>v.segment</li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.segment.html">v.segment</a>
+</em>
+<h2>TODO</h2>
+Join exported text file back to segment point vector.
+<h2>AUTHOR</h2>
+Helmut Kudrnovsky
+<p>
+<i>Last changed: $Date: 2014-05-13 23:17:32 +0200 (Di, 13 Mai 2014) $</i>
+</p>
\ No newline at end of file
Added: grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py
--- grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py	                        (rev 0)
+++ grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py	2014-11-08 16:23:59 UTC (rev 62669)
@@ -0,0 +1,159 @@
+#!/usr/bin/env python
+MODULE:    v.fixed.segmentpoints
+AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
+PURPOSE:   Creates segment points along a vector line with fixed distances
+           by using the v.segment module
+COPYRIGHT: (C) 2014 by the GRASS Development Team
+           This program is free software under the GNU General Public
+           License (>=v2). Read the file COPYING that comes with GRASS
+           for details.
+#%module
+#% description: segment points along a vector line with fixed distances
+#% keywords: vector
+#%end
+#%option G_OPT_V_INPUT
+#% key: vector
+#% description: Name of habitat vector map
+#% required: yes
+#%end
+#%option G_OPT_V_CAT
+#% key: cat
+#% description: Category of a vector line
+#% required: yes
+#%end
+#%option G_OPT_M_DIR
+#% key: dir
+#% description: Directory where the output will be found
+#% required : yes
+#%end
+#%option
+#% key: distance
+#% type: double
+#% key_desc: double
+#% description: fixed distance between segment points
+#% required : no
+#% answer: 100
+#%end
+import sys
+import os
+import math
+import grass.script as grass
+if not os.environ.has_key("GISBASE"):
+    grass.message( "You must be in GRASS GIS to run this program." )
+    sys.exit(1)
+def main():
+    vlines = options['vector'].split('@')[0]
+    vcat = options['cat']
+    directory = options['dir']
+    sdistance = options['distance']
+    fpoints = 'segmentpoints.txt'
+    global tmp
+    # Extract vector line
+    grass.message( "Extract vector line for which segment points should be calculated ..." )
+    grass.run_command('v.extract', input = vlines,
+                                     output = 'vlinesingle',
+                                     cats = vcat)
+    grass.message( "Extraction done." )
+    grass.message( "----" )
+    # Calculate vector line length and populate it to the attribute table
+    grass.message( "Calculate vector line length and populate it to the attribute table ..." )
+    grass.run_command("v.db.addcolumn", map = 'vlinesingle',
+                                     layer = 1,
+                                     columns = "vlength double")
+    grass.run_command("v.to.db", map = 'vlinesingle',
+                                     option = 'length',
+                                     layer = 1,
+                                     columns = 'vlength',
+                                     overwrite = True)
+    grass.message( "Calculate vector line length done." )
+    # Read length
+    tmp = grass.read_command('v.to.db', map = 'vlinesingle',
+                                     type = 'line',
+                                     layer = 1,
+                                     qlayer = 1,
+                                     units = 'meters',
+                                     column = 'vlength',
+                                     flags = 'p')
+    vector_line_length = float(tmp.split('\n')[1].split('|')[1])
+    # Print vector line length
+    grass.message( "Vector line length in meter:" )
+    grass.message( vector_line_length )
+    # Calculation number of segment points (start and end point included)
+    # number of segment points without end point
+    number_segmentpoints_without_end = math.floor( vector_line_length / float(sdistance) )
+    number_segmentpoints_with_end = int(number_segmentpoints_without_end + 1)
+    grass.message( "Number of segment points (start and end point included):" )
+    grass.message( number_segmentpoints_with_end )
+    segmentpointsrange_without_end = range(1, number_segmentpoints_with_end, 1)
+    max_distancerange = float(sdistance) * number_segmentpoints_with_end
+    distancesrange_without_end = range(0, int(max_distancerange), int(sdistance))
+    # Write segment point input file for g.segment to G_OPT_M_DIR
+    grass.message( "Write segment point input file for g.segment" )
+    segment_points_file = os.path.join( directory, fpoints )
+    file = open(segment_points_file, 'a')
+    for f, b in zip(segmentpointsrange_without_end, distancesrange_without_end):
+                                     file.write("P %s %s %s\n" % (f, vcat, b))
+    file.close()
+    file.write("P %s %s -0" % (number_segmentpoints_with_end, vcat))
+    file.close()
+    # Give information where output file
+    grass.message( "Segment points file:" )
+    grass.message( segment_points_file )
+    # Run v.segment with the segment point input
+    grass.run_command("v.segment", input = 'vlinesingle',
+                                     output = 'segmentpoints',
+                                     file = segment_points_file)
+    grass.run_command("v.db.addtable", map = 'segmentpoints')
+#    TODO join point segment file to point vector
+#    grass.run_command("db.in.ogr", dsn = segment_points_file,
+#                                     output = 't_segment_points_file')
+    grass.message( "Segment points file created" )
+    # v.fixed.segmentpoints done!
+    grass.message( "v.fixed.segmentpoints done!" )
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
