[GRASS-SVN] r62678 - grass-addons/grass7/vector/v.fixed.segmentpoints
Sun Nov 9 06:15:38 PST 2014
Author: hellik
Date: 2014-11-09 06:15:38 -0800 (Sun, 09 Nov 2014)
New Revision: 62678
   grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html
   grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py
v.fixed.segmentpoints: distance information added to attribute table; attribute table exported as CSV file
Modified: grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html
--- grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html	2014-11-09 10:34:56 UTC (rev 62677)
+++ grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.html	2014-11-09 14:15:38 UTC (rev 62678)
@@ -5,7 +5,9 @@
 of one line has to be given. Start and end point of the line will be
 considered. The distance option is limited to an integer number. As result
 the vectors vlinesingle and segmentpoints are created. The next to last point may
-be closer to the last point as the given distance.
+be closer to the last point as the given distance. Distance information for every
+point is added to the vector attribute table. The attribute is then exported as CSV
+file.
 <h2>EXAMPLE</h2>
@@ -28,10 +30,6 @@
 <a href="v.segment.html">v.segment</a>
 </em>
-<h2>TODO</h2>
-Join exported text file back to segment point vector.
 <h2>AUTHOR</h2>
 Helmut Kudrnovsky
Modified: grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py
--- grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py	2014-11-09 10:34:56 UTC (rev 62677)
+++ grass-addons/grass7/vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py	2014-11-09 14:15:38 UTC (rev 62678)
@@ -60,6 +60,8 @@
     vcat = options['cat']
     directory = options['dir']
     sdistance = options['distance']
+    fpointscsv = 't_segmentpoints.csv'
+    fpointscsv_export = 'segmentpoints.csv'
     fpoints = 'segmentpoints.txt'
     global tmp
@@ -141,6 +143,7 @@
                                      file = segment_points_file)
     grass.run_command("v.db.addtable", map = 'segmentpoints')
+    grass.message( "v.segment done." )
     grass.message( "----" )
     # Adding coordinates to segment points attribute table.
@@ -154,14 +157,67 @@
                                      option = 'coor',
                                      layer = 1,
                                      columns = 'xcoor,ycoor')
+    grass.message( "Coordinates added." )
-#    TODO join point segment file to point vector
-#    grass.run_command("db.in.ogr", dsn = segment_points_file,
-#                                     output = 't_segment_points_file')
+    # join point segment file data to point vector
+    grass.message( "Join distance information to segment point vector ..." )
+    segment_points_file_csv = os.path.join( directory, fpointscsv )
+    with open('%s' % (segment_points_file), 'r') as d:
+        with open('%s' % (segment_points_file_csv), 'w' ) as f:
+            for line in d:
+                new_line = line.replace(" ", ";")
+                f.write(new_line)
+    grass.run_command("db.in.ogr", dsn = "%s" % segment_points_file_csv)
+    grass.run_command("v.db.join", map = 'segmentpoints',
+                                     column = 'cat',
+                                     otable = 't_segmentpoints_csv',
+                                     ocolumn = 'field_2',
+                                     scolumns = 'field_2,field_4')
+    grass.run_command("db.droptable", table = 't_segmentpoints_csv',
+                                     flags = 'f')
+    grass.run_command("v.db.addcolumn", map = 'segmentpoints',
+                                     layer = 1,
+                                     columns = "cat_2 integer,distance double")
+    grass.run_command("db.execute", sql = "UPDATE segmentpoints SET cat_2 =  field_2")
+    grass.run_command("db.execute", sql = "UPDATE segmentpoints SET distance =  field_4")
+    grass.run_command("db.execute", sql = "UPDATE segmentpoints SET distance =  %s WHERE cat = %s" %(vector_line_length, number_segmentpoints_with_end))
+    grass.run_command("db.dropcolumn", table = 'segmentpoints',
+                                     column = 'field_2',
+                                     flags = 'f')
+                                     column = 'field_4',
+                                     flags = 'f')
+    grass.message( "Distance information added to attribute table." )
+    # export segment point attribute table as csv
+    grass.message( "Export segment point attribute table as CSV file ..." )
+    csv_to_export = os.path.join( directory, fpointscsv_export )
+    grass.run_command("db.out.ogr", input = 'segmentpoints',
+                                     dsn = '%s' % (csv_to_export),
+                                     format = 'CSV')
+    grass.message( "Export done." )
+    grass.message( "----" )
+    # clean up some temporay files and maps
+    grass.message( "Some clean up ..." )
+    os.remove("%s" % segment_points_file_csv)
+    grass.message( "Clean up done." )
     # v.fixed.segmentpoints done!
     grass.message( "v.fixed.segmentpoints done!" )
