[GRASS-SVN] r62683 - grass/trunk/vector/v.net
Sun Nov 9 06:44:14 PST 2014
Author: mmetz
Date: 2014-11-09 06:44:14 -0800 (Sun, 09 Nov 2014)
New Revision: 62683
   grass/trunk/vector/v.net/connect.c
v.net: fix #2473
Modified: grass/trunk/vector/v.net/connect.c
--- grass/trunk/vector/v.net/connect.c	2014-11-09 14:41:32 UTC (rev 62682)
+++ grass/trunk/vector/v.net/connect.c	2014-11-09 14:44:14 UTC (rev 62683)
@@ -29,6 +29,11 @@
     struct line_cats *Cats, *Cline, *Cnew;
     int maxcat, findex, ncats;
+    struct ilist *exclude_list;
+    int pline;
+    exclude_list = Vect_new_list();
     narcs = 0;
     Points = Vect_new_line_struct();
@@ -53,9 +58,9 @@
 	    continue;
 	/* find the nearest line in given threshold */
-	line = Vect_find_line(Out,
-			      Points->x[0], Points->y[0], Points->z[0],
-			      GV_LINES, thresh, WITHOUT_Z, 0);
+	line = Vect_find_line_list(Out, Points->x[0], Points->y[0], Points->z[0],
+				   GV_LINES, thresh, WITHOUT_Z,
+				   exclude_list, NULL);
 	if (line < 1 || !Vect_line_alive(Out, line))
 	    continue;
@@ -114,7 +119,9 @@
 		maxcat++;
 		Vect_reset_cats(Cnew);
 		Vect_cat_set(Cnew, afield, maxcat);
-		Vect_write_line(Out, ltype, Pout, Cnew);
+		pline = Vect_write_line(Out, ltype, Pout, Cnew);
+		Vect_list_append(exclude_list, pline);
 		narcs++;
