[GRASS-SVN] r62737 - grass/branches/releasebranch_7_0/vector/v.generalize
Fri Nov 14 07:13:48 PST 2014
Author: neteler
Date: 2014-11-14 07:13:48 -0800 (Fri, 14 Nov 2014)
New Revision: 62737
   grass/branches/releasebranch_7_0/vector/v.generalize/main.c
v.generalize: check that input map contains lines (trunk, r62736)
Modified: grass/branches/releasebranch_7_0/vector/v.generalize/main.c
--- grass/branches/releasebranch_7_0/vector/v.generalize/main.c	2014-11-14 15:10:31 UTC (rev 62736)
+++ grass/branches/releasebranch_7_0/vector/v.generalize/main.c	2014-11-14 15:13:48 UTC (rev 62737)
@@ -322,6 +322,11 @@
     if (Vect_open_old2(&In, map_in->answer, "", field_opt->answer) < 1)
 	G_fatal_error(_("Unable to open vector map <%s>"), map_in->answer);
+    if (Vect_get_num_primitives(&In, mask_type) == 0) {
+	G_warning(_("No lines found in input map <%s>"), map_in->answer);
+	Vect_close(&In);
+	exit(EXIT_SUCCESS);
     with_z = Vect_is_3d(&In);
     if (0 > Vect_open_new(&Out, map_out->answer, with_z)) {
