[GRASS-SVN] r62859 - in grass/branches/releasebranch_7_0: include/defs lib/gis lib/gis/testsuite
Sat Nov 22 14:03:32 PST 2014
Author: huhabla
Date: 2014-11-22 14:03:32 -0800 (Sat, 22 Nov 2014)
New Revision: 62859
Added:
   grass/branches/releasebranch_7_0/lib/gis/testsuite/
   grass/branches/releasebranch_7_0/lib/gis/testsuite/gis_lib_env_test.py
Removed:
   grass/branches/releasebranch_7_0/include/defs/gis.h
   grass/branches/releasebranch_7_0/lib/gis/env.c
gis library: backport of r61956 to allow mapset specific temporal databases
Modified: grass/branches/releasebranch_7_0/include/defs/gis.h
--- grass/branches/releasebranch_7_0/include/defs/gis.h	2014-11-22 21:54:43 UTC (rev 62858)
+++ grass/branches/releasebranch_7_0/include/defs/gis.h	2014-11-22 22:03:32 UTC (rev 62859)
@@ -225,6 +225,8 @@
 int G_get_gisrc_mode(void);
 void G_create_alt_env(void);
 void G_switch_env(void);
+void G__read_mapset_env(void);
+void G__read_gisrc_env(void);
 /* error.c */
 jmp_buf *G_fatal_longjmp(int);
Modified: grass/branches/releasebranch_7_0/lib/gis/env.c
--- grass/branches/releasebranch_7_0/lib/gis/env.c	2014-11-22 21:54:43 UTC (rev 62858)
+++ grass/branches/releasebranch_7_0/lib/gis/env.c	2014-11-22 22:03:32 UTC (rev 62859)
@@ -47,6 +47,8 @@
 static int unset_env(const char *, int);
 static const char *get_env(const char *, int);
 static void write_env(int);
+static void parse_env(FILE *, int);
+static void force_read_env(int);
 static FILE *open_env(const char *, int);
@@ -84,21 +86,41 @@
     read_env(G_VAR_MAPSET);
-static int read_env(int loc)
+ * \brief Force to read the mapset environment file VAR
+ * The mapset specific VAR file of the mapset set with G_setenv()
+ * will be read into memory, ignoring if it was readed before.
+ * Existing values will be overwritten, new values appended.
+ * \return
+    force_read_env(G_VAR_MAPSET);
+ * \brief Force to read the GISRC environment file
+ * The GISRC file
+ * \return
+    force_read_env(G_VAR_GISRC);
+static void parse_env(FILE *fd, int loc)
     char buf[200];
     char *name;
     char *value;
-    FILE *fd;
-    if (loc == G_VAR_GISRC && st->varmode == G_GISRC_MODE_MEMORY)
-	return 0;		/* don't use file for GISRC */
-    if (G_is_initialized(&st->init[loc]))
-	return 1;
-    if ((fd = open_env("r", loc))) {
-	while (G_getl2(buf, sizeof buf, fd)) {
+    while (G_getl2(buf, sizeof buf, fd)) {
 	    for (name = value = buf; *value; value++)
 		if (*value == ':')
 		    break;
@@ -111,14 +133,43 @@
 	    if (*name && *value)
 		set_env(name, value, loc);
-	fclose(fd);
+static int read_env(int loc)
+    FILE *fd;
+    if (loc == G_VAR_GISRC && st->varmode == G_GISRC_MODE_MEMORY)
+	return 0;		/* don't use file for GISRC */
+    if (G_is_initialized(&st->init[loc]))
+	return 1;
+    if ((fd = open_env("r", loc))) {
+        parse_env(fd, loc);
+        fclose(fd);
     G_initialize_done(&st->init[loc]);
     return 0;
+ * \brief Force the reading or the GISRC or MAPSET/VAR files
+ * and overwrite/append the specified variables
+static void force_read_env(int loc)
+    FILE *fd;
+        fclose(fd);
 static int set_env(const char *name, const char *value, int loc)
     int n;
Deleted: grass/branches/releasebranch_7_0/lib/gis/testsuite/gis_lib_env_test.py
--- grass/trunk/lib/gis/testsuite/gis_lib_env_test.py	2014-09-14 19:37:08 UTC (rev 61957)
+++ grass/branches/releasebranch_7_0/lib/gis/testsuite/gis_lib_env_test.py	2014-11-22 22:03:32 UTC (rev 62859)
@@ -1,75 +0,0 @@
-"""Test of gis library environment management
- at author Soeren Gebbert
-from grass.gunittest.case import TestCase
-import grass.lib.gis as libgis
-class GisLibraryTestEnv(TestCase):
-    @classmethod
-    def setUpClass(cls):
-        libgis.G_gisinit("GisLibraryTestEnv")
-    def test_gisrc(self):
-        # File access
-        libgis.G_setenv("TEST", "A");
-        value = libgis.G_getenv("TEST")
-        self.assertEqual(value, "A")
-        value = libgis.G_getenv2("TEST", libgis.G_VAR_GISRC)
-        # In memory management
-        libgis.G__setenv("TEST", "B");
-        value = libgis.G__getenv("TEST")
-        self.assertEqual(value, "B")
-        value = libgis.G__getenv2("TEST", libgis.G_VAR_GISRC)
-        # Force reading
-        libgis.G__read_gisrc_env()
-    def test_switch_env(self):
-        libgis.G__setenv("TEST", "SWITCH");
-        libgis.G__setenv2("TEST", "SWITCH2", libgis.G_VAR_MAPSET);
-        # Create alternative env
-        libgis.G_create_alt_env()
-        libgis.G__setenv("TEST", "TARGET");
-        libgis.G__setenv2("TEST", "TARGET2", libgis.G_VAR_MAPSET);
-        self.assertEqual(value, "TARGET")
-        value = libgis.G_getenv2("TEST", libgis.G_VAR_MAPSET)
-        self.assertEqual(value, "TARGET2")
-        # Switch back to orig env
-        libgis.G_switch_env()
-        self.assertEqual(value, "SWITCH")
-        self.assertEqual(value, "SWITCH2")
-    def test_mapset(self):
-        # Mapset VAR file
-        libgis.G_setenv2("TEST", "C", libgis.G_VAR_MAPSET);
-        self.assertEqual(value, "C")
-        libgis.G__setenv2("TEST", "D", libgis.G_VAR_MAPSET);
-        value = libgis.G__getenv2("TEST", libgis.G_VAR_MAPSET)
-        self.assertEqual(value, "D")
-        # Force reading
-        libgis.G__read_mapset_env()
-if __name__ == '__main__':
-    from grass.gunittest.main import test
-    test()
Copied: grass/branches/releasebranch_7_0/lib/gis/testsuite/gis_lib_env_test.py (from rev 61957, grass/trunk/lib/gis/testsuite/gis_lib_env_test.py)
--- grass/branches/releasebranch_7_0/lib/gis/testsuite/gis_lib_env_test.py	                        (rev 0)
@@ -0,0 +1,75 @@
+"""Test of gis library environment management
+ at author Soeren Gebbert
+from grass.gunittest.case import TestCase
+import grass.lib.gis as libgis
+class GisLibraryTestEnv(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        libgis.G_gisinit("GisLibraryTestEnv")
+    def test_gisrc(self):
+        # File access
+        libgis.G_setenv("TEST", "A");
+        value = libgis.G_getenv("TEST")
+        self.assertEqual(value, "A")
+        value = libgis.G_getenv2("TEST", libgis.G_VAR_GISRC)
+        # In memory management
+        libgis.G__setenv("TEST", "B");
+        value = libgis.G__getenv("TEST")
+        self.assertEqual(value, "B")
+        value = libgis.G__getenv2("TEST", libgis.G_VAR_GISRC)
+        # Force reading
+        libgis.G__read_gisrc_env()
+    def test_switch_env(self):
+        libgis.G__setenv("TEST", "SWITCH");
+        libgis.G__setenv2("TEST", "SWITCH2", libgis.G_VAR_MAPSET);
+        # Create alternative env
+        libgis.G_create_alt_env()
+        libgis.G__setenv("TEST", "TARGET");
+        libgis.G__setenv2("TEST", "TARGET2", libgis.G_VAR_MAPSET);
+        self.assertEqual(value, "TARGET")
+        value = libgis.G_getenv2("TEST", libgis.G_VAR_MAPSET)
+        self.assertEqual(value, "TARGET2")
+        # Switch back to orig env
+        libgis.G_switch_env()
+        self.assertEqual(value, "SWITCH")
+        self.assertEqual(value, "SWITCH2")
+    def test_mapset(self):
+        # Mapset VAR file
+        libgis.G_setenv2("TEST", "C", libgis.G_VAR_MAPSET);
+        self.assertEqual(value, "C")
+        libgis.G__setenv2("TEST", "D", libgis.G_VAR_MAPSET);
+        value = libgis.G__getenv2("TEST", libgis.G_VAR_MAPSET)
+        self.assertEqual(value, "D")
+        # Force reading
+        libgis.G__read_mapset_env()
+if __name__ == '__main__':
+    from grass.gunittest.main import test
+    test()
