[GRASS-SVN] r62870 - grass/branches/releasebranch_7_0/temporal/t.rast.aggregate
Sun Nov 23 08:11:25 PST 2014
Author: neteler
Date: 2014-11-23 08:11:25 -0800 (Sun, 23 Nov 2014)
New Revision: 62870
   grass/branches/releasebranch_7_0/temporal/t.rast.aggregate/t.rast.aggregate.html
temporal man: minor HTML sync to trunk
Modified: grass/branches/releasebranch_7_0/temporal/t.rast.aggregate/t.rast.aggregate.html
--- grass/branches/releasebranch_7_0/temporal/t.rast.aggregate/t.rast.aggregate.html	2014-11-23 00:21:03 UTC (rev 62869)
+++ grass/branches/releasebranch_7_0/temporal/t.rast.aggregate/t.rast.aggregate.html	2014-11-23 16:11:25 UTC (rev 62870)
@@ -35,13 +35,17 @@
 </ul>
 <p>
-The specification of the temporal relation between the aggregation intervals and the raster map layers
-is always formulated from the aggregation interval viewpoint. Hence, the relation <em>contains</em>
-has to be specified to aggregate map layer that are temporally located in an aggregation interval.
+The specification of the temporal relation between the aggregation
+intervals and the raster map layers is always formulated from the
+aggregation interval viewpoint. Hence, the relation <em>contains</em>
+has to be specified to aggregate map layer that are temporally located
+in an aggregation interval.
 <p>
-Parallel processing is supported in case that more than one interval is available for aggregation computation. Internally several
-<em>r.series</em> modules will be started, depending on the number of specified parallel processes (<em>nprocs</em>)
-and the number of intervals to aggregate.
+Parallel processing is supported in case that more than one interval is
+available for aggregation computation. Internally several
+<em>r.series</em> modules will be started, depending on the number of
+specified parallel processes (<em>nprocs</em>) and the number of
+intervals to aggregate.
 <h2>EXAMPLES</h2>
@@ -50,13 +54,16 @@
 using a daily temporal granularity. The names of the raster maps are
 stored in a text file that is used for raster map registration.
 <p>
-The space time raster dataset <em>precipitation_daily</em> with daily temporal granularity
-will be aggregated to weekly precipitation resulting in the output space time raster dataset
-<em>precipitation_weekly</em>. The base name of the new generated raster maps is <em>prec_weekly</em>, the
-granularity is 1 week. The aggregation method is set to <em>sum</em> to accumulate the precipitation values
-of all raster maps that are temporally <em>contained</em> in a week.
-The sampling option <em>contains</em> assures that only raster maps that are
-temporally during a week will be considered for computation:
+The space time raster dataset <em>precipitation_daily</em> with daily
+temporal granularity will be aggregated to weekly precipitation
+resulting in the output space time raster dataset
+<em>precipitation_weekly</em>. The base name of the new generated
+raster maps is <em>prec_weekly</em>, the granularity is 1 week. The
+aggregation method is set to <em>sum</em> to accumulate the
+precipitation values of all raster maps that are temporally
+<em>contained</em> in a week. The sampling option <em>contains</em>
+assures that only raster maps that are temporally during a week will be
+considered for computation:
 <div class="code"><pre>
 MAPS="map_1 map_2 map_3 map_4 map_5 map_6 map_7"
