[GRASS-SVN] r62934 - in grass/branches/releasebranch_7_0: . scripts/d.polar
Tue Nov 25 06:16:28 PST 2014
Author: martinl
Date: 2014-11-25 06:16:28 -0800 (Tue, 25 Nov 2014)
New Revision: 62934
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/scripts/d.polar/d.polar.py
d.polar: use standardized options (#2409)
         (merge r62933 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925
   + /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933
Modified: grass/branches/releasebranch_7_0/scripts/d.polar/d.polar.py
--- grass/branches/releasebranch_7_0/scripts/d.polar/d.polar.py	2014-11-25 14:13:56 UTC (rev 62933)
+++ grass/branches/releasebranch_7_0/scripts/d.polar/d.polar.py	2014-11-25 14:16:28 UTC (rev 62934)
@@ -33,7 +33,6 @@
 #% required : no
 #%End
 #%option G_OPT_F_OUTPUT
-#% key: eps
 #% description: Name for optional EPS output file
 #% required : no
 #%end
@@ -384,7 +383,7 @@
     map = options['map']
     undef = options['undef']
-    eps = options['eps']
+    eps = options['output']
     xgraph = flags['x']
     tmp = grass.tempfile()
