[GRASS-SVN] r62961 - in grass/branches/releasebranch_7_0: . imagery/i.fft
Wed Nov 26 01:17:04 PST 2014
Author: martinl
Date: 2014-11-26 01:17:04 -0800 (Wed, 26 Nov 2014)
New Revision: 62961
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/imagery/i.fft/main.c
i.fft: use standardized options (#2409)
       (merge r62960 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958
   + /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960
Modified: grass/branches/releasebranch_7_0/imagery/i.fft/main.c
--- grass/branches/releasebranch_7_0/imagery/i.fft/main.c	2014-11-26 09:15:00 UTC (rev 62960)
+++ grass/branches/releasebranch_7_0/imagery/i.fft/main.c	2014-11-26 09:17:04 UTC (rev 62961)
@@ -84,14 +84,13 @@
     /* define options */
     opt.orig = G_define_standard_option(G_OPT_R_INPUT);
-    opt.orig->key = "input_image";
     opt.real = G_define_standard_option(G_OPT_R_OUTPUT);
-    opt.real->key = "real_image";
+    opt.real->key = "real";
     opt.real->description = _("Name for output real part arrays stored as raster map");
     opt.imag = G_define_standard_option(G_OPT_R_OUTPUT);
-    opt.imag->key = "imaginary_image";
+    opt.imag->key = "imaginary";
     opt.imag->description = _("Name for output imaginary part arrays stored as raster map");
     if (G_parser(argc, argv))
