[GRASS-SVN] r62994 - in grass/branches/releasebranch_7_0: . tools
Wed Nov 26 02:27:09 PST 2014
Author: martinl
Date: 2014-11-26 02:27:09 -0800 (Wed, 26 Nov 2014)
New Revision: 62994
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/tools/thumbnails.py
fix tools/thumbnails.py
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62967
   + /grass/trunk:60817,61096,61141,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62856,62879,62881,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993
Modified: grass/branches/releasebranch_7_0/tools/thumbnails.py
--- grass/branches/releasebranch_7_0/tools/thumbnails.py	2014-11-26 10:26:36 UTC (rev 62993)
+++ grass/branches/releasebranch_7_0/tools/thumbnails.py	2014-11-26 10:27:09 UTC (rev 62994)
@@ -152,7 +152,7 @@
         lines, cols = None, None
     grass.run_command("r.colors", map = grad, color = table, quiet = True)
     grass.run_command("d.colortable", flags = 'n', map = grad,
-                      lines = lines, cols = cols, quiet = True)
+                      lines = lines, columns = cols, quiet = True)
     outfile = os.path.join(output_dir, "colortables", "%s.png" % table)
     convert_and_rotate(tmp_img, outfile, discrete)
