[GRASS-SVN] r63076 - grass/trunk/raster3d/r3.in.v5d
Wed Nov 26 07:35:21 PST 2014
Author: martinl
Date: 2014-11-26 07:35:21 -0800 (Wed, 26 Nov 2014)
New Revision: 63076
   grass/trunk/raster3d/r3.in.v5d/main.c
r3.in.v5d: use standardized options (#2409)
Modified: grass/trunk/raster3d/r3.in.v5d/main.c
--- grass/trunk/raster3d/r3.in.v5d/main.c	2014-11-26 15:32:10 UTC (rev 63075)
+++ grass/trunk/raster3d/r3.in.v5d/main.c	2014-11-26 15:35:21 UTC (rev 63076)
@@ -61,28 +61,13 @@
 static void setParams()
-    param.input = G_define_option();
-    param.input->key = "input";
-    param.input->type = TYPE_STRING;
-    param.input->required = YES;
-    param.input->description = "V5D raster map to be imported";
+    param.input = G_define_standard_option(G_OPT_F_INPUT);
+    param.input->description = _("Name of V5D raster file to be imported");
-    param.output = G_define_option();
-    param.output->key = "output";
-    param.output->type = TYPE_STRING;
-    param.output->required = YES;
-    param.output->multiple = NO;
-    param.output->gisprompt = "any,grid3,3d-raster";
-    param.output->description = "Name for 3D raster map";
+    param.output = G_define_standard_option(G_OPT_R3_OUTPUT);
-    param.nv = G_define_option();
-    param.nv->key = "nv";
-    param.nv->type = TYPE_STRING;
-    param.nv->required = NO;
-    param.nv->multiple = NO;
+    param.nv = G_define_standard_option(G_OPT_M_NULL_VALUE);
     param.nv->answer = "none";
-    param.nv->description =
-	"String representing NULL value data cell (use 'none' if no such value)";
