[GRASS-SVN] r63224 - grass/trunk/scripts/db.droptable
Fri Nov 28 01:17:04 PST 2014
Author: martinl
Date: 2014-11-28 01:17:04 -0800 (Fri, 28 Nov 2014)
New Revision: 63224
   grass/trunk/scripts/db.droptable/db.droptable.py
db.droptable: run db.connect in quiet mode
Modified: grass/trunk/scripts/db.droptable/db.droptable.py
--- grass/trunk/scripts/db.droptable/db.droptable.py	2014-11-28 09:05:13 UTC (rev 63223)
+++ grass/trunk/scripts/db.droptable/db.droptable.py	2014-11-28 09:17:04 UTC (rev 63224)
@@ -52,7 +52,7 @@
     if not options['driver'] or not options['database']:
         # check if DB parameters are set, and if not set them.
-        grass.run_command('db.connect', flags='c')
+        grass.run_command('db.connect', flags='c', quiet=True)
     kv = grass.db_connection()
     if options['database']:
