[GRASS-SVN] r63229 - in grass/branches/releasebranch_7_0: . scripts/d.correlate scripts/d.out.file scripts/d.rast.leg scripts/d.redraw scripts/d.shadedmap scripts/d.to.rast scripts/d.vect.thematic scripts/d.what.rast scripts/d.what.vect
Fri Nov 28 01:44:05 PST 2014
Author: neteler
Date: 2014-11-28 01:44:05 -0800 (Fri, 28 Nov 2014)
New Revision: 63229
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/scripts/d.correlate/d.correlate.py
   grass/branches/releasebranch_7_0/scripts/d.out.file/d.out.file.py
   grass/branches/releasebranch_7_0/scripts/d.rast.leg/d.rast.leg.py
   grass/branches/releasebranch_7_0/scripts/d.redraw/d.redraw.py
   grass/branches/releasebranch_7_0/scripts/d.shadedmap/d.shadedmap.py
   grass/branches/releasebranch_7_0/scripts/d.to.rast/d.to.rast.py
   grass/branches/releasebranch_7_0/scripts/d.vect.thematic/d.vect.thematic.py
   grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.py
   grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.py
d.* scripts: check if graphics device is open
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,
 63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,
 63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227
Modified: grass/branches/releasebranch_7_0/scripts/d.correlate/d.correlate.py
--- grass/branches/releasebranch_7_0/scripts/d.correlate/d.correlate.py	2014-11-28 09:43:48 UTC (rev 63228)
+++ grass/branches/releasebranch_7_0/scripts/d.correlate/d.correlate.py	2014-11-28 09:44:05 UTC (rev 63229)
@@ -32,6 +32,11 @@
 from grass.script import core as grass
 def main():
+    env = grass.gisenv()
+    mon = env.get('MONITOR', None)
+    if not mon:
+        grass.fatal(_("No graphics device selected. Use d.mon to select graphics device."))
     layers = options['map'].split(',')
     if len(layers) < 2:
Modified: grass/branches/releasebranch_7_0/scripts/d.out.file/d.out.file.py
--- grass/branches/releasebranch_7_0/scripts/d.out.file/d.out.file.py	2014-11-28 09:43:48 UTC (rev 63228)
+++ grass/branches/releasebranch_7_0/scripts/d.out.file/d.out.file.py	2014-11-28 09:44:05 UTC (rev 63229)
@@ -1,4 +1,5 @@
 #!/usr/bin/env python
 # MODULE: d.out.file
Modified: grass/branches/releasebranch_7_0/scripts/d.rast.leg/d.rast.leg.py
--- grass/branches/releasebranch_7_0/scripts/d.rast.leg/d.rast.leg.py	2014-11-28 09:43:48 UTC (rev 63228)
+++ grass/branches/releasebranch_7_0/scripts/d.rast.leg/d.rast.leg.py	2014-11-28 09:44:05 UTC (rev 63229)
@@ -1,45 +1,38 @@
-# d.rast.leg        (GRASS Shell Script)
-# displays a raster map and its legend on a graphics window.
+# MODULE:       d.rast.leg
+# AUTHOR(S):
+#               Jianping Xu and Scott Madry, Rutgers University. October 19, 1993
+#               Markus Neteler 8/2002: added simple d.legend logic
+#               Markus Neteler 10/2003: added g.parser
+#               Michael Barton 12/2004: remove reference to (null)
+#               Glynn Clements 10/2008: converted to Python
-# Usage:         d.rast.leg
-#        or      d.rast.leg help
-#        or      d.rast.leg rast_map [num_of_lines]
+# PURPOSE:      Displays a raster map and its legend on a graphics window.
-# Description:   d.rast.leg clears the entire screen, divides it into a main
-#                (left) and a minor (right) frames, and then display a raster
-#                map in the main frame and the map legend in the minor frame.
-#                The user can run the program interactively or
-#                non-interactively.
+# Description:  d.rast.leg clears the entire screen, divides it into a main
+#               (left) and a minor (right) frames, and then display a raster
+#               map in the main frame and the map legend in the minor frame.
+#               The user can run the program interactively or
+#               non-interactively.
-# Parameters:    rast_map         A raster map to be displayed.
+# See also:     d.rast, d.legend.
-#                num_of_lines         Number of lines to appear in the legend.
-#                                If this number is not given, the legend frame
-#                                will display as many lines as number of
-#                                categories in the map, otherwise, it will
-#                                display the first num_of_lines minus 1
-#                                categories with the rest being truncated.
-# Note:          The user may adjust the num_of_lines parameter or the size of
-#                graphics window to get an appropriate result.
+# COPYRIGHT:	(C) 1993-2014 by the GRASS Development Team
-# See also:      d.rast, d.legend.
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
-# Jianping Xu and Scott Madry, Rutgers University. October 19, 1993
-# Markus Neteler 8/2002: added simple d.legend logic
-# Markus Neteler 10/2003: added g.parser
-# Michael Barton 12/2004: remove reference to (null)
-# Glynn Clements 10/2008: converted to Python
 #%module
 #% description: Displays a raster map and its legend on a graphics window
 #% keywords: display
 #% keywords: cartography
+#% keywords: legend
 #%end
 #%flag
 #%  key: f
@@ -88,6 +81,11 @@
     os.environ['GRASS_RENDER_FRAME'] = s
 def main():
+    if not mon:
     map = options['map']
     nlines = options['lines']
     rast = options['raster']
Modified: grass/branches/releasebranch_7_0/scripts/d.redraw/d.redraw.py
--- grass/branches/releasebranch_7_0/scripts/d.redraw/d.redraw.py	2014-11-28 09:43:48 UTC (rev 63228)
+++ grass/branches/releasebranch_7_0/scripts/d.redraw/d.redraw.py	2014-11-28 09:44:05 UTC (rev 63229)
@@ -1,4 +1,5 @@
 # MODULE:	d.redraw
@@ -25,7 +26,7 @@
 def split(s):
-    """!Platform spefic shlex.split"""
+    """!Platform specific shlex.split"""
     if sys.version_info >= (2, 6):
         return shlex.split(s, posix = (sys.platform != "win32"))
     elif sys.platform == "win32":
@@ -37,7 +38,7 @@
     if not mon:
-        grass.fatal(_("No monitor selected. Run `d.mon` to select monitor."))
     monCmd = env.get('MONITOR_%s_CMDFILE' % mon.upper())
     if not monCmd:
Modified: grass/branches/releasebranch_7_0/scripts/d.shadedmap/d.shadedmap.py
--- grass/branches/releasebranch_7_0/scripts/d.shadedmap/d.shadedmap.py	2014-11-28 09:43:48 UTC (rev 63228)
+++ grass/branches/releasebranch_7_0/scripts/d.shadedmap/d.shadedmap.py	2014-11-28 09:44:05 UTC (rev 63229)
@@ -1,5 +1,5 @@
 # MODULE:        d.shadedmap
@@ -47,6 +47,11 @@
 def main():
+    env = gcore.gisenv()
+    if not mon:
+        gcore.fatal(_("No graphics device selected. Use d.mon to select graphics device."))
     drape_map = options['drapemap']
     relief_map = options['reliefmap']
     brighten = options['brighten']
Modified: grass/branches/releasebranch_7_0/scripts/d.to.rast/d.to.rast.py
--- grass/branches/releasebranch_7_0/scripts/d.to.rast/d.to.rast.py	2014-11-28 09:43:48 UTC (rev 63228)
+++ grass/branches/releasebranch_7_0/scripts/d.to.rast/d.to.rast.py	2014-11-28 09:44:05 UTC (rev 63229)
@@ -1,9 +1,10 @@
-# MODULE: d.to.rast
+# MODULE:    d.to.rast
 # AUTHOR(S): Anna Petrasova <kratochanna gmail.com>
-# PURPOSE:	Script for exporting content of monitor to raster map
+# PURPOSE:	 Script for exporting content of monitor to raster map
 # COPYRIGHT: (C) 2014 by the GRASS Development Team
@@ -26,6 +27,11 @@
 def main():
+    if not mon:
     options, flags = gcore.parser()
     gisenv = gcore.gisenv()
     if 'MONITOR' in gisenv:
Modified: grass/branches/releasebranch_7_0/scripts/d.vect.thematic/d.vect.thematic.py
--- grass/branches/releasebranch_7_0/scripts/d.vect.thematic/d.vect.thematic.py	2014-11-28 09:43:48 UTC (rev 63228)
+++ grass/branches/releasebranch_7_0/scripts/d.vect.thematic/d.vect.thematic.py	2014-11-28 09:44:05 UTC (rev 63229)
@@ -1,5 +1,5 @@
 # MODULE:       d.vect.thematic
@@ -231,6 +231,11 @@
 def main():
     global tmp_graph, tmp_group, tmp_psmap, tmp_psleg, tmp_gisleg
+    if not mon:
     breakpoints = options['breakpoints']
     colorscheme = options['colorscheme']
     column = options['column']
Modified: grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.py
--- grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.py	2014-11-28 09:43:48 UTC (rev 63228)
+++ grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.py	2014-11-28 09:44:05 UTC (rev 63229)
@@ -1,7 +1,8 @@
-# MODULE: d.what.rast
+# MODULE:    d.what.rast
 # PURPOSE:   Script for querying raster maps in d.mon
@@ -26,6 +27,11 @@
 def main():
+    if not mon:
Modified: grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.py
--- grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.py	2014-11-28 09:43:48 UTC (rev 63228)
+++ grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.py	2014-11-28 09:44:05 UTC (rev 63229)
@@ -1,9 +1,10 @@
-# MODULE: d.what.vect
+# MODULE:    d.what.vect
-# PURPOSE:	Script for querying vector maps in d.mon
+# PURPOSE:	 Script for querying vector maps in d.mon
