[GRASS-SVN] r62186 - grass/trunk/raster/r.univar
Sat Oct 4 20:53:47 PDT 2014
Author: wenzeslaus
Date: 2014-10-04 20:53:47 -0700 (Sat, 04 Oct 2014)
New Revision: 62186
   grass/trunk/raster/r.univar/r.univar_main.c
   grass/trunk/raster/r.univar/r3.univar_main.c
r.univar and r3.univar: move short description to label, include list of statistics into description (for example, now you can find r.univar in Search module in wxGUI by searching for 'sum')
Modified: grass/trunk/raster/r.univar/r.univar_main.c
--- grass/trunk/raster/r.univar/r.univar_main.c	2014-10-05 03:12:22 UTC (rev 62185)
+++ grass/trunk/raster/r.univar/r.univar_main.c	2014-10-05 03:53:47 UTC (rev 62186)
@@ -101,8 +101,13 @@
     G_add_keyword(_("statistics"));
     G_add_keyword(_("univariate statistics"));
     G_add_keyword(_("zonal statistics"));
+    module->label =
+	_("Calculates univariate statistics from the non-null cells of a raster map.");
     module->description =
-	_("Calculates univariate statistics from the non-null cells of a raster map.");
+	_("Statistics include number of cells counted, minimum and maximum cell"
+	    " values, range, arithmetic mean, population variance, standard deviation,"
+	    " coefficient of variation, and sum.");
     /* Define the different options */
     set_params();
Modified: grass/trunk/raster/r.univar/r3.univar_main.c
--- grass/trunk/raster/r.univar/r3.univar_main.c	2014-10-05 03:12:22 UTC (rev 62185)
+++ grass/trunk/raster/r.univar/r3.univar_main.c	2014-10-05 03:53:47 UTC (rev 62186)
@@ -99,8 +99,12 @@
+    module->label =
+	_("Calculates univariate statistics from the non-null cells of a 3D raster map.");
-	_("Calculates univariate statistics from the non-null cells of a 3D raster map.");
     set_params();
