[GRASS-SVN] r62192 - in grass-addons/grass6/vector: . v.in.adcirc_grid
Sun Oct 5 22:53:30 PDT 2014
Author: hamish
Date: 2014-10-05 22:53:30 -0700 (Sun, 05 Oct 2014)
New Revision: 62192
Added:
   grass-addons/grass6/vector/v.in.adcirc_grid/
   grass-addons/grass6/vector/v.in.adcirc_grid/Makefile
   grass-addons/grass6/vector/v.in.adcirc_grid/description.html
   grass-addons/grass6/vector/v.in.adcirc_grid/main.c
   grass-addons/grass6/vector/Makefile
add module to import a mesh grid from the ADCIRC coastal ocean model (www.adcirc.org)
Modified: grass-addons/grass6/vector/Makefile
--- grass-addons/grass6/vector/Makefile	2014-10-06 04:16:45 UTC (rev 62191)
+++ grass-addons/grass6/vector/Makefile	2014-10-06 05:53:30 UTC (rev 62192)
@@ -6,6 +6,7 @@
 	v.curvature \
 	v.db.calc \
 	v.eqsm \
+	v.in.adcirc_grid \
 	v.in.gama \
 	v.in.geoplot \
 	v.in.gshhs \
Added: grass-addons/grass6/vector/v.in.adcirc_grid/Makefile
--- grass-addons/grass6/vector/v.in.adcirc_grid/Makefile	                        (rev 0)
+++ grass-addons/grass6/vector/v.in.adcirc_grid/Makefile	2014-10-06 05:53:30 UTC (rev 62192)
@@ -0,0 +1,12 @@
+MODULE_TOPDIR = ../..
+PGM = v.in.adcirc_grid
+LIBES = $(VECTLIB) $(GISLIB)
+DEPENDENCIES= $(VECTDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass-addons/grass6/vector/v.in.adcirc_grid/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass6/vector/v.in.adcirc_grid/description.html
--- grass-addons/grass6/vector/v.in.adcirc_grid/description.html	                        (rev 0)
+++ grass-addons/grass6/vector/v.in.adcirc_grid/description.html	2014-10-06 05:53:30 UTC (rev 62192)
@@ -0,0 +1,59 @@
+<h2>DESCRIPTION</h2>
+This module will import a grid and boundary information file
+(<tt>fort.14</tt>) created for the <a href="http://www.adcirc.org">ADCIRC</a>
+coastal ocean circulation model.
+The user may choose between importing the mesh grid triangles as lines, or
+by using the <b>-p</b> flag, importing the grid nodes as points. In both
+cases 3D coordinates and identifier numbers are preserved.
+<h2>NOTES</h2>
+MPI users can import the <tt>fort.14</tt> files from the <tt>PE0000/</tt>
+directories to spatially view the sections of the full grid running on
+each node. (e.g. for determining which SWAN control files to manually adjust)
+<p>
+Depths are converted to negative values during the import.
+<h2>EXAMPLES</h2>
+Import the mesh grid as vector lines:
+<div class="code"><pre>
+v.in.adcirc_grid input=fort.14 output=mesh_grid
+</pre></div>
+<p>
+Copy the per-node grid files into the main working directory, then import
+them individually:
+for dir in PE0* ; do
+   cp $dir/fort.14 fort.14.$dir
+   v.in.adcirc_grid input=fort.14.$dir output=mesh_grid_$dir
+done
+</pre></div>
+<h2>TODO</h2>
+Create an attribute database containing node attributes.
+(boundary nodes, ...)
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.in.ascii.html">v.in.ascii</a><br>
+</em>
+<h2>AUTHOR</h2>
+Hamish Bowman<br>
+<i>Geology Department<br>
+University of Otago<br>
+Dunedin, New Zealand</i>
+<br>
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass6/vector/v.in.adcirc_grid/description.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass6/vector/v.in.adcirc_grid/main.c
--- grass-addons/grass6/vector/v.in.adcirc_grid/main.c	                        (rev 0)
+++ grass-addons/grass6/vector/v.in.adcirc_grid/main.c	2014-10-06 05:53:30 UTC (rev 62192)
@@ -0,0 +1,270 @@
+ * MODULE:      v.in.adcirc_grid
+ * PURPOSE:     Loads ADCIRC fort.14 triangular mesh into a GRASS vector
+ * AUTHORS:     Hamish Bowman, Dunedin, New Zealand
+ *              Adapted from v.in.ascii (USA CERL)
+ * COPYRIGHT:   (c) 2014 by Hamish Bowman, and The GRASS Development Team
+ *              This program is free software under the GNU General Public
+ *              License (>=v2). Read the file COPYING that comes with GRASS
+ *              for details.
+ * Format spec:
+ *   http://adcirc.org/home/documentation/users-manual-v50/input-file-descriptions/adcirc-grid-and-boundary-information-file-fort-14/
+/* TODO: when writing nodes as 3D points, store attrs for is_edge,is_land nodes */
+/* TODO: option to write out the trianges as 3D faces and kernels */
+/* TODO: on the fly reprojection for non-LL locations (see r.in.lidar) */
+#include <stdio.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/glocale.h>
+#define BUFFSIZE 12800
+int get_index(int *, int, int);
+int main(int argc, char *argv[])
+    struct GModule *module;
+    struct Option *infile, *outmap;
+    struct Flag *points_flag;
+    FILE *ascii;
+    struct Map_info Map;
+    struct Cell_head window;
+    int zcoor, type;
+    char buff[BUFFSIZE];
+    int *node_array;
+    int *node;
+    double *xarray, *yarray, *zarray;
+    double *x, *y, *z;
+    int *triangle_id, *cnr1_array, *cnr2_array, *cnr3_array;
+    int *id, *cnr1, *cnr2, *cnr3;
+    int i;
+    int n_triangles;  /* aka adcirc "elements" */
+    int n_coords;     /* aka adcirc "nodes" */
+    int n_sides;      /* always 3 */
+    double xarr[4], yarr[4], zarr[4];
+    int idx;
+    struct line_pnts *Points;
+    struct line_cats *Cats;
+    char title[25];
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("Import, ADCIRC, vector");
+    module->description =
+	_("Loads ADCIRC fort.14 triangular mesh into a GRASS vector.");
+    infile = G_define_standard_option(G_OPT_F_INPUT);
+    outmap = G_define_standard_option(G_OPT_V_OUTPUT);
+    points_flag = G_define_flag();
+    points_flag->key = 'p';
+    points_flag->description = _("Load node points instead of mesh lines");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    /* todo: on the fly reprojection from wgs84 lat/lon */
+    G_get_set_window(&window);
+    if (window.proj != PROJECTION_LL)
+	G_fatal_error(_("This module can only be run from a lat/lon location."));
+    if ((ascii = fopen(infile->answer, "r")) == NULL)
+	G_fatal_error(_("Unable to open fort.14 file <%s>"), infile->answer);
+    zcoor = WITH_Z; /* 3D */
+    if (points_flag->answer)
+	type = GV_POINT;
+    else
+	type = GV_LINE;
+    Vect_open_new(&Map, outmap->answer, zcoor);
+    Vect_hist_command(&Map);
+    /* Must always use this to create an initialized line_pnts structure */
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    if (G_getl2(buff, BUFFSIZE - 1, ascii) == 0)
+	G_fatal_error(_("Error reading %s"), infile->answer);
+    strncpy(title, buff, 24);
+    title[24] = '\0';
+    Vect_set_map_name(&Map, title);
+	G_fatal_error(_("Error reading number of elements from %s"),
+		      infile->answer);
+    if (sscanf(buff, "%d %d", &n_triangles, &n_coords) < 2)
+	G_fatal_error(_("Error reading number of nodes: [%s]"), buff);
+    sprintf(buff, "ADCIRC fort.14 triangular mesh containing %d nodes", n_coords);
+    Vect_set_comment(&Map, buff);
+    node_array = (int *)G_calloc(n_coords, sizeof(int));
+    xarray = (double *)G_calloc(n_coords, sizeof(double));
+    yarray = (double *)G_calloc(n_coords, sizeof(double));
+    zarray = (double *)G_calloc(n_coords, sizeof(double));
+    node = node_array;
+    x = xarray;
+    y = yarray;
+    z = zarray;
+    for (i = 0; i < n_coords; i++) {
+	    G_fatal_error(_("End of file reached before end of coordinates"));
+	if (sscanf(buff, "%d%lf%lf%lf", node, x, y, z) < 4)
+	    G_fatal_error(_("Error reading file: (bad coord) [%s]"), buff);
+	/* G_debug(5, "coor in: node=%d  x=%f  y=%f  z=%f", *node, *x, *y, *z); */
+	node++;
+	x++;
+	y++;
+	z++;
+    G_message("Scanned %d coordinates", n_coords);
+    if (points_flag->answer) {
+	    /* Allocation is handled for line_pnts */
+	    if (0 > Vect_copy_xyz_to_pnts(Points, &xarray[i], &yarray[i],
+					  &zarray[i], 1))
+		G_fatal_error(_("Out of memory"));
+	    Vect_cat_set(Cats, 1, node_array[i]);
+	    Vect_write_line(&Map, type, Points, Cats);
+	    Vect_reset_cats(Cats);
+	fclose(ascii);
+	Vect_build(&Map);
+	Vect_close(&Map);
+	exit(EXIT_SUCCESS);
+    for (i = 0; i < 10; i++)
+	G_debug(1, "i=%d,  val=%f", i, zarray[i]);
+    triangle_id = (int *)G_calloc(n_triangles, sizeof(int));
+    cnr1_array = (int *)G_calloc(n_triangles, sizeof(int));
+    cnr2_array = (int *)G_calloc(n_triangles, sizeof(int));
+    cnr3_array = (int *)G_calloc(n_triangles, sizeof(int));
+    id = triangle_id;
+    cnr1 = cnr1_array;
+    cnr2 = cnr2_array;
+    cnr3 = cnr3_array;
+    for (i = 0; i < n_triangles; i++) {
+	    G_fatal_error(_("End of file reached before end of triangle definition"));
+	if (sscanf(buff, "%d%d%d%d%d", id, &n_sides, cnr1, cnr2, cnr3) < 5)
+	if (n_sides != 3)
+	    G_fatal_error(_("Funny triangle: [%s]"), buff);
+	/* G_debug(0, "triangle in: id=%d  a=%d  b=%d  c=%d", *id, *cnr1, *cnr2, *cnr3); */
+	id++;
+	cnr1++;
+	cnr2++;
+	cnr3++;
+    G_message("Scanned %d triangles", n_triangles);
+    for (i = 0; i < 10; i++) {
+	idx = get_index(node_array, n_coords, cnr3_array[i]);
+	G_debug(1, "i=%d  node=%d  val=%f", i, cnr3_array[i], zarray[idx]);
+	idx = get_index(node_array, n_coords, cnr1_array[i]);
+	xarr[0] = xarray[idx];
+	yarr[0] = yarray[idx];
+	zarr[0] = zarray[idx] * -1;
+	idx = get_index(node_array, n_coords, cnr2_array[i]);
+	xarr[1] = xarray[idx];
+	yarr[1] = yarray[idx];
+	zarr[1] = zarray[idx] * -1;
+	xarr[2] = xarray[idx];
+	yarr[2] = yarray[idx];
+	zarr[2] = zarray[idx] * -1;
+	xarr[3] = xarr[0];
+	yarr[3] = yarr[0];
+	zarr[3] = zarr[0];
+	G_debug(5, "tri %d: (%d,  %d,  %d)", triangle_id[i], cnr1_array[i],
+		cnr2_array[i], cnr3_array[i]);
+	G_debug(5, "tri %d: %f  %f  %f", triangle_id[i], zarr[0], zarr[1], zarr[2]);
+	if (0 > Vect_copy_xyz_to_pnts(Points, xarr, yarr, zarr, 4))
+	Vect_cat_set(Cats, 1, triangle_id[i]);
+	/* G_percent(i, n_triangles, 3); */
+    fclose(ascii);
+    Vect_build(&Map);
+    Vect_close(&Map);
+/* returns array idx, or -1 if not found */
+int get_index(int *array, int size, int val)
+    int i;
+    /* first check the easy case when everything is sequentially ordered */
+    if(val > 1 && val < size && array[val-1] == val)
+	return val-1;
+    /* if that didn't work, use brute force */
+    for (i = 0; i < size; i++) {
+	if (array[i] == val)
+	    return i;
+    return -1;
Property changes on: grass-addons/grass6/vector/v.in.adcirc_grid/main.c
   + text/x-csrc
   + native
