[GRASS-SVN] r62245 - in grass/trunk/raster: r.in.bin r.out.bin
Sun Oct 12 05:08:22 PDT 2014
Author: glynn
Date: 2014-10-12 05:08:22 -0700 (Sun, 12 Oct 2014)
New Revision: 62245
   grass/trunk/raster/r.in.bin/main.c
   grass/trunk/raster/r.out.bin/main.c
Explicit support for null=nan
Modified: grass/trunk/raster/r.in.bin/main.c
--- grass/trunk/raster/r.in.bin/main.c	2014-10-10 16:23:33 UTC (rev 62244)
+++ grass/trunk/raster/r.in.bin/main.c	2014-10-12 12:08:22 UTC (rev 62245)
@@ -228,7 +228,7 @@
     const char *outpre;
     char output[GNAME_MAX];
     const char *title;
-    double null_val = 0;
+    double null_val = 0.0/0.0;
     int is_fp;
     int is_signed;
     int bytes, hbytes;
@@ -494,7 +494,7 @@
     if (bytes != 1 && bytes != 2 && bytes != 4 && bytes != 8)
 	G_fatal_error(_("%s= must be 1, 2, 4 or 8"), parm.bytes->key);
-    if (parm.null->answer)
+    if (parm.null->answer && G_strcasecmp(parm.null->answer, "nan") != 0)
 	null_val = atof(parm.null->answer);
     cellhd.zone = G_zone();
Modified: grass/trunk/raster/r.out.bin/main.c
--- grass/trunk/raster/r.out.bin/main.c	2014-10-10 16:23:33 UTC (rev 62244)
+++ grass/trunk/raster/r.out.bin/main.c	2014-10-12 12:08:22 UTC (rev 62245)
@@ -341,7 +341,9 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    if (sscanf(parm.null->answer, "%lf", &null_val) != 1)
+    if (G_strcasecmp(parm.null->answer, "nan") == 0)
+	Rast_set_d_null_value(&null_val, 1);
+    else if (sscanf(parm.null->answer, "%lf", &null_val) != 1)
 	G_fatal_error(_("Invalid value for null (integers only)"));
     name = parm.input->answer;
