[GRASS-SVN] r62325 - grass/trunk/vector/v.in.ogr
Tue Oct 21 10:45:15 PDT 2014
Author: martinl
Date: 2014-10-21 10:45:15 -0700 (Tue, 21 Oct 2014)
New Revision: 62325
   grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: fix driver_name usage (can be NULL)
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2014-10-21 15:46:52 UTC (rev 62324)
+++ grass/trunk/vector/v.in.ogr/main.c	2014-10-21 17:45:15 UTC (rev 62325)
@@ -344,16 +344,16 @@
     driver_name = db_get_default_driver_name();
-    if (strcmp(driver_name, "pg") == 0)
+    if (driver_name && strcmp(driver_name, "pg") == 0)
 	datetime_type = "timestamp";
-    else if (strcmp(driver_name, "dbf") == 0)
+    else if (driver_name && strcmp(driver_name, "dbf") == 0)
 	datetime_type = "varchar(22)";
     else
 	datetime_type = "datetime";
     /* dsn is 'PG:', check default connection settings */
     dsn = NULL;
-    if (strcmp(driver_name, "pg") == 0 &&
+    if (driver_name && strcmp(driver_name, "pg") == 0 &&
         G_strcasecmp(param.dsn->answer, "PG:") == 0) {
         const char *dbname;
         dbConnection conn;
@@ -433,12 +433,12 @@
     /* check encoding for given driver */
     if (param.encoding->answer) {
-        const char *driver_name;
+        const char *ogr_driver;
-        driver_name = OGR_Dr_GetName(OGR_DS_GetDriver(Ogr_ds));
-        if (strcmp(driver_name, "ESRI Shapefile") != 0 &&
-            strcmp(driver_name, "DXF") != 0)
-            G_warning(_("Encoding value not supported by OGR driver <%s>"), driver_name);
+        ogr_driver = OGR_Dr_GetName(OGR_DS_GetDriver(Ogr_ds));
+        if (strcmp(ogr_driver, "ESRI Shapefile") != 0 &&
+            strcmp(ogr_driver, "DXF") != 0)
+            G_warning(_("Encoding value not supported by OGR driver <%s>"), ogr_driver);
     /* make a list of available layers */
