[GRASS-SVN] r62363 - in grass-addons/grass7/raster: . r.rock.stability
Thu Oct 23 05:20:09 PDT 2014
Author: kikapu
Date: 2014-10-23 05:20:08 -0700 (Thu, 23 Oct 2014)
New Revision: 62363
Added:
   grass-addons/grass7/raster/r.rock.stability/
   grass-addons/grass7/raster/r.rock.stability/Makefile
   grass-addons/grass7/raster/r.rock.stability/r.rock.stability.html
   grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py
r.rock.stability
Added: grass-addons/grass7/raster/r.rock.stability/Makefile
--- grass-addons/grass7/raster/r.rock.stability/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.rock.stability/Makefile	2014-10-23 12:20:08 UTC (rev 62363)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.rock.stability
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.rock.stability/r.rock.stability.html
Added: grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py
--- grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.rock.stability/r.rock.stability.py	2014-10-23 12:20:08 UTC (rev 62363)
@@ -0,0 +1,380 @@
+#!/usr/bin/env python
+# MODULE:      r.rock.stability
+# VERSION:     1.0
+# AUTHOR(S):   Andrea Filipello & Daniele Strigaro
+# PURPOSE:     Calculates SMR for a dtm
+# COPYRIGHT:   (C) 2014 by Andrea Filipello & Daniele Strigaro
+#              andrea.filipello at gmail.com; daniele.strigaro at gmail.com
+#              This program is free software under the GNU General Public
+#              License (>=v2). Read the file COPYING that comes with GRASS
+#              for details.
+#%Module
+#%  description: Calculates SMR index for a slope area.
+#%  keywords: rock mass, planar failure, toppling
+#%End
+#%option
+#% key: dem
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Dtm of the zone
+#% required: yes
+#%end
+#%option
+#% key: imme
+#% type: integer
+#% description: Dip direction of the joint (0-360)
+#% options: 0-360
+#% required: yes
+#%end
+#%option
+#% key: incl
+#% type: integer
+#% description: Dip of the joint (0-90)
+#% options: 0-90
+#% required: yes
+#%end
+#%option
+#% key: f4
+#% type: integer
+#% description: F4 index
+#% options: 8-15
+#% required: yes
+#%end
+#%option
+#% key: rmr
+#% type: string
+#% gisprompt: old,raster,raster
+#% key_desc: name
+#% description: RMR index
+#% required: yes
+#%end
+#%option
+#% key: tc
+#% type: string
+#% description: Total Condition of joint, for SSPC output
+#% required: no
+#% guisection: SSPC
+#%end
+#%option
+#% key: imme2
+#% type: integer
+#% description: Dip direction of the joint (0-360). For SMR_wedge output
+#% options: 0-360
+#% required: no
+#% guisection: SMR_wedge
+#%end
+#%option
+#% key: incl2
+#% type: integer
+#% description: Dip of the joint (0-90). For SMR_wedge output
+#% options: 0-90
+#% required: no
+#%end
+################ouput######################
+#%option
+#% key: prefix
+#% type: string
+#% description: Prefix for output maps
+#% required: yes
+#%end
+import os, sys
+try:
+    import grass.script as grass
+except:
+    try:
+        from grass.script import core as grass
+	#from grass.script import core as gcore
+    except:
+        sys.exit("grass.script can't be imported.")
+if not os.environ.has_key("GISBASE"):
+    print "You must be in GRASS GIS to run this program."
+    sys.exit(1)
+def main():
+############################################### leggo variabili###################################
+    r_elevation = options['dem'].split('@')[0]
+    imme = options['imme']
+    incl = options['incl']
+    f4 = options['f4']
+    RMR = options['rmr']
+    prefix = options['prefix']
+    #SMRrib = options['SMRtoppling']
+    grass.message('Starting to calculate SMR index')
+    grass.message('Waiting...')
+#calcolo slope ed aspect
+    grass.run_command('r.slope.aspect',
+        elevation = r_elevation ,
+        slope = 'slopes_' ,
+        format = 'degrees' ,
+        #precision = 'float' ,
+        aspect = 'aspects_' ,
+        zfactor = '1.0' ,
+        min_slp_allowed = '0.0' ,
+        overwrite = True ,
+        quiet = True)
+# Correggi aspect per avere: N=0 E=90 S=180 W=270
+    grass.mapcalc("aspects_1 = if (aspects_ > 90, 450 - aspects_, 90 - aspects_)")
+# calcolo A (valore assoluto)che vale SCIVOL=abs(immersdelgiunto-aspect1); RIBAL=abs(immersdelgiunto-aspect1-180)
+    grass.mapcalc("Asci = abs($imme - aspects_1)",
+        imme = imme)
+    grass.mapcalc("Arib = abs(Asci - 180)")
+# calcolo F1
+# la formula originale e' stata in parte modificata per tener conto dei valori di A compresi tra 270 e 360 sfavorevoli x la stabilita'
+    grass.mapcalc("F1sci1 = if(Asci > 270, 0.64 - 0.006*atan(0.1*(abs(Asci - 360) - 17)), 0)")
+    grass.mapcalc("F1sci2 = if(Asci < 270, 0.64 - 0.006*atan(0.1*(Asci - 17)), 0)")
+    grass.mapcalc("F1sci = F1sci1 + F1sci2")
+    grass.mapcalc("F1rib1 = if(Arib > 270, 0.64 - 0.006*atan(0.1*(abs(Arib - 360) - 17)), 0)")
+    grass.mapcalc("F1rib2 = if(Arib < 270, 0.64 - 0.006*atan(0.1*(Arib - 17)), 0)")
+    grass.mapcalc("F1rib = F1rib1 + F1rib2")
+# calcolo F2 (per il toppling vale sempre 1)
+    grass.mapcalc("F2sci = 0.56 + 0.005*(atan(0.17*abs($incl) - 5))" ,
+        incl = incl)
+# calcolo F3
+    grass.mapcalc("F3sci = -30 + 0.33*atan($incl - slopes_)" ,
+        incl = incl)
+    grass.mapcalc("F3rib = -13 - 0.143*atan($incl + slopes_ - 120)" ,
+        incl = incl)
+# moltiplica F1xF2XF3
+    grass.mapcalc("Isciv = F1sci * F2sci * F3sci")
+    grass.mapcalc("Irib = F1rib * F3rib * 1")
+# Calcola l'indice SMR
+    grass.mapcalc("$SMRsciv = Isciv + $RMR + $F4" ,
+        SMRsciv = prefix + '_SMRsciv' ,
+        RMR = RMR ,
+        F4 = f4)
+    grass.mapcalc("$SMRrib = Irib + $RMR + $F4" ,
+        SMRrib = prefix + '_SMRrib' ,
+        RMR = RMR ,
+        F4 = f4)
+############################SMR_wedge###################
+    imme2 = options['imme2']
+    incl2 = options['incl2']
+    grass.message('SMR index done!')
+    if (imme2 != '' and incl2 != ''):
+#calcola trend del cuneo
+        grass.message('Parameter set for SMR_wedge')
+        grass.message('Starting to calculate SMR_wedge index')
+        grass.mapcalc("T = (-tan($incl) * cos($imme)+tan($incl2)*cos($imme2))/(tan($incl)*sin($imme)-tan($incl2)*sin($imme2))",
+            imme = imme ,
+            imme2 = imme2 ,
+            incl = incl ,
+            incl2 = incl2 ,
+            quiet = True)
+        grass.mapcalc("T1 = atan(T)")
+#calcola plunge del cuneo P2 (sarebbe inclinazione)
+        grass.mapcalc("P=((sin($incl)*sin($imme)*sin($imme2-$imme))/(sin($incl)*cos($imme)*cos($incl2)-sin($incl2)*cos($imme2)*cos($incl)))*sin(T1)" ,
+            imme = imme ,
+            imme2 = imme2 ,
+            incl = incl ,
+            incl2 = incl2 ,
+            quiet = True)
+        grass.mapcalc("P1=atan(P)")
+        grass.mapcalc("P2=abs(P1)")
+#calcola trend del cuneo corretto (TB) sarebbe immersione
+        grass.mapcalc("TA=if(P1<0,T1+180,T1)")
+        grass.mapcalc("TB=if(TA<0,TA+360,TA)")
+#calcola slope e aspect
+#...calcolo A (valore assoluto)che vale SCIVOL=abs(immersdelgiunto-aspect1); RIBAL=abs(immersdelgiunto-aspect1-180)
+        grass.mapcalc("Asci=abs(TB-aspects_1)" ,
+            quiet = True)
+        reclass_rules = "-360 thru 5 = 1\n5.1 thru 10 = 0.085\n10.1 thru 20 = 0.7\n20.1 thru 30 = 0.4\n30.1 thru 320 = 0.15"
+        grass.write_command('r.reclass', input='Asci', output='F1sci_',
+            overwrite='True', rules='-', stdin=reclass_rules)
+# creo una mappa con valore dell'inclinazione
+        grass.mapcalc('mappa=P2+slopes_*0')
+# calcolo di F2
+        reclass_rules2 = "0 thru 20 = 0.15\n20.1 thru 30 = 0.4\n30.1 thru 35 = 0.7\n35.1 thru 45 = 0.85\n45.1 thru 90 = 1"
+        grass.write_command('r.reclass', input='mappa', output='F2',
+            overwrite='True', rules='-', stdin=reclass_rules2)
+# Calcolo di F3
+# Calcolo C che vale SCIVOL=inclgiunto - slopes;
+        grass.mapcalc("Csci=P2-slopes_")
+# Reclass per F3 scivolamento
+        reclass_rules3 = "180 thru 9 = 0\n10 thru 0.1 = -6\n0 = -25\n-0.1 thru -9 = -50\n-10 thru -180 = -60"
+        grass.write_command('r.reclass', input='Csci', output='F3sci_',
+            overwrite='True', rules='-', stdin=reclass_rules3)
+        grass.mapcalc('Isciv_=F1sci_*F3sci_*F2')
+        grass.mapcalc("$SMRsciv=Isciv_+$RMR+$F4" ,
+            SMRsciv = prefix + '_SMRscivWedge' ,
+            RMR = RMR ,
+            F4 = f4 ,
+            quiet = True)
+        grass.run_command('g.remove' ,
+            rast=(
+                'Asci' ,
+                'Arib' ,
+                'F1sci_' ,
+                'F3sci_' ,
+                'F2' ,
+                'Csci' ,
+                'P' ,
+                'P1' ,
+                'P2' ,
+                'T' ,
+                'TA' ,
+                'T1' ,
+                'mappa' ,
+                'Isciv_' ) ,
+            quiet = True)
+        grass.message('SMR_wedge index done!')
+    else:
+        grass.message('No parameter set for SMR_wedge')
+############################SSPC#####################
+    TC = options['tc']
+    if (TC != ''):
+# calcolo DELTA=aspect-immersione
+        grass.mapcalc("delta = aspects_1 - $imme",
+            imme = imme ,
+            quiet = True)
+# calcola A=cosenoDELTA
+        grass.mapcalc("A = cos(delta)" ,
+            quiet = True)
+# calcola B=tan(inclinazione)
+        grass.mapcalc("B = tan($incl)" ,
+            incl = incl ,
+            quiet = True)
+# calcola C=A*B
+        grass.mapcalc("C = A * B" ,
+            quiet = True)
+# calcola AP
+        grass.mapcalc("AP = atan(C)" ,
+            quiet = True)
+# additional condition per scivolamento (dip del pendio deve essere < di AP+5), AP deve essere < di 85
+        grass.mapcalc("AP1 = slopes_ - AP - 5" ,
+            quiet = True)
+        grass.mapcalc("consci1 = if(AP1 > 0, 0, null())" ,
+            quiet = True)
+        grass.mapcalc("consci2 = if(AP < 85, 0, null())" ,
+            quiet = True)
+# additional condition per ribaltamento (AP deve essere> di 85)
+        grass.mapcalc("conrib = if(AP > (-85), 0, null())" ,
+            quiet = True)
+# ANALISI SCIVOLAMENTO PLANARE AP * 0.0113
+        grass.mapcalc("membro_sci = 0.0113 * AP" ,
+            quiet = True)
+        grass.mapcalc("sci = membro_sci - $TC" ,
+            TC = TC ,
+            quiet = True)
+# se il risultato ottenuto e' minore di zero non ho cinematismo, maggiore e' il valore piu' alta sara' la propensione al distacco
+        grass.mapcalc("cinem_sci = if(sci >= 0, 1, null())" ,
+            TC = TC ,
+            quiet = True)
+        grass.mapcalc("$SSPCsciv = cinem_sci * sci + consci1 + consci2" ,
+            SSPCsciv = prefix + '_SSPCsciv' ,
+            quiet = True)
+# ANALISI RIBALTAMENTO 0.0087*(-90-AP+INCLINAZIONE)
+        grass.mapcalc("membro_RIB = 0.0087 * ((-90) - AP + $incl)" ,
+            incl = incl ,
+            quiet = True)
+        grass.mapcalc("rib = membro_RIB - $TC" ,
+            TC = TC ,
+            quiet = True)
+        grass.mapcalc("cinem_rib = if(rib >= 0, 1, null())" ,
+            quiet = True)
+        grass.mapcalc("$SSPCrib = cinem_rib * rib + conrib" ,
+            SSPCrib = prefix + '_SSPCrib' ,
+            quiet = True)
+# processo per sostituire i valori di cella nulli con 0 (passaggio importante per trovare poi il minimo
+        grass.run_command("r.null" ,
+            map = prefix + '_SSPCsciv' ,
+            null = 0 ,
+            quiet = True)
+            map = prefix + '_SSPCrib' ,
+            null = 0 ,
+            quiet = True)
+#elimino mappe
+            rast=(
+                'slopes_' ,
+                'aspects_' ,
+                'aspects_1' ,
+                'Asci' ,
+                'Arib' ,
+                'F1sci1' ,
+                'F1sci2' ,
+                'F1sci' ,
+                'F1rib1' ,
+                'F1rib2' ,
+                'F1rib' ,
+                'F2sci' ,
+                'F3sci' ,
+                'F3rib' ,
+                'Isciv' ,
+                'Irib' ,
+                'delta' ,
+                'A' ,
+                'B' ,
+                'C' ,
+                'AP' ,
+                'membro_sci' ,
+                'membro_RIB' ,
+                'sci' ,
+                'rib' ,
+                'cinem_sci' ,
+                'consci1' ,
+                'consci2' ,
+                'conrib' ,
+                'AP1' ,
+                'cinem_rib') ,
+            quiet = True)
+    else:
+            rast=(
+                'slopes_' ,
+                'aspects_' ,
+                'aspects_1' ,
+                'Asci' ,
+                'Arib' ,
+                'F1sci1' ,
+                'F1sci2' ,
+                'F1sci' ,
+                'F1rib1' ,
+                'F1rib2' ,
+                'F1rib' ,
+                'F2sci' ,
+                'F3sci' ,
+                'F3rib' ,
+                'Isciv' ,
+                'Irib' ) ,
+            quiet = True)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
