[GRASS-SVN] r62449 - in grass/trunk/general: g.list g.remove
Tue Oct 28 12:26:20 PDT 2014
Author: hcho
Date: 2014-10-28 12:26:20 -0700 (Tue, 28 Oct 2014)
New Revision: 62449
   grass/trunk/general/g.list/main.c
   grass/trunk/general/g.remove/main.c
g.list/g.remove: Add -i flag for case-insensitive search
Modified: grass/trunk/general/g.list/main.c
--- grass/trunk/general/g.list/main.c	2014-10-28 19:24:25 UTC (rev 62448)
+++ grass/trunk/general/g.list/main.c	2014-10-28 19:26:20 UTC (rev 62449)
@@ -55,6 +55,7 @@
     } opt;
     struct
+	struct Flag *ignorecase;
 	struct Flag *regex;
 	struct Flag *extended;
 	struct Flag *type;
@@ -125,6 +126,11 @@
     opt.output->description = _("If not given or '-' then standard output");
     opt.output->guisection = _("Print");
+    flag.ignorecase = G_define_flag();
+    flag.ignorecase->key = 'i';
+    flag.ignorecase->description = _("Ignore case");
+    flag.ignorecase->guisection = _("Pattern");
     flag.regex = G_define_flag();
     flag.regex->key = 'r';
     flag.regex->description =
@@ -181,7 +187,8 @@
     if (opt.pattern->answer) {
 	if (flag.regex->answer || flag.extended->answer)
 	    filter = G_ls_regex_filter(opt.pattern->answer, 0,
-			    	       (int)flag.extended->answer);
+			    	       (int)flag.extended->answer,
+				       (int)flag.ignorecase->answer);
 	else {
 	    /* handle individual map names */
 	    if (strchr(opt.pattern->answer, ',')) {
@@ -190,10 +197,12 @@
 		pattern = (char *)G_malloc(strlen(opt.pattern->answer) + 3);
 		sprintf(pattern, "{%s}", opt.pattern->answer);
-		filter = G_ls_glob_filter(pattern, 0);
+		filter = G_ls_glob_filter(pattern, 0,
 	    else
-		filter = G_ls_glob_filter(opt.pattern->answer, 0);
+		filter = G_ls_glob_filter(opt.pattern->answer, 0,
 	if (!filter)
 	    G_fatal_error(_("Unable to compile pattern <%s>"),
@@ -205,7 +214,8 @@
     if (opt.exclude->answer) {
 	    exclude = G_ls_regex_filter(opt.exclude->answer, 1,
 	else {
 	    if (strchr(opt.exclude->answer, ',')) {
@@ -214,10 +224,12 @@
 		pattern = (char *)G_malloc(strlen(opt.exclude->answer) + 3);
 		sprintf(pattern, "{%s}", opt.exclude->answer);
-		exclude = G_ls_glob_filter(pattern, 1);
+		exclude = G_ls_glob_filter(pattern, 1,
 	    else
-		exclude = G_ls_glob_filter(opt.exclude->answer, 1);
+		exclude = G_ls_glob_filter(opt.exclude->answer, 1,
 	if (!exclude)
Modified: grass/trunk/general/g.remove/main.c
--- grass/trunk/general/g.remove/main.c	2014-10-28 19:24:25 UTC (rev 62448)
+++ grass/trunk/general/g.remove/main.c	2014-10-28 19:26:20 UTC (rev 62449)
@@ -49,6 +49,7 @@
     } opt;
     struct
 	struct Flag *regex;
 	struct Flag *force;
@@ -110,6 +111,11 @@
     opt.exclude->description = _("File name exclusion pattern (default: none)");
     opt.exclude->guisection = _("Pattern");
@@ -153,7 +159,8 @@
 	exclude = NULL;
     if ((flag.regex->answer || flag.extended->answer) && opt.pattern->answer)
-	filter = G_ls_regex_filter(pattern, 0, (int)flag.extended->answer);
+	filter = G_ls_regex_filter(pattern, 0, (int)flag.extended->answer,
     else {
 	if (strchr(pattern, ',')) {
@@ -162,10 +169,10 @@
 	    buf = (char *)G_malloc(strlen(pattern) + 3);
 	    sprintf(buf, "{%s}", pattern);
-	    filter = G_ls_glob_filter(buf, 0);
+	    filter = G_ls_glob_filter(buf, 0, (int)flag.ignorecase->answer);
 	else
+	    filter = G_ls_glob_filter(pattern, 0, (int)flag.ignorecase->answer);
     if (!filter)
 	G_fatal_error(_("Unable to compile pattern <%s>"), pattern);
@@ -174,7 +181,8 @@
 	    exclude_filter = G_ls_regex_filter(exclude, 1,
 	else {
 	    if (strchr(exclude, ',')) {
@@ -183,10 +191,12 @@
 		buf = (char *)G_malloc(strlen(exclude) + 3);
 		sprintf(buf, "{%s}", exclude);
-		exclude_filter = G_ls_glob_filter(buf, 1);
+		exclude_filter = G_ls_glob_filter(buf, 1,
 	    else
-		exclude_filter = G_ls_glob_filter(exclude, 1);
+		exclude_filter = G_ls_glob_filter(exclude, 1,
 	if (!exclude_filter)
 	    G_fatal_error(_("Unable to compile pattern <%s>"), exclude);
